PDA
View Full Version : V6 Tech
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14
  1. Richmond gear install kit
  2. Bad 3rd gear??
  3. Which v6 exhaust is better...MAC dual or Kenny Brown ?
  4. removal of the egr valve. what will it do
  5. Question on TBody Spacer
  6. Problems with a 94
  7. how to test the egr valve on a 95
  8. symptoms of a bad egr
  9. how to exactly test fuel psi
  10. New Vortech SCT Dyno Tune results
  11. do i have a bad computer
  12. Wierd Question
  13. h-pipe help
  14. steeda help?
  15. big miss or misses
  16. Advice on Thermactor system
  17. Parting out 98 Auto v6
  18. Transmission
  19. Lightning 2004 18inch Wheels on a 2002 Mustang?
  20. Replaced head gasket in 94 - install ???
  21. IAT sensor, what is it
  22. interior lights out, where fuse??
  23. is a bad idle air control motor causing this
  24. need some opinions on these rims
  25. eibach springs
  26. Mach 1 Chin spoiler
  27. help please
  28. 2002 Mustang windshield whistles
  29. Sound Clips
  30. how much more HP???...
  31. New 200 Amp Alternator w00t
  32. Where to buy a GT take-off cat back??
  33. Supercharging
  34. i wanna make a cold air or ram air intake
  35. Governer
  36. split port heads and single port heads what's the difference
  37. difference in 95 and 98 heads and also 2000 heads
  38. Gas Tank Problem!!!!
  39. half shafting. any info
  40. How do you remove the fiberglass molding between the roof and the door? Pic inside
  41. Auto to 5-speed swap
  42. Looking at hoods, help me out
  43. OK guys code 171 Wtf?!?
  44. Odometer problem.Stopped working after hitting 100,015 miles.Any fix for this?
  45. Luke clutches are great.
  46. 99-00 lower intake work on a 01 v6 with out issue?
  47. Whats a good CAI???
  48. Tire question
  49. exaust help
  50. Will 275/40/17's fit on the front of a '99+ V6?
  51. 1000 hp V6 mustang......
  52. Great sounding exhaust
  53. Do GT's have the same '99-00 PCV problem as V6?
  54. 2002 Rear window factory tint
  55. lower intake question
  56. tps sensor mayhem
  57. speedomoter part..?
  58. 95 with duals and 4 ot sensors.
  59. just put a 91 5.0 tbird's fuel pump in.
  60. Head Gasket Kit Recommendations
  61. Estimate results?
  62. mieneki just tried to rape me
  63. What are those drips and puddles under your car?
  64. Template Needed ASAP
  65. 3.9 Liter v-6 ?
  66. how much money for a dual exhaust??
  67. 2 wierd sounds?!?!?!
  68. Passenger Window...WTF?
  69. odometer disconnect?
  70. swapp v6 ehaust for gt ?????
  71. headers
  72. weird sound
  73. No one has PCM blue prints!?! Fine! I'll get them!
  74. Crate Motor for 95 V6??
  75. Thunderbird/Cougar Charger fit on Stang?
  76. insufficent EGR flow...
  77. need high performance mods
  78. Weird problems at idle....
  79. fuel pump
  80. Brake Problem, Help!
  81. magnaflow duals help!!!!
  82. magnaflow duals help!!!!
  83. spring installation
  84. Chip?
  85. 4.2L??
  86. what should my next mod be????
  87. Odd vibration help!
  88. ascesory cig lighter
  89. Crate Engine for 1995 V6
  90. rear cats
  91. clutch replaced, bad vibrations
  92. Traction lock for V6?
  93. car shakes above 55mph~ any ideas?
  94. Engine Service lite after tune up?
  95. dual exhaust for my 2000 V6
  96. T TOPS
  97. Can I get a WOOHOO! Marvin?
  98. Don't call me stupid but...
  99. Installing an extra keyless remote, help!
  100. Cost to mount spoiler
  101. Anyone Heard Of....
  102. New Owner Here!
  103. 2000 V-6 3.8L Underdrive Pulley
  104. Grease Fittings
  105. Jiffy Lube owned me...sad day
  106. 2005 Massively Over-rated?
  107. Action Traction
  108. About to get a 2000 v6 engine for a 98! need some info!
  109. what is the panel called underneath the door?
  110. 5.0 in a v6 mustang
  111. 3.73 gears!?
  112. Taking off plastic piece?
  113. Sub frames off a 99+ GT vert...
  114. tps and my problem
  115. hts coated mac exhaust
  116. Mach 480 Sound Opinions
  117. pedal troubleshoot....help please
  118. electrical problem
  119. '04 Muffler size needed
  120. rear bumper
  121. unknown mods need help
  122. can i test a tps and is mine screwed
  123. CAI Install Prob Please HELP!!
  124. fuel injectors
  125. 2000 Ready For Mods
  126. I have $2000....
  127. making a saleen conversion?
  128. got code but don't know what part
  129. lifter tick?
  130. timing cover, what vehicles???
  131. guess 1/4 mile time...
  132. gears on 2000 v6?
  133. 1998 v6 3.8, will a 2000 be a direct drop in?
  134. Chrome VS Black Bullits
  135. Disc brake pad change
  136. coil pack not cause of rough idle
  137. removing shift knob
  138. Need to get rid of a 4.2L
  139. car wont start , dont know what else to check
  140. Help!
  141. Wheels
  142. how to set the tps sensor
  143. 04 Rev limiter @ 4000 rpms?
  144. 1. Power steering pump and 2. exhaust
  145. checking codes with a paper clip
  146. duel exhaust
  147. 2002 Mustang common problems
  148. exactly what the 2005 v6 needs *pic*
  149. Bullitt Suspension
  150. V6 tranny
  151. Broken Air Conditioner
  152. Funny Noise
  153. odometer stopped working
  154. 3.8 or 3.9??
  155. Technical Articles - Coming SOON!!!
  156. Cant get new harmonic dampner on HELP
  157. shakes in nuetral
  158. to good to be true
  159. CAI Causing Noises
  160. is this good compression
  161. Automatic Fan, With manual overide?
  162. wheel offset?
  163. 3.8 differences?
  164. Turbo Me
  165. rear end howl at 80km/h
  166. how much to get hood painted??
  167. Use a supercharger off of an older T-brd?
  168. decode thes codes please
  169. ok I got 2 questions
  170. Engine Cooling Fan
  171. suggestions? *pic*
  172. weird kinda banging metal noise
  173. rought idle... new coil pack?
  174. Vaccuum related squeeling driving me nuts!
  175. gears and t-lock
  176. where is stock computer??
  177. Vinyl Inserts and stuff
  178. anybody know what is going on
  179. 30k maint.
  180. normal stock fuel pressure
  181. springs
  182. Exhaust Sound Off Competition
  183. How loud is your transmission?
  184. 99 MAF?
  185. Fog lights install
  186. 1-2 shift delay
  187. oil question
  188. fan does not turn on when sensor is plugged up
  189. test driving 02 v6
  190. MAC Catback Exhaust Questions
  191. front lip spoiler
  192. The Exhuast guys wanna own me!!
  193. Aluminized Steel or not?
  194. Best Stang?
  195. Bassani exhaust rules...
  196. Need some help V6 mod or V8?? Help.
  197. Cant Find This Interior Part
  198. Upper intake bolt question
  199. Slave Cyl - Replace Clutch?
  200. appearance help
  201. Simple question... need opinions
  202. Mandrel Bend? WTF?
  203. upgrading..need advice
  204. Plug Wires
  205. BBK vs. K & N
  206. Oil, what do you use?
  207. Will an 03 cold intake fit an 04 mustang?
  208. New suspension
  209. Shift Kits
  210. Prochamber
  211. P1130 code
  212. Automatics: Tq. Converter vs. Chip
  213. Cd player and a Old School Deck
  214. how many psi do stock 98 injectors put out
  215. still cuts out when on 1/4 tank of gas
  216. Ditching The Cat's....
  217. "Ultra-Clear" GT Foglamps, anyone have these ??
  218. New to the car modding thing.
  219. ATTENTION: how to re-wire my windows!?!
  220. Attention: All Automatics With Rear end Gears Swaps
  221. Car Alarm
  222. Using your cruise control button to turn the volume up and down
  223. P0411 trouble code
  224. Beyond Routine Maintenance
  225. using GT exhaust on V6
  226. For those with Forced induction, couple ?'s
  227. oil problem???
  228. Help me find some Steeda Ultra-Lites
  229. WHeel SIZE
  230. New Amp Rack
  231. Short shifter
  232. eBay CAI...
  233. Porting and Block Prep How-To
  234. torque converter
  235. clear fog lights
  236. VENOM
  237. Power gauge indicator moving to left/low
  238. underdrive pullies
  239. rearend swap
  240. 95 v6 with ac belt routing
  241. blows only thru defroster
  242. ASP Underdrive
  243. Shifting problems
  244. shifter cable out. HELP
  245. Magnapack question
  246. Magnaflow Install Problems HELP !
  247. V6 intake
  248. Snow Handling
  249. "X"pipe vs. "H"pipe
  250. Chip?
