PDA
View Full Version : V6 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15
  1. using GT exhaust on V6
  2. For those with Forced induction, couple ?'s
  3. oil problem???
  4. Help me find some Steeda Ultra-Lites
  5. WHeel SIZE
  6. New Amp Rack
  7. Short shifter
  8. eBay CAI...
  9. Porting and Block Prep How-To
  10. torque converter
  11. clear fog lights
  12. VENOM
  13. Power gauge indicator moving to left/low
  14. underdrive pullies
  15. rearend swap
  16. 95 v6 with ac belt routing
  17. blows only thru defroster
  18. ASP Underdrive
  19. Shifting problems
  20. shifter cable out. HELP
  21. Magnapack question
  22. Magnaflow Install Problems HELP !
  23. V6 intake
  24. Snow Handling
  25. "X"pipe vs. "H"pipe
  26. Chip?
  27. Subframe Install
  28. Exhaust questions
  29. Eaton M90 SC
  30. GT mid-pipe on a sixer?
  31. i think im strangling my stang.
  32. Ok its an exhaust question..but I seriously need help.
  33. V-6 headers which ones are good?????
  34. Fog light bolt size?
  35. Turbo vs supercharger
  36. crankling noise when i start?
  37. The Tornado
  38. what do you consider "moderation"?
  39. Front Wheel Drive?
  40. Finished CAI. some questions
  41. supercharger
  42. kumho ecsta mx
  43. Supercharger psi
  44. V6 to V8 People who have done it:
  45. fuel gauge acting up.
  46. Unknown vibration :(
  47. UnderCar Neons or LED??
  48. Okay, My exhaust ouside
  49. TransGo Shift Kit Installed
  50. 3.8 rough idle
  51. FINALLY!!! See & HEAR my exhaust!!!
  52. WOOHOO!
  53. MR2 VS. 2003 V6?
  54. engine question
  55. NEED AVICE ON V6 EXHAUST
  56. Horsepower gains?
  57. AC and low idle
  58. how to run the fuel pump without running the car.
  59. 2000 Mustang Vs. Sentra SER
  60. 2000 Mustang v6 Spoiler hardware
  61. 2000 Exhaust Options
  62. Pony was misbehaving...Help?
  63. Shifter Noise
  64. New wheels
  65. Porting...
  66. Check engine light, stang runs like crap......
  67. Need some advice.....
  68. 96-up V6 question
  69. Transmission surging?
  70. Exhaust! Yay!
  71. Removing the grille
  72. Engine Swap
  73. broken bolt blues
  74. Supercharger... Computer...?
  75. Just Hit 91K!!!
  76. TLOCK and gears
  77. need advice!!!
  78. shes studdering!
  79. 87/88/89/91?????
  80. throttle pedal???
  81. Underdrive Help
  82. 3.8 head's , heres's the deal..
  83. Exhuast 101, Come in v6 boys and girls
  84. How to tell if sturts are blown/useless?
  85. mustang on wet road condition
  86. Suspension (specifically lowering)
  87. My 2000th should be here!
  88. engine missing under load error code 1151
  89. is a chrome BBK air intake or supercharger?
  90. Where to get gauges installed
  91. Stock gears for 96??
  92. Installing a kill switch
  93. Can't shift out of park
  94. New member with questions..
  95. 98 3.8 starting issue
  96. Concern about removed air silencer
  97. engine swap?!?!
  98. not sure how to change trans oil
  99. Tires
  100. drop in a v8, supercharge, or buy a gt?
  101. what would sound better
  102. Couple of Questions, Help!!
  103. Bypassing the PCV system
  104. Newbie introduction and a cople of questions.
  105. Densecharger intake
  106. 4.2L Crate Motor
  107. My... My... The Tradeoffs
  108. Rear end gears
  109. car on fritz again...eh
  110. autoshifting....bad?!?!!
  111. How to adjust throttle cable?
  112. Suspension and Accesories
  113. Brake booster
  114. What Procharger P-1SC 99 Mustang V6 runs
  115. AIR PUMP
  116. Wierd shifter vibration and hesitation, help!
  117. Where's the PCV valve on a 2000 V6?
  118. Clunking & creaking.. it wasn't the control arm bushings, now what?
  119. 8.8 Rear
  120. Air silencer questions
  121. S/C for 3.8L
  122. can i put a thunderbird charger on my v6 pony
  123. Spiralmax
  124. v6 performance parts
  125. Installed Cold Air Intake, now...
  126. Resurfacing Rotors
  127. Mixing Oil
  128. STANGPEDE EXPANDING NATIONWIDE!!!
  129. one-touch passanger window down module
  130. PURPLE!!!!
  131. 98 Model V6 Ball Joint - Part Number??
  132. Synthetic oil?
  133. tire ?
  134. Ignition Rod
  135. 4R70W Overdrive Server Info Needed
  136. Paint, kits, and grilles
  137. Help Installing Head Lights (Cover)
  138. Questions from the UK 98Model V6
  139. installation pricing help
  140. +20 HP chips on ebay?
  141. need help identifying mustang parts
  142. Oil Change?
  143. Mach 460 Help
  144. tranny fluid change?
  145. Dual exhaust on an 84 3.8??
  146. Noise
  147. Mac exhaust
  148. size K&N for ebay Intake.
  149. Thermostat location?
  150. 84 LX 3.8 not wanting to downshift...
  151. 265rwhp 280rwtq -- ALL MOTOR
  152. Help - Engine, Tranny or Brakes
  153. Suggested tire size for 18s?
  154. Need Help!!!
  155. CAI fenderwell?
  156. << NEWBIE, help
  157. RPM hangs on Deceleration
  158. Help fixing up used '98, step 1 : diff bushing
  159. warranty and pulleys
  160. whats wrong with my battery?
  161. Hows this sound for Exhaust Qutoes?
  162. Help a newbie -- 95V6 shakes and knocks
  163. Replacing the Spark Plugs
  164. Possible HP Loss on CAI?
  165. URGENT!! MACH 1000 HELP
  166. Exhaust choices
  167. Ebay CAI Seriously?
  168. Wiring harness problem
  169. T-lok
  170. new pullies
  171. Is this mechanic gunna hose me up?
  172. 1995 probe Vs. 2000 mustang?
  173. EGR Valve
  174. New Mod Question
  175. need help in performance
  176. adding tweeters to my system, please help
  177. v6 vs. v8 exhaust
  178. UD pulleys and CAI
  179. tranny swap
  180. Shifting my automatic manually, will it hurt my trans?
  181. Installed Oil Pressure Sender w/Vortech...pics inside
  182. As fast as a GT for $200??
  183. car hesitates when giving gas
  184. the v6 is dead again. keeps blowing coil packs...
  185. Paint question
  186. Some exauhst, CAI and wheelsize q's from a newbie
  187. atlantic blue hood scoop
  188. plugs and gaps for SC v6
  189. tranny and rear end Q's
  190. URGENT!!!
  191. Convertible Top Question
  192. California Emmission Car
  193. used h-pipe
  194. hoods
  195. Locating the IAC Valve?
  196. Dual Exhaust
  197. mac or pacesetter?
  198. will 17s work on a V6?
  199. IS THIS WORTH THE MONEY??
  200. bad mpg all the sudden
  201. SORRY FOR THE EASY DUMB QUESTION BUT...
  202. Bad Vibrations
  203. Hood and Brake scoops...
  204. Group Buy on UDs and Tri-Ax
  205. Interior Question
  206. my SC mustang shakes when getting boost??
  207. GT scoop on V6
  208. HELP!! ASAP! Fuel pump gone out, need reccomendations.
  209. Performance Add-ons
  210. Nitrous Oxide
  211. Maximum Exhaust Flow
  212. 289 engine
  213. Question
  214. Ported Intakes?
  215. rear seat
  216. Engine
  217. Stock HP numbers
  218. Where to find Procharger for v6
  219. Exhaust update...No more Ravin
  220. Blown V6
  221. Hood Gas Shocks Group Purchase
  222. car died driving down highway?!?!?!?!
  223. What's the best place to get Mach1 shocks/struts?
  224. replacing my seats
  225. Ticking Noise
  226. Need help about problem
  227. CIA help please!
  228. Should I but the B springs?
  229. Question about a colder plug and timing...
  230. Removing AODE
  231. WTF!!.....Car wont start.... ODD Symptons
  232. Wheels
  233. Attaching CDC Trim Pieces
  234. ANYONE HEARD OF RAVIN EXHAUST?
  235. supercharger info
  236. Sway Bar
  237. V6 Speedo 120mph tops
  238. Chips, 4.10's, T-Locks OH MY!! help!
  239. Question
  240. hood??
  241. Fuel Rails
  242. clutch problems....loud squeel
  243. emblem question for 94-95 mustang
  244. Is this a good price on springs?
  245. magnaflow
  246. Lights!
  247. Need help BAD-Fuel injector part!!!
  248. What would be better...
  249. tire size
  250. Help engine problems!
