View Full Version : V6 Tech
Pages :
10
11
12]
15
- tire size
- Help engine problems!
- need help ASAP check engine light!!
- K&N air intake
- painted block
- Shocks?
- Supercoupe????
- V6 upgrades?
- odd grinding noise ... dun dun dunnnn
- how do i remove brake rotors 98 v6
- Question on Wheels
- best place to get a clutch
- Check Engine Hell!!!
- head gasket
- Exhaust Idea
- Simple Question
- removing automatic tranny
- Mac CAI Question
- long or short for a deep tone??
- electrical gurus....need help
- Auto Trans Shifter Problem (gets stuck in park)
- exhaust
- Flowmaster Exhaust any suggestions?
- I wanna pimp my pony
- SHO v-6?
- Lower Intake Manifold Remove 3.8L
- Holy Damn
- SUSPENSION GURU NEEDED!!!!!
- stock compression question
- dual exhaust question
- SC engine flywheel whoas, help if you can!
- Leaking Break Control/proportioning valvle
- Very important question
- Squeeking
- Steeda Tri-Ax Shifter
- anyone ever put a v6 into a fox?
- Help! Brake swap -> 01 GT to 95 V6
- air in coolant line
- Need code help
- bumper on v6
- headlight switch wiring
- HELP! Supercoupe Longblock Interchageability questions! LONG!
- Touching up scratches on the dash/interior?
- Tips on making your v-6 better
- Service engine soon?
- Help with problems on my new stang..
- Exhaust Price Estimating
- Power Window Problems
- Just got my stang
- CD player broken, Ford blames Flowmaster
- All Supercharged V-6's HELP!
- Dual exhaust Break line interference Problem
- ?Tune up Time?
- HELP!!fuel pump question
- whats up
- mach 460 sub install ??
- New here...Questions.
- Lowering Springs or Under Drive Pully?
- When do I need to change the flywheel?
- Air Box Question
- Modular motor swap.
- Lowering my Stang
- 5.0 swap ?'s and $'s
- Plz need suggestions??
- Oil and Transmission Cooler
- this is what im getting
- vacuum questions
- 99 v6
- is this to good to be true???
- getting supercharged 6, need sites
- Eagle alloy wheels
- Hello fellow 6'ers i just came back into the v6 class
- headlight install
- Stock Front Springs
- Engine
- Is this supercharger legit??
- Rotary Engine swap?
- side exhaust vs. dual exhaust
- More Dual Advice..
- Door panel removal?
- gt takeoffs??
- Speakers
- New Cam
- y-pipe question
- problems starting car the first time...
- Wire Tappers
- Catalytic converter question
- Performance oil pan?
- N2O question on the 3.8L
- True Dual Confusion!!!
- sunroof
- Warning indicator lights out please help
- 99+ PBR's on 96
- tire size question
- rpm question
- Swapping in a new fuse box?
- Help!! Car Won't Start
- Mallory VI-A Hy-Fire CD Ignition
- Any Successful 11PSI Prochargers?
- What's this little thing for?
- 1998 v6 performance headers...
- what should i do???
- dual exhaust for a v6??
- Best way to change a 02 sensor
- 18' or 17' RIMS???
- Tensioner replacement
- Best sites to buy throttle bodies?
- anyone who has to do a brake job on their car....ever
- Rear LCA's/Rear End Gear Problem (Opinions)
- Anyone here have 245x40x17's mounted on 17x10.5 rims?
- Car Noises You Can't Ignore (MSN Article)
- Odometer problem...
- dirty rims..
- Need help with wheel upgrade..
- Who has done a v6-v8 swap on here? i need help!!?
- Mac Duals and H pipe
- I was wondering how long I would last if I really pushed it hard?
- So what about gears?
- Pro-M Racing Univer MAF calibrated for 42lb fuel injectors
- GOD I HATE FLOWMASTER
- Question about driving a manual...
- Anyone notice this on there dual exhaust?
- 3.8L, coil to TFI?
- Car stalled! now won't start help..
- Gas Mileage AGAIN
- 95 mustang exhaust question
- Dual Exhaust conversion
- to remove decklid??
- Clicking noise under acceleration, driveshaft problems?
- Pulleys. Yes or No?
- sounds behind the instrument cluster
- Will this SC fit?
- RPMOutlet Option A
- My TB Spacer Nightmare
- can someone tell me what this is
- Automatic to 5 speed
- another ebay find
- SE Mich, need a shop
- Gas smell coming from vents but nowhere else?
- swapping engines
- What do I need to supercharge my v6?
- MIL Eliminators
- Truspeed
- burning parking brake cable
- Stock 94-98 V6 MAF SIZE?
- manual trans ??
- underdrive pulley ?
- How much Oil?
- Make My V-6 Fun Again
- dirve shaft removal ? howto?
- i know..i know...but exhaust ??
- Engine mods after 75K
- 3.8 V6 computer upgrade
- 01 Cobra Amber Lights
- Loss of Power?
- 250 moding ?'s
- i need help
- Electrical Problem - Need Help!
- Wiring Fog Light Problem!!!
- Redoing suspension,driveline today
- Did 94-95 3.8 T-Birds have the computer as the 94-95 3.8 Mustang?
- What tire will fit??
- '02 Eibach spring question, pro or sportline? Need help.
- SES Light P0401
- Check engine light
- Update and Question bout my battery
- '99 Fuse Diagram needed..
- Reverse glow gauge wiring help!
- Shift "Improver" Kit
- Tire ?
- exhaust...h-pipe?
- exhaust
- 94-98 Heads and 99+ Heads
- Wheels - 17" vs 18"
- Exhaust sound question
- head gasket job o na 3.8
- Is this possible???
- Diablo Chip
- stock 95 gt h-pipe on an 96 v6?
- shift kits
- 4.10 on stock rear end
- V6 convertable mods
- Whats next? (mod wise)
- Where did all the Tech Forums go?
- New Control Arms
- Eibach Springs HELP!
- Car unusually loud, power steering pump?
- Ever heard the exhaust??
- can i trade my auto for 5spd?
- Will a Motorvator work with my CAI?
- has anyone on here swapped a 4.6 in place of the 3.8 ???
- Changing Rotors/Pads
- Help with my V6!!!!
- Blinker Issue on 2000 V6
- Wont start
- 3.8 flywheel
- 3.8 wiring diagram!!!
- need help with clutch problem
- ditching the front license plate
- thinkin about runing at the track
- Future Mod Suggestions
- hooker exhaust
- Problem off the line
- Help Me Out Here PLEASE?!?!
- 2005 V6
- To have or not to have?
- Brakes question
- no more b.s. whats the better cold air intake?
- Can't shift out of park when cold
- tranny swap problem?
- Granatelli Adj. LCA's - Questions
- mufflers
- CAI / Pulleys or GT Take offs
- Which CAI is best?
- ENGINE!!!
- Anyone have a fast V6?
- 00 v6 VS. ram HEMI
- HELP! Will a 225/45/17 tire fit on a stang?
- mustang logos
- Lowering car
- service engine soon light came on
- From Six-cylinder to Saleen's 281-E
- B+G Sport Springs
- Port and Polished heads
- 2000 vert, does lt headers fit?
- Mac Exhaust, Convt, Questions
- 6 to 8 conversion
- Split-port Swap?
- What's happening to the threads?
- Noise when going uphill...
- Synthetic Oil?
- Bullit Suspension Upgrade
- 2" drop too much?
- does anybody know of a good torque converter
- v6 to 5.0
- Knock when accelerating, especially up hills.
- Wiring a line in to the Mach Headunit?
- Buying a chip, but don't know what's best???
- 199 v6 alternator
- my 4x4
- Welcome back gift
- Bassani cat Back Question
- Engine Code P1151
- MAC exhaust
- great deal on a supercharger
- Waterpump 95 v6
- put new clutch in: now engine dont start?
- Engine change???
- Everyone with CAI
