View Full Version : V6 Tech
Pages :
10
11
12
14]
- Pulleys
- Dual Exhaust
- Clutch Install Done, Urgent Questions...
- What lowering springs are you guys using on ur 99+ stangs?
- best v6 year
- Exhaust Help
- Recalls?
- 351W in a 00 V6?
- Let's trade your spoilerless trunk lid for my GT trunk lid with spoiler.
- I need a good source for new Exhaust tips
- What's wrong? My car is falling apart!
- just got a rattle
- Tension pulley
- Who can help with a coolant issue?
- Help
- Eibach Spring Install
- What should I do first?
- Tranny is out... Any recommendations?
- where to get phelic spacer???
- Billet (Chromed) Interior Accessories
- Someone Asked A ? About Engine Hose Painting
- My Mustang sounds like a Bus
- new cam and housing
- Motorvator for 98?
- roots supercharger
- Goodyear Eagle #1 NASCAR
- Remote Start
- Just Got Some Money Need Help Spending It
- 1995 Mustang
- air injected?
- Gas guzzler
- Fog Lights Electrical Q.
- couple v6 questions
- Mustang Problem
- DTC code
- 8.8 Rearend
- 03 vert 460
- Numbers to ponder....laugh at ...etc
- H-Pipe without Cats Illegal?
- H-Pipe and LT Headers (Help)
- Dome Lamp Problem
- 84 vert proj car
- Stock rocker ratio??
- Do any of you have a Diablo Chip?
- '97 V6 with sluggish auto tranny
- cheap t-lok rearend
- What the hell is this?
- Leather Seat Covers
- squeak!!!
- Clutch change... How high
- Disassembling Rearend
- Fog Lights into a 98?
- deck height, rod length..can I get the info?
- 2000 brakes
- pcv valve concerns
- Body kits?
- pedal oddities
- Adding duels...need a bumper
- Heads & Intake
- Headlights
- Online Source: TSB's, Repair Procedures, More!!!
- Thermostat question
- Installing BBK CAI on my 03' Mustang
- I need advice!
- cheap nos kit for 3.8?
- engine picture, how to get more HP?
- when i get a dyno,do they supply the chip?
- exhaust ?'s
- 96-98 transmissions
- Engine+Tranny swap (lil different..)
- Passing smog check...
- 95 V6 3.8L Blown UP?
- Not another tranny swap thread...
- MAF Question?????!!?????????
- New guy on the block
- Help with lights and dashboard
- Brake Transmission Interlock help needed
- Cheap Intake
- grr
- Supercharger and Exhaust right away?
- Air bag Light ON!!!!
- Gears for the V6
- will a 302 (5.0) bolt up to our stock transmission
- Springs
- Question about adjustable lower control arms
- Are 94-98 Throttle Bodies the same???
- What really compliments a supercharger
- My newest MOD! Isn't she a beaut!
- Item Specification
- automatic to standard?
- Best Buy With $160?
- spring question
- Just put in a Spec stage 1 clutch
- Stuck in park??
- Replacing aftermarket intake with stock one
- Side exhaust questions.
- Another question about the supercoupe supercharger?
- want more power
- Used GT exhaust
- T-lok v. Cams
- Maf
- Weight Savings with Fiberglass hood?
- what to do next
- Rear brakes
- flushing coolant
- Upgrades
- gains for P&P
- Question about headers
- As the 3.8 turns
- If you haven't deleted your PCV yet...
- 03 head rest
- Replacement Hoses
- T-5 Rebuild
- wrecked 2000 mustang
- 2001 v6 too 14's?
- 93 V6 foxbody
- suspension setup
- MAC LT's - no good? What else?
- Instructions Insatlling posi-trac...
- Moving spoiler back
- Roush exhaust Q
- gains with this exhaust setup?
- Body Kit Install
- Cruise Control
- alternator fuse
- side exhaust
- supercharger?
- G-Tech?
- 97 V6 exhaust question
- Got fuel pump installed...Just found out I'm a moron, too :)
- flame thrower kit installed...pics!
- $2000 for performance - what would you do?
- Need you advice!
- Question about explorer brake pads...
- How To Create A Bypass For Your Pcv System
- Mass Air Flow Meter Screen
- radiator upgrade
- Coolant Leak very odd
- question about stage II and tuner kit
- shift kits
- pcv technical service bulletin
- MAC + K&N???
- Cost of fuel pump
- Steeda
- RED Lining with the Traction Control OFF. Did any Damage Happen?
- 2003 V6 Supercharger
- Squeeking #@%% Brakes Yet Again
- Flowmaster Products
- Tremec T-56
- Cam Install Prices.
- Just go ahead and buy a built 3.8?
- Fuel Pressure
- port & polish
- MAC Products
- what size are the rear and front speakers
- MAC CAI Install - Service Engine Light ALWAYS ON ???
- which is louder?>
- Exhaust??
- Tranny Question
- 98 V6 Lowering springs
- Side exhaust / lowering
- Order of Importance
- Aftermarket CD player
- 5.0 in a late model
- Diablo Chip?
- 2000 stang- first car
- Best Nitrous systems, worst systems, cheapest, most expensive,
- Side passenger kick panel removal.
- rear window tint
- have you guys had this problem????!?!??!
- 1999 V6 Exhuast
- stuff needed for t-lock install
- Densecharger?
- Fog Light Install Instructions
- A exhaust question that is out of the norm, trust me
- 98 Mustang Alarm Problem
- idle problem
- v6 exhaust question.......
- Duals
- Best Exhaust
- one-touch power window module
- Location of PCV valve on 2000 V6?
- hp gains?
- Dual exit MagnaFlow Exhaust System
- 3.45 vs 3.55 vs 4.10???
- Air Silencer Removel
- 2001 motor swaps
- Snow problem; need tires but low budget
- Synthetic oil, when to use???
- 7.5" rear - capabilities?
- Turbo vs. Super
- Hooker headers..
- Fr500
- Long tube headers and Gt takeoffs
- to chip or not to chip?
- starter problem
- msd ignition wires
- Getting automatic shift knob off..
- Headers or TB?
- Rear Shock Isolators
- suggestions on mods (cam, pisons, supercharger, etc) long post
- Fool Injected?!?!
- Motorvator and 70mm TB
- reverse glow white faced guages install
- DIN's in a 2000 Mustang
- Help, How To Remove Front Seat Headrests
- My custom turbo setup near completion. Pics Inside!
- Headlight Assembly Installation
- alarm question
- Clear Headlights
- track launching?
- Gears
- question about a drop
- clutch troubles
- GT hood??
- Spark Plugs and Wires
- 99+ engine swap to 96 v6?
- The life of a clutch?
- why mod a V6?
- Cams
- idle probs
- Removing Exhaust?
- Hardtop for convertible
- Window Tint
- Check Gas Cap and SES lights fix
- Decals
- 94 3.8ltr Head gasket recall.
- C&L 73mm MAF ?!?
- Motorcraft Oil
- 18" Wheel spinners and other wheel related questions
- ABS question
- Mach 1 grill delete kit
- getting a grip
- Would a Grill Elimator Kit be a bad idea?
- best mods for a V-6
- swap 6 for 8
- Whats this noise...
- launch rpm's and n2o question
- Error Code P0172 System Running Rich Bank 1
- play in the steering wheel
- when porting and polishing heads and intake??
- Anybody done this?
- Help! Need Basic Information on Mods!
