View Full Version : V6 Tech
Pages :
6]
10
11
12
15
- Catalytic Converters, See if you can help me
- 94-98 which year is the best?
- Surging Temp gauge.. slow heat
- where is the computer obd hookup on a v6 stang?
- Nos?
- Anyone had Power Window Problems
- What the hell..? Busted ignition.
- Questions about exhaust mods
- fuel problems with a 95 3.8
- A good day gone wrong...Help Please...
- Roaring/Vibration Any suggestions?
- First mod??
- Exhaust suggestions
- 2004 Passenger seat removal?
- How much power does a S/C give?
- msd ignition install question
- Is my calpier seized?
- Caliper delimia
- newbie needs help...getting laughed at by GT's
- "PYPES" Crossover X Exhaust for V6?????
- Cobra or GT Rear Bumper
- "Squeel" Problem in 1999 V6 5 spd
- tune up intervals?
- help with code
- Help!
- supercharger help
- Daughter's 98 v6 throwing code P1151
- Tire Question!!!
- "TO" Yellow or "NOT" to Yellow ?????
- misfire detection?
- headers...yet agian..but searched 1st
- '95 V-6 Mach 460 Problem Plz Help!
- V-6 Supercharger Idea
- Anyone have an R34 front bumper..?
- How wide is a 97 V6 rear?
- Power steering pump whine
- very weird problem with guage cluster
- Finally got me car fixed, for code P0174
- engine warm up and heater questions.
- What next?? for my v6
- Automatic Shifter Problem
- Fuel Filter...
- Anyone want to sell their black hood?
- Yet another exhaust question, YEAH!
- 3.8L 2000 traction control...
- '02 dies while driving?????
- Check Engine Light
- Mustang Won't Start.
- Will these wheels/tires fit on my SN95?
- engine swap
- engine swap
- rear end question
- Best $20 a V6 Guy Could Spend!!!
- 2000 V6 Underdrive Pulley
- suspension setup
- Where to buy Saleen body kit ???
- New Member.... cold air intake question
- Has anyone hear of progress sway bar?
- 95 overheating
- 2002 V6 brake job???
- some help fittin some subs in
- belt replacement
- Help...what broke?...firewall hose
- Metal Rattle Sounds When Excelerating?
- Fog Lights
- can i please get 245/50/16 pics
- fog light install question and pics of our 2000 Mustang/70-03 Machs
- Busted up bumper 2000 mustang *Pics*
- How to hook up oxygen sensor?
- MIL eliminators
- Anyone with 94/95 Black & Gray Interior update Console??
- Diablo Sport Predator Tuner ?????
- Cabin Air Filter, Help Please
- my O/D OFF button came on. It's not blinking but what could be wrong?
- Idle surge
- white on green decal
- Cam position sensor
- stereo/cd player
- Coil Spring Adjusters??
- wheel decision
- Air Conditioning Problem
- Do I really need an "h" pipe?
- converting transmission
- damn exhaust
- Suspension & wheel question
- EGR and rough running 30-50 mph
- Engine Swap 3.8 to 4.6
- White Exhaust Smoke?
- Startup Problems
- V6 Swap Into Falcon
- Tremec TKO
- How do I remove my parking brake cable?
- Single Exhaust Setup
- What to do with my crashed v6
- Michelin V.S. Pirelli
- Exhaust Advice Needed
- Rear Defroster Question
- 1/4 Window off a 2003 fit in a 2000?
- Mach door tweeter differences?
- Front sway bar anyone???
- Heater only blows from defroster
- Red gauge lights?
- Dist. Hole
- Mach 1 hood
- 95 Mustang 3.8L, Bogs down in 3rd gear. Need help.
- Bad weather tires for on '04 v-6?
- 5.0 into a 2000 V-6 Chassis
- CAI Problems - weird noises - bad startup/shutdown
- SCT X-Cal 2
- 2006 V6 Maintenance Questions
- Idle, startup, revving
- Steeda Sport Shifter
- rear sway bar?
- 94-98 Offroad H-Pipe?
- Help! IAC bolts broke off and still threaded inside.
- Odometer Blinking out
- exhaust
- MACH 1 vs GT ?????
- 2000 Fuel filler tube rusting away
- Turbo 6?
- I want it to go fast... Real Fast.
- GT exhaust for V6
- Couple of Q's
- Rear brake issue - can't get the caliper back on
- Suspension Help
- Fuel Rail Crisis
- 17x10.5 BLACK CHROME BULLITS vs 17x10.5 BLACK BULLITS ???
- Dual Exhaust And Gears ???
- Plug Replacement?
- V6 exhaust Q:
- '96 alarm system ...HELP!!
- I think my car is possessed-need an exorcist
- sticking selt belts
- stalling at consistent speeds
- Fuel Injectors
- twin turbo
- Plugs and wires to get?
- 7.5 differential bushings??
- runnin lean
- install cruise control
- manual windows?
- HELP with CAI ????
- ICA Restrictor Plate? RPM Hang
- considering tire and rim swap
- EVO5 bumper
- Qeution about a V8 Conversion
- P0402 code - "Excessive flow in the EGR system" - ?
- no spark--3.8 sable
- Rear Bumper accident
- tryin for more power but dont know much about the v6
- Exhaust
- new V6 owner w/ exhaust ?
- god dang rattle#@!
- black wheels black car
- X or H pipe
- More Power
- Will Aftermarket GT h-pipe work?
- Help! 12 mpg on 04 V6 5 speed!
- Anyone convert to a Mach 460 soundsystem?
- Second Opinions On 94 V6 Purchase
- Dual Exhaust ?
- OBD I or OBD II???
- Tranny ponderings
- 3.8 Versus 3.9
- Tire PSI
- Superchargers
- Look what I just bought!
- 255/45/17 on 17x9s
- 2002 3.8L automatic, chugs at 30mph in 3rd gear
- Ok i need some tech help?
- Problem with throttle sticking
- 42 lb injectors for 01 mustang?
- ticking noise
- Fuel Filler Leak
- 2001 MUSTANG Tire Size Question
- whining noise from power steering
- Vibrations in 5th Gear
- 315/35/17" on a V6-good or bad idea ?????
- MSD DIS 4 Ignition
- Extended Warranties - outside of Ford???
- camshaft position sensor...where is it?
- Engine revs itself in neutral? Help please.
- help asap please!
- i have some ideas.
- convertible top
- possible reaons for bad gas mileage
- 97 v6 t-5 in a 88 gt
- anti-freeze hose
- 4.2
- Better gas mileage
- Flowmaster Exhaust
- weight
- gear ratio calc?
- Supercharged V6
- A few technical questions
- Car problem after warmed up ..Hestitates
- Problems with revving
- Question about octane
- Steering Wheel, a little help please...
- Brakes and Suspension problems
- Removing side stripes
- gt takeoffs!!
- Driver side speaker not working...Advice?
- Creaking?
- New to site, question about steering rack
- im new with this
- K&N FIPK
- Will a 2000 engine fit a 94.
- GT takeoff, flowmasters
- Cold Air Intake/Check Engine
- More leg room mod? :)
- Bushings for rear sway bar?
- DIY grille delete?
- 2005 wheels on 2001
- DiabloSport Predator
- door speaker
- car stumbling
- brakes spongy after brake pad replacement (didn't open bleeders though)?
- Anyone Want These..cheap
- Bumper Skin Replacement
- Energy Suspension bushings??
- floor mat hook
- RPM ****es/rough idle with A/C on?
- Build Codes - Where are They!?!?
- trash can attack
- Mileage/Tune-Up Questions
- Left Rear hight
- question
- PLEASE HELP with alarm system!
- quick ? sc
- gonna buy somethin
- Computer Re-Adjusting
- overdrive button
- Couple of Questions
- Balancer counterweight?
- Turbo for 97 Mustang Coupe
- New here with Questions about Mods...
- Time for our V6's to shine
- Bigger gears
- making me mad
- Tie Rod
- Wheels...what should I go with ?
- Body Parts
- What about the earlier 3.8's??
- 00 V6 pedal assembley same as GT? Same as 94-95?
- RPO Codes - Where Are They?!?!?!?!
- Engine Swap...
- Ported Upper/Lower Intakes
- Air Conditioner
- check engine light
