- Fixed timing made it worse
- Just a question
- Even more cooling help needed
- No Spark in #1 on dis
- Need some more cooling help
- water lines for the turbo
- If anyone could be interested
- K & N noise?
- piston rings, determine top from bottom
- Got some new wheels!
- Dual plug manifold fit single plug head?
- Roller cams
- Opinions on Brakes
- Differences in block years 83-86 86-88
- mustang reasearch
- turboford is down and i got a problem
- Glocked cat?
- Anyone happen to have "Boport's" email address?
- turbo question
- Changing wheels?
- t-coupe at junkyard
- Hows this look?
- Is that a 5.0?
- Exhaust sound clip links!
- Best exhaust for my car?
- Turbo Water lines.
- Fuse diagram
- Heater/Turn signal help.
- Springs
- 84 Mustang Parts
- adjusted tps, still a bad 15 mpg, what next?
- how much??
- need body repair help
- Loose Motor Mounts
- Should i drive in drive or overdrive?!
- Tranny mounts?
- HELPPPPPPPP can't get it out of park
- help me diagnose my engine problem please
- Hi guys/gals
- help
- I hate to say it...
- check it out
- fresh 2.3L giving me fits, need some help
- Super Quiet Exhaust
- DIY Clear Corners
- really funny
- I Tested the Race Truck Today Warning: Pics inside this thread are Sweet!!
- Starter Replacement Info
- O MAN
- A question about our 2 cats
- Hesitation and bad smell
- about my turning signals.
- the Mustang Rides no more
- injector size?
- What is this doo-hickey for? And can I get rid of it?
- cars running!!!!!!
- Turbo Swap: Are oil pans and motor mounts the same?
- this is great
- Old folks and Mustangs don't mix
- finding a 2.3T
- What good does a Breather do?
- possible te buy an import and not be called a ricer?
- making sure of something.
- This weeks pinto installment.
- extra fuel rail or hoses?
- CAI Inlet Tube
- 300+ RWHP??
- turbo help
- 1g dsm bpv?????
- New to the forum with a question on Qa1 K member and coilover install
- thought i might ask before i bid.
- 7.5" rear-end rebuild
- verts speakers
- How much HorsePower
- Should I?
- How much?
- Just another mourning message another dead SVO
- Turbo Swap
- Tranny Swap ?'s
- EGR problems
- parting ways
- Think it would be cool to put some GT seats in an LX?
- How else to winterize your car.
- hard to start?
- fuel line clips
- New Turbo Need INfo
- Replacing plugs on 8 plug 2.3 I-4.
- how many quarts in a a4ld?
- starting motor w/o exhaust
- Should I buy? Need general 2.3L info
- Stangnet Member of the month
- Driving a mustang aday keeps me from going insane
- WTF my 220k engine runs like crap with 184 PSI
- Turbo exhaust sound clip
- Hard to start in the morning
- Made plexi windows today!!
- Any way to help my 15 mpg??
- Benefits of running a 65mm TB
- Tunderbird Turbo motor in a 2.3 Mustang...?
- Emergency Brake Light in the Dash
- 93' LX door lock
- clutch cable and quadrent
- motorcraft oil
- Sunroof delete question...
- what sensor goes here?
- should I buy it?
- best gas
- does an 89 2.3l auto have a rev limiter?
- Heater Core Replacement
- Smoke help...
- Rear End Comparison
- terrible engine hesitation
- Life is not fair
- NooB Here where to start
- Exhaust changeover woes...
- 87 TurboCoupe wont Idle
- 3.73 Rear End
- Need help
- it's not a stang but I need help
- Where to find internal turbo parts?
- auto shifter
- How many quarts of oil with filter change?
- A buddy of mine is wandering whts the easyest way to get 400RWHP out of a 2.3T?
- what goes here? (head)
- Spring rating
- brakes sound weird...
- Brand/Weight Oil?
- upgrading the seats
- WHAT SHOULD I ASK FOR IT
- rebuilding distributor tech?
- do you guys have alot of interior rattle and noises?
- 2.3 NA Power??
- 2.3T or 2.3Na Cam
- got 86 svo motor for sale
- How much of a hp increase on a stock 88....
- Diff
- so will a flowmaster 40 sound pretty good a NA2.3?
- sunroof
- head question
- Where is the fuel pressure regulator located?
- need help with timing...
- 2.3 Driveablity problem
- Anyone in the Newyork/long island area need a svo rim for free????
- FAST money.SMALL investment...make ur car fast the EASY way!
- searched and... nothing
- ok I want to port out intake manifold, a bit in the heads.
- Engine blues...
- FAST money. SMALL investment...Make your car fast the EASY way!
- Hey Bhuff30 question..
- Humm exaust hehehe come look.
- Installed gauge panel in TC center console...check it out
- Whats the biggest speaker you can find in teh back deck of a 93 coupe?
- 2.3l trouble shooting
- Cruise Control Cable???
- new door panels
- does any one know this guy
- is my a4ld sorta messed up or it suppoed to do this?
- Tint/ other Things
- Wheels for sale!!!
- Picked up new powertrain today!!
- do your guys' cold/hot air dial wiggle?
- Boost guage reading
- Stupid people PLZ READ!
- volvo FMIC w/ 4cyl radiator
- metal armrest latch replacement? where to get it?
- Auto Cross turned bad...
- shaved head tech
- These won't fit on an 89, will they?
- Tick, Tick, Tick, Tick, Tick
- Clips? where to find?
- 302 5.0L Swap?
- 91 mustang lx convertible
- how many miles should i be able to get off a full tank?
- carb to injection
- 17x9's fit?
- Where's the fuel filter?
- a/c vacume hose harness from a/c control
- white face gauges for 2.3
- torque converter bolts
- Shes dead...
- what 2.3 fords came with a front mount intercooler?
- MSD Ignition
- Can I borrow $.02?
- Help timing problems
- new to the board
- GFX fitting problem...
- Question about teh crank, and some other stuff
- 1979 2.3 turbo into 83 NA2.3 ranger
- Removing A/C Belt
- Will a cold air intake made for a 5.0 fit on a N/A 2.3?
- Thinking of getting a chip
- duel plug or single plug?
- Found a 2.3T now what?
- 91 conversion
- Parting 88 Mustang 4 cyl. Need parts?
- Clutch Help Please
- Engine cooling fan question.
- Whats a good company for suspention kits?
- Tranny to the end
- Whats the difference between open & closed chamber heads?
- Widest tire on polycasts?
- Who has the best....
- Stolen!!!
- Oil pressure problem
- SVO Mustang
- Is my tach off?
- what's wrong with my mustang?
- I do not what to do
- Fast idle
- Exhaust clips?
- vacuum schematics
- help... tachs not working right...
- What does SN95 mean?
- Difference Between (M/T)/(A/T) turbo coupe ecu's
- Slide to the left, slide to the right!
- Same as mine?
- 2.3 Turbo engine(value??)
- 88 TC 2.3T into my 86 coupe Wiring nightmare or ??
- Help Please
- Now I understand...
- OverDrive Alt. Pully
- What's up with Turboford??
- changing over to 140 mph speedo , what color circiut board do I need
- Advice for people doing heater cores
- 10MPG!!! whats wrong??
- What sensor?
- after carefull consideration iam just gonna turbo the beast.
- removing part of the dash
- turned key on car for first time with unwanted results NEED HELP PLEASE!!
- how to check if a VAM works?
- do 2.3 mustangs have the same engine as the early-mid 90's rangers?
- Vacuum?
- Tranny...
- Where is the sending unit for the temp gauge???
- What years did they make the T-bird TC?
- In a predicament, please help
- my tires are too wide!!!
- fuses
- Heater Core
- read code and get a 66..
- dual plug head info
- GT gfx kit
- OIL IN THROTTLE BODY HOUSEING
- just got a 2.3na
- merkur
- Rev Limiter? I thought you were jokin'!!!
- soon to have boost
- hey bhuff or anyone else
- water problem
