- HP increase
- A237 or HR276?
- AMP Light - what exactly does it indicate?
- headlights
- Engine dies while idling?
- trun to the tlc channelfrom 9 pm to 10 pm
- mustang manual
- I got a dremel, I got a dremel, I got a dremel, hey hey hey hey....
- Transmission = kaplooey
- What kind of performance can I expect???
- Wiring Question, Need advice quick!
- trunk access to fuel pump
- Quick Paint Questions....
- Alternator belt tentioner
- Why am I having such a hard time setting up a radio?
- Radiator Hoses
- Running Problems
- MM Bumpsteer Kit and CC Plates Installed on the 2.3...
- opinions on gauges
- clutch feels like its slipping???
- Preventing Block rust?
- Ranger Header is in
- GOT MY T3 TODAY !! Bunch of questions and pics
- cool new look
- Done!
- clutch problems
- n2o need too know
- internal engine cleaning
- quick question about rear rotors
- pin #37
- Timing Cover Seal Help
- Bosch Plugs
- need help with timing belt
- EEC Relay Location
- ignition problem, need alittle help
- ?turbo=flamable?
- Parting out a Red/Black 1986 Stang Need some parts too.
- I think the MAF is bad
- Cop wheels
- Early model T5 bellhousing needed??
- oil starvation in the head
- Auto Tran fluid loss (no leaks)
- engine painting
- over drive on manual trans?
- squeaky spring
- svo rear end/front axles & brakes
- Vacuum Probs???
- so where does the clutch cable bolt up?
- IRCM "Black box"
- whats the part# for the rubber valve cover gasket??
- whats the part# for the rubber head gasket??
- Blinkers Again...They are not working
- 140mph speedo problems
- So Did some interior modding
- Need help removing head
- Getting bad gas mileage? Please Read.
- Tranny cross member?
- starter index plate - VERY URGENT
- my new car
- Quick Wheel Questions!!!
- alt's good still no charge?!?!?!?!?
- SVO Probs
- 82 ford thunderbird ??
- Some turbo swap pics
- A Big Wtf!
- light bar brake light cutoff switch
- Head bolts
- head bolt replacement
- Timing vs Boost?
- what year cars have the la3???
- Uh oh, Time for a new Rack&Pinion and PS Pump??
- Nitrous Spinouts? Traction?
- pcv issue
- I Need Help Asap!!
- Question
- water intercooler
- n/a 2.3 hp
- looking to change to a turbo block
- TC computer diff auto to manual
- where to get a turbo motor?
- Heater Core
- Will the T5 from a 5.o work in the 2.3 turbo?
- Fuel Pump Relay Circuit
- Exhaust opinions
- Need help quick!!!
- Fuel pump woes...
- Fuel Pump Hanger/Strainer
- PLEASE HELP with my SVO rear brakes
- General n00b question...
- some problems with the 91. any ideas?
- vacuum diagram
- Turbocoupe wiring harness
- 2.3 in Ford's minivans?!
- Nitrious
- wheel?
- Fuel Pressure Guage In Cowl, What hose or line to buy ??
- My goal for a turbo build, what would it take?
- O2 snesor.....
- 3rd brake light ?
- Turbo Fuel Mileage
- Blinkers!!!
- 2.3L engine problem`s help
- svo hood
- Gas Mileage with a Turbo
- what rangers were carbed??
- code compliance battles: I need to advance my odometer!
- boosting
- valve tap in first
- Need help with head gasket
- Anyone put a turbo on a DP-DIS?
- Automatic TC's....
- head prices
- Can someone tell me what's this color?
- Interior Lights
- I had a fender-bender, now I have some money
- poor gas mileage, or something more sinister?
- Headlight and turnsignal questions
- QUICK firing order for 88.
- Porting Articles
- Rear Wheel Bearings
- T5 Swap Q??
- MustangCoupes.com Now OPEN!!!
- BOV installation
- Cooling problems...
- Quick Rim question?
- electrical porblems
- 2.3L Turbo Engine price.....good or bad?
- Canadain custom fiberglass
- Transmissions
- Difficult start? timing? or lack of fuel?
- Interested in getting a 2.3L
- 4 Cyl Engine + Auto: How good?
- Rear ends need to know!!!!!
- New thermostat new problems
- Poor gas milage
- Ranger Cam
- Tachometer issues
- 4 lug to 5 lug conversion?
- Performance Chip
- New Battery
- My new AFS Cobra R's (pics)
- what's the fastest N/A 2.3 mustang
- 1st time porting pics what u think!!!!
- door hinge
- Auto to Manual
- Oil pressure readings HELP!!!
- What kind of "power" do you other NA guys get?
- Compression too high??
- are bellhousing bolts universal?
- Would a 2.3T fit in this?
- Exhaust leak?
- '85 Cougar XR7=Good Parts car?
- Bolt pattern?
- Sellin the stang
- I6 project is dead. Long live the turbo 2.3L
- Saddam is Captured!!!!
- 88 Mustang Stock Exhaust
- compression test results(i dont think the motor is bad)
- free carb intake
- Anyone bought one of these?
- bell and clutch cable question
- Fuel Pump Replacement
- what should I do???
- painting intercooler?
- What does it mean when there is oil in these holes ??
- Help me identify this Turbo!
- Springs ASAP
- Common places for an oil leak?
- Need Help Cam & Piston Selection
- my new frankenstien (slightly off topic)
- haha
- Removing Driveshaft
- Can any one identify this transmission?
- exhaust
- Cra won't turn over!!
- Thought id show some pics...
- Need help with Gauges
- tornado or hurricane?
- need to buy
- loook what showed up for dinner...(pics)
- Desirable Turbo donor cars?
- switching motors this weekend
- didnt work
- QA1 K-Member
- hatch struts
- Buying an 86 t-top coupe any good or bad about an 86 2.3
- How would my motor run with a single plug N/A head on top, please read
- Want to rotate intake....Alt. in the way
- Where to find a 1990 shop manual and at what $?
- Bunch of Axle Housing Interchange Qs ??
- Rods Rods , Rods everywhere!?
- 2.3n/a tweekers need help!!
- no intank fuel pump!!
- fuel pump ???
- Killing the n/a hp bug with spray...
- Help...Intake..
- hazard switch wiring
- 87 xrt. wireharness auto. good or bad
- headgasket ???
- Radiator Question
- Alright, here goes...
- pulled a couple codes. need help!
- So I wanna come back from the dark side
- Quitting Car bus. Starting new job.
- 1980 Pinto turbo project
- fuel pump ?
- Clutch/Pressure Plate/Flywheel ?
- Is there a difference between Auto and Manuel Crossmembers?
- SVO seats
- What else do I need?
- Subframe install, what to watch out for
- body kit
- Weakest link(s) of 2.3l?
- Is there a small VAM?
- Turbo....swap
- Anyone run coil-overs or been in a coil-over mustang?
- I smell BS...
- Audio & Tranny Questions
- Fuel pump on a 2.3L
- Can you port the intakes on a twin plug?
- (another one of "those" questions)part 2
- Pair of SideDrafts on eBay
- 300ZX twin turbo
- Just bought my first TC, to swap into my Stang!!
- I got a LA3!
- Heads up, an La3 up for grabs @ebay
- How long till 150shot blows the 2.3?
- Are the box intakes on the 87-90 mustangs the same as the square ones in turbocoupes?
- Will an AOD from a 5.0 bolt up to a 2.3
- What size and how many splines is the clutch??
- another one of "those" questions
- turbo swap pre-game prep...
- SN95 Shocks on a '90
- Stuck crankshaft pulley
- Hp estimate
- Questions on a turbocoupe
- got offered some 4.10's
- Want an 88 TC for my 'Stang, found an 87. Any difference?
- n/a 250 hp?
- Porting question....need some opinions:o)
- G-techs and ricers
- dude........
- Bad Vibrations when shifting.
- hey
- How can I make this work...
- ? on 2.3 engines
- thinking of makeing my own header out of a ranger header
- Why remove the Air Silencer?
- My intake
