- Turbo Coupe seats
- Code 224...'92 Mustang 2.3
- dumb question
- Any rubbing issues with 17"x9" & 45 series tires on Mustang?
- Mustang needs new home
- 91 mustang 2.3L
- 87 2.3 stang upgrades
- What should i get??? exhaust system????
- New Gauge
- Thermostat Gasket Woes
- I don't know where to post it.....but
- Good price for pipes?
- just got an 88 turbocoupe
- Just bought a 2.3
- 2.3 liter ranger engine
- What size compressor best...
- Engine cleaning question...
- runing with no filter
- OK so my girlfriend bought a 2.3 ysterday
- Headers
- Fuel Pump Problems
- A little help
- What the heck is a oil separator?
- Trouble Shooting Questions
- exhaust question
- Shifter question
- Ball joint?
- Question about gearing...
- THe swap
- 4 barrel carb on a 2.3?
- Lots 'o Questions
- What does the computer control in the carbed 2.3L?
- Exhaust question
- Speedo swap?
- 89 vs 91??
- Help me win an argument.
- code checking
- 88 TurboCoupe engine swap into a 92 Mustang
- what doors can replace
- Weird Noise
- Is this a deal on a 84 SVO?
- Am I going in the Right Direction?
- gotta get rid of this
- can a clogged mufler......
- engine help
- oil line hole
- Need Carb help
- why cant i turbo?
- Weight question
- Computer Info.
- 4-lug to 5-lug switch
- timing questions
- Dual exhaust
- Rack and Pinion Questions
- So I shattered myu window by shutting my door and iam am wandering if...
- 4x4 gearbox rebuilder?
- Turbo Upgrade
- What's the norm 4 oil pressure
- noisy T5
- Question about rear speakers
- asuming the timing belt broke
- Help. My brake lights don't know I'm pressing the brake pedal.
- Engine Troubles
- IC piping suggestions needed.
- New wheels are on
- Carbed 2.3 turbo
- tranny question
- Anyone have a Turbo they want to sell?
- MAF on a 1990 LX?
- Thunderbird motor mount
- injector ?
- Help choosing an intercooler?
- Clutch Problem !!
- Couple of questions
- 88 A4LD with 87 TC Motor?
- Turboing an N/A 93 LX.
- Dis
- Help guys
- How much amperage does this thing draw?
- Muffler Offset
- Turbo Coupe
- What A Godd Friggin Idea!!!!
- '90 2.3 windshield wipers slow death...
- I told him NA is not a good way to go if ya want more pep but no thick headed basterd
- T-5 swap driveshaft Question
- Got a T5!
- upr clutch quadrant
- 92 4 banger notch
- What if this really happened?
- i DON'T want to buy a 2.3 turbo
- I have lost 1st- 3rd
- Bought a 88 Turbo coupe, $300!!!
- Bhuff, Can I get dibbs on you header?
- Tach Signal feed.
- Engine fan controller problem
- A call to help from a future Turboer!
- my new 92 2.3 runs terrible
- Exhaust
- New custom setup pics
- new personal record
- New parts!! and a Question
- tach problems
- Bellhousing pattern question about 4 cyl
- Will 4-lug SVT Focus wheels fit on my car?
- Lost my keys, what can I do?
- Thunderbird TC
- What SVO with 22psi could runs on 1/4
- I'm installing a Pace Setter header and I need some help
- Fuel Pump
- Wfc 8
- TP sensor
- To those who think its okay to part a perfectly straight SVO out....
- aftermarket guages
- How much speedo will be off with N/A 4 cilynder speedo and SVO motor and tranny
- my car
- Throttle body and rings?
- 1992 Ford Mustang LX
- Turbo Coupe
- Turbo Engines: For Dummies
- Whats the top speed of my car?
- 1993 Mustang LX 4 cylinder running rough
- Transmission woes
- T/C stock fuel pump
- Battery in my 93 LX keeps draining!
- Humm pricy but with a warrenty like this I think its dman worth it(driveshaft stuff)
- svo motor questions
- manual transmission differences?
- Horsepower
- Non Ford Tech Question
- If anyone's interested...I have my old engine for sale
- how reliable is the 2.3?
- Put a turbo on a N/A 2.3?
- SVO differencs....
- Anyone put a shift boot on a Automatic shifter??
- Parts
- obsolete part??
- Civic vs. 88 N/A
- muhahaha, more new 1/4 times from bhuff
- Help me find if this header will fit my 89'
- fuel gauge
- battery light stays on
- sudden loss of oil pressure in 92 2.3
- Flowmaster
- Finally have some pics of my broken Turbo
- One last try
- Anyone Looking for a 2.3 longblock and A4LD Trans
- ATTN: Brake experts?
- Turbo Upgrade
- Turbo vs. N/A Wireing
- Fuel Pressure Reulators?
- 86 mustang problem?
- A4LD w/ 85 TC Motor
- Turbo Coupe Question
- 91 Stang won't start
- just installed...
- Getting back into the game
- Score!
- Shock recomendation for lowered car
- radio intallation
- 1989 2 wire or 3 wire tranny question
- Merkur Parts
- Stock NA exhaust diameter?
- Inline 6 Performance
- parts
- low idle question
- Is my tranny Slipping or No??
- Update: Head Swap Complete
- Thunderbird Turbo Computer?
- M.A.P. sensor help!!
- noise??
- Intake Questions?
- From 5.0 to 2.3T
- ok, so how do you find a turbo?
- Car won't Idle
- Throttle Bodies
- 20psi boost too much?
- Looking for some cheap, easy power
- Rear Control Arms.
- update
- Worth it? looking for a cheap way to lower the ride.
- I cracked the 13s
- Merkur Turbo PSI
- Delta Flow vs. Original Flow
- Going to a Mustang JY next week.....
- eec code diagnosis
- About to be a member of the KC Turbo Club! (hopefully)
- Turn Signals and Ranger Header
- Replacing the impeller..
- Dipstick oil leak solution???
- Any Advantage to Swapping Cams?
- A new set of problems
- Clutch Quadrant
- New 1/4 times for my mustang, Cro, you listening?
- Any pics of rolled fenders?
- good deal?
- twin turbo 2.3l
- Sound
- EXternal wastegate question
- weber sidedraft carb question
- I gonna shoot this bird
- Knock sensor all knocked up...
- Taurus ECC-IV in the stang?!
- falling on face at w.o.t.
- EEC tuner question
- just wondering
- DIS Block
- Air Conditioning-134 Help
- 93 Mustang LX 2.3L
- I really need you guys help on this one
- SVO questions.
- dancing
- 2.3L to 5.0L, how hard?
- 91-93 block same as (fill in the blank)
- 2.3 N/A build-up
- Boost Fluctuations
- NE1 have no cats and a reduction in power??
- BOV question
- Its ALIVE!!! sorta....
- Clutch suggestions
- How much can you see through a good Catalytic Converter?
- Failing Fuel Pump
- Learn me about the 2.3 Turbo engines :)
- Good Deal on svo Pair
- NE1 put glasspacks on there SVO or GT turbo??
- What effect does tire size have?
- anyone have an extra tailpipe OR catalytic coverter?(also a ranger or longtube)
- Cooling Fan Module Part Numbers
- Engine Missing HELLLLLLLPPPPPPPPP
- Transmission Lines
- fuel economy
- My Fuse Keeps Melting!
- Part numbers
- Electric fan question...
- best muffler for a non ricer sound
- Wow, I have overdrive!
- Turbo Hose Hell
- Where to begin!?
- want info on 2.3 1989
- Does anyone know the diameters of a 2.3's Input shaft?
- 65mm throttle body problem with the tps
- IHI Turbo question.
- Final Drive Ratio Question
- DIY alignment, how to make a camber/caster gauge
- Constant flooding...need help.
- Motor Mounts????
- Fuel Pressure woes
- turbo?
- Triing to figure out a motor for my future hotrod....
- Lifter question.
- Turbo manifold prices?
