View Full Version : 5.0 Tech
- How to square up K-member
- Cleaning overflow canister
- Engine Pull Article/How-to
- Fuel Lines tank to body?
- 5.0 swap
- tko 500 swap
- Benefit to having MSD stuff?
- Bassani Header Instructions Needed!
- What cubes am i at?
- car dies when I engage clutch
- Do I really need the Vortech FMU
- emissions removal
- Car starts without clutch engaged
- I need help coil problems
- Vacuume puzzle *pics*
- another wiring question-- jrichter?
- need help!!!
- harmonic balancer
- New Power Distribution Block
- motor Mount advice....don't do this...
- pioneer balancer
- Check Fluids Mayhem
- Which Heads?
- Trick Flow parts madness, wont start
- 7qt pan equals...
- zinging starter...grr what to replace it with or not at all?
- replacing Capri carb.
- Rear Choice....
- Paxton Supercharger need help!
- Why Do I Have Such Horrible Ride Quality?
- 89 5.0 mod prob, take your pic!
- Do i need a chip
- Engine Blocks
- need coolant bottle help
- Mass Air Article?
- Code 33 that will not go away
- sn95 brakes
- Where can I get the tool to take out the ignition switch?
- FRONT RIMS RUBBING ON CALIPERS
- Is it a direct bolt up?
- Tips and Tricks for installing Motor Mounts...
- belt keeps coming off please help
- need help with head question?
- rear suspension nightmares! help if you can...
- Car died, need some help plz!!
- distributor part number
- question about cobra intake
- Cut pistons for 2.02 in-car?
- Dakota Digital fan controller
- 96 Cobra rack on 94-95 K-member?
- engine codes 13 44 94 ???????????
- gt-40 heads and lunati camshaft
- Need help choosing a nitrous kit
- Just Dumped Codes...Advice ?\\?
- Convertible Top fluid..
- getting rear end!
- overheating question
- no start and exhause red hot and burning stuff help more parts more $$$ not an option
- quick egr ? confused
- throttle body spacer and upper intake very hot
- How To / Front windshield Molding
- help me plan my build turbo 331
- Car is starting weird has a mind of its own.
- speedo and clutch cables routing
- horn not workiing...
- Edelbrock RPM II Install Question
- No oil in valve cover?
- 5 lug kits, questions
- Install question on Saleen rear bumper lip
- Adjustable fuel pressure regulator
- Rust... Its getting about time...
- Need new heads...Any recommendations?
- HELP! Overheating
- ok so I know the answer....just funny
- What vehicles had a 130A 6G?
- front suspension question
- electric fan help
- Coolant Hose (Heater Core)....
- Scary Stuff...
- Fiore FWA users?
- Safest Jackstand Practice on 1990 Mustang
- NEW EDGE SEAT INSTALL
- What Brand Convertible Top Should I Buy?
- Looking to build stang that will run 10's
- TPS help
- Recharging AC with the new stuff (retro kit). Low line is where?
- backfiring @ 5200+ RPM..ASAP Please
- Help me install a cam
- injector tuning?
- Roller rockers?
- What intake for EFI351W
- cam question?
- Flywheel weights
- Upgrading from 130 to 200 AMP 3 G alternator Upgrading
- electrical problem fuseable link between starter solinoid and alternator fried
- Hey guys, need help!!!
- wont crank
- h/c/i or low boost blower
- cannister purge circuit
- Adjustable Control Arms
- bad shake at high speeds
- T5 shift fork ?
- Billet quadrant problem.
- single wire alternator
- vents stopped blowing. bad blower motor???
- oil pressure
- Power Window problems... HELP!
- idle surges, gets choppy, then dies...HELP ME!!!
- How to measure for gas shocks for the hood
- What do you think? couple of questions
- 5-lug, advice on application
- back up light switch
- couple codes, no CE light
- rear main seal leak?
- high compression stock stroke
- seat reinforcement
- EASY T-5 QUESTION
- CLUTCH CABLE ?
- Quick Oil pan Q¿
- YES Another mustang head question!!!!
- Just got some 15x9 draglite xps 6" bs now...
- 2 questions about 347
- 18" rims?
- Need Vacuum Motor for 93 Mustang
- Aluminum radiator overflow tank
- brain fart after 3 yrs 3grand car runs but white smoke idles high!! please help
- just got car running but temp gauge isnt working need wiring help so i dont blow it!
- my 5.0 cuts out at 5,000 rpm wtf???
- what causes a bent valve? friend thinks i might have one
- Fuel pump 'whining'?
- Stock axle ID code question
- mustang head question
- Check Engine Light?
- Hey all, new member here with a few questions
- Question About Rocker Arm Install
- Fuel pressure sender location.
- Stock Intake Hardware Compatible With Replica Cobra Intake
- question on MM chassis stiffening
- FUEL PUMP PROBLEMS
- A few nitrous questions
- Just Added 90 GT Vert... Questions....
- will a SUPER VICTOR EFI work on a NATURAL ASPIRATED motor?
- What is This Wire For?
- Stock 03 Cobra blower on 5.0
- what to set timing at
- Been out of the loop for a while... need advice
- head gasket question? Need help!
- car won't start when hot... help please???
- Help install boost gauge
- two plugs need schematic or help or picture NE thing really
- roller rockers and wat to do
- T-5 Swap Wiring
- gt40 topend plus spray ='s ???
- Alternator Question
- cold start issues
- Gauge cluster lights won't come on
- sn-95 dash in a fox??
- Need to know what hoses I need!
- Valve body-clunk question
- Electric Fan?
- gt40 or gt40 P - Which are better if want to keep smog?
- autometer autogage gauges any good?
- 89 to 94 parts
- What psi in ET street slicks?
- world products heads
- 1989 Mustang 5.0, Sputters and Smokes at High RPM
- Any luck with buying used heads online?
- Lakewood traction Bar?
- Deck clearance
- Which nitrous system?
- I need a 90 wiring diagram
- Quick heater core question
- motor mount problem
- T5 Steel Bearing Retainers
- forged pistons
- No heat and Idle jumps during shifts?
- dumping fuel at part throttle?
- Transgo Shift Kit Questions
- tps problem
- Stock rim weight?
- porting a tubular gt40 intake
- 86 mustang speaker replacement
- Engine bay harness removal
- anybody tried these?
- Is my brake booster bad?
- Squeel from trans when clutch is all the way out.
- Trans jumps out of gear?
- 85 GT FI to Carb conversion overheating help
- T5 to C4 swap
- popping and giving out at high rpm
- quick distributor cap question
- 86 Electrical ?'s
- Roll Bar Install
- 331 stroker question
- 86 w/mass air wont start needs jumpstart please i'm dumb
- Anyone run a crazy engine setback?
- exhaust hangers h-pipe
- Engine Balancing???
- non roller 302?
- Braking In Engine???
- HVAC Vacuum Lines - How to Extend
- 85 Mustang 5Lug Conversion
- STARTING THE RESTO OF MY 86 GT...
- fluidyne radiators
- Next suspension mods?
- power loss and back fire at hard trottle
- MAF conversion.....no start
- Procharger D-1SC leaking..Breather also leaking
- coolant pressure ??
- Bench Bleeding
- removing ac lines
- Fuel pump relay for 93 lx location?
- Checking fuel pressure
- Looking for ideas car won't stay running
- 70mm MAF Question?
- Suspension and Traction Q's
- a/c charging
- camshaft choice
- LAM on valve cover
- Electrical asking again
- BBK Performance SSI Intake
- Fox suspension question?
- Please Help - which h. balancer and flywheel...
- Power steering bracket off other 5.0's???
- POWER LAGGING
- Gas Gauge not working
- EGR ???
- GT40 Y302 heads vs GT40P heads
- hatch lock
- thumper heads on a 347?
- Bad vibration under hard acceleration???
- Ditching the voltage regulator... question
- Weird problem
- Stock 1986 5.0.. powertrain into 74-75 1/2 ton?
- Having problems with brake conversion....
- pullies
- Carb Question
- Starter
- 408w which air intake?
- tuning help asap
- PCV Elimination
- wierd problem - coolant fumes
- Help with fuel line to rail connection
- PA racing k-member?
- 5spd swap HELP! PEDAL ASSY.
- Weird Blinker problem
- 335's on a fox
- Harmonic Balancer question?
- Hurst Shifter?
