PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. New starter has only 1 prong?
  2. Question for all you sumped tank guys
  3. Adjustable Fuel pressure?
  4. Cold Start Problems
  5. may have ruined balancer bolt hole threads... need suggestions.
  6. 3.8 bellhousing
  7. Fuel Rail Help.
  8. Engine Build Help
  9. How much power with exhaust?
  10. Which size Head gaskets do I need for a 331?
  11. valve lash adjsutment
  12. How to determine proper fuse and wire size?
  13. cold air intake...
  14. Fuel Gauge always Full
  15. Rear Brake Change problem -ASAP
  16. EFI to Carb Conversion
  17. Whys my timing locked out to 20?!?
  18. new starter, new relay, new problem
  19. push rod length?
  20. Airflow Specialties alum heads
  21. Power loss, weird idle, and temp goes up
  22. NEED ADVICE
  23. NEED ADVICE
  24. Odd heating/blown head gasket?
  25. 14psi blower questions?
  26. Installing caster camber plates...
  27. transmission problems
  28. carb swap
  29. 351 swap questions. cam help
  30. boost level changes
  31. Removing Rear Interior panels on GT for 1/4 window install
  32. Radio Problems ????
  33. new swap won't start----help please
  34. push rod help!
  35. I opened my motor. Does this look ok?
  36. Newbie question
  37. windage trey and girdle????
  38. Does anyone know how a.........
  39. Which will have better street manners: E303 or F303 cam? Something else?
  40. Nitrous, turbo, blower AFR's
  41. heads/cam
  42. Forged or not ???? that is the question
  43. main cap sequence
  44. For those of you that cars run like crap for a min then clear up
  45. Need help on properly installing SFI Balancer
  46. Smaller supercharger pulley
  47. Battery drain, help please
  48. Moroso oil pan/dart
  49. Red Top Optima
  50. Neutral Balance
  51. IAC/IAB
  52. What is this hole in my block for?
  53. What is Operating Temp for 87 Gt?
  54. 98 brakes on fox-what brake line adapters do i need???
  55. Fuel pump?
  56. Really really P.O. New problem NEED HELP!!
  57. do i have everything I need for rear disc conversion?
  58. What tires?!?
  59. Just dies.......
  60. E3 plugs for Fox 5.0L???
  61. fuel pump eccentric and camshaft ?'s
  62. finally bought wheels aaaaand now they dont fit!
  63. Can anyone verify my diagnosis?
  64. Oil pressure gauge
  65. New Guy-New Car
  66. Spark plug #s for GT40s?
  67. rear brakes
  68. 70 mm tb, cobra intake, and different cam, Worth IT???
  69. Laurel Mountain Mustang Drag Spring kit question
  70. Pro products t-body
  71. 1990 5.0 problem. Please help
  72. aftermarket engine block and head question
  73. Rear Quad-Shocks 1989 mustang
  74. C4 Converter
  75. RAG JOINT
  76. Intermitent power to fuel pump
  77. wasnt too satisfied with the first drive.
  78. Valve train question
  79. where is my starter solenoid?
  80. Lights dimming at take off
  81. wiring issue, car wont start
  82. AC Delete??
  83. 03 Cobra braided lines on a fox
  84. think it would be worth it for me to get some twisted wedges?
  85. Info Needed
  86. Looking for a used enkie wheel
  87. Twisted wegde heads Stage II cam PTV clearance?
  88. Stroker Kit Choice - Dished or Flat Top..
  89. Where is the Computer in a 1990 Mustang?
  90. Which ignition system to go with?
  91. t5 removal
  92. Going with a Supercharger, Have Some Questions...
  93. Who has to have emissions test done with a 347?
  94. Adjustable Clutch Quadrant Issues...
  95. VERY BAD BELT PROBLEM
  96. 347 Build - Cylinder Head Recommendations?
  97. Getting ready to replace head gaskets...any tips?
  98. Help with this calipers
  99. Water pump and crank pulleys dont line up.
  100. what do i need to convert to MAF
  101. speed in trans
  102. R302 block???
  103. Engine / Hood Clearance (92)
  104. 17x10.5 on a Fox??
  105. 1986 5.0 HO possible fuel problem help please?
  106. gt40 intake gasket question
  107. hurst line lock install....
  108. RHS head question
  109. Quick pull when brakes are applied then goes away
  110. My new gears
  111. autolight #24
  112. 5.0 driven gear w 3.27
  113. Just ordered a pms
  114. DIY Convertible Top repair
  115. head differences
  116. Lowering Springs and shocks
  117. Compression Ratio
  118. 408 or turbo for high alttitude
  119. need to know a belt size
  120. NEED HELP WITH THIS?
  121. o2 extension?
  122. Flywheel Choice, Balancer Choice, and Tranny Advice..
  123. When to rebuild the bottom end?
  124. who makes the brackets sn95-fox?
  125. tank gas leak how can i fixed?
  126. Dim headlight on one side.
  127. ? about amount of HP my car made
  128. Which headlight switch wire to tap into?
  129. Ticking BADly!!
  130. Black satin paint questions
  131. 460 build???block pref.
  132. What size mass air for this setup?
  133. oh crap.....
  134. DIFF. IN DISTRIBUTOR AUTO AND MANUAL ON CARBED FOX???
  135. 33 spline axles ???
  136. T5 Bellhousin WC VS 3550
  137. rr ajustment
  138. My 5.0 will only run in open loop...
  139. 91 coupe trunk pop problems help!!!
  140. Electric fan wiring???
  141. What should I do about a transmission?
  142. Brake reservier wiring ?
  143. Intstrument Pane / Guage Lights do not work???
  144. Cheap manual steering???
  145. Weird electrical problem
  146. water pump leaking bad but not out weephole
  147. how would this rickflow item strengthen a stock block with stock internals?
  148. Need some help with my new oil pan!!!
  149. User friendly tuning software?
  150. No dash lights/exterior lights, but still headlights?
  151. Will the computer learn my new setup?
  152. Ribbed WP pulley
  153. Engine runs weired......Please Help
  154. Fox tire question`
  155. DCC fan controller not workin+other weird problem...
  156. 88 Mustang GT o2 wiring problems.....
  157. '87 LX High Idle RPM
  158. Side exhuast for fox body?
  159. rough idle?
  160. cobra r brakes
  161. A/F guage question
  162. WTF!!! Springs
  163. Intake Manifolds R vs ... RPM ???
  164. 88 Convt. Quarter Trim vs. 90+ Quarter Trim
  165. question, surge, dropping oil pressure, losing coolant
  166. Dashswap pitfalls and worries and advice please
  167. TEMP SENSOR Q??
  168. Tachometer screwy
  169. Maximum Motorsports control arms vs UMI
  170. 1.7 RR help
  171. 05 wheels on a fox...tire question
  172. paint code
  173. Will oil pan clear main support?
  174. Question about thermostats.
  175. 89GT w GT40x top end kit
  176. Power steering pump leaking....
  177. GT-40's
  178. mass air sensor???
  179. REAR gear lube capacity with girdle cover?
  180. 1991 gt Not starting ??? Help
  181. Blower clearing cowl hood?
  182. Fox Speaker Upgrade
  183. hydroboost install
  184. top end kits for stock motor
  185. Yet another problem
  186. Turbo Coupe Caliper rebuild
  187. Will the T5's from the newer V6 stangs fit?
  188. dead cylinder
  189. What kind of heads do i have?
  190. MAP question
  191. rear suspension
  192. 4" Mach 1 Cowl hood???
  193. Order of engine mods on 92 5.0?
  194. Gauges not working properly
  195. Mak's AOD to T-5 conversion.
  196. Putting on new power steering rack/pump, what size hoses do I need?
  197. Speedo Gear
  198. Axle Upgrade Question
  199. Alternator question
  200. Speed density nerds only please!
  201. Cleaning out an Explorer intake and vacume line question?
  202. who makes a rear coilover kit?
  203. DIY Shortend Axles ??? Anyone
  204. Help.......Codes 22, 44, 94
  205. '91 with no A/C anymore
  206. Help with 8.8 rear
  207. Very odd starting issue im having
  208. T-5 to T-3650 swap
  209. FMU or AFPR?
  210. speedo gear calculator
  211. Bad P/S pump?
  212. Low Oil Pressure
  213. car stalled this morning
  214. Oil Pan Gasket Change - Prime Oil Pump?
  215. Speedometer cable leak.
  216. Springs
  217. Add Power To My 88 Mustang GT 5.0
  218. Warning lights and fuel pump stops
  219. Eibach Drag launch kit
  220. eletric fuel pump
  221. Opinons On clutches?
  222. I got the bug again
  223. Door hinge repair kits
  224. Intake for a 331 stroker???
  225. chrome or ceramic headers
  226. Need new heads! Any suggestions?
  227. Will the stock valve covers clear roller rockers???
  228. Clearcoat vs 2-part paint
  229. what intake and carb should i use
  230. 347 and Trick Flow
  231. Cam choice...
  232. Tauras vs Contour fans, installation...
  233. 317cid stroker?
  234. Lowered Mustang Wheel Rub Problem.. Help Please!!!!!!
  235. production #s
  236. 1985 5.0 Cylinder ?
  237. speedo cable broke again - solution??? right speedo gear
  238. I found this for people that has a supercharged 5.0 mustang
  239. idle issue
  240. 1988 with a high idle
  241. Mustang Wheel Openings...
  242. Gas gauge problem
  243. Et streets on lowered fox?
  244. High Altitude timing?
  245. mac headers
  246. engine build
  247. Whats the thread size of the 02 sensor??
  248. Have a question
  249. Magnaflow catback
  250. Transmission Q
