View Full Version : 5.0 Tech
- brakes
- Tempature gauge in dash? Does it have anything to do with how the car runs?
- Instructions for Ford IAC adjustable idle spacer kit
- Car on Jacks: Wheel movement on front tires
- Who is running a MMR Pro Trans 900 (modded TKO 600)?
- egr spacer
- ARP Head Bolts
- What's the best gasket kit?
- Backfire and popping through intake
- vacuum hoses
- bad vibration
- Just a few ??? on HO swaps
- T-Top Conversion Questions
- 70' 302 in a 94...starter question
- AFR 165 head stud bushings for 302?
- hey guys.. few questions..
- Please help me pic a Cam!!
- Lets play, what is this cut wire?
- efi to carb??
- Which bellhousing and flywheel??
- h-pipe first timer installation
- 89 LX - Extremely rich & pinging under light throttle
- EVAC System
- skipping and wont idle
- XXX block question...
- wot fuel pressure
- Energy Suspension Polyurethane Motor Mounts
- 4 cylinder to 5.0 conversion (map sensor)
- Springs fitment
- 5 pt seatbelts and track tech Q
- Driver Side Air Bag
- Need help with codes...
- Missing vacuum lines
- 5.0 Mustang with Electrica lShort (Help)
- Another Fuel Pressure Post..Please Help
- MGW shifter ?
- Vibration
- When balancing a motor...
- Running rich and surging idle
- injector size question
- stroker kits
- T-bird to mustang computer question Please help!
- trick-flow heads
- AOD trq converter ?
- Fox hood latches
- Drama with the repair shop...
- trickflow head combo, with supercharger
- wiring questions-help!!
- Autolamp came on, speedo flying, no keys in, middle of the night! HELP
- What fluid are YOU using in your T5?
- Centerforce Dual Friction or DFX?
- Anyone having overheating, gauge, or fan problems, Please Read!
- got a question
- whooo hooo!!! my car started!! And I saved it!!
- aluminum bumper
- picking a cam for GT-40ps
- trying to finish engine install, few Qs...
- map to maf swap help
- Anybody know where these wires go?
- How do you install full BBK subframe connectors on 1992 FORD MUSTANG GT
- smog system delete
- Drop Mount Kit
- Tristate Head?
- Please help identify Pro-M mass air meter...
- Cam question on a SD car
- shifting with out me
- Machine shop question
- 1993 LX 5.0 Tires rubbing front fenders towards doors?
- 1993 LX 5.0 Battery charging problems? Help
- spec stage 2 clutch
- Carbed Mod Motor in FOX?
- 306 turbo build with some questions
- Behind bars fuel rails to stock lines and intake clearance
- 5.0 newbie question
- quick head question
- GT40P info anyone?
- shortthrow shifters????
- adjusting clutch cable. please help!!
- 351W
- Need continued advice...ran compression test
- help me repair my smog tube (picture)
- Compression test on 81 conv. 87
- 4cyl to 5.0 questions
- Need speedo drive gear help
- Serpentine Belt Help
- New K-member = higher ride height?!
- Negative battery cable just dangling udner engine?
- Are after market weatherstrip kits worth it??
- TORQUE BOX INSTALL PICTURES?
- Need some info on radio problem
- Misfires everywhere.
- Cam to lifters to heads relations
- Where to install cylinder head temp sender
- Zex nitrous kit
- Weep hole leaking Time for a new WP
- Flywheel for C4 behind 5.0
- Ventilation issues
- car keyed :(...please help
- How can I tell my pedal assy is a v8 assy and not a 4cyl assy before a T5 swap?
- Have 4.10's with 5spd..thinking about 4.30's
- Need HELP bad! Daily driver pony on last leg....
- Another 351 question
- draining fuel tank
- Rear Axle Question
- Thoughts on electronic water pump over regular performance pump?
- anyone explain this weird noise?
- Wires just melted 1993GT
- 2 1/4" catback vs 2 1/2" any difference?
- could i benefit from LT headers and 3" exhaust?
- I don't have the canister purge solenoid hooked up, what would that affect?
- Vent tube?
- CUTTING GUIDEPLATES IN HALF
- broken head bolt HELP!
- Gear Kit
- piston to valve clearance
- Twin e-fan from 88 t-bird turbo coupe - will it fit?
- will 302 Brackets work on 351
- Preparing your 5.0 for winter storage?
- Need help with codes quick
- Damn rear quarter windows!
- Painting aluminum radiator?
- any issues installing heads with head studs IN CAR?
- 87 motor in 89 gt
- Please help wiring problem
- New wheels = exhaust and center cap problem
- New Guy rearend and brakes: Help
- header studs?
- whats this part in the exhaust?
- car wont communicate with scanner
- Vaccum lines
- Pro3i or MM lower control arms....
- AOD Rebuild
- AC delete kit part number?
- Fuel Pressure changes as car warms up
- 4-lug brake upgrade magazine article?
- resurfacing gt 40 head question help
- Couple of Swap Questions
- Need a bolt size!
- 89 Coupe Tire Sizes
- what glue or sealer to use to put lense back on headlight?
- 351
- 245/45/17's on FMS C Springs?
- Pedestal roller rockers
- 96Code
- AOD trouble
- Pushrod Length
- fuel rail: pics:
- Battery Draw Test Procedure
- new fuel pump, pressure drops to 0 after shutoff
- valvetrain loose? what could it be...
- 450-500whp carb 351 build
- replace ACT sensor and coolant temp sensor if not broken?
- fresh engine starting woes
- Wiring questions + Fuel issues.
- My Stang died! Need help ASAP!
- Anyone ever overhauled
- could a bad coolant temp sensor cause
- Bad wheel hop after switching springs??
- Headlights on when key in on position
- Speedometer Needle bouncing....sofa king we tard did
- ? about pcv line from valve cover to blower inlet (pic inside)
- Bad Mod
- Anyone in need of FORD 302 Vic Jr. heads?
- AOD install ?'s
- bad starting
- Timing Lock Down
- What size short belt for this combo ?
- Measuring AFR with cats?
- Steering Issue
- Engine miss...need help quick!
- convertible rear glass
- finding a 351w
- my car is on crack!
- pinion?
- Car starts then dies
- 351w into a 91gt
- trani swap using the.668 input in a2.3
- Att. All Afr Head owners, afr messed up
- 19's/24's
- 8.8 swap for 9" HELP!
- Camshaft Information and Specifications
- OHH CRAP!! fuel line leak..
- fuel pressure question (or problem)
- double tranny swap 5sp to auto and back
- T56 in a fox?
- 1991 Mustang GT Brake Lights Don't Work
- powerdyne superchargers?
- Are these double valve springs?
- 4 cylinder spring and rearend question
- simple 3g question
- need a lil help with this combo(kinda long)
- Need help with MAF and air tube/filter for EFI swap in a '65
- T5Z wiring question for AOD swap
- Air conditioning questions
- Do SN-95 fuel rails flow better?
- trani swap
- advance problem
- 95 engine, 92 tranny
- Tremec 3550 problem
- Injector Harness Question
- Fuel Pressure Testing
- T-5Z???
- no idle
- Fuel cooler
- Steering Wheel upside down
- Pro Cam Degreeers. NEED HELP...PLEASE..Long Post!
- holley aluminum cyl heads
- Need some help with low oil light/CEL...
- 5.0 ecu's
- replacing lifters a must??
- Roll bar and subframe connectors
- Is this clutch wear ok? is this a Spec 2?
- 351w ???
- clutch brands???
- interior paint (dye)
- Drive train noise from the rearend...
- Rear coil springs
- Roller rockers.
- All 79-93's Use 157T Flywheel? I Bought 93 Mini Starter And It Wont Fit My 82, PICS!!
- Starting issue?
- Think I blew a head gasket. Could it be intake gasket?
- Where to lube speedo cable?
- Fuel Injection Screens
- dry nitrous: can i?
- 94 Cobra engine into an 88 GT...
- Coolant Smell
- stock cam v/s b-cam?
- Installing TransGo Shift Kit in AOD - problems
- Car wont start after i was hit!
- Want a 306 and want to add some boost!
- cobra IRS in fox swap
- couple questions???
- Dead battery?
- Wacky Tach?!
- 95' V6 rear?
- electrical / starting gremlins
- Another CA Smog posting......
- gt40p mill and cam questions
- Miss and a Buck
- Blown head gasket?
- 86 radio and speaker harness repair
- 351 swap
- Does anyone have experience with this oxygen sensor kit?
- smog pump BS?
- Help me pick my H/C/I Combo.
- ARGH! cant decide on what to do with heads!
- 2nd Gear Grinding Since Rebuild On T5, Why?
- electric fan...
- rocker stud size
