View Full Version : 5.0 Tech
- carbed intake recommendations..
- TFS 1 vs B303
- Oil Pump help please
- Injector size with no FMU on stock engine
- gt40p milled .025 do i need different pushrods
- Overheating Problems!
- are all block plates created equal?
- Ac clutch turns on on it own.
- One of my fog light outer lenses fell off?
- Speedo gear for T5Z and 3:27=21 Tooth???
- MSD Tach Output Question?
- Rings? Need Help with Diagnosis
- Alternator Identification
- Combining MM K-Member with QA1 coilover
- .60 over or new block??
- T-45?
- brakes on a 94 mustang
- selling t-5 bellhousing. what to keep?
- So I guess now I am in the T5 business. . .
- No start woes
- Question about Headlights.....
- Where can I get a complete chassis and engine wiring harness??
- GT40Y combo question
- need help with cam removal
- Installing new clutch and rear main seal
- check engine light no codes
- Lazy factory gauges and radio question
- recommended rear shocks for a better launch than stock???
- There's gotta be a better way!
- Odd Start-up on 87GT
- DO I HAVE A 351C? WHAT IS THE DIFFERENCE BETWEEN A 351W AND CLEVELAND?
- is a 95 f150 302 a windsor block?
- SFC's for fox verts
- speed density cam?
- A few t5 swap questions
- possible to have a pcm with intermittent failure?
- detecting an exhaust leak...any tips
- H.o vs. non H.o
- How do I check the starter solenoid?
- Transmission Question
- mustang is not running right can anyone help?
- Anyone got a 93 wiring diagram?
- O2 sensor signal wire
- Question about my Vortech.....
- anybody running this cam on a stock bottom end?
- compression test results and videos
- rear shock help also K&N question
- Transmission Troubles
- SMOG PUMP
- Electronic Speedo Q
- Intake Manifold Install...
- PLEASE HELP I HAVE A BIG PROBLEM....
- motor won't turn over
- Stock balancer 28 or 50 oz?
- Holy crap!!! Please help!!!!
- FORD NINE INCH ?'S
- Which Parking Brake for a 5 Lug conversion? Also with Leather Parking Boot???
- think i will pick up some power with bigger valves and F303 cam??
- coolant problems bypassing cap HELP
- Will the harmonic balancer work
- Spark wires problem…
- speed density..won't idle below 1100 rpms...
- 5 lug conversion with 18's......
- heads?
- shock help..
- Last one on this topic promise! Which springs and shocks? for 5lug?
- which axles do i use for the rear then?
- what rear axles are found on the cobra kit from ford racing?
- Is Summit TFI Distributor made by Mallory?
- Adjustable clutch cable pics
- No right hand turn signal?
- Boxing Upper Control Arms
- slipping clutch
- T-45 tranny?
- stock maf to 70 mm maf :S
- What is this part called?
- Rev-Limiter Reprogramming
- T5 where to find parts?
- Fixing gas door
- Exhaust Question
- Header Gasket Questions
- balljoint not budging!!!
- Im back into the mustangs Finally... issues here we come
- Built Rear?
- Temp Question
- MSD iginition-how much of a performance increase?
- '87 5.0 in my 1966GT....need motor help!
- What to do about the rear 4 to 5 lug!
- Air/fuel ratio guage
- Does a stock V1 S-trim setup use stock serpentine belt? PICS!
- Ok...What broke?? (clutch)
- sleeper
- what fuel injectors are best for my set up?? please help
- Oil leak on upper rear of motor
- Fan Fix
- Latest problem...won't start.
- Thinking of going with with 1.7 RR's, got a question
- 3g doesnt charge as well when hot??
- pypes exhaust
- getting the 884cyl coupe ready for the road 86GT and 884cyl interchange
- Possible wiring problems???
- largest tb size on victor jr
- Engine Headache
- Intake Oil Baffle
- help with my headlight switch wiring
- Heater Core drain?
- Gas tank...
- How to remove convertible trim
- Standard bore?
- Fuel pump relay getting hot?
- test day guys
- Control arm bolts
- head lights
- 3.35 or 2.95 T5?
- passenger side window problems
- Weird RPM's Problem
- MATCH PAINT TO VALVE COVERS?
- Paint on my Intake?
- Matchine Throttle body to intake manifolds...
- Aod problem maybe?
- Someone school me on Speed Density...
- Uni-body and rear end
- Tick on #4 and fouled plug
- advantages/disadvantages of X pipe?
- Please ID bellhousing!
- starter and flwheel issues...
- smog pump ?
- Need help with Nitrous install..
- Cutting stock springs?
- IAC Questions
- 4 lug wheel spacers?
- Clutch Cable replacement
- Hissin?
- edelbrock spacer on typhoon
- spacers for 93 cobra wheels
- Pypes Catback Passenger Side Fitment Questions
- Tail light lens install help
- Finally - new motor in, no more oil leaks. But, running warm
- where in the he11 is it??
- hazards work but turn signals dont
- Suspension upgrades
- 92' hatch starter relay wires?
- 89 GT rear end Brake lines
- Failed MD Emissions
- Is My 88gt AOD or ???
- good nitrous installation tutorials?
- wanting to fit 03 cobra wheels on my 90GT!
- Please Help My Car is Running Rich at idle.
- just compeleted 5 speed swap.
- Holley systemax intake with 3/8 spacer
- Timing Issues...AGAIN!!!
- Few issues with new clutch (Hissin and friends comeon it)
- HELP ASAP!
- retrieving codes
- auto paint gun choices
- SN95 TB on Explorer Intake in a Miata!
- SFC question
- Just orderd the rest of the componets for my shortblock
- Idol and running problems?!
- weird issue I couldn't find a thread about
- Installing new headlights
- AN fitting ?'s
- bought some scorpion RR's...will they fit
- 4.10 gear question...
- Adjustable UCA's
- Valve Covers.... HELP!!!
- Wiring Guys. Hissin? Daggar? Anyone?
- start the timer and prey for me!
- Dome Light
- combustion chamber sizes?
- Doing the dreaded heater core- couple questions
- Power Rack Leaking
- 7.5 or 8.8 rear end?
- How much fuel pressure do i need?
- Why can't I fix my codes?
- Help with engine ID
- mass air conversion
- My steering is as loose as a $5 hooker
- starts once then wont start help!
- 86 5.0 questions
- 5 Speed and Clutch Setup Help Needed
- Mass Air sensor question...
- haha, two stangs down in two days... (starter?)
- Mild Street class
- the miss from hell
- intank 255lph fuel pump with a 200 shot
- h/c/.................i/.????
- F cam for my set up
- Are you still rolling stock?
- putting car back together, have a couple questions
- Speaker grill removal from door panels
- EGR / Charcoal Box?
- A9L Computer?
- Pinion angle
- Another tire size question... sorry.
- Help...revisiting the speedo cable bounce???
- Rear 1/4 window help
- Wiring Question again.
- Fuel Pump ?
- '87 mustang 4 cyl to 5.0 swap
- I think I made a BIG mess...
- '88 steering colum question
- engine dyno simulater
- Some 3g Alt problem
- Springs....
- Subframe is cracked underneath driver's seat!
- Installed H-pipe! Thanks for the help guys!
- spark plug question
- need help please!!! out of ideas ...
- What all is needed for a 140 speedo swap?
- Cut Rubber Piece off of Clutch Cable?
- 3500 stick
- Speaker Measurements Inside
- vibration after head gasket fix
- Installing H-pipe in 1 hour! Have 2 questions?
- Oxygen Sensors ?
- cuttin out
- do you think i will be dissapointed if i swap from 3.90s to 3.55s?
- Why are volts low?
- stater flywheel issues!
- From EFI to Carb, give me the down low on it
- Junkyard parts question
- car starts, runs for 10 secs, then dies
- can I use my seat brackets on 99 seats?
- small hesitation/miss after installing ignition box.
- EGR Valve problems
- so my clutch isn't engaging all the way
- Need alt. advise.
- air tube question
- supercharger/turbo question
- major oil leak $5,000 later...sucks
- not sure what to do
- Main bearing Q?
- 84 tranny in an 88 car?
- Wobbly jiggly tilt column....anyone have a fix?
- heater question
- Check valve system removal
- remote start question
- 393 oil consumption problem
- Carb, wiring, and dizzy questions- 5.0
- Tps / Voltmeter dial, pic inside
- What rear end is this?
- gt40 upper?
- replace valve guides, or new heads?
- Nitrous bottle bracket install questions...
- 1993 vert 1/4 window issue
- Intake misc hose?
- tire size help. Wider in ther rear?
- computer wire metal plug
