PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. 347 strocker question
  2. Looking for a good bolt in roll bar
  3. Link Bar lifters in an A4 block
  4. Stalling on first cold start
  5. 93 Gt leans to one side
  6. ported my heads, questions
  7. car wont start after motor swap
  8. 5.0 vs. 5.0 HO
  9. Replacement Coil
  10. diff-ently confused!
  11. "dogbone"
  12. power steering pump
  13. Electrical Chao
  14. Rear springs/suspension help.
  15. Roll Bar Help
  16. Weird Squeal at high rpms
  17. manual steering
  18. IDLE question
  19. 87 Starting problems
  20. '91 5.0 needs new clutch
  21. 1986 GT with a 93 Upper Intake....
  22. Low oil pressure?
  23. Double gasket on water pump - cause a problem?
  24. turbo 5.0 runs pig rich at idle, rough.
  25. 88 GT Drivers Door wont open
  26. gt40p user help please
  27. Fusible Link locations.
  28. Removing T5 without Bellhousing?
  29. 5 lug swap doner car
  30. t5- ?'s
  31. Clutch Throwout Bearing Noise?
  32. 88 Highbeam switch problem
  33. Runs out of gas on turns, below 1/2 tank
  34. Common Vaccum leaks....
  35. N-91 Cam work good?
  36. what alt do I need
  37. 5-lug swap specifics
  38. notch i just bought has no heating system, how much to install one?
  39. short shifter
  40. 89 notch start no run.
  41. Building new dragcar, need rules!!
  42. transmission gears? turbocoupe t5
  43. Help me fix all of my problems!!
  44. Low RPM's... Stalling...
  45. Wierd Starting issue ? Need help
  46. Mustang Throttle Cable Help!!!!
  47. how good is the BBK SSI
  48. Efi......Intake Spacer or no spacer??
  49. Are my lifters shot?
  50. weird noise?
  51. calculate compression ratio
  52. HELP! car wont start
  53. 88 coupe side pipes
  54. fox lean?
  55. After putting on new parts...
  56. just did a compression test. what do you think?
  57. how can i tell the diffrence between SC and S trim?
  58. Tolerance Level - short/long PTV clearance
  59. Some added power for a daily driver
  60. 12" possible
  61. 84 Cardb 5.0 Vacuum Switches
  62. Fuel pump relay question
  63. who knows their mass air stuff....air head needing air help......
  64. Car Shuts down under load.
  65. traction problems
  66. :shrug:Roller rockers driving me nutts!
  67. mac prochamber
  68. I can't pass emission tests.
  69. No power up top after intake and more
  70. efi idling problems
  71. Not getting spark?
  72. what do you think
  73. TV Cable bracket on tranny
  74. king cobra clutch
  75. Car backfiring and hesitant at the top end
  76. give me ur knowledge
  77. shes a beautiful beast!!!!!!!
  78. Plug on side of t5z?
  79. DC Controller/Mark Vii wiring help
  80. Trickflow upper problems...noise?
  81. Pro-M Flow Data
  82. Carb Jetting Help Wanted
  83. computer swap
  84. gears
  85. what fluid in T-5
  86. Newbie Building a Pro-Street 83 Hatch
  87. CLUTCH CABLE !!!
  88. Difficulty in changing rear-end gears?
  89. Codes 41 and 56 what can I do??????
  90. what size injectors
  91. DYI Fuel Pressure Guage (Calling jrichker )
  92. Cleaning Up Engine Bay
  93. aluminum flywheel good or bad??????
  94. cheapest place for OEM stock clutch cable
  95. For those with "In Car" fuel pressure gauges
  96. burns eyes
  97. Flashing battery light
  98. why does it seem people are so worried about detonation??
  99. what kind of hydraulic fluid 89 vert top?
  100. 1990 bronco 5.0
  101. Starter Solenoid/3G Wiring
  102. Trick Flow Street Heat intake TB question
  103. Aftermarket Speedometer
  104. fuses have me conFUSED lol
  105. Front Wheel Bearing Dust Cap
  106. proper way to adjust TV Cable?
  107. My Mechanic has a ?
  108. 90mm?
  109. whats going on here
  110. Clearance w/ tall valve covers Q
  111. will wheel fit?
  112. 3G upgrade *visual help*
  113. loss of power
  114. nasty shake at high speeds
  115. WHERE CAN I TAKE WEIGHT OFF OF CAR
  116. Cog belt
  117. Fuel pump problems. Help!!!
  118. GT-40 Intake HELP ME!
  119. Is my adjustable fuel pressure regulator bad
  120. Tri-state cylinder heads
  121. Fuel Problem?
  122. water pump pullies?
  123. 6g alternator ?
  124. School me on charging guys.
  125. vacuum diagram
  126. sn95 5.0 engine and tranny swap into fox
  127. turbo question
  128. How much spray lol
  129. Fan/Radiator Clearance Question
  130. Need to identify pulleys on my car
  131. Stuck brakes?
  132. 5.0 Distributor suggestion
  133. moved battery to the hatch
  134. Wiring Question?
  135. 2.3 bellhousing
  136. Installed BBK longtube headers and engine runs better without oxygen sensors!!!
  137. 30#'s good enough?
  138. aod to t5
  139. wine ...wine....wine i want you to shut up(trans)
  140. who here knows what a subaru wrx (sti) is???
  141. what gears are best 373 0r 355
  142. Flywheel question
  143. Several Questions, Help Pretty Please
  144. Sluggish take off
  145. Door Acuator Problem
  146. CLUTCH OR CABLE ?
  147. How many here had to change pushrod lengths with your mods?
  148. anyone own vortech y-trim
  149. Good torque box kit???
  150. need help with naming, finding part
  151. car hesitates or stumbles
  152. E-Cam with 1.7s, will my valve springs last?
  153. EGR Valve
  154. 28 Spline Axles VS 31 Spline Axles
  155. Pressed to screw in studs
  156. noisey fuel pump
  157. Valvetrain noise or detonation?
  158. Help me with a cluster swap please?
  159. got a little closer
  160. Mass Air Conversion - Half way through - what the heck??
  161. new motor just rolled 1100, still burning oil
  162. sn95 engine and tranny swap into fox
  163. Oil dip stick tube?
  164. Post up your best headliner fixes!
  165. how big on injectors
  166. Need a starter solenoid with longer threads. What options are out there?
  167. 92 tranny options
  168. Left brake light won't work.
  169. Need suggestions for my engine, just got tore apart
  170. TPS bad?
  171. identify this alternator
  172. why is car popping out of gear!?!
  173. Valvetrain noise
  174. need help with turn signals and flashers
  175. how to customize(newbie question sorry)
  176. Weight Reduction VS Hooking?
  177. how much would you pay for gt-40p heads
  178. power problem with engine?
  179. gear ratio 3:55 or 3:73
  180. Newb question - removing valve spring
  181. Oil Pressure GONE
  182. 351w efi to carb distributor??
  183. How much amps should a alternator read???
  184. Forged pistons
  185. Walbro 255HP fuel pump, couple questions...
  186. How to save gas in a 5.0
  187. help---MAF
  188. ouch
  189. need bell housing help
  190. Code 98 and 64 K.O.E.R
  191. Tensioner Pully Bolt?
  192. 351W Rebuild Questions about rod markings
  193. speedo??
  194. Tuner needed
  195. Equal or un-Equal shorty's ????
  196. AC Diagram
  197. coverting a 302 to a 351?
  198. Need to fix drivetrain slop.
  199. Nitrostang Racing Review
  200. Battery Relocation
  201. New engine runs, but hear popping
  202. 302 XXX block
  203. Can anyone help me out. Not sure whats going on
  204. Car missing up at the top end
  205. hope someone can help
  206. Auto tranny/exhaust isues
  207. electrical questions
  208. 91 VERT feels like a towncar?????
  209. HELP zex nitrous install
  210. Cap & Rotor, Dist, Coil questions...
  211. 6G alternator better than 3G?
  212. car wont start
  213. spark coming out the side of coil
  214. 3 inch exhaust solve problem?
  215. Just goes to show the simplest things
  216. AEM Engine Management System?
  217. pulley swap
  218. Tko 600 handle a 408w stroker?
  219. EGR elimination
  220. Where to find tube nuts & sleeves for steel line?
  221. Mickey Et Streets
  222. Help reading timing marks
  223. Header Gasket Replacement
  224. 84 LX V6 auto swap to 351 5 Speed manual?
  225. Ramchargers Fan install?
  226. When I installed timing chain, did I mess up?
  227. new engine started but no oil pressure?
  228. Tubular K-Member Kits
  229. wut is first year of fuel injection?
  230. Where can I get new front spindles?
  231. why does my car run hot!?!
  232. head gasket?
  233. harmonic balancer
  234. BEST BRAND COLD AIR INTAKE
  235. Stripped Dizzy Gear, Different Pitch? Pics Inside
  236. blinkers wtf
  237. How to test Fuel Pressure Regulator
  238. GT40 interchangeability....
  239. Replace fuel pump connector
  240. please help
  241. 28 inch tall tires on a fox?
  242. Fuel rail o-rings. Where to get?
  243. quick o2 questions....
  244. Torque box + chassis stiffening plans.
  245. 84 hatchback 5 lug convet. using parts from a 95GT?
  246. 03 Mach-1 K member?
  247. build up plans/ parts list and open to ideas
  248. Wheel Spacers
  249. which MSD distributor should i buy?
  250. grant wheel and column questions ?
