View Full Version : 5.0 Tech
- Koni yellow adj,owners
- subframe connectors
- xe series cams??
- Another Mass Air ?
- Modular 2v swap
- How to clean pistons
- Zoom stage 3 clutch?
- dss 331 pro bullet
- GETTIN SOME HEAD
- Mass Air Computer Question
- fuel pressure how much?
- injector harness crossed?
- quick q about ground fx
- cam degreeing!?!?!
- Can someone explain to me about an aftercooler?
- FP Eccentric rubbing timing cover?
- EGR problems
- Wacky factory gauges.
- speed density rich on w.o.t?
- LMAF USING PRO-M SENSOR
- how do i tell if i have a cracked head?
- A/C question
- Compression ratio with S-Trim?
- do the newer 5.0's have hyper. rods as well?
- Fuel Pump won't stop running
- turbo checklist:
- pip sinsor anyone?
- how many fuse boxes do we have?
- Mass Air Electrical
- Headers glowing just a little, is this normal?
- Fuel Injected 408?
- JRICHKER 3G problems please help.
- Electric Fan setup for supercharged car
- Cylinder Balance test w/code reader problem......
- AOD to T5 and cruise control
- xe270hr-14 degree cam
- Those with Bilsteins/Aftermarket springs...LOTS of questions for anybody!
- 1.7 rr with twisted wedge heads help?
- Anyone have the location of the PCV valve?
- fuel pressure?
- Coolant leak, again
- F-cam questions
- 302 to 347
- bbk vs. mac
- Cheap Power
- Vert top
- 1300 rpm idle ? idle air control? please help
- 5 lug swap
- level ride
- oil pressure drop?
- 1995 Gt cuts out periodically
- 91 GT 140 speedo...bounces like mad!!
- brake system question
- Fuel and tranny help
- Looking for clutch recommendation's
- Electric fuel pump on '85 carb'o
- stalling problem
- HELP ! CANT get power at coil???
- 351w exhaust? and slp questions
- fuel press. regulator
- AFM B41 cam
- SCORE!!!
- Emissions Test
- A/C Gurus: Putting A/C Back ON A Fox
- c5 auto speedo gear
- Bonehead mistake.....
- 91 5.0 Cuttin out problem
- trans swap
- 5.0 just not feelin right
- E-303 cam question
- Started Workin on the fox again
- pistons and rods 5.0
- 3.8 to carbed 302
- might have a big problem
- What should I set my timing at
- 91 GT info/help
- Home made door panels. What TYPE of material?
- timming
- How much HP is a stock '92 driveshaft good for?
- maf ?
- Please help!/ electrical
- emissions question
- Speedometer drive gear question
- New 306 OVERHEATING?
- 347 strocker question
- Looking for a good bolt in roll bar
- Link Bar lifters in an A4 block
- Stalling on first cold start
- 93 Gt leans to one side
- ported my heads, questions
- car wont start after motor swap
- 5.0 vs. 5.0 HO
- Replacement Coil
- diff-ently confused!
- "dogbone"
- power steering pump
- Electrical Chao
- Rear springs/suspension help.
- Roll Bar Help
- Weird Squeal at high rpms
- manual steering
- IDLE question
- 87 Starting problems
- '91 5.0 needs new clutch
- 1986 GT with a 93 Upper Intake....
- Low oil pressure?
- Double gasket on water pump - cause a problem?
- turbo 5.0 runs pig rich at idle, rough.
- 88 GT Drivers Door wont open
- gt40p user help please
- Fusible Link locations.
- Removing T5 without Bellhousing?
- 5 lug swap doner car
- t5- ?'s
- Clutch Throwout Bearing Noise?
- 88 Highbeam switch problem
- Runs out of gas on turns, below 1/2 tank
- Common Vaccum leaks....
- N-91 Cam work good?
- what alt do I need
- 5-lug swap specifics
- notch i just bought has no heating system, how much to install one?
- short shifter
- 89 notch start no run.
- Building new dragcar, need rules!!
- transmission gears? turbocoupe t5
- Help me fix all of my problems!!
- Low RPM's... Stalling...
- Wierd Starting issue ? Need help
- Mustang Throttle Cable Help!!!!
- how good is the BBK SSI
- Efi......Intake Spacer or no spacer??
- Are my lifters shot?
- weird noise?
- calculate compression ratio
- HELP! car wont start
- 88 coupe side pipes
- fox lean?
- After putting on new parts...
- just did a compression test. what do you think?
- how can i tell the diffrence between SC and S trim?
- Tolerance Level - short/long PTV clearance
- Some added power for a daily driver
- 12" possible
- 84 Cardb 5.0 Vacuum Switches
- Fuel pump relay question
- who knows their mass air stuff....air head needing air help......
- Car Shuts down under load.
- traction problems
- :shrug:Roller rockers driving me nutts!
- mac prochamber
- I can't pass emission tests.
- No power up top after intake and more
- efi idling problems
- Not getting spark?
- what do you think
- TV Cable bracket on tranny
- king cobra clutch
- Car backfiring and hesitant at the top end
- give me ur knowledge
- shes a beautiful beast!!!!!!!
- Plug on side of t5z?
- DC Controller/Mark Vii wiring help
- Trickflow upper problems...noise?
- Pro-M Flow Data
- Carb Jetting Help Wanted
- computer swap
- gears
- what fluid in T-5
- Newbie Building a Pro-Street 83 Hatch
- CLUTCH CABLE !!!
- Difficulty in changing rear-end gears?
- Codes 41 and 56 what can I do??????
- what size injectors
- DYI Fuel Pressure Guage (Calling jrichker )
- Cleaning Up Engine Bay
- aluminum flywheel good or bad??????
- cheapest place for OEM stock clutch cable
- For those with "In Car" fuel pressure gauges
- burns eyes
- Flashing battery light
- why does it seem people are so worried about detonation??
- what kind of hydraulic fluid 89 vert top?
- 1990 bronco 5.0
- Starter Solenoid/3G Wiring
- Trick Flow Street Heat intake TB question
- Aftermarket Speedometer
- fuses have me conFUSED lol
- Front Wheel Bearing Dust Cap
- proper way to adjust TV Cable?
- My Mechanic has a ?
- 90mm?
- whats going on here
- Clearance w/ tall valve covers Q
- will wheel fit?
- 3G upgrade *visual help*
- loss of power
- nasty shake at high speeds
- WHERE CAN I TAKE WEIGHT OFF OF CAR
- Cog belt
- Fuel pump problems. Help!!!
- GT-40 Intake HELP ME!
- Is my adjustable fuel pressure regulator bad
- Tri-state cylinder heads
- Fuel Problem?
- water pump pullies?
- 6g alternator ?
- School me on charging guys.
- vacuum diagram
- sn95 5.0 engine and tranny swap into fox
- turbo question
- How much spray lol
- Fan/Radiator Clearance Question
- Need to identify pulleys on my car
- Stuck brakes?
- 5.0 Distributor suggestion
- moved battery to the hatch
- Wiring Question?
- 2.3 bellhousing
- Installed BBK longtube headers and engine runs better without oxygen sensors!!!
- 30#'s good enough?
- aod to t5
- wine ...wine....wine i want you to shut up(trans)
- who here knows what a subaru wrx (sti) is???
- what gears are best 373 0r 355
- Flywheel question
- Several Questions, Help Pretty Please
- Sluggish take off
- Door Acuator Problem
- CLUTCH OR CABLE ?
- How many here had to change pushrod lengths with your mods?
- anyone own vortech y-trim
- Good torque box kit???
- need help with naming, finding part
- car hesitates or stumbles
- E-Cam with 1.7s, will my valve springs last?
- EGR Valve
- 28 Spline Axles VS 31 Spline Axles
- Pressed to screw in studs
- noisey fuel pump
- Valvetrain noise or detonation?
- Help me with a cluster swap please?
- got a little closer
- Mass Air Conversion - Half way through - what the heck??
- new motor just rolled 1100, still burning oil
- sn95 engine and tranny swap into fox
- Oil dip stick tube?
- Post up your best headliner fixes!
- how big on injectors
- Need a starter solenoid with longer threads. What options are out there?
