PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. Stock Forged Pistons in 5.0's
  2. Leak at back of intake following Cobra install...
  3. which fluid for G-force/A-5 transmission
  4. Rewiring entire car except steering column? 86 coupe.
  5. Whats the Best Cam to get for a Stock 302?
  6. Flowmasters for an 83, fit on my 90?
  7. new mufflers = better idle???
  8. Help with regulators and like to see pics
  9. 88 ford racing MAF conversion
  10. Computer Question ? ?
  11. Blinkers and AC Blower No Worky
  12. Header clearance question....
  13. cold air kit
  14. 5 lug conversion
  15. Any AoD Know it alls?
  16. Intake Air Temp sensor
  17. Cleaning Egr Passage
  18. No Start - but runs on starting fluid
  19. wont run 86 gt
  20. Ghetto spool?
  21. PMS???
  22. Car is running very bad - need help!
  23. What happen to bad idle check list?
  24. Flat spot
  25. Power Steering Pump spewing fluid?
  26. Roller Rocker Clearance Issues!!!!
  27. posi interchange: '96 t-lok into '93?
  28. MSD 6al box electrical gremlin
  29. is my fuel pump going?
  30. Clutch issue
  31. Jumpy speedo needle? Help!
  32. T4M0 computer not working
  33. Headlight wiring issue on 87 GT
  34. Convertibles Enter
  35. Weird problem
  36. White Goop From Crankcase Vent, Why??
  37. car overheating, may be related to heater core.
  38. gear install ?
  39. Converting a SBF to EDIS??
  40. 5.0 emissions
  41. what degree thermostat to use? 195* or 180* please help
  42. convertible motor mounts in my 88 LX
  43. Ideal air-fuel mixture.. is it really 14.8?
  44. help identify my trak-lok brand?!?
  45. Brake Dilemma Please Help
  46. Intake Spacer
  47. EGR Spacer
  48. efi intake for more low end torque
  49. carbed distribtor
  50. 76mm C&L MAF
  51. Speedo Gear?
  52. HEADER CLEARANCE PROBLEMS....HELP
  53. help with contacting DCC control owner
  54. convert auto to 5spd for 289 in 79 capri
  55. 1995 351 Cobra R Throttle body size?
  56. Fuel pump secondary circuit - What is it?????
  57. leaded fuel on our cars
  58. which head to go with KB blower...?
  59. need new plug wires
  60. my boost/vacuum gauge, are my readings bad?
  61. Engine Removal (1992 5.0)
  62. 1986 351 Engine - Any Good??
  63. 347 stroker emission Question
  64. This wheel work with mark 7 rotors??
  65. highbeams inop
  66. confused about this wiring
  67. the intersection of steering and header
  68. Electrical Help (1992 LX 5.0 Convertible)
  69. AFR and Trickflow Head Information
  70. exciting wire for alternator?
  71. To E85 or not?
  72. Just a little timing help please
  73. trick flow combo?
  74. Why doesn't the key crank the engine?
  75. Please help!! Dont understand
  76. Stupid question
  77. PLease Help, Still Stuck!
  78. supercharger ignition timing?
  79. popping/missing at cruising speeds and part throttle.
  80. horn problems
  81. question for anyone who has installed a Magnaflow catback
  82. Head casting numbers?
  83. Diff Oil level check
  84. motor wont stay running
  85. Remove A.C.??
  86. Front coil springs
  87. Autometer tach electrical tach connections
  88. Griffin aluminum radiator install
  89. MAC rear control arm bushings
  90. New Fox Owner..where do i start?
  91. 86 GT 5 Lug Conversion ?
  92. 88 GT rookie
  93. Caster Camber Plates
  94. 88 Gt convertible rookie need help
  95. car running lean with 30 lb injectors UPDATE
  96. Clutch does not feel right at all.
  97. Any one know the specs for the Lightning 351w?
  98. Late model springs?
  99. Alternator not charging
  100. Anyone tuning speed density with a Crane Interceptor?
  101. Rocker Arm clearance choices and help
  102. WILL ONLY START WITH ETHER, CRANKS NORMAL BUT WONT START, PLEASE HELP
  103. Stocks heads with Cam
  104. Hardwiring O2 Sensors?
  105. E-cam and Low end Torque Question
  106. Pushing the limit of the block...
  107. Bassani BX and prochamber
  108. Rearend Question
  109. A/C Compressor Question
  110. School me on fan clutches
  111. Money to spend
  112. Engine no start, only with ether in throttle body, Help Please
  113. headgasket question
  114. gauge question
  115. The "Air Adjuster"?
  116. down to small stuff
  117. Codes
  118. Which strut tower brace fits over phenolic spacer?
  119. WHat brand STB is this in this months 5.0 mag
  120. Which strut tower brace will fit?
  121. error code help
  122. control arm bolt sizes...?
  123. best way to build a 5.0?
  124. what about this type of turbo kit.
  125. Engine stumbling under hard acceleraion
  126. Budget minded RR suspension
  127. Stock Height Performance Springs
  128. TV Cable on a 5-speed...?
  129. Variable Speed Sensor
  130. rear head smog plugs?
  131. My contols arent coming on now
  132. Where is the Power Window Circuit?
  133. wheel bearing installation.
  134. Gas leak, how could this happen?
  135. O2 Question
  136. New wheel fit issues
  137. Header Question
  138. Weird Line Lock Problem
  139. FR aluminum driveshaft
  140. Non working lights
  141. Need some help with broken bolt before I snap
  142. Wiring Help - Starter & Neutral Safety Switch
  143. Oil pump shaft doesnt appear to be long enough WTF?
  144. Need Help - Steering Column (Can You Identify The Parts?)
  145. lower a arm help please
  146. P/S high pressure line leak
  147. Camshaft Markings? ?
  148. Heater tube thread size?
  149. New balljoints?
  150. Car runs like crap
  151. Semi-stock combo...
  152. 4-eyes!
  153. Gas gauge not right
  154. another valve adjust question...
  155. what happened to my car.
  156. How to fix the Gangster Lean step by step guide
  157. Summit sent my head gaskets and they bent
  158. Carb guys, How do i run my throttle cable? (SS302, Modular2v)
  159. Roof rail molding removal
  160. How to tighten strut
  161. speedo cable
  162. 93 wiring pics?
  163. Rocker Arms??
  164. 87 GT Headlight switch wiring help needed
  165. Gt40-P vs. Windsor Jr's
  166. Strange 'Gear' Whine
  167. Trickflow plug wires
  168. Bracket Bolt sizes...
  169. GT40P heads
  170. Quite Possibly the Strangest Thing... HELP!
  171. O2 Sensors
  172. Tire Rub
  173. Rear end
  174. Fuel tank sending unit
  175. Valve Lift??
  176. Recommended lifters for trick flow?
  177. No 4'th gear
  178. Suspension Spring Orientation
  179. Can I use a polyester finishing putty or a filler on a urethane front bumper?
  180. Tips on high torque 302?
  181. felpro 1415 ?
  182. Looking for 350 swap advice
  183. need help with bolt size for arm rest
  184. Upper Strut mounts.Where can I get these? ( Photo ) ....PITA this is !!
  185. Best drag setup for 1991 notch
  186. 5.0 street/strip N/A build advice
  187. yet another SD to MAF question...
  188. How to make 350Hp to the wheels
  189. Throwout bearing orientation
  190. top end bogging...need help!!
  191. change starter solenoid, and now fuel pumps not getting power
  192. new 5.0
  193. Front/rear brake pads for stock?
  194. Pully Problem
  195. Need help truobleshooting!!
  196. recommend a spark plug part number ?
  197. 2 problems when engine is hot
  198. WOT questions
  199. Surging idle help
  200. car keeps dieing
  201. Can you use 4 gauge or must you use 2 gauge
  202. need help with a part name
  203. Explorer intake...help
  204. next upgrade for my '90 gt racecar?
  205. rearend gears(8.8)
  206. PI 3000 lockup stall too much for a stock setup???
  207. MAF Change
  208. good cam for a 351?
  209. Driver seat went up but won't go down...
  210. 86 earlier 1/4 window on 87+
  211. aod to t5 swap
  212. Charging Issues?????
  213. what does something in the intake sound like?
  214. t-5 whine
  215. roller rocker ticking...
  216. durability, milage on your stock block 331/347 comobs ?
  217. Engine theory: How high can volumetric efficiency be on an NA engine?
  218. M/T ET STREETS??????
  219. Suspension
  220. AOD REDLINE???
  221. Cluster not working?
  222. running rich with blower
  223. 80mm MAF and STOCK AIR BOX
  224. would a gain anything with a powerpipe with a small blower?
  225. Car sucking up antifreeze like its cool.
  226. 331 w/ ported GT40s
  227. Need fan advice.
  228. Wiring new MAF
  229. I am getting fed up with my pony
  230. revved to 6000 by accident, motor dead?
  231. Heads/Cam/Intake Swap Write-Up
  232. 95 5.0 Cobra hot starts issue
  233. Does anyone know the size of the sway bar bolts on the fox body?
  234. 5.0 newbie question
  235. 4th battery dead
  236. Blowing fuel pump hose off!
  237. need performance/maintenance help
  238. How much is the Cobra Intake Hurting me?
  239. 331 stroker problems
  240. Another 5 lug swap question
  241. my 351 build
  242. Which plugs?
  243. Aftermarket Bumper Problems
  244. Can I use 3 core radiator with the stock fan and shroud?
  245. running 16 degrees initial timing
  246. need belt size
  247. Line lock help
  248. another engine swap question
  249. Weird wear patterns on roller rockers
  250. 4cyl to V8 swap thread AGAIN.....but with a twist!
