View Full Version : 5.0 Tech
- Best 351w stroker for my fox?
- Metallic Grinding Noise at Startup
- Not getting enough fuel...need help
- 347 rod bearing issue
- Smog delete in back of heads but keeping smog pump?
- engine help
- Turns over but doesn't Crank Please Help
- RUSTTTTT !!!!
- Major Engine Problem
- Suggest a cam for this combo
- Overheating situation need a Wise person
- Soaked Spark plugs??
- old question but maybe new situation.
- 93 lx HELP Regarding Supercharger & Oil Change
- car won't start.
- 1987 mustang t-top v8
- HELP :D
- How to ID '91-93 fenders
- TWEECER tuners in ny area.
- V6 t5 to 5.0 transmission question
- GT 40 heads, what are they worth?
- Anyone have a complete wiring diag for turn signals?
- help fuel pressure problems!!!!!!
- TPS help
- Looking for you Experts on Horsepower
- power steering fluid shooting out of the reserve
- people with solid motor mounts.......help
- Weird Throttle Response
- Time for a new engine, need advice
- Codes 33 and 41 high idle then car shuts off... Help!
- 17" wheels on 87 gt? re-alignment needed?
- Car starts only under throttle
- Can No Longer Pull Codes?
- brake problem
- Which clutch would you recommend?
- ignition problems mind of its own.
- efi to a carb dist
- CARB OR EFI
- What plugs and gap with MSD and NOS
- speedo cluster rebuild
- clutch problems
- 93 GT help me tune this thing please!!!!
- Engine Miss
- summit brand
- Wierd problem
- EGR Eliminator
- car not idleing
- My huge headache
- Can I drive to Dyno tune with 42lb's?
- Fuel pressure regulator question.
- EVR or EGR went out
- Dipstick location
- quick fuel pump question
- 306 with 13:1 compression, few ?'s
- Lakewood Traction Action bars
- Brake lights don't work!!
- Fuel Pump to fuel filter line?
- valve spring question
- Line Lock as a Security device
- 1985 GT bumper pad swap?
- HELP STARTING
- How to install full-length headers?
- 93 5.0 low fuel pressure
- caliper ?s
- Replacing an oil pan gasket.
- GT40P Users please enter
- A friend told me I will lose rwhp with a 90-93 TB spacer. Anyone experience this?
- 93 cobra question
- 2 step launch control set up. NEED PICTURES
- Marine in Afghanistan Top and bottem end questions please help.
- gt-40p vs gt-40
- TPS question
- Alternator not charging
- Help with Rear end, 31 Spl explorer carrier, FRPP axles ??
- My 331 ran great - TPS didn't even work - fixed - now it runs rough!!
- 5 point harness questions
- Mystery serpentine belt
- EEC-IV GUYS
- How does a 94 t5 fit into a 91?
- need radiator recomendations for S/C and A/C
- Help Identifying My Block
- adjusting master cylinder pushrod
- 5.0 high temp problem
- oil in lower intake
- Combo too much for power brakes?
- Help me with a stroker debate
- Box Intake...Thoughts?
- catted or off road H pipe
- Distributor gear problems...
- Stroker questions
- 5.0 Question
- Oil return for Procharger?
- fe engine swap/nhra class
- Fuel tank removal questions. (Fuel lines)
- 600 Holley cfm info???
- which belt do i use
- dart VS boss
- Stalls when driving
- question about pushrods
- heater core hoses hooked to ac core
- Help with codes
- YES!! Got it started. Question on setting timing, etc
- Piolt bearing removal help!
- 92 vs 94 front spindle differences ?
- tfs2 cam and afr165s..?
- Strut Tower Brace question
- piston picture and question
- Sticky injectors
- Wiring diagram needed
- Another replaced head gaskets and engine won't start thread.
- What size MAF?
- Factory belt doesn't fit after Vortech install?? Help...
- Question on GT40 Heads vs GT40P Heads
- T3/T4
- Need help fast! Fixed head gaskets and now won't start
- steering wheel alignment?
- Problems with a stock '85 carb intake on an '87+ longblock
- Possible to convert thunderbird rear disc 8.8 to 5 lug?
- help with lifters
- Cobra brake caliper install, need help
- 1/4 MPH vs. Air Temp
- Backfiring through intake and cannot check codes
- RUNNING ROUGH AFTER TRACK VISIT
- Fuel Rail question?? (Pic inside)
- I need a cam card for a B303 roller
- popping under load...
- A/C compressor ?
- physics of electrical v mechanical accessories
- Complex Wheel fitment issue
- lifter diameter on 5.0
- Guys running tubular GT40 uppers w/1 inch spacer what size bolts?
- 03 Cobra in 90 LX?
- Code 15?
- Typhoon intake too much for GT40 heads?
- pic request - brake line
- L/t fr 185 gasket
- Edelbrock RPM II cowl required?
- Porting Iron gt40 Questions
- Timing gurus
- magnaflow on 90 LX
- MAF mystery??
- Name this Carb (pics)
- quick noob question
- Anybody with Eibach Sportline springs - have a ?
- Emission Removal? Help?
- How fast with stock airbox intake and k&n panel filter !
- popping through intake under a load and lose of power when hot out !
- VORTECH S TRIM
- Check engine light test not working for me
- Tapping kit for 9" rear?
- crazy timing
- BBK Underdrive Pulleys
- Over Heating
- Fog Lights
- OK i still need help....
- Notch seems slow...diagnosis anyone?
- Quad shock mount help!
- Cylinder balance test not working - Code 77
- Another Mark VIII fan question
- valve covers dont fit...
- valve tap...
- Turn Signal Flasher
- I can not remove the cover of the timing chain
- comp. ratio for supercharging
- Car Wont Start
- steering wheel shimmy...?
- Transmissin ID tag
- Alt wiring question?
- Lightning 90mm MAF on 350hp stroker
- Fuse link help? Car wont start
- Need advice/help setting timing with a Mallory Comp 9000 (mechanical advance)
- Fel-pro MLS head gaskets
- Emissions vacuum question
- Help with fuel pump turning on!
- Coil Question
- Wheel/Tire Sizes with Eibach Pro-Street-S Coil-Over
- After all the problems the last issue is the fuel pressure regulator
- Enginge Formula 4 a high 6 to low 7 second 1/8th small block?????
- A/C conversion ?
- Upgraded heads and Intake. Now its popping
- Correct way to measure wheel offset & backspacing
- Transmission spacr plate/dust sheild
- ET Streets
- Car SOMETIMES doesn't start.
- aluminum driveshaft for 1991
- C-4 GER REVERSE MANUEL VALVE BODY ???
- Picked up an 85 that was "Built for spray"
- Looking to install a supercharger soon....
- AFR Heads (Keith Craft vs. AFR Factory)
- '86 EFI 302 to Carbed 302 transition....
- Horn goes off when i turn the wheel
- a/c bianary switch hot wire color?
- 85 Carb guys got some?'s
- Jeep Speedo Gear? Really?
- The 10 min. tune up.
- Sub-frame connectors?
- Opinions on a good fuel pump.
- Belt Length Problem, PLEASE HELP!!
- 70mm Cobra MAF on LX
- No power at inertia switch
- rear suggestions please
- msd mini starter installation help
- Correct way to remove struts?
- Electronics reset on right hand turns?
- 6G Alternator Help!
- piston to valve clearance
- Maf question...
- Tranny, clutch, clutch cable issues?
- any words on autolite plug wires?
- Flex-A-Lite black majic wiring question
- Trac lok rebuild question
- which EEC-IV wires not necessary?
- Any ideas what this can be???? HELP..
- Your Thoughts On This Intake?
- booster/MC for cobra brakes
- Coolant passage on intake.
- cam help
- Motor Mount ?
- Odd gauge problem
- Fuse Help
- motor won't turn over
- What pushrods for Twisted Wedge heads?
- Fox body gas tank questions
- Battery Relocated...starting issue...
- Stock Tach stuck at 4k
- question on installing struts
- Baer brake ?'s
- valve train geometry?
- Motor Swap
- steering wheel turned to drive straight!?!?!
- Speed Density to MAF
- HELP-- tech guys???
- Swapping rearend completely out
- Idle Issues??
- Anyone who has removed stock 5.0 HO upper intake
- 86 LA Stang Vert Door trim questions...
- 5 lug swap with 93 cobra brakes
- Cranks too long when hot??
- fuel pressure and setting
- air to my 331 ?'s
- Stroker kit what else needed?
- Lifter ?
- Vacuum Line Sizes
- Smoking out one tailpipe
- Anyone have problems with Fel-Pro Head Gaskets
- "Original" Performer RPM Intake Specs?
- torque specs wrong? snapped bolt
- Fuel cell purchase
- tunning a blown 331 stroker
- Fuel gauge
