PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. vibrations under acceleration and over 3k
  2. GT40 lower/Stock lower intake gaskets?
  3. GT40P heads
  4. anyone tell me what these error codes mean?? 34,84,85
  5. Bad timing, running hot , need help!
  6. Pressure plate bolt torque
  7. SPAL PWM fan controller with a Taurus fan FYI.......
  8. R12 freeon or R134??
  9. Canton windage tray wont fit the 347?
  10. I really need some tech help!!
  11. ? About DSS Blocks
  12. timing issue
  13. Intake from a 91 F-150 5.0
  14. What is this electrical box?
  15. need help with pulley setup, belt routing
  16. whistle at low idle
  17. No oil pressure
  18. rockerarms loose when valves are closed?
  19. Help me decide please
  20. Power difference with o2 sensors?
  21. Starter Relay Picture
  22. Has anyone had problems with their PIP in the Distrubitor?
  23. Hatch Latch Snafu
  24. 88 Ford Mustang Convertible mirrors not working??
  25. Tryin to break into the 8's
  26. Can stock intake bolts be used with Cobra/Explorer intake install?
  27. Ground
  28. Set me straight on braided fuel line and plumbing.
  29. LCA bolt removal
  30. Push to start wiring?
  31. splutter
  32. mac prochamber or an x pipe?
  33. Spool on the street?
  34. Clutch dowel pins install questions.....
  35. drivetrain slop
  36. KOEO Codes
  37. E303 cam question...
  38. new gear problem
  39. Oil pressure
  40. More power
  41. Wanna go carb to EFI
  42. Best Holley carb for 347 stroker combo?
  43. ECT voltage source?
  44. Poersteering queston
  45. Electrical Nitemare!! Need Help!!
  46. Running real hot
  47. fusible link burning!
  48. Intermittent Starting
  49. Removing thread sealer from bolts
  50. 5 speed trans ?
  51. Tranny Q's and other help please
  52. What Gains should i expect?
  53. factory temp gauge?
  54. This makes absolutely NO sense to me. Headgasket Q???
  55. what type of heads?
  56. Overheating problem
  57. cooling problem
  58. how to take out center a/c vent?
  59. Drag radial question
  60. 6G Alt Question, Never Asked Before!
  61. '96-'04 Mustang electric fan into Foxbody?
  62. Brake Problems
  63. Need help with rear drum brakes
  64. Turn Signal
  65. Horn Button on Airbag steering wheel
  66. Is this 10.1 compression ratio
  67. what cai w/ c&l mass air meter?
  68. idle RPM question..
  69. Cam Degree Never Happened
  70. C6 transmission swap
  71. Fuel pressure for 88 stang
  72. fuel pressure o when hot
  73. What are these screws for?
  74. Lowering Spring Pic Database
  75. How to find out what type of cam I have? Roller or not?
  76. clutch quadrant
  77. What can this be???????
  78. Help: I need a copy of a N-71 cam card to degree my cam.
  79. Have to hold key on to keep it runing
  80. 24lbers work with 8lbs of boost?
  81. Electrical Problem
  82. c4 tranny problem
  83. Am I running to rich?
  84. not a mustang problem, but need some help...
  85. ****ing car wont start
  86. Power steering
  87. codes 12,33 & 44
  88. Weird electical problem
  89. WC t-5 question
  90. convertible, B springs, and C/C plates?
  91. Paxton blower pulley??
  92. Any tips on installing head unit and speakers in 88 Mustang Conv 5.0??
  93. How does the AC circuit work?
  94. For those of you who have deleted your heater...
  95. Head gasket install?
  96. My car is a slug, I'm out of ideas
  97. maf and tb ?
  98. 351
  99. How do I modify explorer throttle body?
  100. converter question?
  101. H-pipe ?
  102. 12 Volt Key-on power
  103. Oil temp at around 230. Normal?
  104. Why am i ginding in 1st. gear
  105. Stalling out!
  106. no headlights
  107. 4 way flasher help
  108. Air Conditioning dilema
  109. New starter & Solenoid - Still hanging up
  110. Rotating assembly binding after installing oil pan - HELP
  111. convertible winsheild trim
  112. Would you trade?
  113. difference b/w SC trim and S trim?
  114. Which Automatic Transmission?
  115. Help me fix and make $50!
  116. very wierd problem
  117. Painting GT molding
  118. vibration problem please help
  119. ELECTRICAL GREMLIN! Help me!
  120. Mustang Stance??
  121. Steering problems!
  122. Valve cover gaskets..cork or rubber?
  123. best choice for rearend lube?
  124. Cobra Radiator
  125. T5 Whine 1st-3rd
  126. WEIRD timing issues!?!?
  127. WEIRD vaccum issues!!!????
  128. Bearing size for polished crank?
  129. Flywheel: ready to install or balance?
  130. Adjust TPS need help please
  131. removing the center console!!
  132. "check engine" light...
  133. help me ID my motor
  134. 2 imposrtaint question can not FIND?
  135. Do You Insulate a New Fiberglass Hood??
  136. a/c
  137. To anyone who has 3.73s
  138. Alternator help ?
  139. what weight oil??
  140. driveshaft????
  141. whats making my car vibrate?!!!!
  142. 1993 5.0 Detonation after 3000 rpm
  143. Where can I connect my wire for B+?
  144. safety switch
  145. Need Help
  146. maf/conversion
  147. Please Help, I want blinkers again.
  148. eliminate my pcv?
  149. 17 X 9 Rims For Fox Body
  150. Spout Connector - what does it connect to?
  151. Rear springs question.
  152. Coolant Problem
  153. Autometer GaugeCage piece broke...can you get this piece???
  154. Brake Kit
  155. Trans fluid flush?!
  156. Finally pictures of my oil leak!!
  157. Can Someone Help Me With My Fuel Problem???
  158. TKO-500 & TKO-600 users: how high in RPM can you shift?
  159. Exterior trim: Black or Gray?
  160. Tranny clutch help
  161. 87 SD hesitation in low rpms
  162. aod wide open
  163. return/pressure lines.
  164. 86 fuse box diagram?
  165. Narrow Band Sensor On A CARB car?
  166. Timing chain cover & water pump
  167. brakelines help...ik its a lot to ask but...
  168. msd plug wires
  169. ANYBODY KNOW WHERE TO GET 1/4 WINDOW BUSHINGS 91 GT VERT
  170. AOD to T-5
  171. Car loses power and backfires when you hit the gas
  172. convert to 5 lug rear disc brakes????
  173. Help my fuel system has issues i cant figure out
  174. Lets straighten out my suspension before I buy everything.
  175. Installed Coil-Overs....Problem
  176. Pulls harder at Part throttle ?
  177. WINDOWS noise, movement and such
  178. Hmm
  179. No MAF?
  180. foxbody suspension
  181. 5lug conversion/brake ques.
  182. steering shaft
  183. did i s#$% the bed or what?
  184. Flywheel idle surge
  185. need help
  186. 85 302 H.O. spark plug question
  187. Valvetrain/rocker ticking.
  188. Pulled codes...need some help.
  189. 17x 10.5 on a 93LX
  190. Help with codes
  191. MOUNTING MY GAUGES
  192. Running my Starter & 1 wire Alternator cables tonight....
  193. Lifter Maintenance?
  194. Busted my T5, manual transmission advice is needed and greatly appreciated!!!
  195. what injectors are these?
  196. People who changed their FP HELP
  197. 347 parts list
  198. Evacuating A/C
  199. Swap headaches..help a brother out!!
  200. noob here couple of ?s
  201. Converting gt to an lx? Frowned upon?
  202. anyone got the mini starter diagram?
  203. is this a 7.5 or 8.8????
  204. Nothing for puller to grab - pilot bearing
  205. heat gauge rises,, hot air not coming through vents?
  206. MAF Conversion
  207. Exhaust attaching help
  208. Old Sprint Tires Are Good Drag Tires? Link-
  209. TRANSMISSION QUESTION
  210. First Engine Build Advice Appreciated
  211. Is this okay?
  212. check engine question
  213. air bag light
  214. R my motor mounts bad?
  215. Wheel fitment
  216. Rebuild kit for 93 Cobra rear calipers?
  217. HELP!!! tko600 crossmember not fitting
  218. BBk x pipe wont bolt up to bbk headers
  219. overheating
  220. Vacuum line on brake booster (whats it for?)
  221. MAF Voltage Too High At Idle?
  222. 89 gt- gas gauge not working...etc.
  223. Stock 86 4 cyl tank to mech fuel pump?
  224. changed water pump yesterday :(
  225. What bolts for smog pump holes on back of heads
  226. 7000 RPM - how much should i be concerened?
  227. 1st to 2nd gear grind.....can I fix it?
  228. Questions about Trick Flow top end kit?
  229. 351W With Gt40 Heads And Intake
  230. GETTING RID OF OLD WINDOW TINT
  231. Front Draglite Fitment Problem. HELP!!!
  232. Electric Fan ?
  233. DCC HELP! NOT WORKING?
  234. Classic guy looking for help with T5 swap
  235. Spark Plugs for Canfield heads
  236. What Nitrous Kit to Use?
  237. please help im in desperate need of all the help i can get on my wiring issue
  238. Vacuum line question....not an idle issue lol
  239. efi 302/306 1/4 mile times and setup
  240. do the older self contained paxtons have the gear internal?
  241. E7's, does it matter which side?
  242. Rear Shocks help please
  243. N-41 vs. TFS Stage 1
  244. 91 air bag light blinks 5 times then pause? help?
  245. Car starts running hot
  246. 3g alt problem
  247. Brand new 347 has rear main leak!!
  248. Inline fuel pump??? anyone run one? question?
  249. Complete Fog Light Rewire?
  250. Brake Line Size HELP!
