View Full Version : 5.0 Tech
- Front Draglite Fitment Problem. HELP!!!
- Electric Fan ?
- DCC HELP! NOT WORKING?
- Classic guy looking for help with T5 swap
- Spark Plugs for Canfield heads
- What Nitrous Kit to Use?
- please help im in desperate need of all the help i can get on my wiring issue
- Vacuum line question....not an idle issue lol
- efi 302/306 1/4 mile times and setup
- do the older self contained paxtons have the gear internal?
- E7's, does it matter which side?
- Rear Shocks help please
- N-41 vs. TFS Stage 1
- 91 air bag light blinks 5 times then pause? help?
- Car starts running hot
- 3g alt problem
- Brand new 347 has rear main leak!!
- Inline fuel pump??? anyone run one? question?
- Complete Fog Light Rewire?
- Brake Line Size HELP!
- AFM cam specs.
- glasspacks
- MSD Ready-to-Run distributors?
- GT40 Swap now I can't get her started??!!
- K-member install
- losing my turbo coupe rear and going back to drum...a few questions...
- Brake Lights stuck on?
- Tubular control arms and springs
- my top wont come back up... 92 lx 5.0 vert
- Opinions
- LABOR COSTS
- 86 LX 5.0 Blues
- SN95 brake conversion question
- O2's w/o cats?
- heya i cant find any info on these injectors, maybe you can help!
- stock fan, how many cfms?
- Waterpump
- Anyone use Accufab midlengths before.
- Torque specs and head gasket for 460
- Timing for force fed 5 Liters???
- How much is an engine rebuild?
- T5 reverse spring
- ford racing b-303 camshaft
- a/c and p/s delete
- aaRGH when will the error codes stop (CODE 67)
- Need help after replacing pushrods.
- Air/Fuel Gauge on Carb setup?????
- injector reccomendation with my combo and boost
- Zex Nitrous Users
- Head gasket recommendations
- tuning questions
- hows it look in a 1970?
- 4.6 fuel injectors?
- Help, Wont start
- About Magnaflow Muffler Install
- weld torque box question
- Need Help Please!
- Need your suggestions on this issue..
- How to tell a holley system max from a system max 2 ?
- Vac Line diagram for 85 Mustang
- High idle after timing advance
- 85 Mclaren temp guage issue....
- Show me your battery kill switch please.
- Help! Tired of throwing money at problem.
- mild HCI, would i benifit with 3 " exhaust if add boost? and SC questions...
- Bad vibrataions!! help me
- Tune Up???
- Timing really need help..
- Still running RICH.
- 45* or 90* angle for the Fox TB swap CAI???
- 3g alt quest
- proper rims for fox with 5 lug conversion
- Adding cats behind Mac 1 5/8" Long tube's
- Car goes to stall then catches itself
- possible fried computer?
- About to install F Pump any suggestions?
- 1.72 RR on stock 5.0 ??
- Throwing Both Lean Codes No Fix In Sight...
- T-5 Output seal re&re?
- Odd e-brake issue tonight
- Wheel/Tire question. Promise I did search first.
- still no start
- c-clip eliminators
- is the MAP sensor on MAF cars different than Speed Density?
- Do I need c/c plates with my 'b'springs
- Help! Correct MAF ECU???
- windsheilds
- '86 H.O and B-cam question....
- Pushrod length for Performer RPM's/ stock cam
- Hard time starting when hot
- AUTOMETER!!!!!!!!!
- IAC Results
- Wheel Size
- Reverse lights stay on.
- convertible frame connectors
- Weighed a TFS TW Alum Head w/ 1.6 RR's vs E5 Iron Head w/ Stock Rockers
- D.S.S Pro Bullet 306.... Opinions and induction recommendations
- clutch adjustment??
- Line lock questions
- Drove with loose distrubutor...heeelllp!
- gt door moulding location
- Need Help Choosing Wheels
- procharger users chime in!
- Help. (searched and tried another thread previously)
- 347 question
- Rim size question
- Need help w/ electric fan & DCC
- speedometer help
- How would this setup be with speed density?
- 88 Convertible top not going all the way down??
- AC bogs car down
- Cruise control tried to kill me!
- 6 SPEED TRANS
- Poor Man's Leak Down...Will This Work?
- Need help installing items
- No Spark, No Start - going to cry.
- Help Car just died ( no key on power )
- Which sub frames are best?
- MSD box, worth it?
- trans line fitting at the radiator leaks bad
- So my car keeps randomly dying....
- Muffler Inlet Outlet on 88 mustang gt
- reading dipstick
- Ignition system, starting from scratch
- Which gear to buy
- Which trans fluid to use in my 5-speed?
- Stock hood question
- 3g alternator problem
- injector pulse
- Wheel and tire help..
- starting issue
- 5.0 next mods
- ford racing 70mm mass air meter
- check engine light won't work when doing koeo test
- 4.9(300) same bellhouse as a 5.0
- how do i put on my new 1.6 roller rockers?
- egr eliminator....does it work
- 3 Row Radiator Swap
- codes wont show??? am I doing this right?
- 1990 Mustang GT Clutch questions
- rotor rubbing distributor cap inside?
- AutoMeter Mechanical Water Temp & Stock Gauge Question
- C&L mass air meter
- Code 95 Help
- Where to get long oil pan bolts?
- Mustang Heads
- Vin code?
- rocker arms?
- Headers Question
- EGR Gasket Leaking
- 3G not charging... ????
- Help!!!
- Header gasket alignment question
- Header gasket question.
- cooling question
- 89 GT Gas Tank removal
- Fuel Cell Install
- How do you check fuel pressure?
- What is the difference between FRPP B and C Springs?
- Mass air problems
- rack shifting?
- Having some problems with my 408...need input.
- Cam guys in here
- K-members that DO NOT move the front wheels forward
- convertible rear window inop???
- Clutch/Trans tech ?
- Idle Issue, checked checklist
- 89 Mustang 5.0
- My new overflow bottle looks huge....pics inside.
- what cam for the street??
- Shifter to Trans Bolt Sizes
- Setting cold idle time in ECU
- Fuel pressure set right
- bassani vs magnaflow
- Baffle for Factory Valve Covers?
- EGR Similator
- Harmonic balancer help
- Rocker Arm play?
- Need Some Guidance!
- Using a EFI starter on a Carb'd car
- Why does the PCV hose run to two spots on the intake?
- Can you change the PCV system?
- What cars came with 6G Alt?
- could a bad FR cause a rich condition with a 190lph fuel pump?
- window motor: high tq vs low tq?!?!
- Help with SVO rear end for 90 gt
- Need help with Kenne Bell install..idler
- 87 88 thunderbird rear in a mustang
- D/S loop ?'s
- MSD Ignition Testing
- engine: white smoke at high rpm
- Are my 289 heads hi-po
- O2 wires in harness wrong color??
- Manual brakes, anyone running them?
- what should i set my fuel pressure to?
- coolant leak?
- Pulling Codes
- Exhaust Leak
- Pro 5.0 Shifter Help ?
- Long Tube headers! I have shorties? Should i buy them? NEED HELP QUICK!
- Long vs Shorty Headers
- running fine then wouldnt restart
- Can I put a 275/40 17 on a 17X8 rim?
- Clutch Problems
- Anderson N-91 cam?
- Coil over questions
- not running right
- EFI - no start, need help!
- Fog Light Issue
- Back four intake runners wet. Need advice.
- Clearance Issues With Exhaust Cut-Outs
- Fire Wall Clutch Adjuster
- Throttle Response Delay... ???
- 5 Lug Swap Help
- Flip the bird.....I mean IAC
- cobra r intake questions
- pushrods on my 393 stroker
- Front end noise
- Iac question
- Clutch pedal problem
- HELP ME!!! I need help with pushrod length and tips!!!!
- Throttle Body Gasket Part# ??
- edelbrock aircleaner...
- how to hookup autometer tach?
- GT-40P Heads
- Zex nitrous install question
- Does anyone use the FRPP full gasket kit for rebuilds
- who can recalibrate my pro-m 77
- am i going to break my driveline?
- Install quad shocks
- 8.8 31 spline conversion
- Cold start still sucks!
- HELP ME!!I need to know pushrod length!!!!
- coolant flushing?how?
- 1988 gt Tach install Help.
- How does the ac evaporator come out of the dash unit??? lol
- Think tranny is dieing
- Glow Shift gauge question
- Radiator Question
- Brake fitting?
- 5 speed vs 6 speed tranny
- my crap luck continues.....need your help
- 1992 LX Conv side view mirror removal
- Connecting Rod C8OE-A in a 1990 stang?
- 89 GT Fuel pump testing.
- Pulled codes again w/DVM readings!??
- 4 cyl to V8 ignition/wiring options??
- Compression Test Numbers before head install, questions
- Well, I "WAS" having fun at the strip until something broke...
- not starting..Fried Ign.?? Battery dash light ON
