PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. HoooooooWeeeeee..the Merc...it's fixed
  2. Engine put back in. I forgot where some plugs go. Should be easy question
  3. Is my Belt too tight?
  4. Would a exhaust leak sound like ...
  5. Engine wont turn over HELP!
  6. 82 And 89 Water Pump The Same??
  7. new 1992 5.0lx need some advice
  8. Fuel sending unit.
  9. AOD "over drive" trouble-need advice
  10. any advise
  11. 91 5.0 GT FUEL PROBLEMS, PLEASE HELP!!!
  12. What's causing jerky acceleration?
  13. o2 senors and effects on the ecu?
  14. what speedo gear
  15. Wiring question???
  16. Running Lean
  17. dyno:(
  18. streched clutch cable?
  19. AOD won't go back in...
  20. Oil pan gaskets
  21. Opinions on setup, cam ,intake and heads...
  22. sn-95 5 lug conversion...which struts?
  23. Broke two lower intake bolts off into the block....what to do?
  24. hot or cold plug?
  25. making my own timing tape... increments???
  26. Eaton M90 on a fox?!?!
  27. Intalling Front Lower Control Arms...Tips?
  28. Stupid question about timing (new heads and intake)
  29. signal wire on o2
  30. 50oz imbalance flexplate question
  31. Tumbler or starter?
  32. Post your vaccum numbers. Do I have a vac leak?
  33. Water leak
  34. Anyone passed emissions with X pipe and Cats
  35. gt40p heads and tfs stage 1
  36. BiG PRoblem With COBRA INTAKE!HELP!
  37. Broken bolt in thermostat housing
  38. heads
  39. speed gear gurus
  40. vibration when shifting
  41. What Does This Code Mean?
  42. Wobble in front tires- steering rack??
  43. 351w heads ???
  44. Need comments please
  45. How to put 5.0 and Horse back on? Epoxy??
  46. 351W questions
  47. 5.0 to 5.8
  48. Tell me what you thing.... Any Paint Experience!! Would be Helpfull!!!
  49. v belt conversion kit
  50. Misfire/Detonation High RPM
  51. mass air meter size?? 75mm or 80mm
  52. No spark or fuel pressure?
  53. Computer
  54. Hatch Carpet...
  55. Heater Hoses
  56. vert guys--2 ?'s
  57. Thanks for the suggestions but, I remembered a real problem
  58. Quick! Timing HELP!!
  59. Burning Coolant?
  60. Anyone ever make a solid steering shaft?
  61. starter
  62. cant get stang out of gear
  63. how big of a cam
  64. mustang 5.0 relay
  65. silly question?
  66. T5 Clutch Fork Cover ?
  67. Need Help....Car Very Rich
  68. Electric cooling fan questions
  69. Exhaust mounting problems. need help
  70. HELP NEED HELP !!!
  71. Head question
  72. 85 CFI 5.0 throtle bracket & spring
  73. Trick Flow intake owners, I need your help
  74. Ignition switch
  75. ALTERNATOR PROBLEMS PLEASE HELP!!!
  76. TF Track Heat, 1.7RR & E303
  77. Inner tie rod questions
  78. Bypass jet for fuel reg on NOS sys?
  79. TAD/TAB Solenoid & Relay Package Price
  80. 347 stoker help
  81. t56 speedo
  82. Ground clearance mufflers.
  83. Reinstall steering shart...wheel is 180 degrees out!!!
  84. Radiator
  85. IAC and IAB
  86. A drip!!! Just Painted!! Anyone???
  87. cam help
  88. Nasty snot-substance buildup in intake! AAHH!!
  89. carb swap trouble
  90. Alternator ?
  91. need advice,clutch cable kit.
  92. Lowering Springs + 18's! Which springs for street? HELP
  93. Roller cam install q...
  94. Mix and Match Intake...
  95. Stumbling at WOT and above 2 grand...
  96. exhaust hanger
  97. HELP! Which heads (AFR 165's or Track Heat's)?
  98. Axle Dampeners
  99. Help from gurus re intake
  100. a/c controls gone, tach stops working..
  101. Trim removal around windshield and rear window??
  102. Which cylinders for EGT readings?
  103. Where to get fuel line clips?
  104. it's one thing after another...turning my crank
  105. Fuel Pump Noise (not a hum)
  106. Quick A/C question
  107. Tailpipe Comparisons
  108. Buying a Used Block I Have a Question
  109. Help with finding where a wire goes
  110. cobra intake vs tunnel ram EFI intake
  111. mid range
  112. Electric Fan alternator question
  113. Neutral Safety Switch?!
  114. window motor glitch
  115. carbed aod??
  116. Cheep fix, or gambling my life?
  117. New engine problems
  118. How do I keep factory oil pres and water temp guages when adding autometers...?
  119. gt40p head question
  120. EEC Wedgelock Pin
  121. I need help with Timing
  122. distributer
  123. Electrical
  124. Does the motor have to come out for oil pump replacement?
  125. March Power Pulleys. #1015. Good for STREET????
  126. where to get a dust boot/shield for rear shock?
  127. How to run cooler and why am I running hotter after heads?
  128. zoom clutch cables... and routing
  129. Electric help. please?
  130. Running like crap! Pulled codes. Got parts coming, but are they the right ones =)
  131. HELP WITH INSPECTION ? ASAP
  132. Front srpings, etc...
  133. Little Help Please
  134. O2 Sensor Hard Wire
  135. car won't start
  136. car stalls out
  137. 5 lug questions...did search
  138. ever see warped intake manifold??? stock one???
  139. PowerMaster Mastertorque Starter Install?
  140. Underdrive Pulley on Altenator?
  141. Shift Points & Max. Timing?
  142. no more running rich fixed
  143. Painting My 5.0 Vert.. What pressure ??
  144. Head gasket woes
  145. dome light & hatch light
  146. Passenger Door Help..... Any Help Much Appreciated...
  147. STARTING PROBLEMS
  148. 93 Vert. Quarter window.
  149. bad draw somewhere
  150. victor jr intake to much for 347
  151. Push rod size?
  152. Converting 5.0 to 4wheel disc questions!?
  153. Can't go full throttle.
  154. wheels for 5 lug 91 gt (Help need pics)
  155. O2 Sensors backwards
  156. tps voltage wire?
  157. brand new autometer tach is junk?!?!?!
  158. Smog pump problem HELP!
  159. Constant 12V Power Source
  160. vert top motor
  161. Roller Rocker Problems HELP
  162. Am I Rich Or Lean?
  163. Knockin cold
  164. When using a Trickflow Top End Kit
  165. Leaking coolant from water pump/ lower radiator hose connection
  166. running rich....
  167. Sluggish Problem & Backfire
  168. Should I stay close to stock?
  169. speedo
  170. 5.0 Paint Experience Paint.. Help... Please!!!
  171. o2 sensors
  172. Rebuilt my traction lock today.
  173. 351w Starter
  174. Looking for the short harness that goes to the A/C compressor
  175. clevorness
  176. clutch cable help!
  177. what size nuts/bolts for uca's?
  178. OverHeating Issue
  179. anderson b2 cam?
  180. what to do about govener
  181. will this be safe on my car/fog lights
  182. Show me where and how you installed your pcv oil seperator
  183. 42# injectors+SC+New motor to break in (no tune for 500miles) = FMU?
  184. upgrade sway bars or no?
  185. Gears/turbo
  186. picture of stock pinoin snub?
  187. brake lights wont work
  188. Will this intake be alright, or will my car not even run?
  189. Twin Turbo Kit on Ebay
  190. Oil in intake... w/pics
  191. 51014 lunati help
  192. 93 starter for 76 5.0???
  193. Need Help Getting 5.0 INto 83 Mustang
  194. need help with vacuum hoses
  195. Installing power mirrors, etc
  196. Popping and surging while car is cold
  197. Intake Manifolds for 302
  198. ANYONE?? --lowered stang with 275/50-15's--
  199. TFS Heads
  200. Undersize crank bore balancer for Eagle Crank??
  201. Clutch Cable
  202. starts, but shuts off immediately or wount start at all.
  203. replace window harness
  204. Starter
  205. side skirt rivet size
  206. broken control arm
  207. help with pa performance 3g 95 amp alt
  208. C4 or C6 trans?
  209. Wheel fitment question
  210. 2 shorts, where to start looking
  211. Running Rich and Backfire
  212. Ford Rotunda EEC-IV Monitor Help Needed
  213. Noisy Lifters???
  214. Header leak keeps coming back
  215. 351w carbon backfire
  216. Water Temp Gauge Question
  217. Code 98?
  218. 351 windsor problem
  219. Code 95 w/MAF conversion
  220. Help out an old guy...TPS issue...confussed
  221. 5.0L Ford Crate engine valve noise
  222. 1.6 vs 1.7 rockers
  223. somebody PLEASE tell me this can work...
  224. C4 no go....
  225. whats wrong with my t-5?
  226. Need advise on what to do with my motor
  227. need help quick with!!!! (yes ive searched)
  228. big wheels??
  229. Fuel on spark plug..??
  230. oil pan
  231. awwwww crap burning oil help
  232. Base idle reset?
  233. t5 ?
  234. Cobra rear disc e-brake help
  235. good setup?
  236. Fuseholder mounting for 3G swap
  237. suspension help
  238. Throttle HELP??
  239. Engine smoke
  240. Cracked Vacuum Lines, Need to Replace
  241. Tachometer Jumping randomly while driving
  242. Ready For H/C/I And Boost. Need Some Advice
  243. power steering whine...
  244. 70mm TB
  245. quick ? vapor canistor.
  246. Cheapest Place for "Summit" Seats
  247. Tranny fluid
  248. ho vs non-ho cams
  249. synthetic motor oil making engine smoke?
  250. 1 wire external voltage regulator
