PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. 1 wire external voltage regulator
  2. needing helping with gear issue
  3. wont start
  4. 1991 Mustang Strange noise????
  5. pic of eec relay
  6. what are these TWO things and can i delete them? *pics*
  7. 1978 D90E E3A block casting
  8. Fuel injection conversion, problems, popping.
  9. Top shop or DIY
  10. MK8 Fan Motor Replacement
  11. Still problem with the Diablo Chip
  12. Scat Procar Seats
  13. post welding surge
  14. 5.0 HO versus regular 5.0
  15. suspension questions for autox/street
  16. Alright, I've dumped the codes
  17. smog hook ups on back of heads
  18. CLutch cable
  19. Fuel Injection to Carb
  20. CLICKING sound with clutch
  21. Vaccum leak
  22. Movement in Steering Wheel
  23. Question about Exhaust Dumps??
  24. black backfire through carb
  25. No power mirrors on an 89????
  26. power mirror help.
  27. torque box reinforcements
  28. Exhaust : Mufflers with cut-outs...
  29. 302 block question
  30. Running to hot or timing
  31. How did I get rich?
  32. My AOD trans wont shift out of park???
  33. oil cooler.... I hope?
  34. 86 gt frying wire $5,000 later please help
  35. Rolling fenders? Tire rub ...
  36. mass airflow sensor
  37. Speedometer quit working....
  38. windshield gasket/trim
  39. alternator question
  40. Installed bbk cai
  41. fuel pressure reg leaking gas?
  42. Largest Bullit Rim on a Fox Body?
  43. plug-n-chug
  44. break in period for rebuilt motor
  45. Flush Cooling System
  46. x303 ptv clearance with KB355 10cc dish piston
  47. t5 sensor ?
  48. wire getting hot
  49. Car not running as good when hot
  50. Transmission fluid for a brand new T-5
  51. Help with failed emissions (maryland)
  52. Fuel Pressure w/KOEO
  53. Chronic valve ticking,.....please help
  54. Stock FP is what again?
  55. Sluggish to build RPMS; Part throttle bucking/loss of power...
  56. Serpentine Setup Help
  57. BBK FUEL PRESSURE REG INSTALL
  58. speedometer noise and bounce
  59. Opinions on 1 1/2" long tubes?
  60. stang appraisal please$$$$$
  61. Wheel Hop...??
  62. Lincoln Mark VIII Fan Install Problems
  63. C6 Tranny Owners....
  64. quick ? about mass air
  65. Fuel Pressure
  66. Pedistal Mount Roller rocker saddle cracked?
  67. bbk quadrant question
  68. which tranny?
  69. high flow fuel rails vs stock
  70. will my launches get better with suspension upgrades if its hooking decent now?
  71. Fouled Spark plug?
  72. Pinging At WOT HELP!!!
  73. Gimme a brake..
  74. Few codes from KOER test...
  75. Spark plug gap w/ trickflow heads.
  76. quick question about double hook quadrant
  77. where does this go?
  78. starter/electrical issues
  79. Efi to carb need help with fuel delivery.
  80. ? about bumpsteer kit
  81. Rear Control Arms and Track E/Ts
  82. torque converter flush
  83. Powerdyne question
  84. Carb installation help
  85. start or dont!!!
  86. compression question
  87. Quick smog pump question
  88. Quick t-stat question
  89. Oil in upper intake from PCV hose???
  90. Camshaft dowel pin?
  91. A/C shuts down car
  92. How much hp can 24 lb injectors support?
  93. HELP
  94. Starter Problems
  95. Whats the torque spec for the driveshaft U-joint caps?
  96. Bad vibration (I searched)...please help!
  97. guys with crane 1.6 rr's
  98. intake stud loose cant get to it
  99. Good deal or did i screw up??
  100. Aluminum Heads - I can't pull the valves out!
  101. Please ID this fan for me!!!
  102. Bad starter? Relay? Both?
  103. power steering pully company?
  104. push button to turn key?? help
  105. Break in period for new lifters?
  106. brakes
  107. HELP!!! Another Vibration issue!!
  108. Need new steering rack
  109. building a 5.0L
  110. Steering Vibration
  111. Racetronix GSS340 Pump and wiring harness
  112. 1988, MAP vs MAF
  113. Questions about the parking brake?
  114. Need help with these wheels?
  115. No brake lights! Crap!
  116. lost gaudge
  117. All headers seem to suck
  118. Replaced my injectors...still has a miss...
  119. Anyone ever notice a difference in going from 9:1 to 10:1?
  120. loud ticking please help
  121. Getting an 86 with 351 few questions
  122. No tailpipes or dumps
  123. How/When should i install these mods?
  124. Radiator choices...
  125. CHE Performance: Your Opinions
  126. starter shims
  127. Spedo cable
  128. Fast question!
  129. 5 spd racers with line locks
  130. surgung idle
  131. Emergency brake has rear brakes stuck.......Please help!
  132. why is my car jumpy in 3rd and 4th gear at about 30 mph
  133. computer metal clip for harness
  134. spark plug question
  135. 86 Stang once again....
  136. T5???
  137. Passenger Window
  138. runnin lean
  139. Carbon Canister
  140. Door Stuck Closed
  141. 331 stroker
  142. Quick question about e-fan
  143. Smoke coming from dipstick after driving
  144. Last minute dyno advise
  145. How I got rid of the Power Steering Whine
  146. sn95 rack into a fox
  147. I'm tired of this project already....please help..........PLEASE?
  148. Trying to figure out gearing...
  149. HELP WITH HID KIT INSTALL!!!
  150. Quarter Panel Question
  151. Speedo Gear
  152. Newbie intake questions
  153. Mustang Meet and Greet
  154. Aluminum Driveshaft question
  155. Need help with convertible top
  156. Amp meter not working
  157. Drops of oil...with a touch of antifreeze...! Please Help...!
  158. If you have airbag codes: You must read!
  159. Please help me determine what these wires are for :)
  160. clutch adjuster and cable
  161. How do you tell what trans you have?
  162. I'm Back !! A new project - Wiring help
  163. What the hell are these?
  164. Just cracked my 2nd block wtf is going on?!?!
  165. INFO Needed Asap
  166. Performer RPM II too much for stock engine?
  167. help with codes
  168. please help my anoying problem w. IAC cleaning
  169. Emission legal headers?
  170. Door Panel Question
  171. Having problems removing wheel spacers....
  172. ARP rocker stud question
  173. knock under load
  174. bench bleeding m/c...
  175. Small vibration <1500 RPM's, suspension pop, etc
  176. CRANE FIREBALL???
  177. Clutch Cable Splitting
  178. no start, fires with full throttle
  179. Car WILL NOT START
  180. IS A 2000 EXPLORER MOTOR CLOSE TO A 91 HO
  181. camshaft
  182. I NEED SOME HELP WITH STARTING PROBLEM
  183. Airbag code 12 blinking
  184. Steering question??
  185. Anyone ever swap from 5.0 to Supercharged 3.8 ?
  186. Seeing as how it wouldn't hurt.....
  187. 5.0 into 83 mustang V6 Convertible HELP
  188. violent TOB cherp.....major cable slack
  189. Performance Question about stock exhaust!!
  190. Need help, Power steering pressure line
  191. NEW BBK SSI on our 347
  192. Clutch kit choices??
  193. B+M synthetic tranny fluid
  194. Need Wiring Help!!! Please
  195. Back from the shop
  196. Speed Density Modders Please Help!
  197. Hesitation Help
  198. Weather strip install?
  199. valve clatter
  200. whistling noise?
  201. speedo gear when going to 17's
  202. Enough Fuel Supply for S-Trim?
  203. Brakes locked, someone please help!!
  204. HCI THread..Which kit?
  205. Where is the fuse in the "fusable link"?
  206. New to Roller Motors- Couple Q's
  207. Fuel Pressure Regulator Swap
  208. AC Vents
  209. S197 Wheels on a Fox?
  210. efi wiring gurus here please
  211. Under Drive pullies
  212. gear slippin
  213. Replacing Vacuum Hoses
  214. How much hp will a stock 5.0 block handle
  215. 19lb injectors or 24lb
  216. What heads for nitrous
  217. modifying crossmember for TKO. help!
  218. What type heads for a turbo kit?
  219. Head Studs for gt40 irons?
  220. AIR PUMP CONNECTIONS
  221. 88 coupe from computer car to 83 motor carb
  222. edelbrock intake gasket install..
  223. 24lb injector with stock fuel pump
  224. Voltage Regulator?
  225. cant hold idle after novi install & injector swap
  226. AOD to t5 swap question
  227. 4.6 vs 5.0 engine weights
  228. 1990 GT Fuel sending unit question
  229. Clueless Strut Question
  230. Carb or EFI
  231. No fuel pressure !?!?!?!?!?
  232. cam to 302
  233. Will 02 model seats bolt up in a 1998 model mustang
  234. 351w build up questions
  235. super coupe seats
  236. got code 98 on KOER test
  237. Strut Tower Help
  238. Lean + code 66 after "hot-pluggin" MAF
  239. Crap Ass Equal Lengths
  240. Hood Clearance at shock towers H&R with Bliltens
  241. Supercharger question??????
  242. Help, electrical something...
  243. 1985 T-top door panel???
  244. Battery Cable
  245. 87 mas air conversion
  246. auto to stick
  247. 5 lug conversion questions
  248. No start after T5 swap
  249. Strange popping after driving hard...
  250. custom chip to get rid of emissions
