PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254
  1. had my crank turned 10/10...what bearings do i need?
  2. Alignment after offset rack bushings??
  3. How street friendly is a cam with .542/.563 lift???
  4. 265/50/15 fit with quads?
  5. Cal induction hood shocks
  6. Tight Clutch/Cable
  7. Idle wont go below 1000rpm. Doesn't surge.
  8. interior conversion
  9. What do you use to clean your top with?
  10. New car No power
  11. adjustable fuel pressure question
  12. Any tips for axle housing removal?
  13. More 5 lug clarification
  14. stock air intake needed for a 91 mustang notch 5.0
  15. Both front calipers are locked up
  16. Sn95 120amp Alternator Upgrade ??
  17. loss of power after H/C/I install. need help
  18. Belt Question...
  19. Tips for buying used engine?
  20. forged 408 rotating kit
  21. Where can I find this part?
  22. what carb for this setup?
  23. 89 GT STOCK BODY COMPONENTS
  24. For those familiar with dry nitrous systems..
  25. surging, then stalls
  26. autometer temp gauge junk?
  27. Anderson N41 Cam
  28. school me on lifter pre-load and valve lash...
  29. Computer & gauge question
  30. stock gears mustang AOD 1987
  31. Head swap time! What am I forgetting?
  32. 390ci versus 460ci
  33. Compression Test Numbers
  34. Summit fuel injectors good to use?
  35. Front Sway Bar - Need help, plastic retainers on upper mounts broken
  36. really weird ignition control module the devils work?
  37. Valve HELP!!!!!!!
  38. Few quick things
  39. coil over kit
  40. Pulled codes need help!
  41. 86 Stang 5.0L running rich at idle....
  42. Noisy Fuel pump?
  43. Quick 5 lug question
  44. How to make a roller stock lifter a solid lifter for checking push rod length ?
  45. Piston ring gap positioning ?
  46. Roush 200r or Elelbrock heads?
  47. Rewiring Headlights To Only Work With Ignition On
  48. A/C hose
  49. Time to Upgrade Ignition?
  50. A/C and smog delete question.
  51. Weird Accident....Need Help With Repairs
  52. Just Dynoed, runs out of air @ 4650rpm!
  53. What intake for my 93 5.0
  54. 6g alternators
  55. Electric Fan Wiring
  56. Stupid question about air bag trouble codes
  57. noise
  58. More stopping power from svo brake set up??
  59. How high to rev your engine...
  60. how much more of a difference will front drags springs make?
  61. How to change rear main seal in 90 5.0
  62. mail order tune??
  63. goin to the junkyard tomorrow have some questions
  64. heavy duty world class t5 ??s
  65. Code 82.....voltage correct what next?
  66. running nitrous line from bottle
  67. what sensor is this?
  68. Weld Dragelite Lug Pattern?
  69. EGR - How does it work? Is mine broke?
  70. Picked up a cheap used block, few ?'s
  71. Timing belt cover cracks on 1990 5.0L
  72. Car wont stay running after TFS H/C/I install
  73. 2 quick problems
  74. No Hazards, blinkers or defrost.
  75. Overheating probs
  76. completely loose passenger strut, how?
  77. want to put 2005 fan in 1991 5.0
  78. Vaccum lines question.
  79. exhaust leaks
  80. gear change need help
  81. Thermostat Housing
  82. Subframe Connectors on Convertible??????????
  83. car will not run cool
  84. Sun Visors
  85. 351w foxbody longtube question
  86. HoooooooWeeeeee..the Merc...it's fixed
  87. Engine put back in. I forgot where some plugs go. Should be easy question
  88. Is my Belt too tight?
  89. Would a exhaust leak sound like ...
  90. Engine wont turn over HELP!
  91. 82 And 89 Water Pump The Same??
  92. new 1992 5.0lx need some advice
  93. Fuel sending unit.
  94. AOD "over drive" trouble-need advice
  95. any advise
  96. 91 5.0 GT FUEL PROBLEMS, PLEASE HELP!!!
  97. What's causing jerky acceleration?
  98. o2 senors and effects on the ecu?
  99. what speedo gear
  100. Wiring question???
  101. Running Lean
  102. dyno:(
  103. streched clutch cable?
  104. AOD won't go back in...
  105. Oil pan gaskets
  106. Opinions on setup, cam ,intake and heads...
  107. sn-95 5 lug conversion...which struts?
  108. Broke two lower intake bolts off into the block....what to do?
  109. hot or cold plug?
  110. making my own timing tape... increments???
  111. Eaton M90 on a fox?!?!
  112. Intalling Front Lower Control Arms...Tips?
  113. Stupid question about timing (new heads and intake)
  114. signal wire on o2
  115. 50oz imbalance flexplate question
  116. Tumbler or starter?
  117. Post your vaccum numbers. Do I have a vac leak?
  118. Water leak
  119. Anyone passed emissions with X pipe and Cats
  120. gt40p heads and tfs stage 1
  121. BiG PRoblem With COBRA INTAKE!HELP!
  122. Broken bolt in thermostat housing
  123. heads
  124. speed gear gurus
  125. vibration when shifting
  126. What Does This Code Mean?
  127. Wobble in front tires- steering rack??
  128. 351w heads ???
  129. Need comments please
  130. How to put 5.0 and Horse back on? Epoxy??
  131. 351W questions
  132. 5.0 to 5.8
  133. Tell me what you thing.... Any Paint Experience!! Would be Helpfull!!!
  134. v belt conversion kit
  135. Misfire/Detonation High RPM
  136. mass air meter size?? 75mm or 80mm
  137. No spark or fuel pressure?
  138. Computer
  139. Hatch Carpet...
  140. Heater Hoses
  141. vert guys--2 ?'s
  142. Thanks for the suggestions but, I remembered a real problem
  143. Quick! Timing HELP!!
  144. Burning Coolant?
  145. Anyone ever make a solid steering shaft?
  146. starter
  147. cant get stang out of gear
  148. how big of a cam
  149. mustang 5.0 relay
  150. silly question?
  151. T5 Clutch Fork Cover ?
  152. Need Help....Car Very Rich
  153. Electric cooling fan questions
  154. Exhaust mounting problems. need help
  155. HELP NEED HELP !!!
  156. Head question
  157. 85 CFI 5.0 throtle bracket & spring
  158. Trick Flow intake owners, I need your help
  159. Ignition switch
  160. ALTERNATOR PROBLEMS PLEASE HELP!!!
  161. TF Track Heat, 1.7RR & E303
  162. Inner tie rod questions
  163. Bypass jet for fuel reg on NOS sys?
  164. TAD/TAB Solenoid & Relay Package Price
  165. 347 stoker help
  166. t56 speedo
  167. Ground clearance mufflers.
  168. Reinstall steering shart...wheel is 180 degrees out!!!
  169. Radiator
  170. IAC and IAB
  171. A drip!!! Just Painted!! Anyone???
  172. cam help
  173. Nasty snot-substance buildup in intake! AAHH!!
  174. carb swap trouble
  175. Alternator ?
  176. need advice,clutch cable kit.
  177. Lowering Springs + 18's! Which springs for street? HELP
  178. Roller cam install q...
  179. Mix and Match Intake...
  180. Stumbling at WOT and above 2 grand...
  181. exhaust hanger
  182. HELP! Which heads (AFR 165's or Track Heat's)?
  183. Axle Dampeners
  184. Help from gurus re intake
  185. a/c controls gone, tach stops working..
  186. Trim removal around windshield and rear window??
  187. Which cylinders for EGT readings?
  188. Where to get fuel line clips?
  189. it's one thing after another...turning my crank
  190. Fuel Pump Noise (not a hum)
  191. Quick A/C question
  192. Tailpipe Comparisons
  193. Buying a Used Block I Have a Question
  194. Help with finding where a wire goes
  195. cobra intake vs tunnel ram EFI intake
  196. mid range
  197. Electric Fan alternator question
  198. Neutral Safety Switch?!
  199. window motor glitch
  200. carbed aod??
  201. Cheep fix, or gambling my life?
  202. New engine problems
  203. How do I keep factory oil pres and water temp guages when adding autometers...?
  204. gt40p head question
  205. EEC Wedgelock Pin
  206. I need help with Timing
  207. distributer
  208. Electrical
  209. Does the motor have to come out for oil pump replacement?
  210. March Power Pulleys. #1015. Good for STREET????
  211. where to get a dust boot/shield for rear shock?
  212. How to run cooler and why am I running hotter after heads?
  213. zoom clutch cables... and routing
  214. Electric help. please?
  215. Running like crap! Pulled codes. Got parts coming, but are they the right ones =)
  216. HELP WITH INSPECTION ? ASAP
  217. Front srpings, etc...
  218. Little Help Please
  219. O2 Sensor Hard Wire
  220. car won't start
  221. car stalls out
  222. 5 lug questions...did search
  223. ever see warped intake manifold??? stock one???
  224. PowerMaster Mastertorque Starter Install?
  225. Underdrive Pulley on Altenator?
  226. Shift Points & Max. Timing?
  227. no more running rich fixed
  228. Painting My 5.0 Vert.. What pressure ??
  229. Head gasket woes
  230. dome light & hatch light
  231. Passenger Door Help..... Any Help Much Appreciated...
  232. STARTING PROBLEMS
  233. 93 Vert. Quarter window.
  234. bad draw somewhere
  235. victor jr intake to much for 347
  236. Push rod size?
  237. Converting 5.0 to 4wheel disc questions!?
  238. Can't go full throttle.
  239. wheels for 5 lug 91 gt (Help need pics)
  240. O2 Sensors backwards
  241. tps voltage wire?
  242. brand new autometer tach is junk?!?!?!
  243. Smog pump problem HELP!
  244. Constant 12V Power Source
  245. vert top motor
  246. Roller Rocker Problems HELP
  247. Am I Rich Or Lean?
  248. Knockin cold
  249. When using a Trickflow Top End Kit
  250. Leaking coolant from water pump/ lower radiator hose connection
