PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254
  1. Car wont start
  2. Front Brakes???
  3. E3ZR-6394-AA T-5 bellhousing
  4. 1986 Alternator in 1985 Mustang?
  5. Stock lower intake manifold: Any way to improve?
  6. CLUTCH CABLE ADJUST
  7. need correct computer wiring
  8. BRAKE FLUID LEAK!! HELP
  9. Help...My friend's car just died on him..
  10. No headlights on 93 GT !
  11. rear gear install needs
  12. Intake removal...
  13. Climate controls
  14. Smog crossover question
  15. camber/cast issue after five lug swap?
  16. Suddenly throwing 33, 63, 87 and 96
  17. Let's talk Quad Shocks
  18. Overheating after gauge install
  19. Is there much difference in an Astro T5 or a Gforce T5?
  20. Engine Build Question
  21. weather stripping
  22. Slicks
  23. Rear End Lubrication
  24. mark 8 fan switch
  25. Quick injector question
  26. Quick question about setup, please help.
  27. Jacobs Nitrous Mastermind - need size
  28. amp light on, no charge
  29. 3.8L T5 to 5L T5 swap
  30. Computer Swap
  31. Help with Filing piston rings
  32. Thermactor?
  33. Clutch Help Anyone?
  34. Hooker Long Tubes....the secret to the passenger side?
  35. Explorer engine swap recon....
  36. Bolts for Engine Stand
  37. White smoke from tailpipes/ Please help/Running out of ideas
  38. Vortech installation problem
  39. 96 Explorer engine cam valve piston clearance
  40. Pcv valve and breathers
  41. EGR passageway in heads
  42. taillight ?
  43. PA Performance 3G Alt Noise
  44. 84 mustang wont start
  45. fuel pump
  46. Valve cover clearance ???
  47. What AN size is the Vortech oil feed line?
  48. vin
  49. A9p To a9l swap, wiring diagrams?
  50. Who knows about rod/piston/crank specs?
  51. Crank pulley question?
  52. installed new TB
  53. 89 overheating
  54. 3G Alternator Upgrade
  55. What injector size for my combo??
  56. Which Holley brand NOS jet size's = 100 shot?
  57. 90 Mustang 3-2 port p/v conversion questions
  58. Can hydroboost be used on a 5.0 engine?
  59. SN95 steering wheel on Fox tilt column
  60. ? on Autometer volt gauge install
  61. Air Fuel at Cruising, Light Load
  62. Pertronix Ignitor module
  63. 1.6 and 1.7 rockers ?
  64. Is carbs better?
  65. Baro sensor questions
  66. fuel pump
  67. Looking for a cam
  68. Aluminum Radiator install
  69. 86 Alternator In 85 Mustang
  70. 347/OBD1 issues. anyone?!
  71. pro-m maf question
  72. TKO 600 problems..
  73. Highest lift cam with stock E7's?
  74. engine miss fire?
  75. need help with codes
  76. What to look for when purchasing a used motor
  77. battery is not charging
  78. Aftermarket coil???
  79. Are the Ford Racing Plug Wires Solid Core?
  80. Choosing an Intake???
  81. alt. wont charge 500 ohm dash resistor?
  82. my 1991 mustang GT will not crank
  83. A/C Bracket Install
  84. Wierd connector - how to remove?
  85. Beeping under dash?
  86. Balancing my 347
  87. 1991 Mustang GT, Malfunction in Instrument Cluster
  88. which draglites to get?
  89. Autometer oil pressure gauge install
  90. battery location
  91. side skirt rivet replacement ?
  92. speedo gear help
  93. Speedo off
  94. Airbag clockspring part# or interchange list?
  95. T5 clutch fork wobble
  96. got it home now need help with codes, black smoke
  97. Advice on purchasing a used motor?
  98. Tips on Window Trim Removal
  99. MAF Meter electronics replacement....
  100. power steering leaking at rack.... need help on replacing "o" rings..
  101. 5.0 wont start
  102. convertible top frame - how to remove
  103. Misfire, spit and sputter at idle.
  104. HP Gain? Flex fan...
  105. t5 help
  106. need help
  107. NEED HELP!!!! Engine just developed bad Misfire!!!
  108. HELP CODE 92, how to test egr circuit?
  109. smog delete plugs??
  110. Brake Job, Stuck.
  111. Cylinder heads???
  112. maf swap ?s
  113. GT40 lower oil baffle, how do I remove it?
  114. Took smog equipment off - What belt do I need?
  115. Oil in coolant?
  116. 357W CAM CHOICES!! Good brands and kinds!?
  117. shift light
  118. edelbrock rpm II or GT40 intake on modded 302??HELP!!!
  119. what bolt sizes?
  120. WHat size is the fuel tubing in an '88 5.0?
  121. will 91 egr fit an 88??????
  122. Did i blow my amp?
  123. Coolant Ports??
  124. Moroso Electric Drive water pump...How do they work???
  125. vac lines
  126. How To Request: 300whp na on a 306
  127. Need help ASAP before i burn this car...
  128. twEECer tuners in South Denver area?
  129. Sloppy Steering - Need Advice
  130. 65 Mustang question, hope this is ok!
  131. How many oil changes after head gasket install??
  132. Wheel Replicas Saleen SC center cap
  133. Oil pressure drops @ W.O.T
  134. Throttle body stuck!
  135. First thoughts on completed Strange coilover setup
  136. Quick Tweecer Question
  137. Best chip/tuner for modded 91
  138. EFI To Carb Conversion
  139. Electrical problem ??
  140. Spark gap and spark plug
  141. Tuning help needed
  142. 351W swap headers necessary?
  143. How do I tell what gears I have?
  144. Coolant Leak from the firewall... not the heater core.
  145. Removing P/S pump, sealing rack...
  146. clean plugs bad?
  147. injector size?
  148. It all adds up!
  149. 91 Mustang GT, Crack on Sideskirts
  150. code 67????
  151. EGR VALVE
  152. Can't find a code list, trouble codes, running rich.
  153. Flat tappet cam in a roller block?
  154. Question about 3" pipes
  155. 94 5.0 C/S Underdrive pulley same as...
  156. Timing keeps resetting
  157. hesitation backfiring
  158. stalling problems
  159. drag radial question
  160. custom cai
  161. Which injector size
  162. 5.0 oil pan gasket
  163. Clutch adjustment problem!!
  164. noob fuel pump/injector question
  165. oil pressure
  166. Where to buy a new stock HO cam?
  167. '94 5.0... are pistons forged or caste?
  168. what would happen if........
  169. someone please explain the difference between "draw-thru" and "blow-thru" meters
  170. How many bolts go through water jacket into block-WATER PUMP!!!!
  171. Have horrible squeal at start up after heads and intake?
  172. oil pan bolts
  173. electric fan relay
  174. Dumping codes on 87 wiring harness with mass air conv.,no engine light?
  175. Sputtering thruout entire rpms
  176. Long Instructions for Convertible top Install
  177. what size pulley would give Vortech 11 lbs of boost
  178. quick exhaust question
  179. E85 Bible
  180. 3G not charging, alternator is good, few questions.
  181. clutch diameter for an 87 w/ TKO
  182. Cam Help
  183. air pump delete ?
  184. What will stock fuel pump do on 400hp stroker?
  185. a/c giving me fits!
  186. fuel injector rebuild
  187. 93 supercharged tuning??
  188. 2.02" or 1.90" valve for street stroker
  189. Really need help here...
  190. gt40x power increase and Q's ?
  191. EGR question?
  192. Explorer EGR Valve
  193. How to adjust a TPS?
  194. Water pump bolts TQ???
  195. Slit hisitation in throttle response?
  196. Underhood Cleanup
  197. Underhood Cleanup
  198. Water pumps - how to tell one from the other?
  199. fuel injector leak
  200. 5.0 87 stang issues 5spd help!!!
  201. Slow to Start
  202. 331 Short block
  203. I have no luck...
  204. no fire on carb 89
  205. Cooling problems
  206. Pulled Codes and got a 21 and 94?
  207. t-top keys?
  208. Trouble code 53
  209. eec extension harness?
  210. boost gauges
  211. What efi intake for ex carbed Canfield 195/Jay Allen Cam setup?
  212. 351W carbed, nitrous engine tune questions..
  213. Engine builders/Machinist, got a cylender surface Q
  214. Want to Add A/C back, Parts list?
  215. 1 3/4" vs. 1 5/8" long tubes
  216. sn95 radiator fit in fox
  217. engine management system
  218. koeo test problem
  219. List for an AOD to T5 swap?
  220. 1993 mustang power steering rack
  221. What radiator are you running with your DCC Controllers?
  222. 5 angle valve job
  223. Fuel Pump Help Needed
  224. 84lx 351w swap
  225. Which type/size headers do I need?
  226. alternator wiring issues???
  227. How to replace starter?
  228. Which TCI converter for E-cam?
  229. How to replace ignition-key cylidner?
  230. relocating battery....
  231. does arp make header bolts?
  232. Which way to run drill to prime oil system?
  233. alternator question
  234. T5 swap question-what are the two bolts I need from the hardware store?
  235. HELP need pic of brake light switch!
  236. Vacuum Question (Pic inside)
  237. what headers?
  238. Explorer intake on 93 GT
  239. Deleting Smog and A/C kit?
  240. slight cooling issues and how to tell if fan clutch is bad?
  241. twisted wedge removal & reinstall???s
  242. Need help deciding what computers will work w/ my car
  243. Compressor High Side! Help!
  244. GT-40 HEads?
  245. What would cause an 89 gt to die while driving
  246. Hanging idle question??
  247. GATORBACK BELTS DO THE TRICK!!
  248. Rockers
  249. rear brakes get stuck
  250. Cylinder Head Installation Tech 347 Trick Flow
