PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254
  1. Reverse Grind
  2. Distributor gear Q
  3. Help with FRPP heads/Roller Rockers
  4. 190lph fuel pump good for around 280fwhp?
  5. 351w Crankshaft Measurements?
  6. Swap and port
  7. Please help, egr solenoid vacume
  8. Proper fuel upgrade for supercharger?
  9. compression stock engine 5.0L
  10. What transmission crossmember is this? Pic inside! Are 4 cylinder and V8 the same?
  11. what in thee helll bobby???? (comp)
  12. Tranny
  13. new place to get electric fan
  14. 2 quick electrical questions (MSD 6al box, tfi coil)
  15. 289 Roller retrofit
  16. Torque specs and sequence for GT40 Explorer Upper intake?
  17. Spark plug Question???
  18. *Engine won't run right since head install, please help!!!
  19. gotta have my cruise!
  20. It's Alive ( barely )
  21. Rack and Pinion questions
  22. window wiring
  23. 3g set up starting to have problems
  24. Power steering pressure line help!
  25. wireing problem in the steering colomn
  26. pushrod length checker
  27. Anyone have a no-start/battery problem after Grant steering wheel?
  28. Autometer electric oil pressure and water temp gauge issues.
  29. Duraspark box: When powered up, should case be HOT?
  30. F4SF MAF
  31. codes pulled now what do they mean
  32. 86 5.0L dangers with E7 heads?
  33. Do I need to use friction modifier if I use Royal Purple Synthetic Gear Lube?
  34. Tank wont go bolt up properly...
  35. cruise control ????
  36. misfire under load
  37. Help me calculate my compression ratio!
  38. Whats the best...
  39. FRPP SPRING HELP OR HURT BUMP-STEER
  40. Cranking Problems !
  41. replacing covertible top
  42. Car wont start: used some of the check list already
  43. Fuel pressure regulator location...
  44. Tires rubbing, please help
  45. Supercharger Help
  46. Car just up and died! Need help
  47. Spark plug wires, what is the difference.
  48. fuel line disconnect tool
  49. Mini Tub a Vert
  50. Update With Fuel Issue
  51. cobra inake and 351w
  52. Oil filter
  53. Need Help Please
  54. P to V clearance
  55. Flat spot in new tires after emergency skid?
  56. computer codes mustang 1987
  57. Voltage Regulator Wires on Alternator
  58. Best way to reduce body roll
  59. Got a code question for yall like everybody else
  60. 96 Explorer 5.0 Engine?
  61. 3g Help (im a retard)
  62. please help
  63. Quickie Help- removing spindles
  64. Symptoms of stuck injectors
  65. belt tensioner stripped.
  66. 5 Litre Computer, Manual vs Automatic
  67. Axle Question
  68. IAC Spacer kit?
  69. Pulled Codes and have questions.
  70. mounting nitrous solenoids 89 LX 5.0
  71. Still having starting issues?
  72. coolant system pressure
  73. Need HELP Guys!
  74. 5.0l maf & cam advice
  75. spark plug gap with nitrous?
  76. sparkplug help
  77. Intermittent turn signal switch - causes?
  78. Oil Pressure and Water Temp. gauge installation q's
  79. Do they make stronger dog bones and a stronger spider?
  80. C-4 questions.
  81. computers
  82. Are stock lifters good for 400 plus hp?
  83. valve spring shim help........
  84. Those who are using Trick Flow Tall Valve Covers
  85. wheel and brake issues
  86. loose rocker arms cause a sputter?
  87. ALUMINUM RADIATOR REPAIR-aNyone????
  88. spyder intake question
  89. Timing issue
  90. correct u-joint?
  91. Help to indentify these springs!
  92. Warm idle sporratic behavior
  93. HUGE Problem!!! Need help.
  94. ever seen pink spark plugs??????
  95. vibration @ 2300-2500 in EVERY gear except Neutral??
  96. White smoke at idle. Help!
  97. Car dying in 4th Gear
  98. Random Power Loss at Highway Speeds
  99. gt-40 or gt-40p heads
  100. H/C/I Vortech wont run well
  101. Car wont start!! Help!!!
  102. Interior ?s
  103. 89-LX Fuel pump keeps running with Key out of Ignition... Need Help
  104. 351w oil pump?
  105. 351w oil pump drive shaft? witch too get?
  106. Comp Cams question
  107. EASY CONTROL ARM ?
  108. 17 Year Old Spark Plugs, Wires, Cap & Rotor?????????????????
  109. Burning clutch
  110. SMog Equipment.. FMS Throttle Body
  111. ???~Thickness of Ford raciung Aluminum rad???
  112. T5 experts...come in,
  113. 1989 5.0 Engine 218,000 miles
  114. Check oil light!!!! Please help
  115. smoke out left tailpipe once in a while??
  116. running lean
  117. MSD wires long enough?
  118. Code 66 how to test a Maf?
  119. Tweecer owners Please Come In.
  120. Just some info on an idle problem.
  121. ? paxton novi 1000
  122. A couple questions about crankcase pressure...come in!
  123. help with my sunroof
  124. spedocable...
  125. A9L computer ???
  126. Maximum compression on pump gas?
  127. x3z comp
  128. harmonic balencer
  129. rear brakes
  130. Afco Radiator? Need some one that runs it
  131. HOW TO TEST HEATER CORE FOR LEAKS???
  132. A little help needed
  133. Can anyone Identify this two connections??
  134. Same rocker keeps coming loose?
  135. quick question about lifter preload
  136. Backfiring when cold!
  137. Strange intermittent exhaust popping.
  138. Possible tranny problem?
  139. CAM PLACEMENT???
  140. FWA brass piece. Do i need it? (Pic)
  141. How much lift?
  142. Performance Automatic Valve Body Pattern
  143. Hard START after warm up!!
  144. Cracked block/blown head gasget? Tech help!!
  145. Can I use linked roller lifters with an FTI cam?
  146. Stuck blower pulley?
  147. CRANK CLEARANCE!!!
  148. Engine Stays Running After Key Off..
  149. DONT BUY CHEAP ROLLER ROCKERS!...Here's Why..(pics)
  150. brake conversion
  151. plugs for smog ports in back of cylinder head...
  152. Need info
  153. MAF computer
  154. maf conversion = bogging
  155. wilwood Brake line question
  156. Power Steering problem suggestions wanted
  157. Convertable Top help......
  158. G-force break-in?
  159. t 5
  160. anyone have/had t5 leaking problems out of the vent?
  161. Which Flowmasters?
  162. Need Belt Size No A/C No Smog
  163. Best Edelbrock Intake??
  164. Please read guys tell me your opinion.
  165. Bottom 2 Tranny Dust Cover Bolt Size?
  166. Power some times then a little less others
  167. some help for people with idle/rich/power
  168. engine problems need help
  169. Anybody get horrible driveability for about 30 seconds after a cold start?
  170. Engine giving me codes
  171. Help with nitrous
  172. T-5 Shifter Bolt Torque Specs
  173. Hesitation at WOT; Backfiring, TFI Module? Tried everything!!
  174. Where is the ground wire?
  175. Battery dead...
  176. Weird idle miss !! Please help
  177. Clutch Cable
  178. Adding NOS to nearly stock set up.
  179. E6SE
  180. Will BBK Shortys Work For 351 Swap?? Or Do I Need Special Headers?
  181. Cam choice
  182. Last Error Code .. Need Help Please!!!
  183. No Fuel Pump Relay on 4 Banger?
  184. Overdrive Pulley... Belt Tensioner.. Help?
  185. K&N Filter Size Stock AIr Box
  186. Cowl Gauge Concepts cowl w/steeda hood
  187. Drivetrain Bucking and Lurching.... ???
  188. nhra roll cage installation
  189. Quick question about adjusting firewall adjuster
  190. I need some help please.
  191. Slight mess-up with a 393 build...question for people who build a lot of motors
  192. 351 Oil pump
  193. Hissing from under dash while applying brakes?
  194. 351 alternator wiring
  195. Firewall hole
  196. bad vibration
  197. bad vibration
  198. Timing chain cover?
  199. Calling all guys who have rebuilt there trac loc
  200. need help with dccontrol fan.
  201. Crane stud conversion kits
  202. injector ?
  203. 91 LX Bumper Cover
  204. Need some quick sizes of bolts: Transmission bellhousing, pressure plate, flywheel..
  205. what injectors are these?
  206. Bought 89 LX Mustang
  207. how do i check tps
  208. Cubic inch Questions...
  209. 94 t-5 still the same as a 87-93
  210. Bending Urethane Bumper Back
  211. Offroad mac pro chamber and emissions???
  212. Wiring Taurus Alternator In HELP
  213. Steal throw-out bearing retainer
  214. Need steering interlock help
  215. Coolant in throttle body?
  216. 1989 Stang 5.0 - sputters while accelerating
  217. valvetrain troubles
  218. Mysterious drop in oil pressure
  219. 1988 GT - Clearing codes
  220. jrichker another fuel pump question
  221. I need help!, O2 sensor won't come off
  222. spark plugs are white
  223. 10.5" Wheels on a Fox is it Possible?
  224. EGR Valve
  225. Fuel line disconnect tool?
  226. Inline fuse question...
  227. 429 or 302
  228. 351W Swap Header Questions
  229. Hatch Issues
  230. ordering new struts and shocks soon. help with springs
  231. Can I use a reverse water pump with only an alternator?
  232. Car still bucking
  233. Bent Quad shock
  234. Is a Thunderbird Supercoupe AOD the same as a 5.0 AOD?
  235. Wiring a heater box from scratch. I dont have any oem plugs....I need some plug diags
  236. piston/wall clearance
  237. How do I make these fit!!!
  238. wheels for cobra brake uprgrade on 87 gt
  239. Oh crap, leaking coolant
  240. clunking noise
  241. p/v clearance? non-ho 5.0
  242. conflicting cam information
  243. Fox 4 lug to 5 lug, stock axle length
  244. Shoudn't the car die when...
  245. Balancer outter ring slipped...
  246. poss clutch problem
  247. Is more timing necessarily better for my combo?
  248. Fresh AOD...have PROBLEMS, CAN ANYONE HELP!?!
  249. Crossmember brackets
  250. What do I do next? what would you do?
