View Full Version : 5.0 Tech
- What distributors are these? E9AE part no on one, pics inside!
- Anyone ever go from Shorties to LT and notice a diff?
- Stall Size
- Should I have more Power?
- viper spec t56 mac prochamber fit?
- 351w H/C/I....kenne bell?
- Explain the different cams
- FoxBody 10" tire Offsets
- oil pump shaft washer came off
- Use head gasket when checking piston to valve?
- Ticking?
- Ticking once warmed up (not header gasket)
- Pros and Cons of a 393 stroker
- Idle Problems... HELP!
- 89 5.0 timing issues
- Trying to figure out this exhaust
- plastic gauge questions
- eec in a a 94 gt
- thought it may be a fuse...
- Help
- Is there anyway to increase horsepower cheap?
- Rear Suspension Question
- time for tko. D&D perf. OR Hanlon motorsports?
- Is it valve float? Rev Limiter?
- Sparkplug Question.
- console bolts?
- Temp Guage
- clutch pedal way to high
- Smog Pump Question
- Problems with my 87' GT
- Valve Cover Questions
- 17"X10.5" on a notch
- can someone please recommend ARP timing cover bolt set?
- How thick of a head gasket will drop 1/2 point?
- Motor Mounts for Vert
- Shifter Bushing.
- Steeda offset Control Arm Bushings
- Tps setting from .75 to .96ish
- HELP!!!
- need some help act sensor explorer manifold
- What basic mods Can I make?
- School me on Torque boxes
- Tranny goes into gear VERY hard?!?!
- 302 dart block
- Air bag light flashing?
- T-5 rebuild , basic ?'s
- show your gauge mounting
- Exhaust opinion
- All Metal Body Filler/Engine bay detailing. Help!
- What does this coolant hose do?
- Trans question ...
- problem with 4th gear
- Horn
- Pilot bearing
- MAF Problem?
- Help! trans problems
- Head Torque Question
- Charcoal Canister Question.... Can someone with a mustang do me a favour...
- 10 HOLE TIRES.
- help with passenger window
- Port lower intake?
- tick tick boom
- Vacuum Lines Question......
- Overheat.....problem....
- Phantom II by Autometer
- Roller Rockers...Worth it?
- Rough Idle, Misfiring and bucking...
- Timing??? What degrees should it be set at...???
- Need help with wiring
- help me decide on this intake
- Real world costs of a 408 stroker
- 5.8 H.O. rebuild kit?
- Car stumbles and dies at high RPM
- 5.0 Rebuild
- how to remove the black t-handle on a 90 automatic
- Time to buy Gears , Again need tips
- How can i make a ford 289--427 motor push 10,000+rpm?
- Foxbody Steering Column Rubbing Headers
- Plug.... what is it for.... and tps question
- Knocking! Help!
- 19 LB COBRA MAF/smog
- How do I leave the line straight?
- Clearing Computer?
- How warm do you run?
- Cobra Caliper Questions - Urgent!
- S/C Question
- 347 Guys.. Need help on parts...
- Installing New Injector Clip
- 87 mustang help
- MAP sensor
- Edelbrock 5.0 performer intake manifold
- Factory tach has a mind of it's own
- Does size really matter???
- Help please - fuel issue
- Hitting up the JY
- SCT maf
- Stock pushrods good for this set up?
- Compression Question
- Clunk when warm, internal tranny problem?
- no zero on balancer for timing???
- Paxton horsepower!!!!!!
- TrickFlow Top-End Question
- I need help
- What cam do I have?
- tps
- need help deciphering codes
- shocks and struts
- Clutch is givin me greif
- throttle cable clearence with valve covers
- Finally got it running, but won't run under load..
- Finished the 302ci hear it roooaaarrr!!!
- Reardrums to disks with 4 holes
- Commonly asked ? The answer
- Way TOOO much timing???????
- headlight fitment problem
- how about nitto's?
- more RPMS?
- JUNKYARD GURU'S!!
- 94/95 MAF
- Lowering Springs
- Maximum Motorsports LCA's
- Desperately Need FP Help
- Whats The Thread Size Of The ACT Sensor
- Should I buy a trick flow intake...
- 79 Mustang Gas Tank & Sending Unit
- 88 Mustang Electrical
- cold air popping
- header won't go in!
- Tailpipes crooked!
- egr how important is it
- Cam degree
- Ported heads
- 4 cyl conversion fuel pump problem..
- what do i need to rebuild my tranny?
- stock dizzy gear with msd pro billet dizzy?
- Granatelli MAF Problems
- help to ID a Lunati 5.0 cam
- Newbie here with some questions
- Anyone want to discuss throttle bodies? Is bigger better?
- supercharger for 1965 289
- Wrong place to jack a Fox body from
- Will this X pipe fit?
- Fog Light ReWire... Help!
- What lines can go
- Is there any truth to something like this?
- heat spacers worth it?
- whats a good way to clean fuel injectors?
- How Does a Carb. Ignition System Work?
- H/C/I whistle with Systemax intake
- is this possible?
- HCI complete - car won't run - please help
- how many hp?
- Rear Bumper Question
- fuel pressure what to high or low??
- little question about pushrods?
- Painting the car question
- stock oil dipstick hole
- frozen uca bolts
- Cant find a 150a fuse for 3g
- code 32
- how do the MT ET streets act?
- Fuel pump dead!
- Quick Intake Install Question
- Oil in manifold
- 4cyl A/C fit on a 351W?
- What Lug Nuts?
- ordered roll cage , any helpful tips ?
- Fuel pressure too high?
- Best Rear End Gear Oil
- When i swap shortblocks, What should i do? any ideas?
- a/c delete question (vac line)
- Wiper problem
- A/C wiring expert needed: replacement WOT A/C relay socket wiring question
- spark plug wires
- hooking up your airbag(suspension)
- what size pushrods to buy for Coast 306/Thumper?
- Pictures of pistons
- Got the 347 running have 1 problem!!!!
- Fog Lights
- fuel pump wiring help!
- 331ci AFR185's x303 now what intake?
- Throttle Body Question 65 vs 70
- Urgent Distributor Help Needed!!!!
- Error Codes..... idle.... tps... idle air control
- repo sunroof weatherstrip
- paxton 1000 crank pulley
- Can my setup handle any nitrous??
- pulling to the right
- SHIMM THE EGR???
- Fuel injectors how to test
- What chip or programmer should I get
- Please Help!!!! Stuck!!! Problems!!!!!
- Installing Explorer intake?
- Why you should check your new pushrods
- Rear end noise
- EFI swap to Carb.....
- Tweecer...........
- This one's for Jrichker, too!
- Running Radials With Regular Bias Tires?
- ? about Ohms & EEC
- sn95 e-fan in a Fox?
- Please read!!!!! Engine running kinda rough!!!
- Front wheel bearings
- question about vacuum lines
- Removing front seats...
- Anyone wanna help me figure out why my car wont start when hot
- Oiling Questions
- Idle problems?
- Transmission install writeup?
- Need some wheel help, done the search
- ? for Jrichker
- Alignment Done Today, New Problems And Bent Frontend?? HELP!!
- Pic of ground strap. Please help!!!!
- Whose exhaust?
- Swapping from E6SE heads to GT40 irons
- ok, got me a 93 T-bird ho motor.. questions!
- Typhoon vacuum questions!!
- 91 LX build. Any thoughts?
- Quick! Disconnecting high pressure hose from the steering rack
- Roush Alt. Bracket
- Electric fan keeps blowing fuses
- miss under loads
- Fuel wont go in when pumping gas?
- 94/95 Cobra MAF
- what kind of 28oz flywheel & balancer to buy
- 1986 Mustang with 135 Amp Boss alternator and Amp meter?
- Water Spots from Exhaust
- A/C Blowoff
- heater hoses for non-a/c cars?
- Electrical Schemetics/Diagrams
- Help with speedo issue
- Which MAF sensor do I need
- rear rebuilders or rear gurus help please
- AOD Vs. C4. Do the Pro's out weigh the Cons?
- Fuel mixing with oil
- FUEL FOR THE FIRE
- PCV Setup/Deletion(for those w/ Victor EFI intakes)
- Ordered a new 347 shortblock, need bigger injectors?
- What does the Idle Air Adjustment plate do exactly???
- 86 gt to mass air problems
- Annoying Noise in Driver Side Front Tire
- Spark Plug Gap On Supercharged Mustang
- Gauges not functioning right.
- Annoying fuel pump....
- No turn signals
- NEED HELP BAD
- loud sqeaking noise
- How do you wire a three prong, lighted, toggle switch?
- what spark plug gap
