View Full Version : 5.0 Tech
- Chip or Tune?
- smog pump delete question
- A couple of questions.
- My Electrical System is Disintegrating !
- what springs, shocks and struts
- Coolant Falling from the Sky?
- Question about Eibach drag launch springs?
- ? about off-road h-pipe
- which head bolts/studs need thread sealant?
- 302 help
- fuel pressure question
- My cars finally goin under the knife, need some advice!
- Solenoid wiring schematic
- Driveline Vibes Question
- still got the miss
- Rearend rattle when braking
- Need Fuel Line Fitting Sizing on 89 GT
- Injector cap down combustion chamber
- Need to clean up the AC compressor
- Is there a smaller dust cap for stock 4 lug hubs
- What's going on with memory?
- New valve springs, B303 Vs. E303
- GEAR DRIVE? YES OR NO YOUR THOUGHS
- Just finished installing Dynomax Race Bullets
- Help with engine codes
- How far can I take a speed density car?
- '86 GT isn't starting...
- Changed fuel pump now car won't start?
- When to upgrade the stock fuel system?
- School The Noob on Building A 306
- Anybody ever seen one of these before??
- gt 40p heads, e-303< speed density?
- Edelbrock performer 5.0 lower/head gasket?
- so are stock tachs usually off?
- egr question need help
- Angry, frustrated depressed, please help me. (t5 related)
- Nitrous experts, I have questions/need help.
- dash swap
- S/D and bigger cam
- w/p pulley (elec fan setup)
- TW heads and valvetrain
- need help picking out springs
- Bad Catalytic Converter?
- valve spring replacement
- Injector question
- Proform elec fan pics
- i pulled engine trouble codes.. what next?
- HELP WITH VACUUM LINES!!!!!
- valve springs differn't cam
- Fuel Pressure Question
- Adjusting throttle cable?
- Crane Hi-6 or Ign Problems please help anyone have these problems thanks
- how do I tap into negative coil wire for tach signal?
- 3" Wheel Studs ??
- fuel pump what size
- Feels like I am hitting the Rev Limiter to early?
- Trick flow stage 1 cam
- Ford Racing 5-Lug Conversion...Pros & Cons?
- Tremec 3550?
- Will dumps pass state inspection in TX?
- 4 cyl spings good for the track?
- Tranny help
- engine mount to engine, bolt removal *help*
- P/S Pump prob.....
- Roush 200 heads
- Adjusting lifters - TDC? Help!
- 2pt vs 4pt k member brace
- No luck with "crank but no start checklist"
- Intake poping
- Adjustable Pushrod
- can any one help? super rich
- tremec tko 500 @ longtube question
- 4 cyl to fi 5.0 swap
- clutch replacement checklist
- New Guy with 93 LX vert with some??
- I have a homeless plug....
- BBK INTAKE ON 5.0 ?
- valves hanging open
- Are FMU's Safe?
- steering rack
- twisted wedge heads valve covers
- Starting Problem
- Wiring Question -- Which Wire?
- 00 axle
- 5 lug conversion on a 86
- suspension on 90gt
- header collector gaskets... help!
- Dizzy newb! Whats wrong here? w/ pic
- Vacum question
- Baseball card in bike spokes sound
- idle issue
- anyone have their headers jet-hot coated?
- help me identify this fuel pump?
- Fuel injector leak! Help.
- question on hard starts and egr valve
- identify these Canfield heads: 20-450-58-0
- Lowering Springs, 5-lug and noise questions?
- What did I do???? Long post
- bad sqealing sound from motor..
- 400m?
- 2 questions, oil pan and pulley options
- pushrods
- wheres the air charge sensor
- engine troubles
- can anyone help me out?
- 5 lug rotors or go all out
- I will pump you up (fuel pump issue)
- Spring install on good friday - compressor recomindatins?
- best heads for the money?
- Bought the new 89 fox
- some advice for a young mustang fan
- S/D 24lb UPGRADE??
- Pushrod measuring tool??
- 347 injetcor??
- Advancing a 302HO camshaft 4* using the .006 valve events
- rod bolts
- Any one with long tube headers and t56?
- Autometer question - opinions needed
- t-5 question...
- Head bolts leaking coolant!!!!
- Help me out with clutch release bearing
- What kind of bypass do you BOOSTED guys use?
- convertible seatbelt question
- NITROUS PLATE HP QUESTION?
- Scatter Proof Bell housing Installation??
- lakewood driveshaft loop
- serpentine belt???
- Question about this windage tray
- TFS Top End Kit Owners Come in...
- BBK adjustable fuel pressure regulator
- 13* w/o spout, jumps to 30-35 with spout.
- copper header gasket shoulder
- Cracked Intake? Fuel in EGR?
- FMS part #
- mustang injectors
- whats wrong with my car!
- Some Electrical Problems
- fuel injection or carb
- Pilot Bearing...
- eec problems
- getting a clutch kit, Slippage with vidio feed me info
- steeda quadrant and stock cable
- Stock Air Box Vs. Conical Filter
- The ol' AOD
- Is this normal....
- Still milky oil problem
- running and now a lifter noise need advice???
- Camshaft timing dilemma...
- 88 sable 3.0( off topic) but need help
- tokico shocks/struts and help with install.
- exhaust idea??
- Intercooler tubing?
- HELP ME TRANNY!
- TPS Voltage Readings
- Bad lower gt40 intake
- Valley Mustang Club Car Show
- What is your diagnosis?
- Cleaning a shortblock
- Installing Race BUllets with clamps
- Firing order
- 1987 LX 5.0 Firing Order
- switching supercharger to 408
- Collector Thread bolt size???
- clutch cable question
- tko question
- Head gaskets
- explorer intake coolant question
- any easy way to change trans lines with motor still in car???
- What should my times be
- Removing a 1990 front bumper and side moldings
- Coolant sensor
- No idle, knockin, hot engine WTF!!!
- Power Loss and Weird noise
- Code 95 Secondary Fuel Pump Circuit Failure
- Fox body question
- The time has come...
- 331 stroker victor jr heads?
- Installing MAC cat-back...
- Alternator Questions...
- Bad struts? Need some advice/help
- Spin-Tech Sportsman Street Mufflers?
- 92 Mustang LX Rear question
- Beware of Advance Auto Parts Battery cables
- 4 cyl. springs
- What distributors are these? E9AE part no on one, pics inside!
- Anyone ever go from Shorties to LT and notice a diff?
- Stall Size
- Should I have more Power?
- viper spec t56 mac prochamber fit?
- 351w H/C/I....kenne bell?
- Explain the different cams
- FoxBody 10" tire Offsets
- oil pump shaft washer came off
- Use head gasket when checking piston to valve?
- Ticking?
- Ticking once warmed up (not header gasket)
- Pros and Cons of a 393 stroker
- Idle Problems... HELP!
- 89 5.0 timing issues
- Trying to figure out this exhaust
- plastic gauge questions
- eec in a a 94 gt
- thought it may be a fuse...
- Help
- Is there anyway to increase horsepower cheap?
- Rear Suspension Question
- time for tko. D&D perf. OR Hanlon motorsports?
- Is it valve float? Rev Limiter?
- Sparkplug Question.
- console bolts?
- Temp Guage
- clutch pedal way to high
- Smog Pump Question
- Problems with my 87' GT
- Valve Cover Questions
- 17"X10.5" on a notch
- can someone please recommend ARP timing cover bolt set?
- How thick of a head gasket will drop 1/2 point?
- Motor Mounts for Vert
- Shifter Bushing.
- Steeda offset Control Arm Bushings
- Tps setting from .75 to .96ish
- HELP!!!
- need some help act sensor explorer manifold
- What basic mods Can I make?
- School me on Torque boxes
- Tranny goes into gear VERY hard?!?!
- 302 dart block
- Air bag light flashing?
- T-5 rebuild , basic ?'s
- show your gauge mounting
- Exhaust opinion
- All Metal Body Filler/Engine bay detailing. Help!
- What does this coolant hose do?
- Trans question ...
- problem with 4th gear
- Horn
- Pilot bearing
- MAF Problem?
- Help! trans problems
- Head Torque Question
- Charcoal Canister Question.... Can someone with a mustang do me a favour...
- 10 HOLE TIRES.
- help with passenger window
- Port lower intake?
- tick tick boom
- Vacuum Lines Question......
- Overheat.....problem....
- Phantom II by Autometer
- Roller Rockers...Worth it?
