PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 [49] 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. So confussed
  2. Oil primeing tool
  3. replacement fog lights on cobra?
  4. options to get compression up on 91 block w/ 66 cc heads
  5. fuel relay 87 lx
  6. Why does my LMAF only have 4 pins?
  7. reverse light switch
  8. Wierd Vibration
  9. Going nuts and bolts! help
  10. What could be wrong with my brakes?
  11. which cam???
  12. pushrod length ?
  13. Converting a 1990 4 banger...quick question
  14. sfi?
  15. Tilt Steering Column swap???
  16. Tilt Steering Column swap???
  17. Where to start with these codes...?
  18. HELP! Popping through intake? Backfiring when shifting?!
  19. couple of questions
  20. rear defroster contact soldering
  21. Carb Tuning & Ignition Situation
  22. C-4 OR 5.O
  23. how hard to take off fender
  24. need information on exhaust
  25. 5.0 Fuel press regulator
  26. Car short circuiting ? Please Help.
  27. QUICK MAF-Injector Question
  28. Exhaust tip smokes after car is turned off?
  29. Simple engine R&R question?
  30. Right blinked and right brake light wont work
  31. E Fan Controllers
  32. Slow cranking
  33. Kenny Brown Lower Chassis Brace ? ?
  34. tps sensor question
  35. piston to valve clearance
  36. 96 gt spindles????
  37. 393 600HP?
  38. EFI to Carb....what kind???...intake??
  39. Fuel pressure drops when I give it gas! Why? Okay?
  40. 351W hydraulic or mechanical flat tappet cam?
  41. Have some drivability issues.
  42. AOD shifts into high too quick
  43. valve size on stock heads?
  44. motor blown, need a new one questions.
  45. tko problems... or clutch problems...
  46. low end lag after H/C/I
  47. Mechanical Gauges?
  48. What is this? -->Pic<-- Can I remove it??
  49. What do you guys think?
  50. head bolt question?
  51. 408W injected or carb?
  52. Leaky sunroof fix? (Surprise!)
  53. duraspark II question
  54. Little wheel help
  55. Where to buy?
  56. 4 cylinder to 5.0 litre
  57. safe @ 6,500 rpm?
  58. T5 Workshop Book??
  59. witch brake master clynder
  60. strange noise comming from the motor
  61. Autofab Coil Over Kit??
  62. poly motor mount ?
  63. cam option
  64. H/C/I Combo...what else will I need?
  65. ford racing 5 lug front conversion?
  66. a few questions about rollcages
  67. engine rebuild sensors and what not?
  68. Help me decide on heads
  69. 17x9.5 possible on front of Fox body?
  70. URGENT!! Spring HELP??
  71. Nodular cast iron or forged camshafts
  72. deleted
  73. 370hpMotor=?hp to the wheels and combo questions
  74. 370hpMotor=?hp to the wheels and combo questions
  75. 351w lifter ?
  76. Front control arms stuck
  77. Rear spring removal
  78. FPS built 360ci.
  79. draglite tire help!!
  80. How do I reattach the roof rail?
  81. equal length shorty headers
  82. Twisted Frame/body??
  83. Who here is running a H/C/I car untuned...Successfully?
  84. Stock spring rates? help
  85. clutch fork?!
  86. Timing My 302
  87. t5 to c4 swap know car want start
  88. 5LUG SAWP HELP!?!?!?!?
  89. arizona 5.0 swap
  90. duralast water pumps-anyone? ???
  91. NEW Headlights and Harness??
  92. Gearbox Numbers? HELP??
  93. Need help with fuel lines!!!
  94. Worth getting MM UCA's?
  95. Cold air blowing on passenger floor
  96. Crank but no start problem...
  97. Installing a/c delete bracket.
  98. Edelbrock Head Selection
  99. need some shifter help
  100. anyone run a MSD 6AL with a blaster 2 coil?
  101. need cam info
  102. What rods do I have
  103. Need help ID'ing and Intake Manifold
  104. 302 issues
  105. 1989 mustang engine harness schematic
  106. 17 inch wheels
  107. help me with tfs valve springs
  108. flowtech longtubes on gt40p heads
  109. 8.8" / 7.5" rear axle interchange?
  110. Idle probs. W/ 228*/232* @.050" cam...500-600rpm..
  111. Header wrap pics.
  112. just find out what was wrong
  113. rear SS brake lines
  114. Car Won't Start. Dash Lights don't turn on.
  115. How to Install a Spool?
  116. GT40's or GT40p's???
  117. Rocker arm help!
  118. Pypes exhaust??
  119. how much boost for a stock 5.0?
  120. Tire rubbing lower a-arm during sharp right turn
  121. Tire pressure
  122. How do I make a block roller
  123. Help with autometer gauge cage install.
  124. help with cam decision
  125. How do I remove whats left of the harmonic balancer?
  126. Stroker or Supercharged?
  127. winshield wiper help
  128. D&D T-5 question
  129. how to tell 4cyl tranny from 8cyl tranny
  130. Need help quickly
  131. Decision on buying a 91 LX 5.0 AOD
  132. No blinkers, which fuse?
  133. superchip thermostat
  134. EGR delete, getting tuned, have question.
  135. Runner length, Systemax/Performer
  136. Does a rebuilt trans need to be broke in?
  137. pushrod problems
  138. oil pan came today...botton end done **PICS***
  139. Installed fuel pump without strainer...Okay?
  140. best 351W intake and cam combo, carb'd
  141. swapping to 5 speed need help
  142. How many types of GT40 heads are there?
  143. What is this for (Vac lines/wiring??) pic
  144. Need input - Codes and Check Engine Light
  145. Bellhousing to block dowel?
  146. No injector pulse. Complex wiring issue. Help!
  147. AFR 185's on a 306
  148. GT taillights
  149. Help me get rid of "rake" look with frpp "C" springs
  150. dew wipes.
  151. Installing projector headlights on a fox..
  152. What's the bolt pattern on a 1989 Mustang GT?
  153. Something is draining my battery
  154. Just had transmission rebuilt...problems?
  155. 86 5.0 PCV valve location
  156. preloading rockers
  157. Help w. 85 LX Lower Intake Gasket
  158. TKO500 Actual Torque Capacity?
  159. What parts do i need in doing a 302 into a 5.0L HO????
  160. aftermarket H-pipe w/ cats
  161. Does anyone know what this is?
  162. Speedo needle bouncing around - Help -
  163. Cobra Grille
  164. advice on changing carpet...
  165. Rocker Arm Stud Conversion?
  166. question about my cam
  167. Head swap in an 86 w/ e cam
  168. need help with
  169. disgargen valve for super charger?
  170. installing weatherstripping
  171. ran out of gas and now car won't start
  172. '79-'82 taillights
  173. feul relay for 87 lx 50 conversion
  174. Power steering lines Question (5.0 vs. 4cyl)
  175. Carb swap, help
  176. Check Engine light when placed in gear
  177. What clutch ?????
  178. Rear brakes sticking...noticed when trying to move car
  179. 1991 Mustang GT automatic shifter problems
  180. what to do about valve springs
  181. Mass Air Conversion Problems!!!
  182. new fuel pump same bull**** problem
  183. procharger question
  184. injectors and upper and lower intake
  185. E-Brake light comes on ? Help
  186. Best way to drain fuel tank?
  187. A Rebuild.. Cost?
  188. Advancing B cam question..
  189. Tricks To Pass Emissions?
  190. T-56 Noise
  191. Quick Exhaust Question
  192. Need a tune? Is this combo okay without?
  193. T5 question
  194. ARP Head Bolt Torque!
  195. Exhaust Question
  196. IAC sticking...effect on part throttle driving?
  197. 93 coupe swap
  198. Computer Question
  199. starter trouble with carb swap
  200. clyinder head porting
  201. Emgine building help
  202. Flex-A-Lite fan wiring install?
  203. Electrical interlock
  204. Compression test #'s. What do they mean?
  205. axles are loose in the spider gears
  206. Solid versus Hydraulic Roller Camshaft?
  207. ? bout 82 mustang L.
  208. Rear axle alignment (need opinions)
  209. Rear axle alignment (need opinions)
  210. What T5 bellhousing do I use to run a cable clutch?
  211. Got IRS??
  212. Comp 987 Valve Springs
  213. 86' STANG, PROCHARGER, NITROUS=NO TRACTION PLEASE HELP..!
  214. pistons hitting the heads
  215. cobra brakes
  216. gt40p users in here please
  217. Rod ratio. Don't hate me
  218. Fuel Pump
  219. Nitrous newbie
  220. Custom Pistons
  221. Rear gear suggestions
  222. New Heads
  223. Budget 306 need advice.
  224. Need cam help.
  225. What glide ratio?
  226. mass air ?
  227. Identify this motor by the heads?
  228. Bump Steer Kit Problem
  229. 80mm. ford maf for 5.0
  230. SS Brake Line Question
  231. Underheating???
  232. different rebuild parts for 2.95 gearset?
  233. header bolt question
  234. pro m mass air meter question
  235. PCV questions
  236. 5.0 efi distributor vs 302 distributor
  237. stock 302 rebuild
  238. 302 long block total weight
  239. Horse power difference between a 302 and 306
  240. which alternator wire do i route to the kill switch?
  241. does anyone have this kit ...
  242. Bore out connecting rod?
  243. cobra grill insert install
  244. DOOR HANDLE/ WINDOW LOCK
  245. 351m/400 wrist pin???
  246. New Build
  247. distributor trouble during carb swap
  248. heads and intake question
  249. Cobra intake...
  250. 140 mph Speedo question
