PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 [51] 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254
  1. There goes my paycheck
  2. Everything to do a T-56 swap?
  3. need a paint code, any gurus?
  4. Steering problems
  5. 327 internals
  6. upper and lower radiator neck sizes?
  7. So confussed
  8. Oil primeing tool
  9. replacement fog lights on cobra?
  10. options to get compression up on 91 block w/ 66 cc heads
  11. fuel relay 87 lx
  12. Why does my LMAF only have 4 pins?
  13. reverse light switch
  14. Wierd Vibration
  15. Going nuts and bolts! help
  16. What could be wrong with my brakes?
  17. which cam???
  18. pushrod length ?
  19. Converting a 1990 4 banger...quick question
  20. sfi?
  21. Tilt Steering Column swap???
  22. Tilt Steering Column swap???
  23. Where to start with these codes...?
  24. HELP! Popping through intake? Backfiring when shifting?!
  25. couple of questions
  26. rear defroster contact soldering
  27. Carb Tuning & Ignition Situation
  28. C-4 OR 5.O
  29. how hard to take off fender
  30. need information on exhaust
  31. 5.0 Fuel press regulator
  32. Car short circuiting ? Please Help.
  33. QUICK MAF-Injector Question
  34. Exhaust tip smokes after car is turned off?
  35. Simple engine R&R question?
  36. Right blinked and right brake light wont work
  37. E Fan Controllers
  38. Slow cranking
  39. Kenny Brown Lower Chassis Brace ? ?
  40. tps sensor question
  41. piston to valve clearance
  42. 96 gt spindles????
  43. 393 600HP?
  44. EFI to Carb....what kind???...intake??
  45. Fuel pressure drops when I give it gas! Why? Okay?
  46. 351W hydraulic or mechanical flat tappet cam?
  47. Have some drivability issues.
  48. AOD shifts into high too quick
  49. valve size on stock heads?
  50. motor blown, need a new one questions.
  51. tko problems... or clutch problems...
  52. low end lag after H/C/I
  53. Mechanical Gauges?
  54. What is this? -->Pic<-- Can I remove it??
  55. What do you guys think?
  56. head bolt question?
  57. 408W injected or carb?
  58. Leaky sunroof fix? (Surprise!)
  59. duraspark II question
  60. Little wheel help
  61. Where to buy?
  62. 4 cylinder to 5.0 litre
  63. safe @ 6,500 rpm?
  64. T5 Workshop Book??
  65. witch brake master clynder
  66. strange noise comming from the motor
  67. Autofab Coil Over Kit??
  68. poly motor mount ?
  69. cam option
  70. H/C/I Combo...what else will I need?
  71. ford racing 5 lug front conversion?
  72. a few questions about rollcages
  73. engine rebuild sensors and what not?
  74. Help me decide on heads
  75. 17x9.5 possible on front of Fox body?
  76. URGENT!! Spring HELP??
  77. Nodular cast iron or forged camshafts
  78. deleted
  79. 370hpMotor=?hp to the wheels and combo questions
  80. 370hpMotor=?hp to the wheels and combo questions
  81. 351w lifter ?
  82. Front control arms stuck
  83. Rear spring removal
  84. FPS built 360ci.
  85. draglite tire help!!
  86. How do I reattach the roof rail?
  87. equal length shorty headers
  88. Twisted Frame/body??
  89. Who here is running a H/C/I car untuned...Successfully?
  90. Stock spring rates? help
  91. clutch fork?!
  92. Timing My 302
  93. t5 to c4 swap know car want start
  94. 5LUG SAWP HELP!?!?!?!?
  95. arizona 5.0 swap
  96. duralast water pumps-anyone? ???
  97. NEW Headlights and Harness??
  98. Gearbox Numbers? HELP??
  99. Need help with fuel lines!!!
  100. Worth getting MM UCA's?
  101. Cold air blowing on passenger floor
  102. Crank but no start problem...
  103. Installing a/c delete bracket.
  104. Edelbrock Head Selection
  105. need some shifter help
  106. anyone run a MSD 6AL with a blaster 2 coil?
  107. need cam info
  108. What rods do I have
  109. Need help ID'ing and Intake Manifold
  110. 302 issues
  111. 1989 mustang engine harness schematic
  112. 17 inch wheels
  113. help me with tfs valve springs
  114. flowtech longtubes on gt40p heads
  115. 8.8" / 7.5" rear axle interchange?
  116. Idle probs. W/ 228*/232* @.050" cam...500-600rpm..
  117. Header wrap pics.
  118. just find out what was wrong
  119. rear SS brake lines
  120. Car Won't Start. Dash Lights don't turn on.
  121. How to Install a Spool?
  122. GT40's or GT40p's???
  123. Rocker arm help!
  124. Pypes exhaust??
  125. how much boost for a stock 5.0?
  126. Tire rubbing lower a-arm during sharp right turn
  127. Tire pressure
  128. How do I make a block roller
  129. Help with autometer gauge cage install.
  130. help with cam decision
  131. How do I remove whats left of the harmonic balancer?
  132. Stroker or Supercharged?
  133. winshield wiper help
  134. D&D T-5 question
  135. how to tell 4cyl tranny from 8cyl tranny
  136. Need help quickly
  137. Decision on buying a 91 LX 5.0 AOD
  138. No blinkers, which fuse?
  139. superchip thermostat
  140. EGR delete, getting tuned, have question.
  141. Runner length, Systemax/Performer
  142. Does a rebuilt trans need to be broke in?
  143. pushrod problems
  144. oil pan came today...botton end done **PICS***
  145. Installed fuel pump without strainer...Okay?
  146. best 351W intake and cam combo, carb'd
  147. swapping to 5 speed need help
  148. How many types of GT40 heads are there?
  149. What is this for (Vac lines/wiring??) pic
  150. Need input - Codes and Check Engine Light
  151. Bellhousing to block dowel?
  152. No injector pulse. Complex wiring issue. Help!
  153. AFR 185's on a 306
  154. GT taillights
  155. Help me get rid of "rake" look with frpp "C" springs
  156. dew wipes.
  157. Installing projector headlights on a fox..
  158. What's the bolt pattern on a 1989 Mustang GT?
  159. Something is draining my battery
  160. Just had transmission rebuilt...problems?
  161. 86 5.0 PCV valve location
  162. preloading rockers
  163. Help w. 85 LX Lower Intake Gasket
  164. TKO500 Actual Torque Capacity?
  165. What parts do i need in doing a 302 into a 5.0L HO????
  166. aftermarket H-pipe w/ cats
  167. Does anyone know what this is?
  168. Speedo needle bouncing around - Help -
  169. Cobra Grille
  170. advice on changing carpet...
  171. Rocker Arm Stud Conversion?
  172. question about my cam
  173. Head swap in an 86 w/ e cam
  174. need help with
  175. disgargen valve for super charger?
  176. installing weatherstripping
  177. ran out of gas and now car won't start
  178. '79-'82 taillights
  179. feul relay for 87 lx 50 conversion
  180. Power steering lines Question (5.0 vs. 4cyl)
  181. Carb swap, help
  182. Check Engine light when placed in gear
  183. What clutch ?????
  184. Rear brakes sticking...noticed when trying to move car
  185. 1991 Mustang GT automatic shifter problems
  186. what to do about valve springs
  187. Mass Air Conversion Problems!!!
  188. new fuel pump same bull**** problem
  189. procharger question
  190. injectors and upper and lower intake
  191. E-Brake light comes on ? Help
  192. Best way to drain fuel tank?
  193. A Rebuild.. Cost?
  194. Advancing B cam question..
  195. Tricks To Pass Emissions?
  196. T-56 Noise
  197. Quick Exhaust Question
  198. Need a tune? Is this combo okay without?
  199. T5 question
  200. ARP Head Bolt Torque!
  201. Exhaust Question
  202. IAC sticking...effect on part throttle driving?
  203. 93 coupe swap
  204. Computer Question
  205. starter trouble with carb swap
  206. clyinder head porting
  207. Emgine building help
  208. Flex-A-Lite fan wiring install?
  209. Electrical interlock
  210. Compression test #'s. What do they mean?
  211. axles are loose in the spider gears
  212. Solid versus Hydraulic Roller Camshaft?
  213. ? bout 82 mustang L.
  214. Rear axle alignment (need opinions)
  215. Rear axle alignment (need opinions)
  216. What T5 bellhousing do I use to run a cable clutch?
  217. Got IRS??
  218. Comp 987 Valve Springs
  219. 86' STANG, PROCHARGER, NITROUS=NO TRACTION PLEASE HELP..!
  220. pistons hitting the heads
  221. cobra brakes
  222. gt40p users in here please
  223. Rod ratio. Don't hate me
  224. Fuel Pump
  225. Nitrous newbie
  226. Custom Pistons
  227. Rear gear suggestions
  228. New Heads
  229. Budget 306 need advice.
  230. Need cam help.
  231. What glide ratio?
  232. mass air ?
  233. Identify this motor by the heads?
  234. Bump Steer Kit Problem
  235. 80mm. ford maf for 5.0
  236. SS Brake Line Question
  237. Underheating???
  238. different rebuild parts for 2.95 gearset?
  239. header bolt question
  240. pro m mass air meter question
  241. PCV questions
  242. 5.0 efi distributor vs 302 distributor
  243. stock 302 rebuild
  244. 302 long block total weight
  245. Horse power difference between a 302 and 306
  246. which alternator wire do i route to the kill switch?
  247. does anyone have this kit ...
  248. Bore out connecting rod?
  249. cobra grill insert install
  250. DOOR HANDLE/ WINDOW LOCK
