View Full Version : 5.0 Tech
- oil galley plugs? locations??
- non roller high comp.
- 351W swap
- benefits of aftermarket clutch quadrant
- bushings for bbk lca's
- Speed Density Mustang Searching For Idle
- Door panel pins??
- Custom grind cam question,
- monitoring system 5.0
- track heat heads
- 347 missed shift update...rod bearing?
- 3G ?
- Auburn Help
- New brakes, but still no better at stopping
- 1992 Fuel Pump probs
- Tall Valve covers, will they fit?
- Help! Wheel hop? (need experts)
- 1" DROP
- Any daily drivers with aftermarket K-members & front coil over kits?
- Aside from MAC, does anyone make a true bolt on 3" cat back?
- Stock fuel pump limitations????
- 93 cobra 5 lug conversion?
- Questions about the GT-40 lower intake
- Cam
- 8.8 swap
- Best spark plugs and gap for my 5.0?
- Misfire at high rpm...help...
- BBK Bolt/Weld In Subframe Connectors
- Will this 9"/Hub/Axle Combo Fit?
- radio size
- Hoods
- A/C Clutch will not engage, but air will blow.
- pilot bearing installation
- Tranny Problems.
- TFS Stage 1 or 2?
- Cam idle sound clips
- Rear Strut Tower Brace Installation???
- Question about head bolts
- Grind Noise
- headlight question......
- 190 LPH fuel pump
- EGR
- 331 I'm lost..
- MAF
- Tire Size
- Need HELP!!
- Cam Degree HELP
- headlight problem
- internal door help
- 89 gt questions
- cam help
- need help which supercharger
- tranny id
- cam center line with efi
- buying an 8.8 assembly with 373's. quick question
- 93 5.0 lx- which springs and shocks to get?
- Fuel Pump Inertia Switch
- First mods?
- help
- Door weatherstripping
- thunderbird 5.0
- Wont start
- looking for a new AOD for 84 what years will fit?
- Some Nitrous Questions
- Pulled KOER code 91 ...
- Remove rear spring isolators? (FMS B springs)
- MAF requirements for SC?
- Interior Woes
- Oxygen Sensor Signal Wire
- Should I go bigger? TB, Injectors, & 3" exhaust?
- Pro-M 77 Meter Pics?
- 408 combo
- Some of the best cam info on the net!!
- need some advice!!!!!engine builders come on in here
- Exhaust question/please help.
- AOD to t5 reverse light?
- hesitation and dying
- NEW HERE NEED HELP!!!!!!!!!!!!
- Distributor Help. Wont Start
- Powersteering Pump Replacement.
- 1.6 or 1.7 RR Question
- Steering and the Engine cradle
- How small to gap my plugs
- South Side Lift Bars and 50/50's?
- whistling tb,cai, mass air
- Machine Shop
- Need help tapping oil pan
- New computer Or reprogram??
- brake questions
- 90 fox with dart 351
- Subframe Connectors
- Window bushings??
- Bad brake booster check valve?
- Special tools for t5 rebuild?
- Trick Flow Track heat camshaft
- 03 h pipe on a fox
- Weight Jacker LCA's
- Gauge Wiring Diagrams
- it wont start.
- Anyway to test heater core?
- Timing Chain Tech
- 1990 question about a "beeping"
- Why is my alternator doing this?
- no high speed wipers
- idle problem
- 2 Power Adders 600+RWHP and have a few ?'s of all sorts
- Power Gain from These Bolt Ons
- fuel filter help / taking out console help
- fanageness
- P/S pump or r&p gone bad?
- Digicon Smart Spark Controller instructions
- Windshield Wiper Problems
- IRS rear swap in a fox?
- getting the dreaded "click" when its cold. any ideas.
- Difference between 86 and 88 5.0 motors
- What Wheels Are These - What Lug Conversion 2 Use
- fox w/94/95 ponies??
- 3rd & 4th Gear really loose
- planning on 5-6 psi boost. whats minimum inj. size need to get rid of FMU?
- Transmission Rebuild
- 87 5.0 coupe with issues
- Best heads for my combo.
- Answer to my 80mph+ Vibration
- t-5 snap ring
- Best combination H/C/I, most power.
- Backfire question
- Engine block help
- Any pics of Mark VIII Fan installed on Supercharged 5.0?
- Rocker arms: To shim or not to shim? That is the question
- ONE CHAMBER FLOWMASTERS
- drinking radiator fluid and oil
- typoohn intake good/bad?
- Installed new K Member now have issues......
- Headlight,radio,hood lamp same fuse???
- water/oil mixing questions.
- MAC Shorties vs. Stock Tubular
- No spark..what should I check now?
- Problem with Thermactor system?
- Thumper/Tmoss/TFS1.....what injectors?
- Lx Foxbody(Intercooler)
- 2005 and up wheel fitment
- Best heads with Typhoon and b303 W/1.7's ???
- Please recommend bolt on off 2.5" off road X & CB for BBK 1 3/4" LT's
- cat question...
- Anyone with problems doing the 3G swap with stock wiring?
- Odd transmission noise...
- New guy to boards needs help with rear end
- DEAD IN THE WATER
- Hot starts...
- Help save my T-5
- Help save my T-5
- Help save my T-5
- How do you install front spring???
- how many miles are fords 5.0s good for?
- What parts for a 3G Install????
- No oil pressure
- What to do with my heads?
- tried and true rear suspention
- horn problem
- best junkyard heads???
- no cat car to a highflow setup....what could happen
- Supercharger Question
- e303 question
- Any problems with Eibach Pro kit lowering rear springs?
- ecm relay,no spark i
- AFR 165? 58cc or 61cc?
- will these wheels fit? please
- Electrical Problem Help!!!
- Steering rack and alignment
- Water temp gauge install
- I need s/c maf recomendations please.
- Side-exits off, SS tails and Violators back on
- fuel pressure
- the dreaded leaky fox sunroof
- Solid motor mounts
- bought gt40p heads, slap on or upgrade first?
- keyless trunk release mechanism help
- remote trunk release mechanism reinstall question
- crazy 86 gt
- A couple Trickflow kit questions (valve springs and street/track intake)
- Matched Injectors
- Horn not working....
- E303 or B303 Cam? and other Questions.
- Highest flowing 5.0/5.8 head?
- Loose Doors
- fuel line broke while driving...help needed
- Help with codes 29, 31, 63
- Aeromotive Fuel Pumps
- Headlights turn off after fogs are on for a short period of time
- Hid's Installation Question
- Basic info: Welding?
- Brake Problems
- new time slip
- Interior Swap Possible "Without" too much mods?
- killing two birds with one stone
- Which bypass valve?
- Stalling Fox when I downshift!!! Please Help!!
- gt40 heads
- Radio Installation problems
- EFI to Carb trade off
- Just installed pcv valve, cant get the engine to idle
- Window regulator car specific?
- funky smell with heat
- Anyone have pics of 15x9 welds with 5.5 bs on a fox
- Anyone have a bumpsteer / adjustable tie rod kit?
- brittle vacuum lines
- help with pre 87 doors!
- M90 Supercharger
- cam change
- belt question
- car dies when i put it in gear
- Flickering Lights
- Tranny Rebuild Kit
- car having idle problems
- How can I tell what kind of steering rack do I have
- Trunk Latch wont Release.
- 2.3L to 5.0L swap need help
- KC Clutch question
- Anyone used J302's with an F303 Cam or similar?
- window fitment issues?
- Do Eibach coil springs go bad?
- Pinion shims/depth on 8.8 gear install.. advice..
- Has anybody used a wet NOS system on a stock motor on a regular basis?
- AFR 185 cant let them go to waste.
- Clutch problems
- Car Cranks, No Start
- electrical short
- Window is scraping, help !!
- going carburator by spring...
- car still won't idle
- 4 cyl igntion module
- So why wont my steering come back around after turning
- brake bleeding / One simple ?
- Tire size question
- Is it my power steering pump or my rack thats bad
- Lost Key
- another 5 lug question?
- 93 Cobra Intake
- Head casting number F5TE?
- Car no start
- Meziere or CSI electric water pump for weekend street drivn?
- Car no start
- EMISSIONS???
- What brake options do I have??
- What is the best tint glue remover??
- think i have a problem here. Rocker install
- please help pulled code 34
- egr question buy new or use without
- Stuttering and hesitation (possible causes)
- Need Tokico/KYB strut opinions (buying today)
