PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. 4 cyl igntion module
  2. So why wont my steering come back around after turning
  3. brake bleeding / One simple ?
  4. Tire size question
  5. Is it my power steering pump or my rack thats bad
  6. Lost Key
  7. another 5 lug question?
  8. 93 Cobra Intake
  9. Head casting number F5TE?
  10. Car no start
  11. Meziere or CSI electric water pump for weekend street drivn?
  12. Car no start
  13. EMISSIONS???
  14. What brake options do I have??
  15. What is the best tint glue remover??
  16. think i have a problem here. Rocker install
  17. please help pulled code 34
  18. egr question buy new or use without
  19. Stuttering and hesitation (possible causes)
  20. Need Tokico/KYB strut opinions (buying today)
  21. TKO600...What Part Number?
  22. Mounting Taurus fan
  23. missed shift results
  24. stock 302 is dead!!!!
  25. FRPP Engine Kit
  26. Best bang for buck: SC or heads?
  27. piston question
  28. Whats this sound mean?
  29. fuel door opener
  30. Need some help or advice on a T5
  31. Please help, Front Brakes are locking up
  32. found the problem cost for labor and parts
  33. Need Help Bad Hooked Up Computer and Bad things are Happening
  34. problems
  35. What size rear end came stock in 86GTs?
  36. told i had a cracked ring ???
  37. Seat Upholstery Q
  38. 10 hole wheel weight question
  39. 31 spline 8.8
  40. damn snowball effect!
  41. srod 4-spd to 351
  42. 96' 4.6L In A Fox??
  43. 4 eyed no option car - to option car
  44. Victor 5.0 VS Ported Cobra/Downs Box
  45. c and l mass air meter
  46. 460 swap...FMS Pan question
  47. C6 Questions 460 project
  48. afr pushrod
  49. Tranny help!!!
  50. AFR 165 heads, but what valve springs?
  51. tremec 3650
  52. Cobra body kit ???
  53. Question about cleaning gasket surfaces on heads and block
  54. exhaust and now gas tank issue.
  55. Need wiring diagram
  56. Vortech Q's
  57. odd cold starts fuel pressure
  58. Alternator underdrive pulley
  59. Aftermarket steering wheel install
  60. 91-93 front fenders upgrade
  61. Is it my computer or the harness thats bad
  62. One last question guys - Cam choice?
  63. Both Door Handles Broke.
  64. Sorry another timing question
  65. master cylinder need bleeding?
  66. Anyone ever change their key/ignition in the steering column?
  67. car started but died need help
  68. Hooked up wiring harness and car wont start
  69. Is this a good intake for the 347?
  70. Which Heads!!??!?!
  71. Heads off - stock cylinder walls/pistons? (pic)
  72. Springs question.....
  73. Differences for 87-90 and 91-93 saleen kits
  74. head bolt question
  75. Help need repair suggestions for 79-86 Dash assembly
  76. Engine need balancing even with stock internals?
  77. Quick wire connect question
  78. Problems with Mac Longtubes
  79. New Radiator, quick question.
  80. Block dowels
  81. turbo, What cam?
  82. What size is the top strut mounting nut?
  83. Header Install Woes
  84. how do i tell what size my lines are for my n2o. and do these jet sizes sound right
  85. Gear Drive vs. Double Roller Chain....pros and cons
  86. WELD Backspacing HELP
  87. Problem w/ Starting.
  88. Suspension Upgrades this winter on my 91LX Coupe
  89. Rust in the door jams and rear-end
  90. World Class T-5 vs. Cobra Tranny
  91. Injector Filter Removal Help
  92. Challenge question!? Camshaft!
  93. older 302 cam question
  94. 460 P/U Headers Help, Cant Find Any..
  95. New thermostat is sticking
  96. Timing for a 1989 302 .30 over
  97. charcoal canister
  98. 160 stat bad for ill winters
  99. Clicking through brake/clutch petal.
  100. what size gear for 89 LX
  101. Question for those with a Flex-a-lite electric Fan
  102. vacuum question
  103. Transmission
  104. Need help real quick
  105. Need help real quick
  106. Am i missing a nut?
  107. Decked block...shaved heads...now manifold wont fit? HELP!
  108. suspension upgrades this winter...
  109. Key wont turn back????
  110. Key wont turn back????
  111. Too low!!
  112. Anyone have Roush aluminum heads
  113. Clutch Slipping part 2, Pressure plate looks shot????
  114. Can someone tell me how to get my heat to work, detailed pics inside
  115. the good news about Jesus Christ the Son of God... and how SPAM causes teh bant
  116. Limitations of rear drums
  117. Nitrous question?
  118. Swapped MAF today.
  119. Clutch Cable Travel
  120. Anyone Running the PA SFI Bell Housing?
  121. HELP Fuel Pump/Regulator problem?
  122. Header Install Help!
  123. Toploader Speedo Issues
  124. installing NOS wet kit. where do i tap into for fuel
  125. '89 GT won't start
  126. engine combo.
  127. COBRA cumputer
  128. Question about cleaning pistons
  129. New Motor
  130. Taurus fan/alt. help
  131. Lincoln 430 info anyone ?
  132. upr k members?
  133. svo 5 speed in a 5.0
  134. how to bend pipe....
  135. help fixing seat rip!!
  136. Replacing exhaust system
  137. trans problems (not my stang)
  138. Coolant passage question
  139. oil pump bad, different oil pan?
  140. beeping behind radio
  141. Early Ford Lightning GT40 intakes
  142. car wont run unless i keep giving it gas
  143. Truck Lower Intakes
  144. side impact beams
  145. Need pics of Vac tree and components
  146. what kind of bushings in bbk control arms
  147. Head Chamber Size
  148. Punnting an end to the PROCOMP head mystery *MANY PICS*
  149. engine identify
  150. radio question
  151. Economy and power from a H/C/I combo
  152. What is this?
  153. 347 kit
  154. all new brake lines?
  155. Anyone have to "clean up" BBK headers
  156. Synthetic to Motorcraft oil?
  157. Tranny/Differential fluid change trick
  158. headlight/foglight switch fix
  159. headlights blinking/factory tach sticking
  160. What gasket
  161. Adjustable FP regulator question
  162. 3:73's to 4:30s
  163. Fuel line connectors and JB Weld?
  164. Fuel pump problems i need help with.
  165. Car won't start and run when cold
  166. Low Coolant Light
  167. What type tranny fluid?
  168. to "P" or not to "p"
  169. Machine costs
  170. new heads?
  171. heads and pistons question
  172. Crankshaft... yikes
  173. Do oxygen sensors work with out cats?
  174. Lincolin Lsc rear fitment issues!!
  175. overheating and excessive water leaking from exhaust
  176. Mileage for SD vs. MA.
  177. problem starting up
  178. QUESTION ABOUT TIMING
  179. suvlights.com headlight harness
  180. Which Royal Purple fluid to use is my t5?
  181. Battery Drain Normal: Key ON only?
  182. Mustang Alarm
  183. Gasket Question
  184. Strange Headlight Problem !
  185. Anyone drilled a hole for oil cap in Comp Cam valve cover?
  186. is there a difference in the c6 bell housings !
  187. Need help! Left Signal.
  188. Need colder plugs for GT40P's.
  189. Smoking
  190. How to weld new O2 sensor Bung?
  191. My gears are spinning... yea, or nea
  192. Cobra Lower question!
  193. Drums or disc 1/4 times
  194. How far is to far down for 02 Sensors?
  195. Quarter Panel Replacement on a Vert??
  196. quick dizzy question
  197. TPS Part Number
  198. Swapped 87/88 Tilt into 93 (Problem)
  199. Storing a car outside: How to save the brakes elegantly.
  200. Lights turning off on their own
  201. one wire alternator?
  202. Fluidlyne Radiator Work With Black Magic Electric Fan?
  203. 1/4 window moldings coupe
  204. Disk in rear require new mc?
  205. help me ID 302 block
  206. car running at etremely high temps
  207. oil coming from dipstick?
  208. AFR 185 or 165/clutch
  209. Valve Cover Breathers
  210. Interior question...
  211. Rear axle seal
  212. PLEASE HELP, DONT KNOW WHAT TO DO
  213. fluid question
  214. Injector Question?
  215. 93 Cobra Brake Booster
  216. Rear lower control arms, help
  217. Going to the Junk Yard in the morning!!!!!
  218. Question about fuel delivery
  219. Balanced fox setup for drag/autox/road???
  220. yet another tire ?.sorry
  221. 5th gear to 4th wont go...
  222. Longtube & starter issues!!!
  223. need help!!!! prochamber
  224. Valve Cover Breather Or Evacuation System?
  225. Quieter mufflers than Flowmasters?
  226. Installing A 10 Point Rollcage!!!..
  227. Hubs
  228. Hp/tq increase question
  229. 1986 grand marque engine
  230. e7heads FIT ON AN E6 BLOCK WITH FLAT TOPS?
  231. Coolant leak
  232. Quick header question
  233. Went to Racetrack Times....
  234. Explorer GT-40 heads a direct bolt-on?
  235. 73mm caliper work with a stock MC?
  236. Black spots on spark plug insulators?
  237. A few questions on my soon to be turbo fox
  238. Cylinder wall
  239. rockers issue
  240. Coil Connection
  241. heat takes a long time to come on
  242. Will These Wheels Fit?
  243. 351 power steering bracket bolts?
  244. 86 gauges - need wiring help
  245. Temperature and gas mileage relation?
  246. My setup Help
  247. Best place to get ZEX perimiter plate kit?
  248. Wheel fitment help
  249. Best place to get ZEX perimiter plate kit?
  250. Those with King Cobra Clutch-
