View Full Version : 5.0 Tech
- So why wont my steering come back around after turning
- brake bleeding / One simple ?
- Tire size question
- Is it my power steering pump or my rack thats bad
- Lost Key
- another 5 lug question?
- 93 Cobra Intake
- Head casting number F5TE?
- Car no start
- Meziere or CSI electric water pump for weekend street drivn?
- Car no start
- EMISSIONS???
- What brake options do I have??
- What is the best tint glue remover??
- think i have a problem here. Rocker install
- please help pulled code 34
- egr question buy new or use without
- Stuttering and hesitation (possible causes)
- Need Tokico/KYB strut opinions (buying today)
- TKO600...What Part Number?
- Mounting Taurus fan
- missed shift results
- stock 302 is dead!!!!
- FRPP Engine Kit
- Best bang for buck: SC or heads?
- piston question
- Whats this sound mean?
- fuel door opener
- Need some help or advice on a T5
- Please help, Front Brakes are locking up
- found the problem cost for labor and parts
- Need Help Bad Hooked Up Computer and Bad things are Happening
- problems
- What size rear end came stock in 86GTs?
- told i had a cracked ring ???
- Seat Upholstery Q
- 10 hole wheel weight question
- 31 spline 8.8
- damn snowball effect!
- srod 4-spd to 351
- 96' 4.6L In A Fox??
- 4 eyed no option car - to option car
- Victor 5.0 VS Ported Cobra/Downs Box
- c and l mass air meter
- 460 swap...FMS Pan question
- C6 Questions 460 project
- afr pushrod
- Tranny help!!!
- AFR 165 heads, but what valve springs?
- tremec 3650
- Cobra body kit ???
- Question about cleaning gasket surfaces on heads and block
- exhaust and now gas tank issue.
- Need wiring diagram
- Vortech Q's
- odd cold starts fuel pressure
- Alternator underdrive pulley
- Aftermarket steering wheel install
- 91-93 front fenders upgrade
- Is it my computer or the harness thats bad
- One last question guys - Cam choice?
- Both Door Handles Broke.
- Sorry another timing question
- master cylinder need bleeding?
- Anyone ever change their key/ignition in the steering column?
- car started but died need help
- Hooked up wiring harness and car wont start
- Is this a good intake for the 347?
- Which Heads!!??!?!
- Heads off - stock cylinder walls/pistons? (pic)
- Springs question.....
- Differences for 87-90 and 91-93 saleen kits
- head bolt question
- Help need repair suggestions for 79-86 Dash assembly
- Engine need balancing even with stock internals?
- Quick wire connect question
- Problems with Mac Longtubes
- New Radiator, quick question.
- Block dowels
- turbo, What cam?
- What size is the top strut mounting nut?
- Header Install Woes
- how do i tell what size my lines are for my n2o. and do these jet sizes sound right
- Gear Drive vs. Double Roller Chain....pros and cons
- WELD Backspacing HELP
- Problem w/ Starting.
- Suspension Upgrades this winter on my 91LX Coupe
- Rust in the door jams and rear-end
- World Class T-5 vs. Cobra Tranny
- Injector Filter Removal Help
- Challenge question!? Camshaft!
- older 302 cam question
- 460 P/U Headers Help, Cant Find Any..
- New thermostat is sticking
- Timing for a 1989 302 .30 over
- charcoal canister
- 160 stat bad for ill winters
- Clicking through brake/clutch petal.
- what size gear for 89 LX
- Question for those with a Flex-a-lite electric Fan
- vacuum question
- Transmission
- Need help real quick
- Am i missing a nut?
- Decked block...shaved heads...now manifold wont fit? HELP!
- suspension upgrades this winter...
- Key wont turn back????
- Too low!!
- Anyone have Roush aluminum heads
- Clutch Slipping part 2, Pressure plate looks shot????
- Can someone tell me how to get my heat to work, detailed pics inside
- the good news about Jesus Christ the Son of God... and how SPAM causes teh bant
- Limitations of rear drums
- Nitrous question?
- Swapped MAF today.
- Clutch Cable Travel
- Anyone Running the PA SFI Bell Housing?
- HELP Fuel Pump/Regulator problem?
- Header Install Help!
- Toploader Speedo Issues
- installing NOS wet kit. where do i tap into for fuel
- '89 GT won't start
- engine combo.
- COBRA cumputer
- Question about cleaning pistons
- New Motor
- Taurus fan/alt. help
- Lincoln 430 info anyone ?
- upr k members?
- svo 5 speed in a 5.0
- how to bend pipe....
- help fixing seat rip!!
- Replacing exhaust system
- trans problems (not my stang)
- Coolant passage question
- oil pump bad, different oil pan?
- beeping behind radio
- Early Ford Lightning GT40 intakes
- car wont run unless i keep giving it gas
- Truck Lower Intakes
- side impact beams
- Need pics of Vac tree and components
- what kind of bushings in bbk control arms
- Head Chamber Size
- Punnting an end to the PROCOMP head mystery *MANY PICS*
- engine identify
- radio question
- Economy and power from a H/C/I combo
- What is this?
- 347 kit
- all new brake lines?
- Anyone have to "clean up" BBK headers
- Synthetic to Motorcraft oil?
- Tranny/Differential fluid change trick
- headlight/foglight switch fix
- headlights blinking/factory tach sticking
- What gasket
- Adjustable FP regulator question
- 3:73's to 4:30s
- Fuel line connectors and JB Weld?
- Fuel pump problems i need help with.
- Car won't start and run when cold
- Low Coolant Light
- What type tranny fluid?
- to "P" or not to "p"
- Machine costs
- new heads?
- heads and pistons question
- Crankshaft... yikes
- Do oxygen sensors work with out cats?
- Lincolin Lsc rear fitment issues!!
- overheating and excessive water leaking from exhaust
- Mileage for SD vs. MA.
- problem starting up
- QUESTION ABOUT TIMING
- suvlights.com headlight harness
- Which Royal Purple fluid to use is my t5?
- Battery Drain Normal: Key ON only?
- Mustang Alarm
- Gasket Question
- Strange Headlight Problem !
- Anyone drilled a hole for oil cap in Comp Cam valve cover?
- is there a difference in the c6 bell housings !
- Need help! Left Signal.
- Need colder plugs for GT40P's.
- Smoking
- How to weld new O2 sensor Bung?
- My gears are spinning... yea, or nea
- Cobra Lower question!
- Drums or disc 1/4 times
- How far is to far down for 02 Sensors?
- Quarter Panel Replacement on a Vert??
- quick dizzy question
- TPS Part Number
- Swapped 87/88 Tilt into 93 (Problem)
- Storing a car outside: How to save the brakes elegantly.
- Lights turning off on their own
- one wire alternator?
- Fluidlyne Radiator Work With Black Magic Electric Fan?
- 1/4 window moldings coupe
- Disk in rear require new mc?
- help me ID 302 block
- car running at etremely high temps
- oil coming from dipstick?
- AFR 185 or 165/clutch
- Valve Cover Breathers
- Interior question...
- Rear axle seal
- PLEASE HELP, DONT KNOW WHAT TO DO
- fluid question
- Injector Question?
- 93 Cobra Brake Booster
- Rear lower control arms, help
- Going to the Junk Yard in the morning!!!!!
- Question about fuel delivery
- Balanced fox setup for drag/autox/road???
- yet another tire ?.sorry
- 5th gear to 4th wont go...
- Longtube & starter issues!!!
- need help!!!! prochamber
- Valve Cover Breather Or Evacuation System?
- Quieter mufflers than Flowmasters?
- Installing A 10 Point Rollcage!!!..
- Hubs
- Hp/tq increase question
- 1986 grand marque engine
- e7heads FIT ON AN E6 BLOCK WITH FLAT TOPS?
- Coolant leak
- Quick header question
- Went to Racetrack Times....
- Explorer GT-40 heads a direct bolt-on?
- 73mm caliper work with a stock MC?
- Black spots on spark plug insulators?
- A few questions on my soon to be turbo fox
- Cylinder wall
- rockers issue
- Coil Connection
- heat takes a long time to come on
- Will These Wheels Fit?
- 351 power steering bracket bolts?
- 86 gauges - need wiring help
- Temperature and gas mileage relation?
- My setup Help
- Best place to get ZEX perimiter plate kit?
- Wheel fitment help
- Those with King Cobra Clutch-
- Lowering my '90 GT
