PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. belt tensioner
  2. Oil Dipstick question
  3. Capri struts
  4. K&N Air filter question
  5. Can't get codes to pull.
  6. What block do I have?
  7. Where to put horn honk output on keyless entry
  8. Motor Runs Rough w/ new install............HELP
  9. My cars running rich and wont idle ?
  10. Dart heads
  11. what is the name of this part and where to buy it?
  12. BLOCK QUESTION?
  13. ideal head for my 331
  14. Clutch recommendations for high horsepower
  15. Pulling codes = Car won't start?
  16. Question for those with Tremec 3550/TKO
  17. tranny problem?
  18. how much HP?!
  19. Valve springs, pushrods, and other head part questions
  20. 331 builld up questions
  21. Which Intake Manifold To Run ?
  22. what cc is the stock 5.0 combustion chamber?
  23. Car performance/stock intake
  24. Car performance
  25. Summit mini starter for 89 5.0
  26. Finally DYNO numbers and glowing header problem solved
  27. What kind of cam should I suggest...
  28. Dimmer Switch
  29. What to do over winter?
  30. Cold cranking amps
  31. 460 swap....oil pan
  32. wiring fuel pump
  33. WOT display on PMS.
  34. Clutch questions...
  35. Smog Pump, Good or Bad? Q & A
  36. sn95 maf on fox
  37. Oil In Intake Runners
  38. sn95 maf on fox
  39. Clutches
  40. question??
  41. Codes: 33, 41, 63, 91 Car running like crap (maybe 3G alternator to blame??)!!
  42. 5 lug conversion
  43. speed density cam stuff
  44. Need head stud torque
  45. What do you guys think of this set up? LONG
  46. Serpentine belt for my 91 5.0
  47. Vic Jr head porting
  48. Help me find vaccum leak intake noise !
  49. Weird Idle/Timing problem, seems to miss on load.
  50. Please help with idle...I just want to drive my car!
  51. Car wont start
  52. Driveshaft Bolts
  53. Where to buy hard radiator hose
  54. GT40 + GT40P CSA
  55. Edelbrock performer heads
  56. Volvo Problems
  57. gt 40 problems?
  58. more noisy rockers...
  59. Proper way to install aftermarket roller rockers?
  60. Middle of Header stall and hit a snag!
  61. Injector testing?
  62. deck on a 74 351W??
  63. Electrical Problems
  64. k member allignment shop
  65. susupension
  66. Which Throttle Body ?
  67. Who has TrueTrac? Please give opinions!
  68. got my 4cly springs and adjustable struts today...any tricks?
  69. did upgrades and power is just ok
  70. valvetrain-E7's
  71. What rear end & tranny do I have?!?!
  72. nos jet chart?
  73. Wiring diagram conflict--which do I believe?
  74. N E 1 in AZ have a... Want ads not permitted in tech or talk
  75. Which Transmission with Crate Engine?
  76. A/C Compressor......
  77. coolant problems
  78. Tokico
  79. anyone running the HP stage 1 turbo kit??
  80. help....missed shift rpm hit 7k
  81. Tremac question
  82. new 5.0..... hows this sound. need to decide by 2marro. please help. i cant decide
  83. zoom ductile iron flywheel vs replacement cast iron
  84. Weighed a Trickflow Twisted Wedge Head today
  85. differances in distributors
  86. What 1.6 roller rockers are these? (pics)
  87. power steering pump and rack
  88. Belt size for 87 GT after A/C removal
  89. Rocker ratio
  90. Muffler Heat Shield
  91. 5.0L HO Cylinder head volume
  92. Major Blow-By after HG + Cam
  93. Problems with 5.0 please help
  94. ? on new motor
  95. Speedo Swap
  96. Stroker street/ strip guys- I need suspension help!
  97. how much power can the stock t-5 take
  98. Sn95 v8 swap..
  99. Misc Part ID
  100. mustang brakes
  101. Door Panels
  102. pro m housing
  103. need traction
  104. Coil Kit
  105. Wiring diagram for hazard light switch?
  106. Brake Kit Question
  107. Pinging and light smoke at top-end RPM's
  108. Alternator problem
  109. Floor Pan
  110. T5 Swap Bolt Question
  111. part number for best fel pro head gasket?
  112. megasquirt
  113. Fuel line replacement questions
  114. Smokin stang
  115. 3G Alternator Upgrade-Now I have Head Light issues!
  116. Cobra Intake Questions/Help
  117. CAM SWAP
  118. 89 Mustang rebuild (elect.question)
  119. Before I hurt the stang...someone help (video)
  120. Heater hose question.
  121. New to the EFI world!
  122. Installing FRPP radiator Problems
  123. 460 distributor gear question. slip fit?
  124. Weird miss at higher rpms, need help
  125. Ram-air kit to go with Ram-Air hood ?
  126. Is this a AC/PS bracket or just a AC bracket?
  127. GT40P and 1 5/8" BBK longtubes will it work, pics?
  128. Timing gears anyone?
  129. power pully
  130. tfi module and msd box
  131. 408w Engine Build Questions
  132. Best way to cool car? Electric fan or Rad?
  133. quick easy o/r h pipe ?
  134. quick easy o/r h pipe ?
  135. Putting a Cam in an 86
  136. Codes how do I fix?
  137. GT40 351W intake question
  138. Rev limiting problem
  139. Starter or Starter solenoid?
  140. Things to do before clutch goes in???
  141. Summit's 75mm Thottle body
  142. EGR and bypassing EGR spacer coolant... debate
  143. Moldings...
  144. more problems with engine, please help
  145. 1st AOD 5.0
  146. Accel vs. FRPP injectors
  147. Mach 1 Calipers and Rotors
  148. which Tremec directly replaces the T5Z
  149. Got in an accident...
  150. 3.73 or 4.10.....for the 100th time...
  151. hot headers no power over 2000
  152. Fuel level gauge problems
  153. anyone ever heard of saleen cc plates?
  154. ..blue smoke 3rd gear only ...?
  155. Tweecer Unit
  156. MSD Coil difference
  157. T-5 Pwer Limit
  158. fuel gauge show full all the time
  159. How to tell calibration on C&L mass air meter
  160. I hate it: I cant get my interior door skin on!!!
  161. Question regarding C&L inlet pipe and Pro-M meter
  162. 10 sec n/a 347's and 408's need info
  163. Projector HID swap...
  164. Sticking starter...any ideas on fix?
  165. What is wrong with titanium valves for the street (daily driver)?
  166. trak-lok rebuild
  167. need reply asap please
  168. Surging idle, and PVC problem?? ran some checks, pulled codes, Pics inside..
  169. Consuming 1qt oil every two weeks
  170. does anyone know the best place to order a reman rack and pinion unit?
  171. Solid lifter valvetrain question?
  172. Collars in coolant pass. between heads and block?
  173. Bad problem...spark or trans...help! Long
  174. 1969 351W Block
  175. 02 stripped how to get out?
  176. steering problem
  177. How far can i push the stock 302?
  178. Alternator
  179. Belt question
  180. 12.9 with 347
  181. do my dyno results sound right?
  182. What do I need to switch to carb?
  183. Were to find port and polish tutorial/info?
  184. do you think a shop would take in my t5 for rebuilding?
  185. Liberty Mustang Supply/Hoods??
  186. Take off supercharger belt for the winter???
  187. Here are the codes I got
  188. Freshen up the heads..
  189. Car won't start?
  190. 6G alternator ?'s
  191. pcv/crankcase ventilation issue and/or bad head gasket. UPDATE!!!
  192. AOD rebuild problems, help if you can!!!
  193. Tire Pressure on Street with Nitto Drag Radials
  194. how would this 347 be
  195. Exhuast leak question
  196. why does ac cycle ? & fuel press ques ?
  197. Anyone with information on this product
  198. Please help!!!
  199. ha check out these new times!
  200. E7 Powerheads vs. Aluminum Heads, What would I gain?
  201. Fuel Pump Is NOT Priming
  202. Heating and AC question
  203. Idle Screw/rpms/battery voltage.
  204. AOD guys valve body choices
  205. guys with mini starters help.
  206. Interest in E85 or other blends (related to CA Proposition 87)
  207. 02 sensor issue
  208. Air Silencer
  209. Clutch cable question...
  210. Kenne Bell super charger destroyed
  211. importance of pcv valve?
  212. combo question
  213. Changed plugs 4 white rest good? and code 81?
  214. Catted H pipe question
  215. C-4 swap to 90 motor
  216. One-wire alternator help
  217. No trac-loc on 93 5.0? I read it was standard equipment
  218. annoying tick sound-short pushrods?
  219. Any 5.0 conversion tips?
  220. Speedo Gear problems
  221. Looking for pics of side exit exhuast on LX, and other ?'s
  222. How much HP from stock bottom end?
  223. 5.0 swap question everyone HELP!
  224. brake booster question
  225. throttle body question
  226. 351 swap issues
  227. fuel regulator directions??
  228. Knock sensor and solid roller camshaft
  229. New Harness?
  230. EEC Tuner vs. Tweecer
  231. what tubular a-arms?
  232. battery box placement?
  233. Will 70's 302 parts fit onto a 91 302 ?
  234. Questions on camshafts and valvetrain
  235. will hyper pistons be fine?
  236. timing gear/balancer ??
  237. 87-93 custom instrument cluster/???
  238. Budget 8.8 Build?
  239. fuel pressure
  240. mass air
  241. Emissions
  242. weird prob to have
  243. What TFS heads are these? Part numbers 59325-3 & 59340-3
  244. Throttle hangs and slow to drop. I read the sticky too. Please help
  245. Which resistor to get when removing TAD/TAB solenoids?
  246. Carbureted v. EFI
  247. Are these parts useable???
  248. Help
  249. A/C condenser for heater core?
  250. Edelbrock Performer,RPM, @ RPM2 use same gasket?
