View Full Version : 5.0 Tech
- Edelbrock Performer,RPM, @ RPM2 use same gasket?
- EGR questions??
- Anybody got the formula to figure out what gears you have?????????
- Could i have blown a fuse?
- 130 amp in a 85 cfi
- Clutch Cable install
- 89 convertable circuitbreaker location
- Guys with bullitt suspension...
- Relocate Oil Filler Spout?
- Low electrical Power
- 20w50?
- Mechanical Roller
- Rack leaking at steering yoke..thoughts and ideas required.
- Wheel studs
- heater core box broke!!
- Window trim hold down clips
- Quick question about the dreaded surge??
- Valvetrain
- Will 9333-PT1s work with E7TEs? need help!
- 3G alternator wiring problem
- BBK Throttle Body ???
- 1991 Thunderbird 5.0 Questions
- Bent firewall = AC leak?
- anyway to lock 85 aod into 2nd gear permanetly
- Pretty Good Sites For Neewbies
- Converting to carb questions
- Battery DEAD after sitting......
- NOS spraying out of knob?
- msd question
- Low Coolant light problem
- Electric Fan question
- Stiff clutch pedal that looses after driving....
- dash question
- Front strut question for those with 99 newer front setups
- fuel pump electrical problems
- trick flow streetheat/trackheat differences
- electrical problem
- G-Force T-5 Tranny Problem.... Tranny people I need advice!!
- removing headlights
- trick flow top end kit
- motor mounts
- Need help finding correct BAP sensor!
- wiring cd head unit no sound need help (factory amp)90 crown vic 5.0
- Window run channel seals
- engine build questions
- 96 V6 spindles, brakes and axles into 89 stang
- K-Member Install
- Roller Rockers with GT40-P heads?
- What to do about minor floor rust....
- aod tranny shifting ?
- Full Length Subs vs. Standard Length
- im lookin for more power, sum1 plz help me out
- Help with Clutch Problem.
- lost 4 mph in 1/4 mile after new rims?! Help
- Can anyone identify this camshaft?
- little bit of a problem
- Looking for motor mount torque specs
- Official wire hiding thread?
- Can you help me ID this fuel pressure regulator?
- Viper Spec T56 swap: Guys who have done this..
- Fox Manual Brakes
- Which Sparkplugs ?
- ok same problem new question getting tired of this car
- cobra intake
- Shuts off when put into third
- 03 Cobra Radiator in a 92??
- Which gear to get with AOD??
- new heads....got questions (not newb questions)
- transmission line size
- When should I change oil on new engine???
- Okay guys, help me out here
- Alternate place for jack stands
- 330 RWHP On Nitrous vs. 330 RWHP N/A
- Powerband question
- coil doesnt spark, where to look?
- G-force install how hard???
- Suggestions with vibration...
- Car bucking untill i push in clutch !!!!
- Installing a LC-1 WB o2 with TwEECer through EGR input.
- Fuel pressure drops/Please help!
- Fuel pressure drops.
- Help Picking out new cam....
- soft brake pedal
- Aluminum Drive Shaft Question
- distributor- 5spd vs auto?
- please help off and on car no start
- HELP disappointing time slips!!!!
- stereo elec problem
- Valve spring help
- Backspacing and offset for 99 Mustang GT cobra wheels polished/painted
- Water pump question
- Quest for suspension improvements
- how to fix tire rubbing caused by k member install.
- injector size?
- Will this clutch work?
- Need help:surging problem when cold, fuel pump doesn't want to stop priming
- 306 to be tuned and dynoed
- Super Rich at idle .... ???
- Correct way to get pushrod length
- 331 STROKER COMPRESSION INPUT NEEDED
- Heat isn't very warm.
- gt40p heads?
- removing the charcol canister
- Electronics gurus: Wiring a fan-off warning light?
- New to thread
- 8.8 questions
- Vibration, Clunking, and small Leak in 93 GT
- Fuel rail reccomendations
- Did Turbo Coupe rear-ends come with 4:10s?
- Seafoam How-to
- H-Pipe Fitment
- Where is my fuel pump relay?
- Tips Wanted for Head Gaskets Replacement
- spark plug gap
- HCI :D
- Help with codes 63 and 31
- HELP!!!!
- firing order for a 302 mustang
- tell me the story on my plugs...
- FUEL PUMP RELAY ???
- Good clutch for h/c/i car?
- best gear combo
- oil pan question?
- Amplifier Problems
- Need Some Help Solving Vibration Problem
- Quick zoom clutch question
- Bad engine vibration...new mounts made it worse??
- N41 users. what other alternatives?
- Battery light came on for a second
- Compression Test Results ?
- Will this work?
- Code reader connector problem??
- holley carb identification
- Air bag code 32 - 33 Need info please
- Cutting Drag Launch springs
- convertible top
- How do you test the injectors???
- Vacuum leak
- Passenger side door wont unlock or open!
- nitrous question
- Craigslist dude on crack!
- Clutch quadrant probs, maybe
- sn-95 interior ina 88lx
- whats wrong with my transmission?
- exaust leak
- alt charging
- Special tool for a/c hoses?
- HELP:Engine rotates but does not start 93LX
- COOLANT LEAK FROM EXHAUST
- New to 5.0's
- Aftermarket steering wheel connections
- ignition wires
- swapping out stock cam
- 295's Fit on a Fox
- ... and then?
- Back Yard Alignment
- White Smoke out the Tailpipe!!! Frustration Level High!
- stock stall with e cam
- Mechanical or Electric
- 4cyl LX to GT Brakes
- firing order for an 90 mustang motor
- Stud bolts on heads
- intake suggestions?
- Rear Shocks Help???
- What cars have 3G alternators???
- High Idle
- trying to determen whether this is a 24# injector, please read
- Paxton supercharger...
- HELP... awkward noise... from tranny?
- want more from my 347
- Motor
- New to mustangs
- 15" wheels with 13" brakes
- charging problem
- S-Trim from 96 Cobra on 90 lx?
- Need Help, 5.0 Electrical Problem!
- clutch ques
- How many 87-93 5.0 guys/gals using twEECer?
- 357 or 408
- Clutch electrical crap???
- stage 1 cam
- tfs stage 1 cam
- tfs stage 1 cam
- tfs stage 1 cam
- Is my harmonic balancer bad??
- Looking to go to a built aod and ditch the T5
- ok here we go again
- another maf thread please read interesting topic
- Quick Question!!!!!!
- maf
- What kinda mileage am I looking at?
- shocks / control arms?
- Confused about bearing retainer.
- Screaming windows
- Anyone deburr and paint lifter valley?
- Another F*n problem,, Headers/Plug wires
- T5 experts come in
- Learned something new tonight...
- FRPP E303 Cam
- edelbrock a/f meter--has anyone used it?
- EPW rockers? Pics inside
- cannot find 5th gear snap ring for the life of me!
- Fuel system question(s)
- Solid Axle vs. IRS weight?
- Fuel injector question
- What heads does my 82' have? Is there a chart?
- Bad brakes
- Bad brakes
- Attn: Jrichker or any other electrical Guru...Will I get more amperage from a smalle
- Machine shop
- Need help.
- Removing fog light bulb
- Electrical Question- I am stumped! PICS
- Failed Smog...
- PushRod Question
- Bosch design 3 injector upgrade
- strange idle - 87 5.0 LX
- AFRS are here, what else do I need for the motor?
- Need help planning my setup...
- best place to get a 3g alt sawp
- how to get ground off?
- OT-Expedition exhust leak
- Throttle body/egr plate questions
- fuel pressure Question
- Car hard starting hot...help
- Looking for torque specs...
- Lower intake question
- Master Cylinder question???
- ok still backfires another new question
- ground wire help read on
- help with trick flow intake instructions
- Need info on intake sizes
- need help
- What sensor on 02 wiring harness?
- Good Suspension Mods?
- new parts now car running rich please help
- mustang turns over won't start
- Few Weird Drivetrain Noises?!?!
- 351 stroker so many options....??What do you recommend
- gforce t-5 vs tremec 3550
- start up issues
- drivetrain vibration?
- Engine Configuration to Perform--or Not?
- bumpsteer kit
- BELT SIZE ????(NO SMOG PUMP)
- engine size?
- Lakewood Drag Shocks
- 3G Alternator Install Problems
- Felpro 1250 Intake Gaskets Are Trash!!
