View Full Version : 5.0 Tech
- anyone here use 69-70 351w heads on a 302?
- New codes.
- 90 Police Interceptor Alternator Help
- Where to buy oil separator???
- 5.0 Re-wiring and clean up
- o ring'd head question
- Question about PCV Valve on dart block
- detonation???
- Guys running COBRA INTAKES-Please need some 411?
- Getting ready to start the project
- Power Lumbar in GT Seats....
- what piston rings and bearings???
- Quality Clutch Quadrant?
- fuel pressure wont go no lower than 43 ?
- sensor question
- High RPM noise!
- help no O.D
- Cut Headliner
- please help me guys.
- What are the part numbers for the water pump to heater hoses?
- 83 GLX vert 5.0 Certification label PLEASE HELP!!!
- Are 68' C80E Heads Any Good?
- codescanner help/already searched threads
- In the middle of changing Fuel Pump..now Stuck..How do I remove tank? it's stuck?
- Installed Cobra intake...now is backfiring and stalling..can it be this sensor????
- fuel pressure acting weird !
- DD help! not my stang
- what is your fuel pressure set at/w 24lb inj !
- Running rich........
- engine GREMLINS...help me please!!!!
- 5.0 fox roller
- Newbie question
- tach....
- Pivot Ball Torque Specs
- Computer Question
- maf ?
- Yes, Another one of these, Please Help !!!
- If you had to choose a cylinder to....
- 306 not idling when cold
- Has anyone seen/used those "Voltage Stabilizers" that a lot of ricers are selling?
- Anyone for a good mystery?
- engine performance problem
- oil pressure gauge fogging up INSIDE car? help?
- wiring gurus help!
- Mark VIII fan install comments
- A different "which intake" thread....honestly
- New combo not starting?
- New (used) EEC, got codes to pull.... stumped.
- whats the difference performer and p.5.0
- Door lock actuators...
- Who here daily drives with 4.56's
- swap to a 4.6
- ARP Wheel Studs
- Another Bad Vibration
- 4CYL TO 5.0 COV
- Need info on tuning up an old 5.0 engine in an F-150
- Pro Products Throttle bodies sticking problem (SOLUTION)
- 5.0 c4 hookup
- Anybody have a wire pinout for the AOD wire harness?
- REALLY BAD ROCKER TICK....Please Help
- What size injectors?
- which clutch?
- Distributor Wiring
- Weird Thumping in Driver Floor Board??????
- Weird Turn Signal Problem
- Weird Beeping Noise From Under Dash??????
- Wife's ford focus problems...
- Cooling fan question
- While the car is out of commission....
- finding LCD code scanner jrichker
- Coolant leaking into heads??
- WHAT DO YOU THINK OF THIS ET?
- 2 questions EGR and Vac.
- Good place to install gears?
- Wont stay running.
- no. 7 cylinder not firing
- lincoln conti shortblock
- ? about 96 brake swap to a 91 Fox body, Help!
- Bad Shudder Around 75mph
- What should the fuel pressure be?
- Convert door on a ttop car? Will it work?
- alternator bolt sizes
- belt tensioner
- Oil Dipstick question
- Capri struts
- K&N Air filter question
- Can't get codes to pull.
- What block do I have?
- Where to put horn honk output on keyless entry
- Motor Runs Rough w/ new install............HELP
- My cars running rich and wont idle ?
- Dart heads
- what is the name of this part and where to buy it?
- BLOCK QUESTION?
- ideal head for my 331
- Clutch recommendations for high horsepower
- Pulling codes = Car won't start?
- Question for those with Tremec 3550/TKO
- tranny problem?
- how much HP?!
- Valve springs, pushrods, and other head part questions
- 331 builld up questions
- Which Intake Manifold To Run ?
- what cc is the stock 5.0 combustion chamber?
- Car performance/stock intake
- Car performance
- Summit mini starter for 89 5.0
- Finally DYNO numbers and glowing header problem solved
- What kind of cam should I suggest...
- Dimmer Switch
- What to do over winter?
- Cold cranking amps
- 460 swap....oil pan
- wiring fuel pump
- WOT display on PMS.
- Clutch questions...
- Smog Pump, Good or Bad? Q & A
- sn95 maf on fox
- Oil In Intake Runners
- sn95 maf on fox
- Clutches
- question??
- Codes: 33, 41, 63, 91 Car running like crap (maybe 3G alternator to blame??)!!
- 5 lug conversion
- speed density cam stuff
- Need head stud torque
- What do you guys think of this set up? LONG
- Serpentine belt for my 91 5.0
- Vic Jr head porting
- Help me find vaccum leak intake noise !
- Weird Idle/Timing problem, seems to miss on load.
- Please help with idle...I just want to drive my car!
- Car wont start
- Driveshaft Bolts
- Where to buy hard radiator hose
- GT40 + GT40P CSA
- Edelbrock performer heads
- Volvo Problems
- gt 40 problems?
- more noisy rockers...
- Proper way to install aftermarket roller rockers?
- Middle of Header stall and hit a snag!
- Injector testing?
- deck on a 74 351W??
- Electrical Problems
- k member allignment shop
- susupension
- Which Throttle Body ?
- Who has TrueTrac? Please give opinions!
- got my 4cly springs and adjustable struts today...any tricks?
- did upgrades and power is just ok
- valvetrain-E7's
- What rear end & tranny do I have?!?!
- nos jet chart?
- Wiring diagram conflict--which do I believe?
- N E 1 in AZ have a... Want ads not permitted in tech or talk
- Which Transmission with Crate Engine?
- A/C Compressor......
- coolant problems
- Tokico
- anyone running the HP stage 1 turbo kit??
- help....missed shift rpm hit 7k
- Tremac question
- new 5.0..... hows this sound. need to decide by 2marro. please help. i cant decide
- zoom ductile iron flywheel vs replacement cast iron
- Weighed a Trickflow Twisted Wedge Head today
- differances in distributors
- What 1.6 roller rockers are these? (pics)
- power steering pump and rack
- Belt size for 87 GT after A/C removal
- Rocker ratio
- Muffler Heat Shield
- 5.0L HO Cylinder head volume
- Major Blow-By after HG + Cam
- Problems with 5.0 please help
- ? on new motor
- Speedo Swap
- Stroker street/ strip guys- I need suspension help!
- how much power can the stock t-5 take
- Sn95 v8 swap..
- Misc Part ID
- mustang brakes
- Door Panels
- pro m housing
- need traction
- Coil Kit
- Wiring diagram for hazard light switch?
- Brake Kit Question
- Pinging and light smoke at top-end RPM's
- Alternator problem
- Floor Pan
- T5 Swap Bolt Question
- part number for best fel pro head gasket?
- megasquirt
- Fuel line replacement questions
- Smokin stang
- 3G Alternator Upgrade-Now I have Head Light issues!
- Cobra Intake Questions/Help
- CAM SWAP
- 89 Mustang rebuild (elect.question)
- Before I hurt the stang...someone help (video)
- Heater hose question.
- New to the EFI world!
- Installing FRPP radiator Problems
- 460 distributor gear question. slip fit?
- Weird miss at higher rpms, need help
- Ram-air kit to go with Ram-Air hood ?
- Is this a AC/PS bracket or just a AC bracket?
- GT40P and 1 5/8" BBK longtubes will it work, pics?
- Timing gears anyone?
- power pully
- tfi module and msd box
- 408w Engine Build Questions
- Best way to cool car? Electric fan or Rad?
- quick easy o/r h pipe ?
- Putting a Cam in an 86
- Codes how do I fix?
- GT40 351W intake question
- Rev limiting problem
- Starter or Starter solenoid?
- Things to do before clutch goes in???
- Summit's 75mm Thottle body
- EGR and bypassing EGR spacer coolant... debate
- Moldings...
- more problems with engine, please help
- 1st AOD 5.0
- Accel vs. FRPP injectors
- Mach 1 Calipers and Rotors
- which Tremec directly replaces the T5Z
- Got in an accident...
- 3.73 or 4.10.....for the 100th time...
- hot headers no power over 2000
- Fuel level gauge problems
- anyone ever heard of saleen cc plates?
- ..blue smoke 3rd gear only ...?
- Tweecer Unit
- MSD Coil difference
- T-5 Pwer Limit
- fuel gauge show full all the time
- How to tell calibration on C&L mass air meter
- I hate it: I cant get my interior door skin on!!!
- Question regarding C&L inlet pipe and Pro-M meter
- 10 sec n/a 347's and 408's need info
- Projector HID swap...
- Sticking starter...any ideas on fix?
- What is wrong with titanium valves for the street (daily driver)?
- trak-lok rebuild
