View Full Version : 5.0 Tech
- 3G Alternator Install Problems
- Felpro 1250 Intake Gaskets Are Trash!!
- Car wont turn over!!
- need help!!! bad electric bug
- Door gaps. Pics inside...help
- Tach question????
- rear yokes?
- What is Ford's name for my car's color
- suspension
- Brake Kit
- which cam??
- rod endplay
- Car runs in rain but dies when floored
- Bad fuel filter??
- Mystery Vibration..Help
- Anyone have trouble with rings seating, anyone use sealed power R9771035 plasma moly
- need a new center cap
- Welding Axle tubes?? Pros & cons
- Block stampings?
- 87 Mustang Charging problem
- Getting block bored...
- Manual Brakes
- Clutch pedal question...
- Whis is this wire/connection???
- will gt40 upper intake fit on cobra lower?
- Alt wiring Q's jrichker and wiring gurus come in!
- trouble starting hot
- Will an electric fan an underdrive pullies kill my stock alt?
- will gt40 upper intake fit cobra lower?
- 5.0 swap
- Dech Motorsports ASG
- fuelage pumpage!!!
- installing a upper and lower intake
- help
- Steering column/ ignition problem...
- What Main Support is this??
- Car Won't Start
- How do you remove the ignition cylinder???
- Is hatch rattle really this bad?
- Is this T5 worth the effort?
- alternator wiring
- Cosmetic Stuff
- Steering Shaft vs. Header Clearance
- Opinions
- Trickflow R-Series intake vacuum lines question
- Traction Lock experts?
- codes
- Should I reassemble before painting?
- FMS C-Spring Measurements.
- Argh... friend over-torqued valve cover bolts!
- Basic TwEECer tuning questions.
- wtf is going on with my 86
- looking at exhaust need help!!!
- 1970 351w heads on 5.0?
- painting interior problems
- ahh car is acting up, oil pressure is all over the place
- Head Help...351 to 302
- wheres all the vacum lines go on a carbed car?
- Air bag code 33 - High resistance or open circuit in passenger air bag circuit
- Widest rims possible in the rear of a fox???!!!
- Where to go from here
- Canton oil pan pickup questions on a dart block
- damn no progress out of ideas
- Wobbling shifter?
- Metal heater line problems!
- Passenger Mirror Replacement....Will 96-98 mirrors fit 94
- 5 lug rear disc conversion has me pulling my hair out
- Measuring Hood Clearence?
- Car not running right
- MAP/BARO question
- ? about moving power steering to delete AC
- Door Prob. Not 5.0
- What shifter knob will fit this shifter?
- help sunroof leaking!!!
- 347?
- dog teeth on input shaft are worn, not the blocker ring? what do i do? help t5 guys!
- gas mileage revisited
- notch the block
- Clutch
- 3g Help
- Brake issues....couldn't find in search
- 12 Years in Storage
- New engine problem.....
- 351W Assembly Instructions Anyone?
- car is cranking and getting gas but wont start need help
- HELP need....changing over to mass air on 87 gt
- Head Gaskets
- 5 lug stainless lines
- is there a return fuel line in carb setup?
- C4 or C6 trans 90 fox body
- What are my chances??
- starter
- GT40P heads and BBK LTs
- 17 inch pony wheels
- O2 sensor problem codes 41 and 91. *pics*
- How do codes get cleared??
- e7's a upgrade?
- autometer gauges
- ok i dont get it
- battery light comes on at idle
- btm timing
- ok lost power again new question
- how to get a SUPER exhaust seal at the head???
- dyno numbers--Suggestions??
- ripped my t5 out and found out my OD problem. need help finding parts
- header ?
- Swaybar removal
- Broken Shock- WTF?
- Ignition actuator switch broken please help!!!!
- got fuel but no spark
- Jegs radiator and electric fan
- Rearend whine, what's with these shims? Pics. Help!
- How to run lhigh 12 - mid 13's
- Supercharger Help Please!
- 5.0 help please ... 2 issues.
- Can someone educate me on ignition systems please!!
- Fox3 T-Top Owners....need some help
- How to measure rocker ratios and question about heads
- Cam for TFS set-up?
- Cam for 347
- switch
- Upper Strut bushings squeak
- checking piston to valve clearance
- Some smog stuff
- Engine vibration question.
- More EFI problems
- What Have I Done???
- Global West Subframe Connectors - Request For Pics And Install Tips
- Need help with Tach install
- O2 Sensor Question (Code 91)
- Another turbo question
- Odd cylinder balance test results. Possible problem.
- explorer TB
- Code 91: Shift Solenoid 1 circuit failure???
- Smog Pump making noise
- Cobra vs. Performer vs Performer RPM II intake
- exhaust leak
- Why is this kit so cheap?
- 1984 GT wont start need help
- when going from efi to carb, does your tach still work?
- 17x9s w/275s
- injectors
- thumper heads
- Wheel fitment?
- normal idle for e-303 cam?
- Ranger with a 5.0 V8
- What size belt with this get up???
- Belt question
- Ford Racing's Cold Air and tune. Also, 6sp tranny?
- What other cars have a Fox 4-lug pattern?
- Car shutting off while driving and freaky tach
- New brakes
- FRPP HCI vs. TFS HCI
- Subframe/Torque Box ?
- What kinda cam is this # 201129 492-512 lift !
- 400hp out of a 351
- Which lowering spring sits just a bit higher than Sportlines??
- trick flow heads
- My New Project
- Raptor shift light?
- GT-40 Heads
- Best location for a wideband O2
- fox body w/ a IRS - good for open track events and autox???
- engine temp a little unstable
- Must I convert?
- fuel line kinks
- crankshaft machining
- Need help with cobra brake/line lock upgrade - diagrams inside DUW
- can someone identify these heads
- Question about pressure plate installation
- Stumped
- To big of turbo?
- Octane booster....hurt performance?
- Engine question...tech guys come on in.
- fuel pressure question
- Brake Upgrade for 1986 GT
- Torque link or Prothane engine mounts
- Getting off Wax?
- Is THis A Good Carb?
- Speedometer cable lubricate or R&R
- How fast have you run with worked cast iron heads ?
- Smog pump removal
- 2 questions
- Emissions BS!
- Will a Crane HI-6S CD ignition work with a fox?
- E- brake Q ?
- ecu usage
- engine identify
- plastic gauge clearance
- EEC pins
- Going to Summit What To Buy?!?
- running a 50% crank underdrive pulley...charging problems?
- cobra mass air meter
- 30lb
- Quick Question!!!!
- Anyone use 302 long tubes on a 351 swap?
- 347 motor sport forged short block
- motor sport z head crate motors??
- Benefit of LT's with h/c/i?
- head springs
- Whats the peice called that holds the alternator to the head?
- Pulled codes, help me out, mem code 53 and koer code 33
- Coil Over
- Best Mas/Maf
- Exhaust GLOWS red from heat help???
- Mac H = Lose Torque?
- 2.3 to 5.0 conversion ?
- 2.3 to 5.0 swap question?
- Underdrive Pulleys
- Fenders
- Low Coolant light
- Hydraulic Stabilizers
- coilovers and strut tower reinforcements
- 306 solid roller motor, how would you build it?
- Mother Buckin' Problem!
- 427ci too big...
- Code 15: ECA Mem Failure - ?
- Tensioner question running electric fan/water pump with no A/C
- Most Cost Effective 5.0/Fox Build?
- how did everyone wire there electric fuel pump on carb setup?
- tubular k-members
- SN95 TB on a Fox 5.0? need to make it work
- yellow headlights
- convertible tops
- It's not a 302, so what pistons do i have?
- People with m2300 kit, question for ya
- going for torque.
- Centri blower or KB?
- what size injectors?
- Torque boxes
- Got RPM II intake! now what Heads?
- 331 Build, running into problems.
- Got engine running and have a few questions.
- Wheel mounting surface distance
- Front lower control arms
- Last minute checks before I start brand new engine??
- ok repost about surging at 2000 rpms new question
- Highest cam for Paxton 2000
- Valvetrain noise! Metal against Metal!!!
- OTS shelf suggestion
- 2.3 to 5.0 power steering
- 87 Camaro t5
- Convertible Top Install - Will 83-90 Top Pad Set work on a 92?
- Pushrod question
- Are shorties a stock replacement?
- Shock/Strut combo
- Question about intake runner length/volume
- Codes 63 & 98
- Aod to ?? swap?
