View Full Version : 5.0 Tech
- Codes
- Checking P2v and flycutting questions
- frame rail
- wheels on fox mustang
- Dumb question
- Built 5.0HO- HP to gain with computer mods?
- Hydraulic, Solid and Roller...
- help needed in DC,Md, Va Area with weird 5.0 over heating problems
- Thunderbird 5.0 rollar block?
- front rotor part# question
- Need some EFI help
- need help engine breaks up at 2000 rpms
- T5 identification
- Possibly impossible MIL Question
- wierd noise (buzzing) and smell after valve cover gaskets
- Suggestions on gearing
- Front Control arm bolts
- Draw on the battery on an '88 LX
- stock stud size?
- what tranny do I have??*Pics*
- Fuse box diagram please
- Brakes Question
- steering rack coupler (pinch bolt) problem
- Canton oil pan question.
- AOD to TKO swap car wont start
- can't get car to idle down below 2 grand
- toook a 200mile trip now leakin oil
- cam/intake swap help
- Surging Idle after 3g Install
- mexicano block!!
- Fuel Tank ??
- 3g Wiring
- RPM Power Band?
- How Much RWHP Will This Combo Produce?
- junkyard---Salisbury area
- someone can definetly help me out with thi-possible fuel leak
- Tire size?
- Radiator ? for FOX Coupe
- 1986 Rear Seat
- Difference b/t 2.3 and 5.0 Tranny?
- car goes low 12's should be faster
- bad EGR...
- Fuel pressure help
- Are these good heads for my set-up?
- McLeod Bellhousing "L" Bracket
- distributor
- Strange Noise Coming from Engine/Drivetrain
- Something strange with supposedely bad clutch...
- Help with drag suspension build up. Put me in the 12s
- Cougar 8.8" rear swap Q's....
- drop-in alternator upgrades?
- 26spline G-Force T-5 ? and Cam suggestions for N20..
- another delema
- new m/c and bb... pedal still goes to the floor, WTF?
- New engine in!!! Where does this wire go???
- manual steering coupler, which cars have the right size.
- where to find a better clutch cable?
- Mystery head threads...
- Light wire on Tach Help
- What Wiring Harness Do I Have? *Engine Fire*
- Accel 40lbs injectors and 76mm C&L meter
- Tremec issues!!!
- got the pump priming, still wont start
- Spongy feeling steering wheel...what are common causes?
- removing headlights from 87-93 mustangs
- Lean Mixture Code
- almost new motor with timing problems
- adjusting rockers help!
- chp vs dss
- what cam should i use
- 14.3 again....
- Random Starting Issues...HELP!
- Headlight Cleaner
- Rattling noise from passenger side
- non painted 2.5 inch cowl induction?
- Quick help please with moser c-clip elim instructions
- which gt40 heads do i have?
- QA1 Coilover Install Q's
- ecc relay power question
- T5 Swap Question
- Interior
- what do plugged catalytic converters act like??
- Front control arm bushings question
- Cam and Intake for AFR185's
- Non Mustang related... Need advice
- ECT Relocate...Have Some ??'s
- Starting problems with the Explorer
- What do you think of my combo !
- Are my bearings ok (post mortem of oil pump shaft failure)
- Installed Longtubes Now I've got Idle issues.
- will 2.02 valve heads work on stock bottom end ?
- t-45 behind a 351w?
- a/c & heater control
- what does the buzzer mean when turning the key?
- Vacuum Leak???
- new engine troubles...
- Stud Mounted Rocker, Keeper Torque
- still no power windows
- Carb Guys Please Help
- is anyone running lt1 24lb injectors ?
- Which air intake??
- Installing C-clip elims and spool this week have ?? still
- Mass Air not functioning? Video
- G force trannys. Whos got um and what do you think
- 70 or 75 mm throttlebody?
- Installing mech water temp gauge
- Sportsman Block
- 1.7 rockers
- Benefits of a Short Throw?
- Will carpet from 82 capri fit into my car?
- O-ringed heads help!!!!
- Installing window motors?
- now i have no power to fp relay, fp, ecc relay etc...
- 2nd gear launches?
- What size belt do I need??!!
- Need help with Screwy H pipe
- 97 Explorer 5.0 build for 66
- 5 speed swap ?
- Fuel system too small!!!
- My car won't start!!
- gear drives (timing)
- going to look at an 84 5.0 tommorow
- 302 for airplane
- Stock gt40p springs with bcam?!
- looking to buy a used oxy acetylene welding kit! what to look out for???
- Air bag question
- Overheating
- oil pressure
- What to do next?!
- How do I adjust my timeing when the balancer has no markings??
- question about timing
- motor not lining up right with k member
- Weird Over Heating Problems with my 5.0?
- 5.0 Over Heating Problems
- Stock or a SS alternator?
- Throttle body
- symptoms of bad front wheels bearings?
- 306 or 351 what to do Input PLZ
- heater tube assm.
- Problem with Cobra Brake Install
- 9.8:1 too much compression for BLOWER?
- I know... but I do gotta clutch pop noise
- Where to get standard throttle linkage
- breakout box, grounds 40 & 60, ohms reading koeo, koer ... help!!!
- Dart block questions, and part # if you have them!
- TwEECer RT performance?
- Viper 791xv alarm with remote start
- Vin check please?
- Extreme Sludge Problem!!!
- No smog/AC belt question
- ? About a T-bird T5 Tranny
- Just installed mgw shifter: problem
- fuel pump on ignition switch ok?
- powerhouse heads
- Max HP stock blocks can handle???
- Can't get my H pipe to seal to headers
- Spindle Identification HELP.
- Capri hood on '79-82 nose? 4 eye guys chime in
- EGR Question - Code 33
- what compression gauge do you guys use?
- Pro-Comp Heads???
- SVO 5 lug question
- Oil seperator question?
- Electric Fan Wiring?
- Fuse #15 keeps blowing
- Hey Guys Still Stumped..
- KOER Codes 94 & 44...any fix??
- Engine or Suspension/Exhaust
- Couple Problems
- Oil
- electrical problem
- What other bolt-ons are beneficial?
- INTAKE MANIFOLD
- Is the Mustangs Unlimited Strut Tower Brace.....
- what else to check before putting in new ecc
- Cobra Intake?
- 85 automatic 302 versus 86 302
- Question about Transmission bolts on a T5
- 93 LX 5 speed.......what gears come factory?
- Can i use convertible lowering springs on a hatch?
- 7.5 e-brake cable work with an 8.8?
- new cam : new lifters a must?
- Help with 3g install in or around Md, DC,, Va Please
- Difference between 86 and 87 heads???
- Sway bar removal?
- Door Hinge removal
- serpentine belt
- Going for a budget 11-12sec fox...?
- capri and mustang compatibility
- Spark plugs dont fit in new engine!!
- PMS info please.
- New motor's in, Question for the experienced!!
- Fuse box Q
- Seats! Elec to manual?
- SN95 Mass air sensor in a fox?
- new transmission. wont go in gear!
- Where are the power window fuses??
- installing front suspension want to slot caster plates.
- Removing 3.5" speaker grill...
- o2 sensors
- water pump?
- 5.0 harness questions.
- Still need help with vibration noise
- Fuel Pump Replacement
- Driveshaft Issues
- Springtech Front Camber Kit??
- BRAKE KITS???
- Dumbest Question Ever
- labor to weld in griggs subframes
- how the mess do you remove the cowl grate?
- converting to 4 corner idle...worth it?
- NO2 Q's....
- maier racing 3" quarter
- Looking for some drawing and pics and a couple last questions
- 1988 Mercury Topaz
- Plug gap
- 351 Clearance problems
- ok machine shop question
- 15" 10 hole rims + stock studs: Long enough for slicks?
- p/s relocate vs. pulley
- 165/80/15 tires
- Rearend question
- heads
- 1.7 ROCKERS
- STROKER INSTALL WRITEUP???
- mclaren taillights
- trans. problems
- Power/Price estimates?
- whats wrong with my car???
- Can I pass emissions with an o/r pipe?
- intake spacer
- new problem when driving
- cam degree question
- removing oil pan with tubular k member
- dash illumination problems
- how to install a k member.
- Tach Installation
- runs poorly in the rain or cold?
- Help Help Need B303 Cam Card Specs Please
- steeda caster/camber plates any good. i am getting a pair.
- mass air conversion question?
- KB question
- trick flow socket size help
- Need Help Finding a Wiper Part
- flywheel differences?
- Best Heads for this combo
- performer rpm efi Vacum Lines
