View Full Version : 5.0 Tech
- Going big... 460 big.
- NEED HELP WITH FUEL PUMP PROBS ON 91 GT!!!
- Heater Core Headache
- guys with no coolant hose to egr spacer HELP!
- so im now at a crossroads with my nirtrous setup
- so im now at a crossroads with my nitrous setup
- 2 351Ws to get or not to get
- Question about water pump bolts
- Bought an 87 GT...problems and questions!!!
- 1986 Horn Problem
- Speedo Gear Question
- Overheating Issue
- forged or hyper?
- quick heatercore hose question please!
- Front bumper cover removal
- timing question
- aod to t-5 question
- Power to coil?
- Clutch question
- Big enough radiator
- Installing nitrous on DD for track use only, what needs changing?
- what CR for a small blower
- white haze on spark plugs and exhaust valves?
- need help 80mm pro m mass air
- pilot bearing for eagle crank?
- Crank pulley spacer question
- what 4 banger parts can i use?
- Cat-back exhaust question
- smoke from the dipstick tube. what is going on.
- lifter tapping
- anyone know what bolt size?
- Lower PCV Hose routing
- Motor questions.Need help!!!!!!!!!!
- Underdrive Pullies
- i need 351 swap gurus's
- Cluster Question
- Licoln Fan wires
- what do you all think of QA1 suspension
- Throttle Stuck
- anyone ever bent a pushrod and not bent a valve?
- Opinion needed on paint for GT..
- U-Joint Leaking?
- Does anybody make correct 84 GT seat covers?
- Strange Electrical Problem
- belt problem
- car missing after startup????
- removing trim peices -help
- PA Performance Alternator Questions
- another darn fan question
- Tips Installing BBK Longtubes in 89 stang
- Quick smog delete question.
- BBK-SSI manifold
- Do I need a new MAF and injectors?
- is this a racing cam???
- Is there a difference in the 87 and 88+?
- leaky t5
- Horn troubleshooting, '89 Mustang GT
- Taking the leap.
- How do you replace couping disc?
- Ported E-7 heads installed......finally
- Slight Stumble Off Idle (Normal?)
- NEED INTAKE GASKET #
- Enough fuel pump?
- How do you change tranny fluid in T-5?
- air intake sensor?
- Vaccum & Pumbling Question
- QA1 Suspension???What Do You Think
- Do I have gears?
- DC Fan Controller Users...In Here Now...Help!!
- Injector chart? At what point are 19s too small, or 24s too big?
- Pulling motor AGAIN...need some help
- fuel injector help
- Belt route
- 5.0 throttle cable in 66
- Some questions about 85' stang LX
- LOWER RAD HOSE
- how much do you have to replace in a 150,000 mile car?
- Checking for worn suspension parts
- Fuel pump doesn't work, also can not pull codes
- Superchargers??
- $$347 stroker
- 5-lug conversion question
- Clutch Slips past 3500 rpm :(
- '94 Custom Cam in a 91?
- speedo
- Installed Dumps Exhaust Hangers??
- Help!!! Engine Stand
- Clutch oriblem when cool?
- warm up issues!!
- syncros
- speed density/supercharger ??s
- Whats the difference between header gaskets?
- Teflon rack seals
- engine rebuild kit companies
- smog pump performance rebuild?
- COOLING
- What's the best book for engine rebuilds?
- Billet Flywheel? needed?
- Converting from Speed Density to Mass Air
- heat cycle retorque
- Need help diagnosing a miss, and one other odd issue.
- Who makes the Speedo cable eliminate plug???
- 18:1 AFR....and it didnt grenade itself..HELP!!
- Radiator Core Support
- car runs for a minute, falters and dies
- Refinishing pony wheels
- when i check my timing with the spout out and its at 12, what should it be with it in
- Automatic/Manual, with or w/o AC
- roller lifters and solid lifters??
- horn came on last night out of nowhere
- New fox owner
- Correct Fluid for T5
- Junkyard electric fan
- Cloth headliner w/ sunroof
- BBK LT ?
- Shop recomendations for Fox vert top replacement in Az
- Stock sized injectors on ford cars
- 92 T-bird rear end gears
- Overheating Issue
- car still cranking over with keys not in car??
- timing and fuel pressure ?'s
- R.I.P. Peter Brock
- Freeze Plug Questions
- Those with Comp Cams xe282hr-12 hyd
- NEED HELP WITH A BOTTOM END REBUILD
- Oil pump installation Q
- So who has removed their charcoal canister?
- 351W guys need some help with the clutch
- heads intake and cam?
- Where to buy a PMAS online?
- Granatelli K-member 87-93
- Error code 74?
- Need heads...Help!!
- Tips-Tricks(steering shaft)
- Aluminum head durability in NA 306?
- fLOWMASTER 2 CHAMBERS DUMPED? needs opinions
- Car Smoking, diagnosis?
- TKO or 3550?
- 5.0 resto
- Do i need a cat back?
- Battery recomendations????
- enginekits.com/powerhouse
- it's got to be an alternator, but still weird
- blowing black smoke under wot. any ideas?
- Help with Exhaust Leak.
- Whats all involved with engine swaperoo!!!
- Oil leak help
- What MAF and injectors for combo????????
- t5 swap problem... please help!
- ok need some more help! car runs like crap
- Opening rear hatch without key
- Fuel Line Question
- What style MAF is this?
- my car has a twisting problem
- Wierd idle problem
- Codes 67 and 85
- Detonation problem with 14* timing!!
- school me on head studs
- 351 Fox Question
- having more problems with intake please help.
- 331 or 347?
- gt-40 p's deal or not
- vacuum correct with f cam.
- motor mounts
- Wheel weight question
- MAF test or replace
- MAF sensor or distributor modual
- reason why I think it is the booster and not the m/c
- What will happen going from *25 to *15 timing?
- Code 29 - Anything Limping?
- Shift problem
- Couple questions on changing out suspension.
- rear control arm bolts
- Turbo 408 or 427 EFI system
- Perfect hose for bypassing the heater core on your Fox
- Difference Between Fox Block and SN95 Block?
- will these wheel studs work?
- What to use...FMS "B" Cam or "E" Cam ???
- Body Twist AND Shout
- Anyone want a good laugh while they answer my header/head question?
- any change in trickflows?
- SN95 5 Lug Conversion: Weird Hum after install.
- short idle video with intake.
- Can injectors be TOO big??
- Timing marks
- How much do used hatch's go for?
- Manuals
- Odometer not working.
- Aftermarket Multi-function switches?
- Mass air meter for a Foxbody?
- 90 Convertible quarter window won't move
- My Car died on me.. HELP!!
- i just f'ed something up...help
- bbk fuel pressure gauge wont read pressure?
- driving long distance, precautions?
- what rims will fit svo five lug?
- 4 cylinder springs up front?
- Dynomax mufflers: where will I get the best price?
- No gauges?!?
- IAC gasket
- 93 cobra question
- HELP carbed stang not getting... Fuel??
- speeds in each gear
- T-Bird 5.0 Info Please
- Fuel Pump?
- what size stall should i get?
- Anyone ever replaced the rear side windows black weather moulding
- Sparkplugs
- Freshen up motor or leave it alone?
- Bronco 331 with older (circa 93) Paxton intake hose question.
- vortech v2 safe for stock motor
- gas gauge problems
- Paxton Novi 2000 good for 427?
- removign cig lighter
- smog pump
- intake done, vacuum leak?
- Fog Light Bar
- code 95
- remote mounted shift light
- Injector missing yellow ring on bottom
- Does this *sound* like a bad lifter
- help 351w nightmare
- Need Help removing a Ignition switch from a steering colum with out a key?
- How much is this engine setup worth?
- how to identify
- turn signals headache
- Bad 02 sensor?
- Gas gauge question
- Nitrous plate???
- HELP, my oil pressure and where my charger line is tapped
- still stumped??
- Emergency please help
- What Heads for 600+ RWHP?
- Symptoms of faulty water pump?
- 79 motor mounts, questions
- egr hose question on explorer intake
- washed car, sprayed motor, wont start
- EEC tuning, tweecer rt, long tubes, 88 converting to maf
- Getting there with my 1992 Mustang LX 5.0
- Need help for tomorrow
- what head gaskets with nitrous?
- anyone run MEGA SQUIRT?
- smells bad in car
- T-5 Popping Out Of 1st.....Firewall Cable Adjuster?
- Temp gauge not working??
- tranny coolers
- Can Head gaskets be reused ?
- setting idle on an 82 5.0
- no spark after head swap!!! wtf!?!?!
- which injectors? 24# or 30#
