PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 [64] 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. still stumped??
  2. Emergency please help
  3. What Heads for 600+ RWHP?
  4. Symptoms of faulty water pump?
  5. 79 motor mounts, questions
  6. egr hose question on explorer intake
  7. washed car, sprayed motor, wont start
  8. EEC tuning, tweecer rt, long tubes, 88 converting to maf
  9. Getting there with my 1992 Mustang LX 5.0
  10. Need help for tomorrow
  11. what head gaskets with nitrous?
  12. anyone run MEGA SQUIRT?
  13. smells bad in car
  14. T-5 Popping Out Of 1st.....Firewall Cable Adjuster?
  15. Temp gauge not working??
  16. tranny coolers
  17. Can Head gaskets be reused ?
  18. setting idle on an 82 5.0
  19. no spark after head swap!!! wtf!?!?!
  20. which injectors? 24# or 30#
  21. sunroof glass
  22. The Horrible Mustang Lean....
  23. Need help. 4 cyl T-5 into v8 HELP PLEASE
  24. Car won't start!
  25. Those with GT40 setup or similar N/A, what is your fuel pressure & timing?
  26. Engine Build questions
  27. Valve seals....oh fun!!!!
  28. Broken Bolt Problems
  29. The splashguard behind the flywheel
  30. speedometer cable install problems
  31. 347- AFR 185's, Edel RPM II and custom cam
  32. Finally got some new times on the nitrous!
  33. will a 91+ hatch latch work on an 89?
  34. rpm gauge stuck on 4k
  35. Electrical Problem
  36. Rust on oil pan
  37. draining radiator?
  38. where to put the hoses that connect to the bottom of you stock intake? when using a..
  39. Help with codes
  40. question on compression
  41. 80's era or 90's-2000 era what would u pick
  42. Question about porting GT40x heads?
  43. explorer intake vacum setup help!
  44. 65mm tb hurting me
  45. car seems liek its missing somthing.
  46. computer question on 86 mustang/MAF CONV
  47. car wont start when warm
  48. wth, should this be right
  49. Oil pressure drops... help !!!!
  50. Help musatng engine swap...
  51. how to change valve springs
  52. 2.3 to 5.0 suspension question
  53. Intake Flow Data
  54. ball joints
  55. Need Help Finding the Boost Problem.
  56. Need some help with my 347 stroker
  57. Is the BBK CAI big enough?
  58. Can a TB be rebuilt?
  59. GT-40 INTAKE ???'S
  60. anybody runnin a carb?
  61. Front brake changes
  62. stock lower control arms,, 4 cyl and 8 cyl the same?
  63. Should I Replace Gas Tank - Car Sitting for 3+ Years
  64. tonight is the night
  65. Entire Dash Creakey
  66. 94+ Gauge Cluster in 5.0? Anyone try this?
  67. Failed Emissions On A Truly Grand Scale...
  68. Need some help...car running terrible
  69. Downloads for 84 Central Fuel Injection?
  70. ST. Louis Stangers I need tuning help???
  71. Turn Signal & Back-up Light TROUBLE
  72. cant get into gear! Help!
  73. AOD work in place of C5?
  74. Whine in reverse/vibration at speed
  75. starter acting up...help!!!
  76. Anti-seize vs. Thread lock?
  77. MAf i think.
  78. ignition starting to act up
  79. door panel upgrade
  80. How much power for this setup?
  81. new computer?
  82. Hate my car!!!!!!!!!!!!!!!!!!!!
  83. 1990 Wiper pivot removal?
  84. Aftermarket blocks for roller 5.0 setups
  85. Hypothetically Speaking......
  86. tranny or converter???
  87. D & D rear coilover kit
  88. msd install
  89. PLZ HELP, I NEED TO KNOW ABOUT THESE GT40 HEADS
  90. Carb Runs Rich Until I Pull Of The Vacum Line!!
  91. What size fuel lines do I really need
  92. what fuse location and alt. wire question.
  93. explorer intake bolts
  94. Fuel Pressure Question
  95. Transmission...what to do?
  96. Are longtubes really worth the expense and hassle?
  97. need help car mustang wont run
  98. IAB or IAC
  99. QA1 10-way adjustable struts?
  100. Lightning mass air
  101. Wedge Engineering Seat Backets...anyone use them???
  102. 93 Cobra Rear End Install
  103. *Canadian Transmission Shops QUESTION*
  104. So when a dipstick tube breaks off flush with the block...
  105. 2 HEAD GASKETS BLOWN.....WHAT GIVES??
  106. What size injectors are enough?
  107. Guessing approx. HP-1/4 mile
  108. trick flow cam question
  109. which rockers
  110. Pulled codes.. need to know how to fix.
  111. No electrical power at all! Need help...
  112. How much psi is my supercharger putting out????
  113. Neutral safety switch(the one on the trans not clutch pedal)
  114. 347 Stroker beginnings?
  115. Foglight lens fell off...
  116. Rods and Lifters...
  117. helpppppp
  118. cpu question
  119. Spring Questions
  120. what alt. is this and how many amps am i using
  121. Bogging
  122. Lifters lifters lifters............
  123. Which plugs to run?
  124. Whose got a battery in the trunk?
  125. turn signal indicator and markers not working
  126. which way to wire fan,thermal fan sensor
  127. 351W rwhp guess?
  128. Fuel pump relay still warm after changes...normal?
  129. heater core removal
  130. Need a website
  131. wont idle with clutch in
  132. Need help with Boost Guage install
  133. quick MAF help??
  134. smoke then dead...
  135. BIG WIRING PROBLEM PLEASE HELP
  136. Rubber vs Poly vs Solid Motor Mounts
  137. Headrest Cover Install...How the heck....
  138. 3G Alternator
  139. Weird Clunk
  140. Fuel level gauge
  141. 351M, 351W, 351C, what's the difference?
  142. Needs some pics/ suggestions for 351W
  143. quick converter question
  144. A lil help please? :)
  145. not starting anymore
  146. help buildin up the baby
  147. Just got my first project,need to know if anyone thinks i have something to work with
  148. How much power should my new motor make? I'm hoping 340-360hp??
  149. Need help think I'm f'ed
  150. where do i get this part????plz help
  151. Thumper Heads
  152. Parts Pics
  153. Catted vs. Off Road X-Pipe
  154. Rounded starter bolt
  155. TOKICO adjustable shocks plz respond!!
  156. installed coil overs have a ?
  157. need help I.D.ing a wire..green with black stripe
  158. help removing cross-member
  159. how to lower compression for turbo (shims?)
  160. New to stangnet first question
  161. Nitrous HELP
  162. 1988 GT electrical
  163. Another but slightly different electrical question
  164. GT40Y303 and 331??
  165. Any proven E-fan controllers besides DCC?
  166. 95 5.0 is super slow! Why? Please help!
  167. Fuel Neck Removal from Fuel Tank
  168. question about timing
  169. Having trouble shifting
  170. squeal and smoke
  171. Quick T5 fluid question
  172. suspension swapping
  173. idle problems
  174. Same problem again!
  175. fuel press reg
  176. What oil ?
  177. Firing Order
  178. Need new headlights
  179. T5 Tranny Noise ???
  180. Power loss above 3K
  181. anyone ever use this????
  182. White Face Gauges
  183. couple questions about matching engine parts
  184. Will a mechanical fuel pump work?
  185. K-member Quick questions.
  186. occasional starting problem ??????
  187. the best is not working
  188. Could this cause a bad vibration?
  189. 84.5" short belt?
  190. lost a fitting for the mechanical temp gauge.
  191. Change from Synthetic oil to conventional.
  192. 24s or 30s
  193. HELP! Idle problems!!!
  194. doesn't seem to idle
  195. come on need help pro m
  196. OVER HEATING ???
  197. t-5 tranny question
  198. and now the heater core..a 85
  199. header steering shaft clearance
  200. 94 trans
  201. headrest removal
  202. IAC? god this is frustrating
  203. 95 cobra quiting when driving down the road
  204. FMS Oil Cooler Mounting!!
  205. went to the track.....
  206. Overheating... best fan
  207. Front Brakes "sticking"
  208. A couple questions for my dad
  209. Power Mirror Disassembly
  210. Fuel line + exhaust is no good...
  211. What weight oil for tranny?
  212. gauge cluster question
  213. Removing outside door handle rivets?
  214. TPS VOLTAGE
  215. Help! Trying to remove rocker panel trim...
  216. car wont start????
  217. 315 in the back(tires)
  218. what fuel presure for 24lb injectors
  219. Tranny swap Question
  220. What is this hole? (pics)
  221. HELP brake issues after 5lug conversion, bled brakes 100+
  222. DYI turbocharging... whats it take??
  223. Sold my notch and bought another
  224. "shakey" starts
  225. Worth it ???
  226. new parts: car wont start
  227. Please help me!
  228. Anyone familiar with buying impounded cars???
  229. 104 octane
  230. what to do with a DD, high mileage car
  231. O2 sensor question
  232. what cam?
  233. Fox AOD T5, Same Exhaust System?
  234. vert 1/4 windows wont go up
  235. 85mph speedo upgrade
  236. 1/4 mile
  237. which valve covers clear
  238. first start motor troubles...
  239. SN95 5 Lug Swap Thread
  240. Valve spring keeper issue?
  241. Hood will not release after hood install
  242. Radio install
  243. Modified TKO 500 (MMR PT750) installed. First impressions
  244. 85 Mustang GT HO problems
  245. Advice/SD/MAF
  246. Pro Products Intake Manifold Typhoon
  247. NEED axle bushings in ARIZONA!!
  248. Manifold Hoses???????
  249. No Mufflers?
  250. 351W Waterpump and Serp. Help Needed!
