PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. will 91 cluster work in a 89?
  2. sn95 fox transplant
  3. pro m size question
  4. New Pics & Video of my LX
  5. SLOW TURN SIGNAL BLINKERS
  6. Dumb C&L Question.
  7. Is 4cyl & 5.0 stock A-Arm the same?
  8. Short throw shifters worth the cash?
  9. Knocking Noise please help
  10. Broken E-brake cable
  11. Brakes feel spongy after replacing rear hardware?
  12. Advice needed...sort of long
  13. Rear main Seal
  14. Swapping Wiring Harnesses???
  15. 50resto weatherstrips....leaking.
  16. Timing Questions
  17. Leaking Air Conditioning System
  18. water pump pulley bolt size?
  19. My brakes suck big time..help
  20. Going to look at a 90 GT in a little bit...
  21. which one is it, 50 or 28 oz. flexplates.
  22. Coolant/Temp issues
  23. Cooling issue
  24. opinions on this front end swap
  25. How to check for a bad balancer?
  26. Installing new cam...TDC?
  27. Ticking Noise!!
  28. x-pipe for long tube question.....??
  29. x-pipe for long tube question.....??
  30. Anyone ever greased their convertible joints?
  31. strange shaking/vibration
  32. Installing Intake/Exhaust valves hard?
  33. what needs changed to put explorer motor in 95 stang?
  34. Getting code 95, anyone had this?
  35. GT40 GT40P's?
  36. Fuel pump prime-how much pressure?
  37. Air Injection?
  38. Need H/C/I combo for 11's
  39. C6 trans in a fox?
  40. New Fuel Pump Install Question
  41. race pulleys
  42. need to know ya know.............
  43. Is there a difference ?
  44. need some to check my temp #'s
  45. Autometer Gauge Install Help Needed.
  46. High RPM Vibrations
  47. Took Off Center Cap And Heres What I Saw HELP
  48. how to put efi 351 heads on efi 5.0
  49. police oil cooler location?
  50. welding in O2 bungs.
  51. 1/8 mile results
  52. Build up
  53. Just spun the 5.0 onto a medium/island what damage should I look for.
  54. tranny question
  55. Low Collant
  56. Smaller turning radius with new rack?
  57. paxton s/c install
  58. To chip, or not to chip....that is the question.
  59. How involved is the manual steering rack install?
  60. i know its bench racing but lets try to estimate my et
  61. idler pulley reversal to bypass P/S & A/C
  62. Dynotuned - Average Results
  63. Did I break my clock spring?
  64. pushrods
  65. 1 dead hole???
  66. Went to Track Weds... Broke EVERYTHING
  67. well i took the big plunge......
  68. Will a bigger mass air help with my combo?
  69. WHY does every starter solenoid KEEP STICKING?!?!?
  70. EFI to Carb
  71. Which direction would you go if you had the money.
  72. info on how to replace hatch window.
  73. Bolt chain down to pull motor...
  74. Is it possible ?
  75. setting the timing......
  76. 8.8 Turbo Coupe Rear end?
  77. intake install help please asap
  78. whats the deal with foglights and my guage cluster
  79. rebuilding sd 5.0
  80. New UPR Suspension, Need Help
  81. Horizontal intercooler? Will I rip it off?
  82. battery trickle charger question
  83. Which Block Will Work?
  84. 89 Stang Restore *PIC*
  85. TKO 600 install?
  86. what gears are in this 8.8.
  87. how to pull codes?
  88. need lower intake help
  89. t-5
  90. $200 for a hood
  91. 351 Windsor
  92. Factory Stock Rocker replacement
  93. Anybody have the new MGW TKO500/600 shifter?
  94. Fuel pressure guage question
  95. Do I need a line loc to do a decent burn out?
  96. Deleting A/C
  97. TIRES?? plz respond!
  98. Discount!!! Discount!!! Discount!!!
  99. Turn signal keep blowing fuses...HELP!
  100. Suspension help.......
  101. should i remove spare tire, jack?
  102. PCV to manifold
  103. 331 stroker
  104. Ford head specs
  105. Fan belt part# w/Mac pullies?
  106. 5.0 carb questions
  107. How much do gears really help?
  108. msd problem need questions with a 6al box
  109. Brake bleeding problem HELP!
  110. Speedo Problem
  111. stock auto tranny in 90 5.0L???
  112. My intake install progress/procedure
  113. Turn signals and Vert top, what's the connection
  114. wiper governor assembly
  115. Basic Electrical question...
  116. Problems finding pushrod length
  117. exhaust ?
  118. Anybody looking for 5 lug Roush wheels found them on clearance
  119. no spark
  120. Injector and MAF Upgrade
  121. Flat tapped to roller
  122. i need help asap
  123. new heater core in but problems!! PLEASE HELP!
  124. No sound on aftermarket deck
  125. Cranks but no start, backfiring through intake.
  126. need to replace my ball joints
  127. Towncar MC adapter fitting
  128. My 76mm C&L MAF and intake tube review
  129. future 5.0
  130. Copper Header gaskets VS Stock BBK gaskets
  131. 90 Stock Short Block Longevity ???
  132. cruise control
  133. #1 cylinder has quit firing, heeeeelp
  134. Anything special needed for B&M Deep tranny pan install?
  135. Windsor Engine Database - Please add your engine!
  136. Gearing question
  137. 10.5in wide rear wheels?
  138. buying saleen rims...what offset? backspacing?
  139. HOLLEY SYSYEMAX II PEOPLE PLZ RESPOND
  140. Why so much vacuum???
  141. SN95 conversions opinions
  142. t5 acting up
  143. Starting Problems
  144. Whining from rear?
  145. cam reccomendations
  146. cam reccomendations
  147. 5.0 tuning problems need advice
  148. A/C, need ideas
  149. Mcleod Bellhousing Questions?
  150. Need Some Electrical Help
  151. one stock and 1 tubular A arm
  152. 4 cyl conversion problem!! need help!!
  153. Which block to start with???
  154. where?
  155. stock e7te heads
  156. Wheel Spacers
  157. What is this? & Where does it go?
  158. low low compression
  159. 02 sensor problem need help
  160. junkyard question
  161. wheelie!!!
  162. sensor question
  163. No tailpipes?
  164. how much would it cost in labor?
  165. Brake Question
  166. Need electrical Jedi Masters help....
  167. I need that relay .....
  168. What Alternator for a Carbed 302?
  169. Help me find a clutch cable please :)
  170. please help Edelbrock RPM II and RHS 200s gasket/leaking problem
  171. timing marks
  172. b303 cam problems
  173. Damm electrical problem...Help!
  174. pro m
  175. studders and hesitates ???????????
  176. 85 GT HO Troubles
  177. 1995 GT Overheating issue
  178. smog pump...fitment.
  179. is this a good code reader?
  180. car dies right after start
  181. mechanical vs electrical gauges
  182. 347 turbo Help
  183. Safe to run E-Cam with 1.7's?
  184. mass air vs. speed density
  185. MAP sensor questions
  186. boost
  187. full length or shorties?
  188. Code 66 + maf install
  189. Loud popping when taking off.
  190. Rearend Help
  191. 347 stoker engine. Brand new, custom built. How do I sell it?
  192. Is there a way to make the C&L 73 MM MAF work with my combo without a custom tune?
  193. Maybe not a tech question......
  194. gauge cluster
  195. H/C/I Install...
  196. Edelbrock performer VS RPM II
  197. headlight wiring
  198. 347 locked down.
  199. 1/4 mile time
  200. chassis stiffening
  201. What is it worth????
  202. battery tie down..
  203. Roll bar/cage questions
  204. anyone ever do a tub or mini tub?
  205. New 331 running great but 1 issue
  206. Boring a 5.0 +.060
  207. normal operating temp w/ aftermarket gauge?
  208. Fuel pump issue...
  209. Disaster -- tranny leak, engine stalling.
  210. help 5.0 vert owners....
  211. rust issues
  212. 331 vs 347 must choose for new build HELP!
  213. oil pressure sending unit
  214. Electric Fan
  215. New guy needing a question answered!!!
  216. Cold backfiring?
  217. 331 Stroker hesitating between 2-3k RPM's? CAM or Fuel/Ignition?
  218. exactly what harnesses
  219. anyone?????????
  220. swapping to 86 front end, what wiring issues.
  221. Vaccum Question
  222. Battery
  223. TAB and TAD solenoids
  224. How to update seatbelts?
  225. no squat no lift????help
  226. what camshafts are recomended for my 5.0
  227. Help I broke 2 Clutch cables in a day..
  228. What is this?
  229. Help with Powerdyne 9psi kit
  230. need help quick.
  231. any 347 guys using R-series trickflow intake
  232. Need advice with which route to go, combo question.
  233. tire rubbing issue...
  234. gauges messed up
  235. Car is still running like crap
  236. 5.0 Swap, just got an LX today.
  237. Where to order 351W short block
  238. what will theese do for me
  239. Anybody ever use an accelerometer?
  240. Need upper to lower intake bolts fast, can't find any
  241. help 4and 7 fouling out!!!
  242. need help have oil in upper plenum
  243. NOVI 1000 pulley question
  244. junk parts?
  245. car randomly stalls
  246. DOES THIS MAKE SENSE?
  247. EFI to Carb
  248. turn signals dont work???
  249. Tranny's?
  250. boss 302 block
