View Full Version : 5.0 Tech
- Consumption
- RUNNING HOT
- EGR and Smog System
- tune-up!! what all to change?
- Finishing my engine build, a couple last questions
- need pictures of wheel/ tire combo fox 5 lug
- cfi to carb help!!!!!
- having trouble w/ the 5.0...HELP.
- car wont start
- i need help with efi wiring harness and vaccum lines
- computer chips are they worth it need help
- A/C has no power - jumped low pressure switch/checked fuses
- what is this
- Egr Valve on Ebay will this work?
- annoy beeping noise
- new here an hope you guys can help
- Need help diagnosing dead power window
- 245/50 R16 Widetrac SR...good tire? Will it fit a '87?
- a9s to a9l
- o2 sencers
- PCV System
- Bellhousing bolts - what size and length??
- I NEED HELP WITH INSTALLING MY TRICK FLOW MANIFOLD. SPACER, OR NO SPACER?
- Piston stop for gt-40's
- powder coating upper intake.
- 18" pony rims - 4 lug
- 3.73's too much for road racing?
- Changing rear springs...
- Tranny extention housing thread stripped
- whistle
- Performance of a 302
- Can 5-6psi of supercharger damage 10:1 engine?
- Water in the floorboard. Pic of possible problem:
- fuelpressure?
- I get heat even when the heat is turned off.
- Correct A/C Liquid Line?
- 3.73 or 4.10
- Gas gauge not working?
- Timing & HP?
- no fuel! HELP!
- Stock Intake 1989: Hoses underneath curved part
- Question about body panels
- 50 ounce vs 28 ounce flywheel?
- engine analyzer 3.0
- blower motor replacement
- Tranni broken? cost of rebuilt?
- question about valvetrain
- Running like crap !!
- rear seat question
- Wiring harness length on 93 Fox O2 sensors?
- What's the best gap for GT-40X heads
- power gain with bigger MAF??
- guage cluster disassembly
- Installed new engine, Tranny Inoperable
- 2.3 to 5.0 conversion - fuel lines help
- Educate me on shocks.
- 5.0L won't start when hot, stalls when decelerating
- Noise when going over small road irregularities
- best way to install gaskets?
- Chemical Dipping or Media Blasting?
- Got the EXPLORER engine running, FINALLY!!!!
- catalitic converters and resinators do i need them
- 302 to 351W
- What other Ford cars used the same A/C comp.?
- 2 ?'s i need answers two asap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- For you notch lovers, me and my buds stang...whorin it up *DUW*
- 306 longrod w/ windsor jr. heads what sparkplugs??
- Could the Underdrives Cuase This?????(i am confused)
- budget aluminum heads
- Line Lock
- Trying to get quick horses and torque, please help!!!!!
- Engine Operating Way Too Hot No Explination..
- Educate me on Rear Axles
- 1986 5.0 Intake Manifold Removal
- Anyone ever siphon gas from a fox mustang??
- 3 questions i would like some help with
- Head Light Switch Wiring Problem
- Electric Fan with Toggle Switch
- eccentric
- Convertable rear view mirror lights won't shut off
- 3G Alt guys, come in... need help
- Dipstick location (5.0 Block)
- pop or clunk sound 50% of the time when going from forward to reverse or vice-versa
- Actron or Autoxray?
- What springs for GT-40 Y303 heads?!?! need help bad
- summit headers
- magnaflow X pipe $$$$$ why so much
- E303
- Ignition tumbler?????
- AOD question
- Timing Problems
- which counterweight for Spec flywheel? Need 28oz
- 7.5 or 8.8 rear end
- ECT Sensor Location
- what kind of springs
- transmission conversion help needed.
- i run 9's in an 1/8mile what do i run in a 1/4?
- Wet or Dry Kit for S/C
- Need help hooking up!!
- holley regulator ???'s
- Another "How much power?" thread...
- did ball joints today... still a creek sound!
- wiper arm removal?
- Question about wiring in the diode for an e-fan install?
- drivetrain clunk
- SN95 calipers on 85 GT
- best head gaskets for a 88 gt 5.0?
- Weird Problem
- computer ?
- aod overdrive blown
- Any problems with Maximum Motorsports SFC's ??
- Will SROD Bellhousing Fit TKO?
- Idle/Stall problem
- Motor Mounts
- Anyone ever use the Holley distribtuor (carb'd)???
- T-5 Transmission Leaks (I believe)
- Mustang convertible rear seat
- finally
- Hemp installing T-Top Rubbers
- Ignition Wiring?
- 13'' cobra brakes up front
- Exhaust Gauge Gas Temps?
- Throttle body
- Core Support
- Carb'ed ignition
- occaisonal backfire, also bogs
- Blowing coolant, overheating HELP!
- comp cams k kit
- spark plug question
- Timing and oct. for e303
- How much power/tq is this combo worth?
- 331
- new engine, black exhaust condensation, question
- What drag radial are you guys running?
- Pinion snubber removal
- will stock calipers work?
- 6400 RPM ok for stock engine.
- Setting pinion depth using gear marking compund
- afr edl trick flow numbers
- Battery Master Disconnect Switch Locations
- proform electric fan
- T-5 ID
- 100 miles/tank ?
- which pushrods??
- 351 or AFR???
- Consistent on Nitrous?
- 87 GT running rich
- Some ignorant newbie questions
- Is this all I need for clutch swap?
- 13" rotors in the rear...how do these work?
- 95 cobra r's fit on svo five lug brakes??
- 302 on engine stand
- C4 torque ratings
- Turbocoupe 4 lug disc swap
- need advice A.S.A.P
- Heads Milled .007... shorter pushrods?
- Fuel Grommet
- Timing cover questions
- T4MO and AOD?
- blower is on now I have tuning questions
- oil pan gasket question
- Good loud knock at idle
- tailpipes
- 5" tach acting up.....what could it be
- chassis and suspension mods what to expect?
- what original equipment ?
- Another Horsepower?
- How hard is it to rebuild a C4 transmission?
- Bolting back on stock rocker arms... Tourque specs? Adjustments?
- Cfi to Carb swap list
- weird stuff happening? bad ecu?
- Old cam, will computer like it?
- What the problem is?
- noise in the front end
- Having Fun Last Night Untill...BOOM...!
- radiator cap Vented/nonvented ??
- How good is the stock cam?
- supercharging a 347
- headbolt washers
- Should i get a Tubular K Member and coilovers?
- 5.0 Carb, T70 possible?
- Will 6.5" speakers fit all around?
- Vortech crank pulley question
- OH Gee-Willikers, this sound like a oil pump problem or worse?
- intake filter
- EGR SPACER OR NOT?
- Flowmasters on otherwise stock exhaust
- Removal of FMU
- 2000 suspension in a fox
- Engine trouble
- ABS, CEL, and idle problem
- a/c clutch crossover
- 93 with Mk VII rear brakes...Need help with parking brake
- shifting troubles
- New member with questions
- Running a 5.0L with no VSS
- 1987 Mclaren Mustang Convt. #171 of 479
- Centrifugal SC on a carbed fox
- i'm stumped
- All fairly stock motors, what does your Fox idle at?
- 4 cyl. to v8 swap what wiring
- Need help with my DD. A 2001 VW someone that knows the clutch
- whats right??
- t5 swap
- check engine light trouble
- Pinion snubber location
- B303 Cam worth the install???
- some advice on cleanin up this intake. . .
- Fan wiring help: Volkswagen switch + AC/on.
- This ones for you Crane Interceptor 2 guys...I need HELP..
- NEED INSTRUCTIONS ON GOING FROM '86 TO '87-'93 INTERIOR
- is there a way to identify springs???
- transmission gasket help!
- black seat belts!
- Anderson Power Pipes
- will aftermarket control arms and SFCs make the car less streetable..
- What Guage Wire For o2 sensors?
- another idle question
- 302 with SC or 331 stroker?
- Stalling on deceleration?
- need help with cam
- Question about drive axles
- I NEED HELP!!!
- Question about MAP/BAP Sensors
- Please help pick a Cam. Thanks!
- Car shuts off...
- cams
- Clutch Cable Problems.
- smell of raw fuel coming from the engine
- Surging Idle
- AOD fluid change/ Missing two Bolts! ?
- Cam timing dowel/pin
- priming oil pump
- sorry... I also have a v6 s10. Tried evrything
- Anyone have tranny fluid leaking AOD in RAD???
- Cracked Alumimum Oil Pan - Repairable? (non-mustang)
- I posted spam on Stangnet and got OWN3D!
- Crashed and Damaged
- Exhaust Woes
- spraying carb cleaner in carb....
- how big for rear tires...
- what to do next??? ideas???
- Fox Questions.. Need Help!
- Cam and Head combo that works well?
- 02 GT to Cobra brake conversion...
- Gatorback Belt???
- Tell me about these Holley heads I bought?
- 14.X:1 Fuel/Air ratio with a 300 shot of nitrous, is that right?
