View Full Version : 5.0 Tech
- Tell me about these Holley heads I bought?
- 14.X:1 Fuel/Air ratio with a 300 shot of nitrous, is that right?
- Car will not start! NEED HELP!!
- dead pedal is loose...
- Limp mode and CEL
- Just started running ruff ??
- No 5th or reverse in T5...
- Marchel fog light covers?
- Opinions on MAC vs Flowmaster catback
- New Baer brakes, not working so well
- Clutch problem ??? HELP
- A/C Commpressor not turning on, 110degrees outside!!
- WHICH YEAR IS BEST AND WHY 89 5.0, 94,5 GT,96-8 GTOR99??
- 89 L.X. 5.0 gas gauge always points full even with Key out
- Rear Wheels Noise (Clicking)
- CAN THE STRIKER POST FOR THE HATCH BE ADJUSTED
- Dcc installed..up and running
- Couple of easy Kenne Bell questions
- Possible OIL in rad, flowing through coolant..
- EFI experts; problem studdering acceleration... makes me wanna go carb
- quench clearance
- losing coolant, headgasket?
- Help me locate a whine
- Is it the driveshaft or what else?
- Overheating
- alt guage
- running hot no power
- anybody running a holley systemmax efi intake on a n/a setup
- sticking throttle/pedal question
- Longtube Installation Troubles
- Heads from a 85 351w on my 302
- timing cover and water pump question
- Plug gap for aluminum heads?
- electric fan ??
- need help with power steering linkage!!!
- viper t56 in 5.0 ?
- super charger questions...
- Installing driveshaft
- Major Problems after intake swap on carb'd 5.0
- Do i have EEC-IV on my 85 GT?
- Codes - What to fix?
- Cap, rotor, & wire help
- Where to get rear dogbone bushings
- Headers and GT40-P's
- Rocker nuts keep breaking...HELP!!??
- Head stud Question
- spark plug wire Poll
- If i deleted my A/C do I still need this vacuum line? PIC
- E cam and Speed density??????
- Did your 5-lug conversion?? IN HERE PLEASE!!!
- Running on 2 cylinders ??
- 5 lug ?
- trickflow,tw heads on a stock short block
- 1993 dash fit my 1988?
- Headlight adjustment
- 302 in a 79 4x4?
- oil pump shaft
- 5 lug swap rim choices... ( svo rotor swap )
- pushrod length
- radiator question
- E7 heads on a 289?
- 5.8 AND E7 HEADS...?
- '88 Quarter Window
- Recently upgraded alternator with electrical problems.
- DONE!!
- 5 lug brake light question and pedal firmness
- Fuel Line Install
- Which AOD/AODE?
- motor mount qusestion
- Shiftkit coming... what brand?
- Just bought 85 GT have a few questions guys
- Pulling motor!!!! HELP
- What Size Belt
- Air Bag
- steering "chatter"
- Effectiveness of O2 sensors on an off-road H pipe?
- EMISSIONS
- TrickFlow head questions....
- what size fuel pump should i use with my mods???
- Installing gears and locker diff..What else should I do??
- Master Cylinder failed. What upgrade options do I have?
- 190lph pump give power increase?
- gas gauge not working
- SMOG and check engine light
- PP bolt broke off into flywheel
- Bullit/Mach 1 shocks on '85 with C springs
- The best sespension for the job
- so whos all running the infamous afr 165s on stock shortblock?
- QUICK QUESTION?
- Electric fans off 95 gt fit 89?
- Aftermarket MAF sensor
- does anyone know if the tv cable
- car spudders when 1/4 of tank left of gas going up hill....
- Changing drive belt on 85 Mustang GT
- I think I screwed up
- DCC Unit
- The Drone stops here.
- Degreeing a Camshaft... HELP!
- Broke my thermactor tube during header install
- what do you think
- Thermactor plug using silicone?
- Just found rust on my floorpans....what do I do?
- Loud Droning Engine - Will Cervinis Hood Liner Suppress The Droning?
- looking to swap a 5.0 EFI/T-5 trans into my 68 Fastback....
- what else is needed?
- Looking for more HP!
- A/C Clutch cycles off/on above Idle.
- Shifter Install Help
- Correct header gaskets
- help taking off hatch
- Not sure what this is called?
- Seat Track Hardware
- WTF header leak wont stop...
- Foxbody vs 03 cobra engine
- does gear whine go away with break in
- Stock header bolts are rusted hard to remove it
- Got my transmission apart....more questions...
- Stripped header bolt threads on TW's
- Cast or steel gear diff need help asap.
- Spacer help (new wheels)
- T-Top kits?
- Cobra rear brake pads
- safe to patch leaking break line
- 89 GT auto shifts like crap!
- Clear up some conflicting 351 info...
- computer/circuit damage by running wrong sesnor?
- Teflon Rear Main Seal - Worth it??
- Finishing up the motor, need a few questions answered first please...
- gauge install help plz
- Fairbanks AOD tranny shift kit?
- Opinions on PA and TCI valve bodies for AODs
- I need drag racing help
- T5 gurus, broken T5, reverse problems, linkage questions
- 05/06 bullitt wheel backspacing???
- Are ARP Headbolts Ok? or should i do studs?
- supercharger VS. NA motor question
- i am confused about the valve geometry. i hate this thing
- Conflicting responces to flushing AC lines...can we clear this up?
- a/c robbing power?
- Where to buy upgraded valve springs for AFR heads?
- mass air conversion
- engine whiz's come in, head and cam compatable?
- cobra intake mani
- what could cause this??
- clutch prob
- Help! wheel lock gone.......
- newbie question 'bout crate motors
- camber plate
- Does IAC operate on a COLD start?
- Axle Length
- Nothing positive about the GT-40 Intake?
- Gt40 Irons?!?!
- No LOW BEAMS!
- Interior brake light comes on
- Thread on MOTIVE GEARS! SHARE INPUT
- new motor qestion?
- Rear DIfferential Fill/Drain Plug
- PA, Art Carr, or Lentech..which would you choose and why?
- need deserprate help with clutch and throwout bearing
- quick help please! upper control arm bolt size
- a NERVE RACKING RATTLE AT 5 MPH TO 35
- Spark plug gap too big?
- 12.5-13# oil pressure @ hot idle??
- convertible headliner
- New catalytic converters stink?
- Loosing coolant
- PA Performance 200-Amp Alternator
- Bronze Valve guide installation?
- anyone running tfs stage one with stock heads?
- UPR X-pipe w/cats?
- help with iginition switch issues
- sideloading the valves, stock rockers
- Incredibly weird engine problem. No SEARCH function will help me out!
- LT for GT40P's????
- Vortech s-trim 10-12 psi. What spark plug gap
- Junkyard today, need a little help
- Brake Pads
- what is this and should i replace it?
- UPR Boostpipe install
- engine problem found-rocker arm bolt snapped off in head-HELP!
- AutoMatic Preformance
- Will smog pump delete hurt cats?
- What does a valve slapping a piston sound like?
- Be Cool radiator question
- Doing my first Cam swap today.. 4 easy questions..
- Info needed on beehive valve springs
- Want a little more power...1.7 RR's or New Cam?
- Just help,thats all i need.
- $200 @ the machine shop?
- Control arm question
- noisy steering
- Ac + Smog delete power benefits? Mark vii
- whats the difference between 96-98 and 99-04 spindles?
- Pros and cons of different stroker motors
- Track legal Battery Box for Hatchbacks
- Is this the right Dizzy i need?
- Need Wiring Diagram for Under Dash
- 5.0 serges after it warms up
- Funny Problem, Limp Home Mode Solves Everything
- 4 lug axles
- No2 question how much will hold
- Help Went to the Dyno Today! 307hp and 325tq
- Hard Starting HOT ONLY, ACT Sensor Fixed The Problem
- 5.0 badge location.
- sn95 steering, what about pump?
- Possible Fuel problem?
- electric fan question
- ignition switch
- tranny question!!
- 3G: Fused Finally
- when do you need a transmission cooler???
- Aerostar 5lug swap parts?
- Need help... Gave a tune, won't start!
- Modifying E-Brake After disc conversion
- wiring help
- Check engine prove?
- por15 brushing on?
- 87-93 mustang sunroof???
- where to set fuel press
- FRPP 5.0 wiring harness
- No Turn Signals!! Help!!
- anybody have a quarter stick in their aod equipped fox
- Radio does not work.
- swaybar and suspension questions
- Help quick....I took my driver seat out now no start?
- what should i set timming at??
- eletrical problems, no power throught car
- 2 EZ QUESTIONS
- Vaccume Problem?
- Anyone know where I can find adjustable tailpipe hangers?
- interpretation of marking compound results
- window trim prep/paint
- E6SE Cobra (Gt-40) heads? what intake?
- Are the hatch cargo covers for sale online anywhere?
- Lowering with Eibachs
- Will this work ok?
- 351 heads
- Carb Help/suggestions needed
- Aftermarket Alarm
- Dash gauges in my 83
- MSD Problem
- chevy question, sorry!
- FE in a fox
- Who's passing emissions without smog equip.?
- an other cam question
- how to identify a frrp cam
- i hate threads like this but...
- Need help ASAP
