PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. can i use gt-40p heads
  2. pro 5.0 shifter question
  3. Will AC work after removal?
  4. Dexron II or B & M stick shift GL-5 fluid?
  5. Can I adjust the clutch here: *pic*
  6. I have been gone for a while. but bought more parts when i came back
  7. got my 351w......got any details????
  8. Strange hiss & ping noise at part throttle.
  9. Has anyone seen this before? (A little long but interesting)
  10. Guys with weld prostars, front brake clearence ?
  11. NO BRAKES
  12. Is the air being sucked into the filter supposed to be loud?
  13. Hyd. Flat Tappet Question
  14. vehicle wrap vr's paint
  15. Fuel pump, which one?
  16. New wheel bearings when doing front rotors?
  17. SN95 Rack & Pinion Swap, anyone done it?
  18. nitrous for my fox
  19. Need help w/ wiring for electric water pump
  20. can i use gt-40p heads?
  21. Little Blue Box????
  22. Transmission
  23. What is the plug going into the tranny? *pics*
  24. Suspension and rear drive line??????
  25. Exhaust mount for a TKO 600
  26. Moving ACT sensor on a Speed Density car
  27. Need Passenger side spindle.. Where to get?
  28. Ignition shift interlock cable
  29. painting fiberglass hood?
  30. pcv valve replacement, is this the correct one?
  31. time to replace the spec clutch... one question though..
  32. Autometer tach and boost gauge questions, almost done
  33. looking for the idle control sensor
  34. gt-40/ ford explorer intake
  35. do u think i will need an adjustable regulator for my combo?
  36. new combo in the works.. help appreciated (matching)
  37. gt-40 head info
  38. Vert Top Switch Problem
  39. Undercoating My Car
  40. how to tell is maf is pegged or bad?
  41. 86-88 GT Fuel Pressure Regulator Location?
  42. Build the 347 from hell!
  43. o2 harnes help
  44. Parking brake causing rear shoes to not sit properly...
  45. question about mini high torque starter and headers
  46. Still have problems!!!!!!
  47. 5.0 fuel injection big problem
  48. new dyno numbers are in!!
  49. dashboard substitution
  50. AFR 165, 185 or Trickflow
  51. Ignition Switch problem
  52. All new parts and shoes still wont fit right!!!
  53. '94 carpet in a '88???
  54. 5 lug question
  55. Where to read timing marks???
  56. Won't start...not a mustang
  57. starting issues
  58. Which cam?
  59. My stang is shifting to early, help needed.
  60. tremec 3550 gear ratios
  61. sunroof
  62. trick flow old streetheat old tfs
  63. Drifference between 302 stroker and 351W?
  64. front end sqeuaking noise... just a quick question.
  65. 94 rearend
  66. hood pin cable
  67. Speedo gear for Tremec?
  68. my typhoon vs a GT40 intake
  69. Fuel pump install question
  70. how to go about this?
  71. bbk t body whistleing: any way to stop it
  72. bbk t body whistleing: and way to stop it
  73. Hunting Idle, Random Stalls, No Power...
  74. Trying to gather information on stock/351/aftermarket blocks and I need your help!!!
  75. Tremec 3550 reverse light switch
  76. Replacing a Heater core
  77. Squeaks & Rattles
  78. Temp Gauge
  79. Steering wheel vibe! *help*
  80. SX performance fuel pump help
  81. i need help
  82. need help bad!!!!!!!!!!
  83. Autometer or Ford Racing OP and WT gauge
  84. does anyone know if they make a plain rear bumper cover to fit a 95 cobra
  85. looking for a plain rear bumper cover for 95 cobra
  86. Header Bolt Question
  87. 88 GT: please evaluate
  88. Friend with Vortech, Question about setup.
  89. Emissions test=Failed!! HELP!
  90. Clutch fork
  91. Oil Leaks Argh!!! Cant figure out..
  92. Another problem.....
  93. coilover conversion c/c plates and alignments shop ?s
  94. Need help bad...
  95. Hedman longtube mid pipes PLEASE!
  96. 56000 mile long block What to do, What to do?????
  97. Quick question.
  98. LOW BUDGET!! Need advice!
  99. Saleen vs FR500 replicas
  100. cooling q's
  101. How to rebuild a carb?
  102. Lower Ball Joints
  103. Traction
  104. What ranger axles ?
  105. which clutch cable (searched)
  106. Oil Pressure drops above 3k rpms......
  107. Broken water pump?
  108. looking for gt40 heads...
  109. carb guys in here now
  110. How much louder without cats?
  111. How's my dyno look?
  112. Help Side window install
  113. which eaton differential unit?
  114. Crane PS92 coil required with HI6 box?!
  115. timing chain cover
  116. AGR steering rack opinions?
  117. Help! '79 Latch Striker rattles like Morse Code
  118. Trick Flow Kit/ top end build up questions?
  119. running sluggish
  120. revelation! could this cause me to overheat?
  121. Just got back from the dyno...
  122. new radiator on budget?
  123. update pics on the taurus fan install...
  124. What should I use to clean my new cam before I install it?
  125. are long tubes headers hard to put on?
  126. Smog and A/C delete. Need belt size.
  127. Drive car with Supercharger Belt on?
  128. Idling High at a Stop?
  129. weird throttle or gas flow problem
  130. fuel line replace, help?
  131. Installing gauges. Sender question.
  132. Adjustable Rockers
  133. FMS 5 lug cobra conversion kits?
  134. p1sc folks...What's the belt size?
  135. Time to replace the Valve Seals
  136. rear end swap
  137. should stangnet make a FABRICATION section? VOTE
  138. Quick Question, Need Quick Answer!!!
  139. Those of you w/ 331-347 N/A Stangs
  140. Suspension Upgrades and Brakes Help
  141. Catted X-pipe or Catted H-pipe?
  142. Does anyone elses wipers skip across the windsheild?
  143. arp headbolts
  144. Stock Rocker arm geometry
  145. 1999 Gt wheel info needed
  146. New Engine Crank Seal Leaking??
  147. Duplicolor paint
  148. convertable top
  149. Air deflector
  150. Biggest, yet most practical street blower?
  151. Where did you install your wideband oxygen sensor?
  152. AC question....wont blow out vents?!?!?!?
  153. R-12 Freon
  154. 306 block capabilities
  155. how to prepare a manifold for paint
  156. Will this fan work...help an old guy out
  157. intake spacer question
  158. How do I choose which rocker arms to use?
  159. Brke Booster Upgrade for Fox Brake Conversion
  160. BBK long tubes collector size??
  161. Flywheel, Starter Problem
  162. Need More boost help me out
  163. QUESTIONS : TFS 1 cam and 1.7 rockers
  164. How to tell AOD and C-4 apart?
  165. getting too hot!!!
  166. AODE with Paddle Shifters?
  167. What gives with these codes?
  168. Blew Out My Trac-Loc Tonight...Dammit Couple Questions
  169. Surging Idle
  170. engine noise
  171. fuel gauge goes way over full... any ideas?
  172. Engine Swap Questions...
  173. shifter grease
  174. Best Springs???
  175. Resetting ECU? And where to use Dielectric Grease?
  176. AOD gurus to the rescue please...
  177. Best way to check for vaccume leaks?
  178. thermostat and oil pressure sending unit
  179. I need a List of Ford Engine sizes
  180. Vortech Timing/Fuel Psi Question
  181. Easiest way to remove the diff?
  182. supercharger guys
  183. 1984 GT Purchase
  184. Torque Converter changed - problems
  185. yet another 3G question (cant find what i need)
  186. Cats and smog equipment
  187. Car won't start, please help with ideas?
  188. Carburetor Question
  189. OEM windshield vs. company-specific windshield
  190. Electric Fan Overheating
  191. need info for possible paint job
  192. Failed E-test
  193. ground shorted?
  194. notching stock pistons
  195. car keeps moving with clutch pushed to the floor
  196. Opinion on these Hedman Headers
  197. Cheapest and best fitting 351 oil pan
  198. 79-93 SCUFF PLATE, BLACK
  199. What size are the water pump bolts?
  200. Do i need a breather cap?
  201. 4cyl. to 5.0 question
  202. What can I expect from a chip on my setup?
  203. My cats are rattling...Any way to make them stop?
  204. running hot head gasket leak?
  205. New Fan time !?!?
  206. tranny issues
  207. c-4 trans with reverse man valve body help
  208. AOD or AODE come stock in 93 GT
  209. engine build ??
  210. WTB: 85-93 5.0,5sp,notch... OHIO
  211. horsepower
  212. older 302 ?
  213. Help me find a huge vacuum leak.
  214. Max power for stock ca's? PICS INSIDE
  215. Engine Pro's.....Help needed with rocker arm setup!!
  216. i want a little FP guage for under hood, is this what i want?
  217. i want a little FP guage for under hood, is this what i want?
  218. POwermaster 140A alternator - is it going bad?
  219. to everyone who cant afford an electric fan..
  220. Battery Relocation issues
  221. new engine stumbles at wot
  222. A/C O-Rings?
  223. Whats stronger?
  224. stock 5.0 = no power after 4,000
  225. RPMS increase on its own!
  226. supercahrger!
  227. Starter Upgrades?
  228. A/C compressor clutch?
  229. 302 heads ?
  230. cam swap
  231. RPM's wont drop down after driving
  232. '87 HO-GT40P Engine Build Question
  233. Which cars came with C-4 trans
  234. A3M Computer
  235. H/C/I Q's and bolts
  236. Alt vs electric fan
  237. Heat doesn't turn off!!!
  238. door hinge pins.... how to remove???
  239. cobra rear bumper and tail pipes
  240. How about this block.
  241. .030 milled from a GT40Y head OK?
  242. wich differential off of what to buy?
  243. svo turbo on 5.0?
  244. V1-SC Install but no boost!
  245. Luggage rack on 92 LX
  246. tranny issues...help!
  247. Who has replaced their steering shafts?
  248. 5 Lug Done & New Wheels
  249. Chroming stock 5.0 5 stars
  250. No Gages
