View Full Version : 5.0 Tech
- RPM's wont drop down after driving
- '87 HO-GT40P Engine Build Question
- Which cars came with C-4 trans
- A3M Computer
- H/C/I Q's and bolts
- Alt vs electric fan
- Heat doesn't turn off!!!
- door hinge pins.... how to remove???
- cobra rear bumper and tail pipes
- How about this block.
- .030 milled from a GT40Y head OK?
- wich differential off of what to buy?
- svo turbo on 5.0?
- V1-SC Install but no boost!
- Luggage rack on 92 LX
- tranny issues...help!
- Who has replaced their steering shafts?
- 5 Lug Done & New Wheels
- Chroming stock 5.0 5 stars
- No Gages
- Has anyone installed these rockers before?
- What does compressed volume mean with head gaskets (little long winded)
- Good news, bad news
- 24 # injectors and timming
- how to identify gt40 heads??
- Speedo making a clicking noise...
- Temp Gauge Install Advice Request
- is my fuel injector broken?
- How are ball joints affected when vehicle is lowered?
- Belt routing with just an Alternator???
- Adjustable regulator if it has a screw in it?
- EGR holes one back of head, best way to plug em?
- steeda light wight drag sway bar?
- Wiring Problem
- Cooling issue..but not problem
- Running on 7?
- WHAT IS THE BEST 351 BLOCK TO USE?
- spring compressor?
- rivetless door handles?
- Best Cam to use for my setup?
- TKO 600 and bellhousing indexing - Is it necessary?
- 4.10gears with AOD Guys come in
- performer rpm on stock 5.0
- Cross threaded a bolt on header,how bad???
- PAS With K-Member?
- Best Oil to help Oil Pressure
- Snow Performance Methanol problem
- Which pistons for supercharged 306? Compression ratio questions
- Need Fuel System Suggestions. Going 347 Carb'd in 89 5.0
- Ping at idle , due to plug heat range or something else?
- Steering problems fixed but , is locktight needed?
- A couple of simple questions.......
- Has Anyone Used Studs to Bolt Down Their Upper Intake???
- oil pressure
- Mass air conversion questions???
- Map sensor issues
- Electric fan and keeping the stock shroud
- Autometer water temp gauge issue..electric
- Mod help, low voltage from pullies? Also intake help!
- help with codes 56 and 66.
- cleaning my engine
- Valve Guides worn out?
- fuel injector question
- Through the floor subframe connectors
- No mufflers at all
- Oil Separator pic
- Compression Test Question
- What bulb is brighter/better than Silverstars?
- dual quad manifold
- injector and timing seal ???
- Gonna be getting a new top on Wednesday...easier to do with the interior out?
- Suspension Question
- what cam is best?
- Convertible motor mounts = lower exhaust?
- tweecer rt....?
- long tube headers vs shorties, which is better?
- Do-it-yourself headwork......
- Putting in a used compressor,anything to watch out for just in case
- pics with cobra rims
- Am I out of gas?
- what hp #'s will i have, what 1/4 mile times?
- Quick Trans Crossmember Question
- Heater Core placement
- AC and Vent questions
- Would a 97gt 30lb injector fit on a 5.0
- Procomp dizzy run one?
- what parts do i need for a 5 lug conversion
- nos
- Gauge light??
- how to test a maf.....help please
- Computer fix?
- Valve lash adjustment?
- Dyno results (dynocom)..any thoughts?
- Spark plug gap
- Need a paint code
- Where to route ebrake on 5 lug conversion
- wire harness question
- Which parts store brands to avoid for brakes, steering, sensors?
- Any muffler suggestions?
- value and benefits of an angle plug job
- BBK H-pipe
- Spark plug wire ?
- Just bought some Bullitts!! Need an answers!
- Wrong-sized washer stuck to ARP head stud...
- Computer identification
- anyone have a dyno of afr205/347/kennebell setup?
- 5 lug conversion ?
- Speedo is 15mph off.
- Putting a balancer on-
- 418w stroker witch intake & cam to get?
- Clutch pedal problems or tranny(hope not)
- too much crankshaft endplay
- Speedo Cable fix
- How is my porting skills? Too big or Just right?
- reverse lights
- Unique accessory belt routing. I need help!
- My car has got the hickups....
- Sticky Gas pedal after making a hard run...
- stiff gas pedal
- Tri-Ax shifter vibration (adv tech help needed)
- are these b or c springs
- Need an engine measurement ASAP
- Speedometer Not Working
- Any tips on replacing in tank fuel pump with holley blue
- help me
- stock TFI module on MSD Distributor?
- High RPM Miss - need help!
- trunk mount battery wiring questions
- no timing pointer...
- installing a hood scoop
- 94-95 f-150 5.0
- What size battery cables? The bigger, the better?
- tremec 5spd?
- Pushrod Guideplates too wide
- stud mount rocker HELP!!! pretty please
- Quick AEM UEGO WB question.
- Interior help
- Rearend question--yes I've searched
- What are the best budget shocks and struts for a 88 LX?
- cooling
- Fuel Pressure regulator/Valve Springs?
- Air/Fuel Gauge ?
- Need Help Bad!!!!
- 1988 Ford Ranger 5.0 (1989 Mustang GT)
- Pinion Seal
- sensor question
- Non H.O engine
- Clunking from front suspension
- Fox Ball Joints
- PROBLEMS need help!!
- How to remove rear speaker deck cover?
- A/C not blowing cold air!!!
- Door handle question
- Y303 Heads and TFS Stage 1
- Where to get a Shortblock
- Interior Screws - Which go where?
- intake choice for 331
- tko-500
- Breslin locking headers bolts questions
- Has anyone used holley projection 4 or a newer 950 cmdr?
- fault code reader
- 5.0 pcm tuning?
- cam and crank timing????
- Cant figure out this screeching noise!!!
- Autolite 24
- What kind of fuel pump do I have here?
- Who Knows what this does?
- Will this work for my 3g install?
- does anyone know how to hookup a hightork starter/help me!!!
- removing stickers
- WILL 70MM THROTTLEBODY FIT
- McCleod Bellhousing Owners Come In
- Engine is Almost done, a couple last questions
- Tublar k member
- 24's good for stand-alone on an SC-trim??
- brake plumbing trouble!!!
- Electric Fan Question
- Good Intake (etc) Recommendations?
- 24's on a 331...please tell me that will work
- 331 shortblock : CHP or DSS
- Progressive rate springs stiffer than specific rates?
- wiring speakers - 89 GT
- billet steel timing set or not?
- vogtland springs?
- thinking of going carb'd (another one)
- If the balancer ring spins...would the engine vibrate?
- Painting Interior Parts
- will stock pushrods work?
- Alarm wiring color code?
- installing BBK longtubes
- Autometer gauge's question
- Rear-End Makeover questions
- Anyone ever have EGR or TPS problems..
- Help Me HISSIN!! +other cooling gurus
- taurus fan in....temps only lowered a bit??
- Guys using Lakewood Tracion Action control arms pn-21900 come in
- Lower Intake Manifold Leak
- valve cover for gt40 heads...
- Mechanical Fuel Pump
- adjustable clutch cable or stock????
- Notching stock pistons
- 3g question: Where to find connector for white wire.
- Carb--> EFI... Can (2) Regulators be used w/EFI Fuel Pump ??
- How much HP will Stock Fuel lines handle.....??
- Timing Question
- Clutch cable
- What intake/injectors would you go with?
- stock pistons?
- Brake Line 7.5 to 8.8 Rear Swap ???'s
- Will excessive heat kill batt?
- wire hack job
- 50resto door armrest pads. Securing issues.
- what differential is this? e6s-wba
- Stereo wiring problem!! Help needed!
- color code list
- wiring problem
- v-1 vs. novi 100
- Plug looks majorly diff from others! Any ideas?
- SN95 MASS Air
- powerdyne XB-1A blower
- Smog Elimination Questions
- Am I missing something???
- How can I tell if 6AL is working?
- Carbed in MA: Failed Emm(HC:2/1.2 CO:27.37/20) Need tips!
- Cowl Hood Vent
- spindel?
- Help Antifreeze leak
- Cam timing
- fuel pump
- Help with problems on first startup after h/c
- Need Fuel System Help. Going 347 Carb'd in 89 Fox
- To port, or not to port, that is the question.
- anyone use a MSD cap and rotor kit
- whining noise
- Fuel Leak...damn
- Weld wheels, help!!
- Did starter take a *****?
- MSD Digital 6
- Did any of the Foxes come with metal clutch quadrants?
- need options for good nitrous cam
- Vehicle Speed Sensor Seat
- 351 or 331?
- Is 130amp alt. enough? Pulley Question.
- Sticker Tech
- Convertible p/w p/l wiring harnesses...
- installing a new clutch cable
- Spark Plug Question...
- deciding on a new color
- info please
