PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254
  1. what condition are these pistons in? (pic)
  2. Hot Start Flooding?
  3. Anyone try these Accel 5mm plug wires?
  4. Questions about V8 Explorer/mountaineer heads and blocks
  5. Throttle response delay and hanging idle...
  6. Help me get into the 115-116 mph zone!!!
  7. Brake tech 95 to 99 cobra set up on FOX mustang
  8. aod
  9. T-top Door glass
  10. Bought a street avenger carb idle is at 1900 help
  11. Do I need injectors?
  12. rough idle still..
  13. 1/2 Dead Stang
  14. 99-04 convertible seats - do they fit in 92' vert?
  15. 99-04 seats in a 1992 Notchback
  16. Missing
  17. Hard Upper Radiator Hose...is this normal?
  18. 3 g alt swap question about the 2 capped wires
  19. What tires???
  20. 351w deck height??
  21. Car Shakes at 65-70 mph?
  22. Weekend mods, will I be sorry?
  23. coolant temp question
  24. wiring help
  25. is this worth the $$$$
  26. Engine Balancing Questions
  27. engine coolant light
  28. Low Power to the Pump
  29. Trying to get the perfect stance... help/ideas
  30. Where can i get a drum backing plate?
  31. ANYONE HAS QUAD SHOCKS>?
  32. OK, has anyone switched to Royal Purple Synchromax w/positive results in their T5?
  33. transmission whine
  34. Where to get a harness
  35. Cam dowel short or long?
  36. removing and installing engine, easiest way??
  37. FOR ALL THE AOD-T5 SWAP GUYS
  38. K-member
  39. Quick question on fan controllers
  40. NITROUS GT-40 QUESTION............
  41. Jasper 306 cid motor specs....
  42. Belt tensioner modification
  43. Gear in the rear- does brand matter?
  44. REAR SUSPENSION SET UP WHAT TO DO?
  45. Codes 21,29,41,87 after mass air conversion
  46. Car wont fire -- GOING TO CRY
  47. i'm fearing the gear......reassurance needed
  48. 24#r's not enough 30#r's to much which one's to play with?
  49. Engine problem driving me crazy, nothing I try seems to be working, please advise!!!
  50. Changing T-5 transmission fluid - Royal Purple Max ATF or Royal Purple Synchromax?
  51. WHICH A-ARMS?
  52. did Bog Warner t-5's come in a 4 cyl
  53. T5 Swap done.....No Start????
  54. Back-fire through intake
  55. Have a little scoring on end of crank.......
  56. Fuel pump help! Under my friends car right now!
  57. Fuel pump help , working on friends car right now!
  58. ratech, solid spacer pinion shim setup
  59. x-cam clearance
  60. electric fans?
  61. Car is overheating sometimes.. broken thermostat bolt
  62. starting my single turbo install
  63. 3G Upgrade on 88 GT
  64. Super Fast T-5 Disassembly Question
  65. help with 83 5.0 cam
  66. which gearing?
  67. What exactly is CRYo2?
  68. heard of a subframe technique... sounds like it would work.
  69. flowtech headers
  70. oil pan gasket
  71. 393 long block ?
  72. Kicker shocks
  73. Anyone use the Summit Carb'd complete fuel system?
  74. Looking for mechanic for sub-frames?
  75. Getting pretty ticked off!!!
  76. where to buy a blocker ring for a t5?
  77. TKO 600 PROBLEMS
  78. Did original verts come with a glass window or plastic window?
  79. bolting heads on!!
  80. help on exhaust!!!!!!!
  81. anyone replaced rear window panel only on their vert top?
  82. Carpet soaked, interior is out, anything else to do while its apart?
  83. the site for pulley sizes
  84. 347 ?
  85. fuel cell question
  86. How bad is the flaming river manual rack install?
  87. ECT question
  88. Short Belt set-up pics needed please
  89. Starter question
  90. MAF Question
  91. ratech solid, pinion shims
  92. Has ANYONE found out the vibration prob?
  93. 3" collector /w 2.5 inch mid pipe
  94. Anyone using a lincoln injector harness come inside
  95. exhaust question???
  96. exhaust question???
  97. what isss this for ?
  98. ELECTRIC FAN INSTALL Qs
  99. TPS Sensor Accuracy???
  100. LMAF and 42lbs
  101. now im really bummed
  102. Mac gt40p header clearance problem
  103. problems
  104. distributer question ? need help
  105. Clutch worn or stretched cable?
  106. Early Fox body question... 79-84 era inside please.
  107. 4 cyl springs in a 5.0
  108. 94 t-5 in 90 vert
  109. shift kit
  110. ignition switch.....
  111. Cam Size??
  112. 331 Stroker pistons
  113. After a near accident, What makes Fox brakes so bad?
  114. Diagnosis Help
  115. Oil control thru PCV with Procharger
  116. car shakes when clutch is released after t5 swap
  117. Need help with EGR reinstall
  118. Camshaft questions? Lope, good sc cam
  119. Cam Guru's help me choose Comp, crane, or trick flow cam for my 306.
  120. 96-98 Maf on an 89
  121. AOD To T5 Conversion 86 Mustang GT
  122. Clutch cable OK with 135k?
  123. MSD 6al/SCI-l question? Sacralege?
  124. help with part # suggestion for exhaust parts behind h-pipe
  125. Did I just blow the motor?
  126. Hatch leaking when rains!! help desperate plz! i need these look
  127. need carb size for a 418
  128. Those with Flowmaster Catbacks on their 5.0's!!!!
  129. fuel pump eccentric on 351W questions
  130. what parts do i need?
  131. Parking Brake Cable Placement
  132. Intake Manifold
  133. Cowl Hood Install
  134. How to decide header size? 1 5/8 or 1/3/4.
  135. '01 injectors on a '93?
  136. 3.73 question
  137. GT40/GT40P head questions, worth it with my setup?
  138. youve gotta be kidding me.... bolt in the oil pan
  139. MSD TFI Problems?
  140. wheres the VSS located????
  141. Eccentric bolts to adjust camber??
  142. Help! I've done the checklist and still having idles issues, s/c, cai and maf...
  143. Power rating on 86 5.0
  144. What loc-tite to use on cam bolt?
  145. valve covers
  146. Which Offset/Backspacing with 96+ spindles?
  147. Balance assembly to 28oz or 50oz
  148. Engine Builders: Need HP numbers? Enter
  149. 3g alternator upgrade problem
  150. Need help with external shift light
  151. my theory of valve float
  152. Another “which mods next”?
  153. i upgraded my oil cooling & pvc / valve cover baffle setup - pretty amazing results
  154. Can you figure out which Heads are these? *pic*
  155. Black magic extreme electric fan
  156. Will they fit ?
  157. won't turn over after t5 swap
  158. Need eibach spring help? #59382
  159. window trim and rain?
  160. How Tight should the AIR Tubes be?
  161. brake booster
  162. manual brakes and steering
  163. I am in trouble
  164. who has best price on m2300k brake conversion
  165. Good front tires to match nitto 555r rears?
  166. stock tach help
  167. made some additions, what is your estimate on my et?
  168. Should I buy this 86 Capri RS ???
  169. Speedometer way off
  170. Spark Plugs
  171. gt 40 heads what size inejector should be used
  172. How to i.d. police 87 notch?
  173. Flex-a-lite electric fan controller?
  174. 3G Conversion Tech Articles
  175. What paint gun do you guys recomend for a beginner?
  176. How to put a speedo in
  177. PCV Valve help !!
  178. Why do my lifters keep cocking sideways?
  179. WHAT SENSOR IS THIS ?!
  180. should i have the flywheel turned
  181. Summit is producing new 302 blocks now?? Anything special about them?
  182. My Car died leaving me stranded
  183. A/C knob ?'s
  184. Ratchet sound
  185. clutch cable melted
  186. Intake project... need help on ideas/input.
  187. xpipe question
  188. New Muffler Time!! SLP Loudmouth vs Bullets vs 1 chamber flows
  189. Svt Contour Seats?
  190. Belt size ?'s. Smog delete and AC delete
  191. 3g alternator upgrade
  192. victor jr. header gasket
  193. AC charging ? Re: vacuum pump
  194. connecting rod questions
  195. Problem with idle. idles low then cuts off
  196. Problem with idle. idles low the cuts off
  197. short block?
  198. rubber boot onto MGW
  199. electric fan increasing gas mileage?
  200. 1993 Cobra Mass Air Meter!!!
  201. 79 to 90 Fuel gage/ sender question
  202. Heater Control Assembly
  203. Newbie Tech thread
  204. front sway bay and end links
  205. Removing lower intake
  206. Starting Problems
  207. MSD Coil Failure
  208. Further on possible failing O2 sensor
  209. Uneven Rear Brake Wear
  210. Would you use these gears?!?
  211. coolant coming from firewall/waterpump noises
  212. 94 Cobra shortblock question
  213. Best California Emissions legal CAM for
  214. Where is brake booster stuff located?
  215. 351
  216. Stalling when downshifting, suggestions?
  217. Load Leveler from ebay?
  218. Front Struts
  219. AFR heads but what cam?
  220. How does this combo sound?
  221. 3G Alternator....The Right Alternator for My 5.0?
  222. Anyone ever replace a backing plate on rear drums?
  223. BBK H-pipe and O2 sensors
  224. 351w Harmonic Damper Spacer
  225. What's the shortest aftermarket intake manifold?
  226. Carpet R&R Question - 90 GT HB
  227. exhaust setup question...
  228. Has This Happen to Anyone elses Kirban Reg.
  229. FRPP cobra aluminum radiator
  230. vortech super charger worth a crap?
  231. Stroker Kit
  232. IS this a big job?
  233. rev limiter question
  234. Installing timing chain
  235. another stupid smog pump question
  236. Cobra brake upgrade in jegs 4 $900
  237. Tach Issues....
  238. *VIDEO* Vacuum Leak Sound from Upper Manifold?
  239. Hatch Trim Pieces 5.0
  240. Starting Problems - Battery Sparks, Car Starts By Itself
  241. T5 SWAP DONE!!!!! CAR WONT START??? HELP
  242. 331 cam
  243. could this be my lean problem?
  244. Ho do you remove the head rest's on a GT
  245. Question on fuel lines
  246. Need Help PLEASE
  247. Taurus fan depth? Water pump rotation direction?
  248. Need some help with MAF convertion
  249. Suspension gurus: Need help with uneven tire wear
  250. Is this a T-5 Z or not????
