View Full Version : 5.0 Tech
- re-degree the cam?
- Sunroof Removal
- whats my compession ratio
- PISTON RING QUESTION
- Doing afr165 heads and stock bottom..what else?
- Solved Vibration!! but now tranny leaking badly!
- Putting my oil pump and pickup on tonight...
- 86 GT Brake Upgrade (What E-brake cables?)
- Should I switch to an RPM 2?
- Stock pushrod length??
- A/C question
- vortech 5-6 lbs kit , what pulley for 8lbs?
- head unit upgrade question
- truck lower and holley upper?
- haha look what i got
- question about spintech exhaust
- please help with ac
- Fuel pressure gauge
- Backfire?
- Fuel tank replacement?
- Another Cam Saga
- AOD to T-5 swap shifter console same?
- Pulled codes. help
- Has anyone done this?
- Any opinion on Pypes Violator mufflers?
- Doing stock rebuild, want more compression...piston recommendations?
- 24# injectors
- 92 LX 5.0 T5 with vibration at 85 mph or 5000 rpm??
- need a tune badly could anyone help?
- 5lug REAR disc conversion
- Rick91GT..need info.
- Anyone running Dr. Gas x-pipe and Magnaflow catback?
- Two Questions
- To anyone wondering what I was talking about "weephole"
- 347 StrokeDaily Driver Opinions and advice needed please..
- t-5 help
- more idle troubles
- Can someone help????
- Software that Ford uses to look up parts
- Different years, different harnesses?
- Rim Back Spacing on 9" Rear End?
- trickflow stage1 cam annoying?
- CAR GETTING HOT!!! PLEASE HELP
- alignment wholes on strut tower?
- T5 SWAP HELP!!!!!!!!!
- what should i do?
- why wont this @$%@ come out!
- My car overheated, now I have hesitation
- wheels that work with summit ford 5 lug conversion
- Fuel Pressure Gauge
- After TFS h/c/i swap, car runs rich + stalling...
- Clutch problems and fluid question
- fuel pump bad??? need your help!
- Possible Blown Head Gasket
- mark VIII fan vs a crown vic fan
- NEED HELP ASAP - adjusting valves.
- Starter help! Starter continues to turn seconds after car fires
- Spark plug for Dart-Pro heads?
- Not running a Smog Pump, cool or not cool
- best upper intake
- Weird noise from wheel
- Rear end problem
- Dart block and keeping cool
- Possible crate engine issues with AOD
- 7.5 vs. 8.8
- Thermostat
- blower experts needed: blown HG on my kb'd 5.0
- How to Put New Hatch Window Trim On?
- new smog pump
- question about my 68 289 heads
- Thinking of twisties vs. drag strip
- car wont start....help!!
- t-5 to auto swap??
- Spend my money
- Gutting Interior of 90 GT Hatch
- TAB, TAD, and A/C Wiring Q's
- spark plug gap ?
- battery in trunk with 3g alt
- coolant temp spikes when lights are turned on...
- got a question about my catback
- Fox sun visors - vert VS notch/hatch?
- What Are These Things?
- ac drops my voltage
- Help me build my rear suspension please!
- wheel bearings
- can you id these heads
- 4 lugs to 5 conversion question
- new block sitting in garage....
- Found the bolts, how many do i need?
- what's wrong with my clutch?!?
- What hold on the side door moldings??
- how to fix hydrolocked motor.
- My Rear End Situation
- Best Fox Suspension! Your opinion matters!
- Custom IC Install (Pics!)
- addition of oil for 134A retrofit
- T5 Swap Complete-No Reverse Lights, Which wires do I splice???
- Question..plzz?
- ford tech help needed
- underdrive pulleys?
- Car sits at an angle
- 88 Coupe 302 won't start
- Install Problems Yesterday
- In need of bolts, cant find them anywhere!
- hood latching ?'s
- Locking hood pins? what pins to get?
- Stereo draining battery
- Bottom end Rebuild
- Head gasket options...
- Your opinions of this Intake/Cam/Head combo...
- no fuel to motor yet the sparks fine (2.3 to 5.0 swap)
- What gears for the 1/8th ?
- Cotton Filters
- Roof rail moulding question
- New wheels
- Cardomain
- Suspension Set-Up Sound Good
- Tokico or Bilstein?
- ECU issue / question
- Speedo Gear
- Tubular K-member not clearing steering rack
- What Would You Do????
- astro performance super alloy t5
- transmission ready to give up?
- Fuel Pressure???
- Removing Swaybar
- T5 Swap Question
- SO MANY SUPERCHARGER KITS! Which one to choose?!?!
- Car Wont Crank
- violent motor shaking..please help
- bottom halves of door hinge
- Diff Bushings.......Porta-Power?
- Tranny help!!!
- Third Gear Help????
- Exhaust and Sensors?????
- Any idea how to fix exhaust with no welder, no money, no lift, and no time?
- Delayed clutch chatter?
- what size TB??
- Synthetic Oil Pressure?
- torque spec on arp main cap studs w/ girdle
- Should I do springs
- size of hole and thread needed for return line for a supercharger??
- T5 BEARING RETAINER TORQUE SPECS????
- TPS question
- new syncro, big deal or what?
- Considering purchasing a used s/c
- adjusting the tv cable
- Injector Question 5.0/4.6
- B & M short shifter any good?
- Installing transbrake...
- One Chamber Flowmasters
- Radiator which one to get?
- HELP STALLING PROBLEM AFTER SC INSTALL!!!! & Hard start!! ARGH!
- C4 guys in here.
- ONE MORE 5 LUG QUESTION
- Fault Codes
- Cranks Ok, but does not start Checklist
- are the aod's in all ford vehicles the same?
- Long Tube Header Question: H or X pipe?
- Cruise Control Linkage
- Fuel pump
- 351 Help
- 8.8 questions
- Why is my MPH slow
- Cam&Heads and now...
- belt sizing
- 460 project
- CLUTCH QUESTION..
- Gears and shims
- sudden idle problems..
- 351W build ?'s
- strut tower braces anyone?
- re: distributor rattle
- which ecu pin to wire up C.E.L on 87 mustang
- Bad engine mount?
- T5 tranny connector
- Remove heater core through glove box?
- Thumper Guys - Valve Question
- Maximum Motorsports Control Arm Install
- electric water pump ...question
- Wierd Problem... Vacuum through Oil Filler on Valve Cover
- Just finished TFS h/c/i swap and the car wont idle...
- Tranny/B&M Hammer Shifter Questions
- 650-cfm carb on a 408/427?
- building engine from ground up... need assistance
- anyone else have this same noise under thier hood
- Rear End or Clutch Problem?
- Pre - Ignition
- c4?
- GT40P specs
- Charging issue!!
- 351 shorty headers
- Axle cover fill plug
- Air harge temperature sensor
- A/C compressor squeaking
- autometer tach install??? help
- STS's response to disadvantages with rear-mounted turbos
- AOD T5 SWAP HELP!!!!!!
- KSR Underdrive Pulleys
- How to prep bumper after sanding
- now what?
- procomp 9000 series distributor
- Car Should Do 11's But Wont?
- Question!!
- 86 - VSS Signal Wire Color Codes
- Supercharged Vortech guys with electric fan, show me what you're using
- Help with ring install
- Speedometer
- Odd oil pan leak Please advise
- help with cobra MC
- Electrical Question...
- help me find a good setting for shocks/struts
- what is leaking?
- 351 cam info please help
- Need Help
- ET sacrifices running 17" wheels
- Wont start,puff of smoke
- HELP please
- Will it Work?
- bumpsteer Kit
- Headers Questions
- Another "What is This Plug?"
- Timing Question
- remote reprograming
- Code 22 - MAP/Barometric Pressure Sensor
- Intake baffle=more Horsepower
- torque specs
- Oil Pump Q's.....
- Spray Painting Front Bumper
- COBRA INTAKE UPPER AND LOWER
- 4 lug FR500 wheel??
- what all is needed for a 2.3 to 5.0 swap
- fuel/induction gurus....maf help
- Power window and door lock problem
- clutch release bearing question.
- Ignition Switch Harness
- OMFG! BBK X O/R sounds like a tin can
- Coil spring compressor???
- Help me identify this vibration...
- Need Some Help
- Power door lock install/alarm experts needed
- Aluminum driveshaft=last vibration gone (long post)
- Crank pulley problems
- blown 347
- HELP!! MY horse is running hot !!
- Spring isolators
- computer ?
- Muffler hanger locations changed?
- Removing A/C setup need help
