PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 [84] 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254
  1. Throw Out Bearing
  2. 5 lug??
  3. What Type of Welder for Frame Rails?
  4. rad cams,high compresion, vibration 3500rpm help
  5. weight vs 60'
  6. Trick Flow Stage 2 cam?
  7. engine question
  8. 302 93. from F150/e van.
  9. 6G Alternator Install
  10. C4 transmission help
  11. Really Weird Problem
  12. BBK LTS Anyone Run em straight
  13. 8.8 rearend rebuild help
  14. how hard is it to bleed brakes?
  15. non HO motor to HO
  16. What is the easy way to pull U-Joints?
  17. Whats the most power anyone's put down with 30# injectors??
  18. need help reinstalling shifter in my T5
  19. Here's a newbie question
  20. Airbag Troubles - Is it Broken?
  21. supercharger on trick flow h/c/i
  22. Which Heads? 165's or 185's?
  23. Lowering without the rough ride?(searched)
  24. Post your 302 based stroker combo's
  25. Check engine light is on but I can't scan any codes
  26. Water Temp Sending Unit Questions?
  27. 4 Eyed Help! Car wont start!!!!
  28. I want tilt sterring. COST???
  29. LM-1 with rpm converter
  30. 96 cobra engine, value??
  31. Best wires to get???
  32. Will a T5 tranny from a 4 cylinder be Ok for a few months?
  33. gt40 head valvetrain upgrade
  34. bearings failed in Crane Gold Race Rockers/Rebuildable?
  35. battery/alternator problem?! please help
  36. fan noise
  37. timing adnvance
  38. What should I look at now
  39. cant find speedo gear for 3.90s
  40. Using Jrichker's Fuel pump test. Do I really have two bad computers?
  41. Heater Bypass kit??
  42. Some nitrous questions.
  43. Quad shock removal?
  44. 302 headers work on 351w
  45. I need help with Rim size! I know.....
  46. Motor Mount issue in a 2.3 to 302 swap
  47. Who here with a fox body runs an off road X with an AOD
  48. Hi-newbie w/ questions
  49. spurtering when pushing on the gas
  50. Prayer for a Mustang God
  51. HVAC issue
  52. pennzoil HP gear oil, says not to use modifier
  53. T5 oil and emissions hole block off?
  54. should i get another electric fan or go back to belt driven???
  55. What size Carburetor?
  56. Vic jr spark plug
  57. :nono Nitrous,and Boost a smart thing?
  58. One last stupid 5 bolt question
  59. Please Quick Answer
  60. Reinstalling heads...ARP bolts worth it?
  61. Motor feels sluggish after being put back together
  62. Valve piston clearence
  63. Removing locking lugnuts that I don't have a key for.
  64. Injectors?? do any other ford vehicles come with over 19lb?
  65. Major Clutch Problems
  66. Talked with QA1, need some input
  67. need check engine light help
  68. what kind of timing light
  69. Window Question
  70. 140 mph speedo, what year?
  71. what CR for a 306
  72. Full Length Headers for Automatic??
  73. What will I gain with a 3G upgrade
  74. tips for driving for better milaege?
  75. 8.8 Rearend Fluid
  76. Fuel pump control ?
  77. 4 cyl throwout bearing retainer
  78. 351 roller info
  79. T5Z questions
  80. I need help, bad. T5 swap in 88 5.0
  81. suspension
  82. Injector size?
  83. Opinion please
  84. True Fit Exhaust tricks? Tired of the leaking!!
  85. Couple questions
  86. 4 Eyed Help!!
  87. Need Help....87 5.0!!!!!!!!
  88. HELP! valve springs swap
  89. Need Help..347
  90. Expected HP/TQ gains??
  91. Using thicker head gasket to lower compression?
  92. Taillight Help!
  93. MAF problem with supercharger
  94. SEAT WEIGHT - GT vs LX stockers
  95. Suspension Question
  96. Swap motor OR everything else?
  97. Another Battery relocations question..I just cant decide. help.
  98. highest compression and still on pump gas?
  99. max psi for psi testing A/C with nitrogen
  100. rear end issue
  101. Summit Line Lock
  102. March Ram Air
  103. x3z with an aod?
  104. what is your opinion???
  105. Idle Problems-Different
  106. Need help with engine codes 66 & 87
  107. Engine? Please help? money? DESPERATE
  108. idle ?
  109. 900 dollars is it worth it
  110. panther platform
  111. Noisy T5...Going Bad?
  112. best alum heads for Bcam and cobra intake?
  113. lots of problems, could use the help
  114. How to Install throw out bearing
  115. 95 seats in a 91
  116. Bassani cats are smoking
  117. question about flaming river rack
  118. 17x9 Wheel, Need Help -pics!
  119. Tire help please....
  120. does anyone have zex install instructions?
  121. Power loss
  122. Need some Questions answered.
  123. Short block question
  124. Bone stock GT and 8g's. What do I do?
  125. Brake Help
  126. engine swap please help!
  127. Large vibrations at high speed and on decel. Rear end is clicking.
  128. how do you pull codes?
  129. how to measure wheel width?
  130. Best year/type of mustang for drags
  131. Do i need a mounting bracket?
  132. Quick question for people with Trick Flow Kit
  133. throttle body to big?
  134. Timing Chain Question
  135. TPS install?
  136. Drag Radial Question
  137. Throttle Body Size help
  138. How do you test the fuel guage sending unit???
  139. Valve spring clicking?
  140. 5.0 Compression test & head gasket question
  141. Pypes catbacks
  142. spider web and dog bones any problems?
  143. Switch From Equal Length Shortys to Full Length?
  144. Quick Pro-M question
  145. 4 or 8 cyl. t-5?
  146. dummy catalytic converter for mac off road
  147. nitrous not working...95 GT 5.0, dry kit..help??
  148. what spark plugs to use with edelbrock heads ??
  149. small hesitation after plug change???
  150. Airbag light and clock spring replacement
  151. C4 Dipstick Q
  152. Injector Question!
  153. innovative wideband controller
  154. rearend rebuild! help please!
  155. Drag Suspension
  156. How do i get to these bolts??
  157. Knocking at startup
  158. Way off topic- Anyone have an Escape?
  159. switching computer found unclipped wires?
  160. Need coil over help (Length, lbs. ?)
  161. FRPP 347
  162. How much abuse can an AOD take?
  163. Computer Question
  164. Ride Height
  165. CANNOT GET THE BRAKE LINES OFF!
  166. cold relay help
  167. A/C and smog removal. Need info.
  168. Clutch Question
  169. Nitrous and Boost
  170. Catted H pipe comparison fox v SN95
  171. Which Heads?
  172. Need Help with Engine Swap please!
  173. guys with trick flow stage 3 cam come in!
  174. Heater pipe delete - water pump bypass?
  175. Will it survive part 2
  176. Will it survive part 2
  177. Little gas and the engine stays at 2500rpm...
  178. How do i get my car to idle w/b-cam
  179. Who Knows
  180. Uh, what fluid is this?
  181. T-stat housing bolt help
  182. New engine help...
  183. What CFM carb for my combo?
  184. Stock Axels?
  185. 88 Mustang GT Won't Start
  186. ring and pinion gear
  187. Electric Fan install?
  188. Weld draglite part number.
  189. My SN laid down will a vortech fit my bracket???
  190. H/C/I & AOD to T-5 CONVERSION COMPLETE!!
  191. rod journal resize on crank?
  192. weld Draglite torque
  193. Suspension Parts Needed For Upgrade
  194. FRPP top end kit?
  195. Quick Camber Q
  196. C&L sample tube ?
  197. Header leak
  198. Best intake gaskets...Fel-Pro or Mr.Gasket?
  199. block selection help
  200. North Carolina Emissions?
  201. VOTE: speedo gear sticky
  202. What weight oil?
  203. Fox Body work
  204. trick flow or system max???
  205. rockers for stock heads
  206. finding coolant leak with compressed air
  207. Tach needle stuck
  208. i need help with belt routing
  209. Auto Meter Shift Light and Stock tach Q?
  210. Synthetic Oil?
  211. Mysterious coolant loss - 5.0 in a FFR Cobra
  212. battery light comes on at high rpm's
  213. dampner not right??
  214. Quick brake question
  215. Calling all-COOLING Guru's-HELP???????
  216. 351W HORSE POWER EST.NEEDED.
  217. '87 Project LX Update
  218. spark plug gap
  219. Illumination Issue
  220. Thanks to everyone the helped with info
  221. balljoints
  222. PLEASE HELP!@!!
  223. Which speedo drive gear 7 tooth or 6
  224. 275's alot wider than 255's???
  225. Why is my speedo off so much?
  226. Will it survive?
  227. wheels 17x9 in 4 lug?
  228. Anti-theft ideas?
  229. 100Amp 1 wire Alt questions!! Please help!
  230. A/C flush with nitrogen
  231. AOD not Shifting
  232. Power Loss with Injector swap??
  233. Need info on Traction-Lock clutch pack replacement.
  234. Anything else I need?
  235. which speedo gear?
  236. What inch converter?
  237. Black Magic Xtreme Fan
  238. head question
  239. throttle body size for this application?
  240. Pull the back window tint myself or let a pro do it?
  241. Help..need good fuel line disconnect tool
  242. Reverse glow gauges.
  243. why is my car so slow???
  244. SN95 5 lug conversion? - Brake lines
  245. Power steering hose pics?
  246. Engine rebuild book
  247. It Hot as Hell Down Here
  248. Will FMS Tall valve covers clear a Performer Intake?
  249. Finally got another 5.0
  250. mgw or pro 5 0
