PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. Stock Intake... Extra Hole vs. Explorer
  2. Help with ECU's
  3. Getting super Bogged Down!!! MAF???? Help
  4. A Question About Bushings. Please Help!
  5. Question about going down an injector and the MAF
  6. Can anyone tell me what this piece in the R/S fender on my 91 5.0 is???
  7. Buying TB 4 Exploder Intake 2nite...
  8. wiring diagrams needed please!!!!
  9. headers??
  10. ford racing catback
  11. Fuel pump problems?
  12. tap dancing.. under the valve covers
  13. Lets talk gas mileage folks…..
  14. Need a new headliner!! Help!!
  15. 8.8 rear diff rebuild
  16. Coolant temp question
  17. going on dyno (questions)
  18. Comp Polymers Intake
  19. run an A9L with a AOD?
  20. Popping out of first!
  21. difference with control arms and drag springs??
  22. Gauge mounting
  23. What did i do? Please help!
  24. belt tensioner
  25. new 1.7 rr's are noisy - how to adjust?
  26. Volts jump up and down. Bad ground?
  27. Need Electrical Pinout info
  28. A/C -heater core problem
  29. Supercharger BOV Question
  30. 1985 Mustang GT Carburetor Gas Leak
  31. 325 Stroker Dyno numbers????
  32. Ok problem with brothers car
  33. Belt size with FORD A/C Delete
  34. just a thought....
  35. Blown Head Gasket vs Bad Intake Gasket? How to diagnose? Coolant in Oil!!!
  36. my new project
  37. Which seats fit a Fox?
  38. trick flow track heat ?
  39. 1986 5.0L any aftermarket heads fit with the flat top pistons?
  40. 94' supercharged
  41. Idle surges then engine dies
  42. Whats needed for the rear
  43. car won't start???
  44. Have a couple questions...Engine builders come in
  45. wanting auto...
  46. Is what I describe a collapsed lifter...?
  47. Intake manifold vaccum fittings
  48. gauges
  49. Part Number for plugs to use on GT40 irons?
  50. Wire Hiding question
  51. A/C delete bracket from steeda... pix??
  52. Did 3.73 rearend swap.. now thing but more problems
  53. Looking for alignment specs for lowered coupe.
  54. manifold questions
  55. nitrous question?
  56. fuel pump relay
  57. spyder and spyder 2 efi
  58. ext. electric fuel pump location?
  59. what causes valve rattle?
  60. factory sunroof weatherstripping
  61. good heads on stock bottom end?
  62. lc-1 wideband
  63. CLUTCH QUESTION
  64. non mustang question
  65. Motor Build-up Help! 'Rods and Pistons'
  66. Heads By Rick, Ever heard or him
  67. how to run s trim
  68. Engine getting hot
  69. Skinnies
  70. Mustang 8.8" rear end diagram
  71. New to Fox bodies, quick spindle/brake question
  72. 87-93 Replacing Front Ford Emblem
  73. vortech oil return
  74. Compression Ration for turbo?
  75. 86 mustang no start
  76. reusing fuel injectors
  77. In need of A/C help
  78. engine dies when unhooking battery, alternator dead right??
  79. T-5 EXPERTS COME IN!!!...Need your expertise
  80. E85 and new Engine Build.
  81. head spec's question
  82. tire size question
  83. Timing question.....
  84. Neutral safety switch & reverse lights!!
  85. performer or performer rpm?
  86. 83 mustang not firing
  87. Has any one changed the Evaporator on their Stang?
  88. Finished gear swap,now have whine on deceleration
  89. Clutch Ford Help!
  90. White Fuel Injector Size
  91. Mass Air Conversion
  92. little more detail on my cold air prob
  93. Throttle body blade
  94. need help! i'm top stupid
  95. Need AOD help: Only have 2nd gear in every shifter position
  96. 4 to 5 lug adapters
  97. What is this intake fitting for?
  98. cold air=sluggish??
  99. wideband air/fuel
  100. Weight difference Alum and Copper/Brass
  101. Any help identifyin this trans?
  102. 170 Deg.....Too Cold or Okay
  103. Flywheel Vibration
  104. Timing Crank Gear?
  105. Cold air fender kit and heavy rain don't mix!
  106. shortie
  107. Which Clutch?
  108. Bleading new brakes...LEAKS AWAY!
  109. Need an opinion/diagnosis. Eng./Tran./Clutch issue
  110. N20 infront of mass air meter?
  111. What's the best flow #'s on X heads
  112. New brake system, car won't stop!
  113. May have fixed surging idle...
  114. Crane HI-6 problem
  115. Grounding Locations?
  116. electric or mechanical that is the question?
  117. normal to develop leaks at header after new gasket?
  118. Parts store fan same as Ford OEM?
  119. passenger door not locking
  120. Moroso Heavy Duty Switch
  121. Pulled codes, and have a few questions.....
  122. What the heck?
  123. MAP + MAF???
  124. Help with question about Drag Lites
  125. not A mustang Q but a car question none the less
  126. Need to know about axles!
  127. custom trunk lift?
  128. Just switched to a Performer Intake
  129. What the hell do these wires go to?? (hiding wires)
  130. Whats the diff. between B and C springs?
  131. VSS for 94 GT with TKO600
  132. Safe way ofcleaning gaskets of heads before header install
  133. Dyno'd the vert today here are the number's
  134. 3 1/2 intake hose
  135. Which water pump to buy?
  136. Plug Gap?
  137. EGR delete kits????
  138. WHAT DOES VALVE FLOAT SOUND LIKE?
  139. front spring/rack & pinoin/P.S. pump intall. did search
  140. DIFF MARKING COMPOUND CHECK
  141. Not sure if motor is blown or not.. help plz
  142. car keeps running
  143. 5spd gear question after torn down
  144. Hooking up a fuel pressure gauge on a cabr'd car?
  145. Hooking up a fuel pressure gauge on a cabr'd car?
  146. build a combo from the stuff in my garage
  147. going to mess with timing tonight at track ....need help
  148. help with crank
  149. iridum plugs
  150. Mass Air Meter
  151. tank size
  152. throw out bearing
  153. Best place to buy Cobra brakes...experiences??
  154. Any tips/tricks for doing a oil dipstick on a canton pan?
  155. -Sub Frames-, do I need to remove the carpet before welding??
  156. need help
  157. gauge install
  158. Anyone running VRS Longtube X pipes?
  159. Quick electric fan CFM question
  160. Vaccum question...Line to EGR???
  161. ped rocker ?
  162. Ten Hole Rims
  163. Issue with DCC FK35
  164. Low oil Pressure Please help
  165. ignition question
  166. oil where it shouldnt be
  167. Hmmm...Help Needed
  168. difference in trannys?
  169. SN95 Brakes on a Fox to Cobra's. I need answers.
  170. won`t start, need advice
  171. how to get 275/50s on the car (quads)
  172. rear end question and gear oil...HELP
  173. problems with a/c delete install, wrong bracket!!!
  174. flowmaster cat back install problem
  175. SCT tuning
  176. GT40 Irons, spring question, another one!
  177. opinions on lift of hood...
  178. Water pump a good ground?
  179. loose drivers side tailpipe
  180. will SHO seats fit in a fox
  181. Tire size?
  182. 351 dart block stroked to 427ci
  183. Has this ever happen to someone here?
  184. Blowing Out Spark
  185. Firewall Adjuster Wisdom
  186. tweecer
  187. Question for you guys running T5's
  188. Motor Blown today
  189. 5.0 difrence
  190. Stock Headunit issues
  191. alt. question
  192. Hurst Line Lock question?
  193. How do I 'burp' the coolant system?
  194. Ford racing flywheel or daikin flywheel??
  195. Clutch pedal feels funny
  196. Foxbody Parking Lamp Bolt/Voltage Question!
  197. braided fuel lines
  198. May I pick your brain?
  199. stall convertor
  200. Stock oil pressure guage???
  201. March Ram Air
  202. Clutch Fixed 1 other problem now
  203. 89 BLACK INTERIOR. VINYL HELP PLEASE. HOW TO VINYL DOOR CARPET??
  204. quick trany question
  205. BAD misfire problem, cant figure it out...
  206. Bolt Size???
  207. Electrical issues
  208. Idle Vacuum with your cam.
  209. spyder intake and 2 1/2 hood clearance
  210. Does anyone work at a ford dealership? (Need a part number)
  211. Dyno Tune Finished...
  212. Tapping after oil flush
  213. Tire Fitment
  214. What is the best alt?
  215. Should I chip or not?
  216. MSD coil noise
  217. 3 inch exhaust too much?
  218. Mustangtuning.com?
  219. how to take off side mirrors?
  220. Cheap Cold Air
  221. Strange issue with 10" sub in coupe trunk.
  222. Will The Tire Rub?
  223. Can someone please tell me what cylinder spark plug wire goes too. (PIC)
  224. Question about where to mount wideband o2 bung!
  225. Friend weighed his 93 Notch today, aluminum heads & basic weight reduction
  226. carb/cam????
  227. Driveline noise
  228. quick ? Is this the right stuff for my tranny?
  229. A9L vs. X3Z
  230. Taking the dive...
  231. trick flow kit
  232. Removed stock gauges, need help
  233. Engine management software
  234. Grounding Question
  235. elec fan and stock alternator
  236. Blown head gaskets at water passages
  237. Re use pinion nut?
  238. mass air problem
  239. HELP! CENTER CONSOLE ISSUE. BUTTON NOT WORKING CORRECTLY
  240. Emissions Q': Is This Even Possible?
  241. 5 Lug Fox Experts In Here Please
  242. BBK intake...need blue pipe connecters!!!!
  243. GT side skirt hanger pictures?
  244. Pre cat vs. Cat: They both shouldn't rattle right?
  245. Pin-on hood help please (4 point)
  246. Who has installed a Autometer electric fuel pressure guage
  247. Official No Start When Hot Thread!!!
  248. Questions about T-5
  249. EEC wiring info needed
  250. Oil catch tank ?'s
