PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 [86] 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. Removed stock gauges, need help
  2. Engine management software
  3. Grounding Question
  4. elec fan and stock alternator
  5. Blown head gaskets at water passages
  6. Re use pinion nut?
  7. mass air problem
  8. HELP! CENTER CONSOLE ISSUE. BUTTON NOT WORKING CORRECTLY
  9. Emissions Q': Is This Even Possible?
  10. 5 Lug Fox Experts In Here Please
  11. BBK intake...need blue pipe connecters!!!!
  12. GT side skirt hanger pictures?
  13. Pre cat vs. Cat: They both shouldn't rattle right?
  14. Pin-on hood help please (4 point)
  15. Who has installed a Autometer electric fuel pressure guage
  16. Official No Start When Hot Thread!!!
  17. Questions about T-5
  18. EEC wiring info needed
  19. Oil catch tank ?'s
  20. completely rebuilding rear end
  21. Idle speed questions
  22. Blinkers and reverse lights do not work all of a sudden? What could it be...
  23. Need a little help
  24. Rear Main Seal Checklist.
  25. intake diference
  26. Need to find the inner tie rod roll pin/rivets
  27. Help! Need a quick answer
  28. Bumper Cover with Cobra Grill Insert
  29. BEEN A WHILE... but have finished 351W swap
  30. Please help with main harness wiring issue!!
  31. 302 to 351 fuel injected swap?
  32. "Extra" plug issue on a 2.3 to 5.0 Swap
  33. difference in fox body brackets & 94-95 stangs
  34. Need help NO start Hot condition
  35. Problem with my new Pro-Motion clutch setup *pic*
  36. Oil pan to fit Coast High main girdle 331 stroker
  37. Failure mode for the DCC FK35?
  38. PMAS 6-Pin connector
  39. How does the shifter cable and bracket bolt onto the AOD?
  40. O god, I just did the dumbest thing on my AOD install, quick question
  41. New to the forums, and new to 5.0
  42. Camshaft End Play cause smoking?
  43. diablo
  44. info on electric fan
  45. need help with fuel pump
  46. control arm nut being a pain
  47. retrofitting 5.0L into 2000 mustang
  48. Anyone have a second to measure something for me on their 8.8? PLEASE!
  49. results of marking compound check
  50. Stock rear springs good for drag?
  51. Electrical people please help! spout connector
  52. Budget computer control for electric fan doesn't work
  53. Fuel system overkill????
  54. Am I missing anything for this project? 4-eye resto-mod
  55. Know of any good fitting seat covers?
  56. gt40p heads, direct bolt on?
  57. How to change out frontend bulbs in foxbody?
  58. Spark Plug Wire-Looms on 302, where???
  59. 2.3L shifter working with aod transmission?
  60. Two Suspension questions, need help!
  61. No Oil psi. Found something interesting. Please Help!
  62. Rear Seat Question
  63. Would a Paxton Novi 1000 be safe to use with my motor combo?
  64. Which rings and bearings for blown 308?
  65. whats slowing me down?
  66. Axle/Posi install check list
  67. my backlash spec
  68. Bassani exhaust install advice
  69. Regular head gaskets vs. 0-ring groove
  70. auto to manual clutch ****
  71. Lightening a Flywheel?
  72. better breathing
  73. Vic Jr or AFR 205's
  74. should I use 20w50 synthetic in my 331 Stroker?
  75. block plate-needed with a stick car?
  76. Figure out RPMs
  77. Anyone have any mustang engine pics?
  78. Cam question.
  79. boost on a stock block
  80. bad gas mileage
  81. Max lift possible with stock springs?
  82. Help question?
  83. GT40 heads and rocker question??
  84. 5spd input shaft bearing part number for 1993 GT
  85. 5.0 swap question, PCM and injectors
  86. did I set the pinion bearing preload too tight?
  87. Help me with codes! Lots of em :(
  88. Freeze plug Popping out
  89. What should i do? take it to the shop?
  90. What ALL comes in a FRPP gear set?
  91. Line Lock Wont Hold
  92. egr
  93. Car barely running
  94. Cometic Head gaskets
  95. Why the F wont my AOD cross member bolt up??? Need help ASAP!
  96. What to get rid of after shortbelt
  97. Tweecer newbie question
  98. New 302/351W Valve Cover Design - Pic
  99. No Vacuum at idle, Surging around 2000 rpm ? help?
  100. DEXCOOL & T-stat noises-ANYONE???
  101. spec 3 clucth
  102. need help with clutch problem asap
  103. Narrowed down the clicking
  104. T5 Tailshaft Plug
  105. Who has the best prices on 331 stroker kits?
  106. discovered a tick from water pump
  107. any additives or special fluids for a t5?
  108. Considering 03-04 Cobra Calipers? Read This.
  109. Filter size for maf
  110. Determining pushrod lenght
  111. Need Some Radiator Input
  112. Where am I supposed to idle at?
  113. Anyone ever installed air horns on their fox?
  114. 95 GT rear end bolt into 92 GT???
  115. Which piston rings do you prefer?
  116. Internal vs. External Balance in Relation to Redline
  117. Will I break into the 12's
  118. I needd a hego harness asap
  119. f303 in automatic 93
  120. believe i need to mill my intake. what to do.
  121. wheels causing ticking sound
  122. cobra intake
  123. Pre-5 lug swap / wheel offset question
  124. Man I messed up!!! Can it be fixed?
  125. roller rocker question
  126. C-Back problem
  127. Roller Rockers, how much thread is enough?
  128. need help on what this thing is called
  129. installing 1.7 roller rockers - blue threadlocker??
  130. 86 wiring diagram
  131. Rear Stainless Steel Brake Lines
  132. Cool-Shot Nitrous Injection ? ? ?
  133. fuel pressure question
  134. Charcoal canister
  135. what jets should i be running?
  136. Intake upgrade on SD car
  137. motor feels like it's skipping
  138. Painting my Stang's mouth (**Pics**)
  139. ebay listing for alum j302 motorsport heads
  140. 85 5.0 HO question
  141. Inside a vert??
  142. Why wont my car idle right?
  143. Power - Temperature Related
  144. crown vic question
  145. Need Help with MAC Windage Tay Installation
  146. Q's about a 90 vert
  147. big project this weekend, tech tips appreciated...
  148. Help Please! Crank Pulley Spacer!
  149. Stupid Question about AOD install: Need help ASAP.
  150. tps voltage? how to?
  151. will eagle alloy cap work with are wheels?
  152. Replacing radiator
  153. Fusable link for fuel pump???
  154. Stupid question of the day: what exactly does advancing the timing do?
  155. 94-95 cobra
  156. CAR WONT START WHEN HOT.. I've gone through the checklist already and did searches..
  157. which hook?
  158. Quick Injector question
  159. How do I change the Oil Pump Drive Shaft
  160. Trickflow Top End kits....Anything I should know before ordering?
  161. U-joints removal and installation
  162. POWERDYNE SUPERCHARGER?!?!
  163. How to go about removing my A/C
  164. SN95 Dash in a Fox Body
  165. oil from distributor?
  166. Identifying Trick flow heads?
  167. B&M Supercooler Install!! Do i have it right???
  168. Got a good one...AL heads + roller rockers = runs like crap.
  169. car won't start after valve cover swap
  170. car won't start after valve cover swap
  171. What kinda HP numbers can a T5 handle?
  172. car won't start after valver cover swap
  173. Can I do a compression test by turning the engine by hand?
  174. Edge converter Questions: Bolting up to flex plate and fluid
  175. Compression test today / oil on plug
  176. cam degree ?'s Advance 2* = ? seat of the pants
  177. help! auto to manual conversion.....won't start!
  178. What is this? (Pic)
  179. Cobra lower Manifold..Coolant Plug size? part number?
  180. Throttle body question?
  181. gauge questions...????
  182. Do i need a new clutch?
  183. Failed emmisions, What could i do?
  184. sizes and offsets for drag wheels
  185. battery short
  186. Wheels! Backspacing, Offset, Confusion on wheel purchasing
  187. *amazing update!* '88 5.0 5-speed shifting problems
  188. Prof. Products Upper Bolt to Edelbrock Lower? (EFI)
  189. Line Lock Wont Work
  190. mustang radiator
  191. NO SPARK!!
  192. Does any 5 lug spare fit on a foxbody?
  193. Will this combo hit 320 rwhp N/A
  194. Save old Exhaust System?
  195. Real Quick, where to connect tach wire???
  196. Just installed TFS Kit. now surging problem??
  197. Help installing cold air intake
  198. Swapping Computers...? X3Z to A9l...?
  199. Need Help. ASAP
  200. Went to the track last night.... good numbers
  201. how much power to brake an axle???
  202. Novi-2000 and Underdrives?
  203. Weird fuel fail seepage (NOT the o-rings/injectors)
  204. Can't Figure out the problem.
  205. timing cover question
  206. Gauge Cluster help....
  207. Is this blower ready?
  208. Fuel Pump Question...
  209. Wilwood Brake Help!!!
  210. 351W fitment questions in a fox
  211. Anyone know how Pro M meters are calibrated??
  212. camber/caster woes after 5 lug swap-suspension advice needed!!
  213. Neutral sensing switch
  214. Stock 5L specs
  215. Tuning question
  216. A/C Compressor and Fan ??
  217. Found cause of shifting problem *pics*
  218. fuel pressure regulator vs stock one...
  219. Installing AL heads...torque sequence??
  220. convertable top ?
  221. surging devil back again
  222. What rear battery kit????????
  223. What is a roller motor?
  224. Waterpump direction
  225. knocking noise
  226. in the market....is mileage an issue?
  227. press in studs ???????
  228. shocks
  229. In Gear Shifter Slop......Anyone??
  230. BLACK INTERIOR CONVERSION PAINT JOB QUESTIONS?? HELP
  231. I installed a new fuel tank and now...
  232. new suspension what will it 60'
  233. Cutting Springs??
  234. Water Wetter....does it actually work?
  235. 94 Cobra running rough (PLEASE HELP!!!)
  236. styling light bar install instructions anyone?
  237. anyone buy carpet from 5.0 resto?
  238. what rings???? ASAP!!
  239. Manual Valve body?
  240. how to get door trim off?
  241. what fuel PSI for 410W?
  242. Alternator
  243. Header leak problem with macs? Anyone had the same problem?
  244. I Want to Make 450 N/A HP
  245. Best formula to rebuild Traclok
  246. Question about 3G alternator install using FFI harness
  247. Inspection
  248. I want to install a C4 in my Fox. How?????
  249. Which cam?
  250. Pilot bearings
