View Full Version : 5.0 Tech
- Wire Hiding question
- A/C delete bracket from steeda... pix??
- Did 3.73 rearend swap.. now thing but more problems
- Looking for alignment specs for lowered coupe.
- manifold questions
- nitrous question?
- fuel pump relay
- spyder and spyder 2 efi
- ext. electric fuel pump location?
- what causes valve rattle?
- factory sunroof weatherstripping
- good heads on stock bottom end?
- lc-1 wideband
- CLUTCH QUESTION
- non mustang question
- Motor Build-up Help! 'Rods and Pistons'
- Heads By Rick, Ever heard or him
- how to run s trim
- Engine getting hot
- Skinnies
- Mustang 8.8" rear end diagram
- New to Fox bodies, quick spindle/brake question
- 87-93 Replacing Front Ford Emblem
- vortech oil return
- Compression Ration for turbo?
- 86 mustang no start
- reusing fuel injectors
- In need of A/C help
- engine dies when unhooking battery, alternator dead right??
- T-5 EXPERTS COME IN!!!...Need your expertise
- E85 and new Engine Build.
- head spec's question
- tire size question
- Timing question.....
- Neutral safety switch & reverse lights!!
- performer or performer rpm?
- 83 mustang not firing
- Has any one changed the Evaporator on their Stang?
- Finished gear swap,now have whine on deceleration
- Clutch Ford Help!
- White Fuel Injector Size
- Mass Air Conversion
- little more detail on my cold air prob
- Throttle body blade
- need help! i'm top stupid
- Need AOD help: Only have 2nd gear in every shifter position
- 4 to 5 lug adapters
- What is this intake fitting for?
- cold air=sluggish??
- wideband air/fuel
- Weight difference Alum and Copper/Brass
- Any help identifyin this trans?
- 170 Deg.....Too Cold or Okay
- Flywheel Vibration
- Timing Crank Gear?
- Cold air fender kit and heavy rain don't mix!
- shortie
- Which Clutch?
- Bleading new brakes...LEAKS AWAY!
- Need an opinion/diagnosis. Eng./Tran./Clutch issue
- N20 infront of mass air meter?
- What's the best flow #'s on X heads
- New brake system, car won't stop!
- May have fixed surging idle...
- Crane HI-6 problem
- Grounding Locations?
- electric or mechanical that is the question?
- normal to develop leaks at header after new gasket?
- Parts store fan same as Ford OEM?
- passenger door not locking
- Moroso Heavy Duty Switch
- Pulled codes, and have a few questions.....
- What the heck?
- MAP + MAF???
- Help with question about Drag Lites
- not A mustang Q but a car question none the less
- Need to know about axles!
- custom trunk lift?
- Just switched to a Performer Intake
- What the hell do these wires go to?? (hiding wires)
- Whats the diff. between B and C springs?
- VSS for 94 GT with TKO600
- Safe way ofcleaning gaskets of heads before header install
- Dyno'd the vert today here are the number's
- 3 1/2 intake hose
- Which water pump to buy?
- Plug Gap?
- EGR delete kits????
- WHAT DOES VALVE FLOAT SOUND LIKE?
- front spring/rack & pinoin/P.S. pump intall. did search
- DIFF MARKING COMPOUND CHECK
- Not sure if motor is blown or not.. help plz
- car keeps running
- 5spd gear question after torn down
- Hooking up a fuel pressure gauge on a cabr'd car?
- build a combo from the stuff in my garage
- going to mess with timing tonight at track ....need help
- help with crank
- iridum plugs
- Mass Air Meter
- tank size
- throw out bearing
- Best place to buy Cobra brakes...experiences??
- Any tips/tricks for doing a oil dipstick on a canton pan?
- -Sub Frames-, do I need to remove the carpet before welding??
- need help
- gauge install
- Anyone running VRS Longtube X pipes?
- Quick electric fan CFM question
- Vaccum question...Line to EGR???
- ped rocker ?
- Ten Hole Rims
- Issue with DCC FK35
- Low oil Pressure Please help
- ignition question
- oil where it shouldnt be
- Hmmm...Help Needed
- difference in trannys?
- SN95 Brakes on a Fox to Cobra's. I need answers.
- won`t start, need advice
- how to get 275/50s on the car (quads)
- rear end question and gear oil...HELP
- problems with a/c delete install, wrong bracket!!!
- flowmaster cat back install problem
- SCT tuning
- GT40 Irons, spring question, another one!
- opinions on lift of hood...
- Water pump a good ground?
- loose drivers side tailpipe
- will SHO seats fit in a fox
- Tire size?
- 351 dart block stroked to 427ci
- Has this ever happen to someone here?
- Blowing Out Spark
- Firewall Adjuster Wisdom
- tweecer
- Question for you guys running T5's
- Motor Blown today
- 5.0 difrence
- Stock Headunit issues
- alt. question
- Hurst Line Lock question?
- How do I 'burp' the coolant system?
- Ford racing flywheel or daikin flywheel??
- Clutch pedal feels funny
- Foxbody Parking Lamp Bolt/Voltage Question!
- braided fuel lines
- May I pick your brain?
- stall convertor
- Stock oil pressure guage???
- March Ram Air
- Clutch Fixed 1 other problem now
- 89 BLACK INTERIOR. VINYL HELP PLEASE. HOW TO VINYL DOOR CARPET??
- quick trany question
- BAD misfire problem, cant figure it out...
- Bolt Size???
- Electrical issues
- Idle Vacuum with your cam.
- spyder intake and 2 1/2 hood clearance
- Does anyone work at a ford dealership? (Need a part number)
- Dyno Tune Finished...
- Tapping after oil flush
- Tire Fitment
- What is the best alt?
- Should I chip or not?
- MSD coil noise
- 3 inch exhaust too much?
- Mustangtuning.com?
- how to take off side mirrors?
- Cheap Cold Air
- Strange issue with 10" sub in coupe trunk.
- Will The Tire Rub?
- Can someone please tell me what cylinder spark plug wire goes too. (PIC)
- Question about where to mount wideband o2 bung!
- Friend weighed his 93 Notch today, aluminum heads & basic weight reduction
- carb/cam????
- Driveline noise
- quick ? Is this the right stuff for my tranny?
- A9L vs. X3Z
- Taking the dive...
- trick flow kit
- Removed stock gauges, need help
- Engine management software
- Grounding Question
- elec fan and stock alternator
- Blown head gaskets at water passages
- Re use pinion nut?
- mass air problem
- HELP! CENTER CONSOLE ISSUE. BUTTON NOT WORKING CORRECTLY
- Emissions Q': Is This Even Possible?
- 5 Lug Fox Experts In Here Please
- BBK intake...need blue pipe connecters!!!!
- GT side skirt hanger pictures?
- Pre cat vs. Cat: They both shouldn't rattle right?
- Pin-on hood help please (4 point)
- Who has installed a Autometer electric fuel pressure guage
- Official No Start When Hot Thread!!!
- Questions about T-5
- EEC wiring info needed
- Oil catch tank ?'s
- completely rebuilding rear end
- Idle speed questions
- Blinkers and reverse lights do not work all of a sudden? What could it be...
- Need a little help
- Rear Main Seal Checklist.
- intake diference
- Need to find the inner tie rod roll pin/rivets
- Help! Need a quick answer
- Bumper Cover with Cobra Grill Insert
- BEEN A WHILE... but have finished 351W swap
- Please help with main harness wiring issue!!
- 302 to 351 fuel injected swap?
- "Extra" plug issue on a 2.3 to 5.0 Swap
- difference in fox body brackets & 94-95 stangs
- Need help NO start Hot condition
- Problem with my new Pro-Motion clutch setup *pic*
- Oil pan to fit Coast High main girdle 331 stroker
- Failure mode for the DCC FK35?
- PMAS 6-Pin connector
- How does the shifter cable and bracket bolt onto the AOD?
- O god, I just did the dumbest thing on my AOD install, quick question
- New to the forums, and new to 5.0
- Camshaft End Play cause smoking?
- diablo
- info on electric fan
- need help with fuel pump
- control arm nut being a pain
- retrofitting 5.0L into 2000 mustang
- Anyone have a second to measure something for me on their 8.8? PLEASE!
- results of marking compound check
- Stock rear springs good for drag?
- Electrical people please help! spout connector
- Budget computer control for electric fan doesn't work
- Fuel system overkill????
- Am I missing anything for this project? 4-eye resto-mod
- Know of any good fitting seat covers?
- gt40p heads, direct bolt on?
- How to change out frontend bulbs in foxbody?
- Spark Plug Wire-Looms on 302, where???
- 2.3L shifter working with aod transmission?
- Two Suspension questions, need help!
- No Oil psi. Found something interesting. Please Help!
- Rear Seat Question
- Would a Paxton Novi 1000 be safe to use with my motor combo?
- Which rings and bearings for blown 308?
- whats slowing me down?
- Axle/Posi install check list
- my backlash spec
- Bassani exhaust install advice
