PDA
View Full Version : 5.0 Tech
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252
  1. Cut pistons for 2.02 in-car?
  2. Dakota Digital fan controller
  3. 96 Cobra rack on 94-95 K-member?
  4. engine codes 13 44 94 ???????????
  5. gt-40 heads and lunati camshaft
  6. Need help choosing a nitrous kit
  7. Just Dumped Codes...Advice ?\\?
  8. Convertible Top fluid..
  9. getting rear end!
  10. overheating question
  11. no start and exhause red hot and burning stuff help more parts more $$$ not an option
  12. quick egr ? confused
  13. throttle body spacer and upper intake very hot
  14. How To / Front windshield Molding
  15. help me plan my build turbo 331
  16. Car is starting weird has a mind of its own.
  17. speedo and clutch cables routing
  18. horn not workiing...
  19. Edelbrock RPM II Install Question
  20. No oil in valve cover?
  21. 5 lug kits, questions
  22. Install question on Saleen rear bumper lip
  23. Adjustable fuel pressure regulator
  24. Rust... Its getting about time...
  25. Need new heads...Any recommendations?
  26. HELP! Overheating
  27. ok so I know the answer....just funny
  28. What vehicles had a 130A 6G?
  29. front suspension question
  30. electric fan help
  31. Coolant Hose (Heater Core)....
  32. Scary Stuff...
  33. Fiore FWA users?
  34. Safest Jackstand Practice on 1990 Mustang
  35. NEW EDGE SEAT INSTALL
  36. What Brand Convertible Top Should I Buy?
  37. Looking to build stang that will run 10's
  38. TPS help
  39. Recharging AC with the new stuff (retro kit). Low line is where?
  40. backfiring @ 5200+ RPM..ASAP Please
  41. Help me install a cam
  42. injector tuning?
  43. Roller rockers?
  44. What intake for EFI351W
  45. cam question?
  46. Flywheel weights
  47. Upgrading from 130 to 200 AMP 3 G alternator Upgrading
  48. electrical problem fuseable link between starter solinoid and alternator fried
  49. Hey guys, need help!!!
  50. wont crank
  51. h/c/i or low boost blower
  52. cannister purge circuit
  53. Adjustable Control Arms
  54. bad shake at high speeds
  55. T5 shift fork ?
  56. Billet quadrant problem.
  57. single wire alternator
  58. vents stopped blowing. bad blower motor???
  59. oil pressure
  60. Power Window problems... HELP!
  61. idle surges, gets choppy, then dies...HELP ME!!!
  62. How to measure for gas shocks for the hood
  63. What do you think? couple of questions
  64. 5-lug, advice on application
  65. back up light switch
  66. couple codes, no CE light
  67. rear main seal leak?
  68. high compression stock stroke
  69. seat reinforcement
  70. EASY T-5 QUESTION
  71. CLUTCH CABLE ?
  72. Quick Oil pan Q¿
  73. YES Another mustang head question!!!!
  74. Just got some 15x9 draglite xps 6" bs now...
  75. 2 questions about 347
  76. 18" rims?
  77. Need Vacuum Motor for 93 Mustang
  78. Aluminum radiator overflow tank
  79. brain fart after 3 yrs 3grand car runs but white smoke idles high!! please help
  80. just got car running but temp gauge isnt working need wiring help so i dont blow it!
  81. my 5.0 cuts out at 5,000 rpm wtf???
  82. what causes a bent valve? friend thinks i might have one
  83. Fuel pump 'whining'?
  84. Stock axle ID code question
  85. mustang head question
  86. Check Engine Light?
  87. Hey all, new member here with a few questions
  88. Question About Rocker Arm Install
  89. Fuel pressure sender location.
  90. Stock Intake Hardware Compatible With Replica Cobra Intake
  91. question on MM chassis stiffening
  92. FUEL PUMP PROBLEMS
  93. A few nitrous questions
  94. Just Added 90 GT Vert... Questions....
  95. will a SUPER VICTOR EFI work on a NATURAL ASPIRATED motor?
  96. What is This Wire For?
  97. Stock 03 Cobra blower on 5.0
  98. what to set timing at
  99. Been out of the loop for a while... need advice
  100. head gasket question? Need help!
  101. car won't start when hot... help please???
  102. Help install boost gauge
  103. two plugs need schematic or help or picture NE thing really
  104. roller rockers and wat to do
  105. T-5 Swap Wiring
  106. gt40 topend plus spray ='s ???
  107. Alternator Question
  108. cold start issues
  109. Gauge cluster lights won't come on
  110. sn-95 dash in a fox??
  111. Need to know what hoses I need!
  112. Valve body-clunk question
  113. Electric Fan?
  114. gt40 or gt40 P - Which are better if want to keep smog?
  115. autometer autogage gauges any good?
  116. 89 to 94 parts
  117. What psi in ET street slicks?
  118. world products heads
  119. 1989 Mustang 5.0, Sputters and Smokes at High RPM
  120. Any luck with buying used heads online?
  121. Lakewood traction Bar?
  122. Deck clearance
  123. Which nitrous system?
  124. I need a 90 wiring diagram
  125. Quick heater core question
  126. motor mount problem
  127. T5 Steel Bearing Retainers
  128. forged pistons
  129. No heat and Idle jumps during shifts?
  130. dumping fuel at part throttle?
  131. Transgo Shift Kit Questions
  132. tps problem
  133. Stock rim weight?
  134. porting a tubular gt40 intake
  135. 86 mustang speaker replacement
  136. Engine bay harness removal
  137. anybody tried these?
  138. Is my brake booster bad?
  139. Squeel from trans when clutch is all the way out.
  140. Trans jumps out of gear?
  141. 85 GT FI to Carb conversion overheating help
  142. T5 to C4 swap
  143. popping and giving out at high rpm
  144. quick distributor cap question
  145. 86 Electrical ?'s
  146. Roll Bar Install
  147. 331 stroker question
  148. 86 w/mass air wont start needs jumpstart please i'm dumb
  149. Anyone run a crazy engine setback?
  150. exhaust hangers h-pipe
  151. Engine Balancing???
  152. non roller 302?
  153. Braking In Engine???
  154. HVAC Vacuum Lines - How to Extend
  155. 85 Mustang 5Lug Conversion
  156. STARTING THE RESTO OF MY 86 GT...
  157. fluidyne radiators
  158. Next suspension mods?
  159. power loss and back fire at hard trottle
  160. MAF conversion.....no start
  161. Procharger D-1SC leaking..Breather also leaking
  162. coolant pressure ??
  163. Bench Bleeding
  164. removing ac lines
  165. Fuel pump relay for 93 lx location?
  166. Checking fuel pressure
  167. Looking for ideas car won't stay running
  168. 70mm MAF Question?
  169. Suspension and Traction Q's
  170. a/c charging
  171. camshaft choice
  172. LAM on valve cover
  173. Electrical asking again
  174. BBK Performance SSI Intake
  175. Fox suspension question?
  176. Please Help - which h. balancer and flywheel...
  177. Power steering bracket off other 5.0's???
  178. POWER LAGGING
  179. Gas Gauge not working
  180. EGR ???
  181. GT40 Y302 heads vs GT40P heads
  182. hatch lock
  183. thumper heads on a 347?
  184. Bad vibration under hard acceleration???
  185. Ditching the voltage regulator... question
  186. Weird problem
  187. Stock 1986 5.0.. powertrain into 74-75 1/2 ton?
  188. Having problems with brake conversion....
  189. pullies
  190. Carb Question
  191. Starter
  192. 408w which air intake?
  193. tuning help asap
  194. PCV Elimination
  195. wierd problem - coolant fumes
  196. Help with fuel line to rail connection
  197. PA racing k-member?
  198. 5spd swap HELP! PEDAL ASSY.
  199. Weird Blinker problem
  200. 335's on a fox
  201. Harmonic Balancer question?
  202. Hurst Shifter?
  203. thumper heads on a 347?
  204. Performer Intake + Aftermarket Fuel Rails = ?
  205. vortech y-trim come in
  206. Window Motor Replacement
  207. odd miss fire
  208. lower torque box reinforcements
  209. strange ticking noise
  210. Does the TV cable.....
  211. Marchal restoration?.....help!!
  212. What fluid in a T5Z?
  213. What Carb Do I Use?
  214. Just bought another fox... time for a 351/393 setup! tips wanted!
  215. Lean? white plugs
  216. 331 Build - odds and ends Q's - PICS
  217. Lower Intake Gasket??
  218. Part throttle bucking ?
  219. New 3-Inch Studs
  220. Anyone Running a Black Magic Fan from FAL?
  221. motor and trany mounts
  222. NEED HELP!!! Need to fill my diff with oil!
  223. Automatic idle problem
  224. 4cyl conversion tranny questions
  225. how much fuel pressure do i need?
  226. Engine Oil in the MAF
  227. explorer accessories
  228. fuel filter
  229. What size belt
  230. what size tires for draglite skinnies
  231. wore out suspension?
  232. Is this a lot of timing chain play?
  233. Cobra brakes instaled... Doesnt stop well at all...?
  234. 302 cam
  235. Will a 315/35/17 Nitto D.R. Fit on a 17x9" wheel?
  236. oil choice
  237. crushed cyl #8 sparkplug
  238. One Headlight Low Beam Works Passanger
  239. what is a good afr for an HCI car?
  240. need help on an intake/carb combo
  241. How to replace door roller bushing?
  242. Let's play guess that vacuum line *pic*
  243. ignition problems! please help
  244. 92 mustang 5.0 Problems
  245. Electrical Problems, bout to give up
  246. "Big Stuff 3"
  247. T-5 or tremec?
  248. Radiator support causing fan blade to rub
  249. Code readings
  250. How to go back to EFI?
