View Full Version : 5.0 Tech
- Trickflow Upper intake manifold whisteling
- Deep Dish Bullits on fox
- Lots of Pics. calling all 5.0 experts. Engine rebuild. Need HELP
- gt-40 heads with 1.7 crane gold rr???
- Rear Upper control arms?
- Swap headers not working
- Surging idle checklist?
- Cam Install???????
- Rear lower control arms What goes with mac?
- JUST INSTALLED THE WET KIT
- flasher relay?
- oil pressure woes
- CC plate slotting.
- Head gasket help!
- T-5
- ELECTRICAL AND BATT RELOCATE Q
- Installing Long Tube Headers, Advice/Opinions?
- What size injectors?
- Valve seals split down the side....damn it
- t5 vibration. please help?
- electric fan good or bad!!??
- where to get a timing chain set locally
- What is the Plug and Grommet Kit?
- sealing timing chain cover
- stock cam for 1991 5.0
- LRS "Micro-Click" Firewall Adjuster...
- slight miss/buck when at steady speed
- Ford Racing B or C springs?
- blow thru mass air wiring
- Bummed out - Need 5.0 Help
- Oil Leak....aftermarket guage kit
- 10-11k to play with for engine/tranny..need help
- wheelbase
- Best way to burnout...
- Removed smog pump and lines, can I remove the smog radiator thing too?
- Opinions on 429 - Coworker is selling
- Too much injector???
- AFR 165 or tf tw or other?
- Tryin to get my baby running before summer..HELP!!!
- Headlight problem PLEASE HELP!!!!
- fox suspension
- Any advantage to installing a cobra upper and lower?
- Anyone have a picture of the FRRP A/C Delete
- Engine crapped out....
- Replacing steering column.
- Auto to 5spd swap??
- brakes
- any roller 351w users? what cam do you have?
- Engine running: Question about my timing (different ?)...
- running rich real bad fuel smell
- Oh $H!7 Something popped (electrical) car died and smoked, won't crank now
- Tranny Help
- T-Stat Install
- Tire Pressure M/T ET Drags 8.5 15in
- Noises coming from T-stat housing-WTF!!!!!
- Car won't start...help!
- question about pushrods
- Whisteling noise at idle
- question on thi H/C/I combo??
- New to Nitrous...Need Some Pointers...!
- Anybody remember the movie "The Wraith"?
- gas smell?
- dome light switch (removal)
- Canton, Milodan, Moroso? WHICH ONE????
- What would it run????
- Drilling 1/8 hole in T-stat- Good/bad idea???
- What fuel pump for a mild 306?
- TRANNY COOLER???
- 95 GT : 28 or 31 splines?
- Tech help in stereo section.
- Coolant leak. Help me find it
- AFR heads
- 351W fuel injected questions
- whats up with this fel-pro 1011-1 ?
- Exhaust Hitting Tires...Help.
- x-pipe vs. h-pipe
- One man job?
- will a convertable rearend bolt into a notchback?
- Cam Q
- tool to remove those plastic rivot thingies??
- Car runs like crap
- Odometer, speedo, trip doesn't work...suggestions on what to check?
- For Sale: White Face Gauge Overlays
- timing chain.
- EFI swap questions
- hardned pushrod egg shaped on the end
- trouble getting crank pulley off
- '90 GT hesitating
- solid or poly??
- fuel pump installation ?'s
- need for a chip
- Head Help
- shock removal??
- OEM a/c delete pics? forgot how mine goes back on
- HELP! What I think is oil leaking on my foot.. experts come in
- Ford Racing Coil Springs on a 93 Cobra?
- Wanna get a new midpipe, but without the drone
- Muffler Sound Comparison by 5.0 Magazine Question
- mostly stock....what timing?
- 96 cobra 5lug conversion
- Stroker kit
- What to do.....
- Fuel Pump Didn't shut Off Today
- Possible to remove passenger side shorty header with motor in car?
- what am I missing
- Electrical Nightmare
- Need new brakes all around, suggestions please
- What to fire with?
- Wreck, Airbags, and $ OH MY!!
- GT lower body paint code, gray/silver?
- Help w/ Trick Flow Rocker install
- why is gas coming out of cap?
- trickflow head
- Really need help picking U/L Control arms!
- Part III of my Turbocharged Mustang build.
- S/C guy needs help
- Wheels and tires
- What is behind water pump?
- fuel line questions
- Coil over kit that fits Lakewood nicely???
- Quick t-stat question
- Proper way to eliminate EGR???
- Front End Conversion?
- Headlight seal
- How many guys running "NO" thermostat???
- crate motor bugs....
- T-5 Question....easy I hope...
- Car won't start, need some help.
- Backwards swap, T5 to AOD, what do i need to know.
- can someone post instructions for me?
- 3 inch exhaust on 351w
- tooth missing from flywheel hurt anything??
- How much should my motor suck?
- Stalling Problem
- got a tremec tko 600...
- stiff clutch
- whats the diff between wiring harness LX / NOtch
- magnetic dial indicator (pushrod length)
- Questions about my Optima red top battery and stored for the winter!
- Chromemoly vs Steel vs High Energy Pushrods?
- Opinions?
- HELP!
- Possible Bent Pushrod?
- exhuast vaccum line line?
- Edelbrock Performer RPM Install
- SCT Eliminator 6600 Chip
- ELECTRIC FUEL PSI AND N20 PSI GAUGE ?'S
- Head gasket or Leaking water jacket
- 03/04 cobra motor and tranny in a fox
- ATTENTION:OPINIONS WANTED
- Which lowering springs ?
- Need an electrical connector
- best cam for this combo ?
- Short belt at the track?
- Is my cam too big? Cam sheet inside FTI
- WELDING SEAMS
- ? for anyone that has done the SN-95 rear disc brake swap, do your Fox emergency
- suspension
- Stock Suspension Help
- Backfiring????
- Code 31...what do I do?
- Need help, want to start my car!
- Swaybar End Link install question
- Question before i buy
- renegade bracket for procharger p600b
- HELP!!!! A Couple Questions... Gas tank floater, Gaskets, FuelPump Connection...
- Will BBK Longtubes work with a C4?
- Rear axle q's - yes I've searched...
- Supercharger crank pulley ??
- hydraulic roller to solid roller?
- What kind of timing advance should I be able to get away with?
- Will this supercharger fit my car
- how to...
- cigarette lighter help
- ok surging idle...
- duraspark distributor gear shaft sizes
- Aluminum Driveshaft vibration Q's
- 69 windsor heads
- 70/30 drag struts
- questions about 351w lower intake
- March 351w accessory brackets help!!
- Has anyone made any custom bracket for their LM 1 wideband unit?
- need some help with codes and code scanner
- How long are SN95 axles?
- AFR 185's Spring Upgrade
- need combo advice
- Anyone with AFR 165cc heads, Valvetrain geometry question
- Paint prep... some q's (Paul Perreca, etc come in)
- Intake manifolds/please help
- fuel pressure and plugs on ati setup
- Red interior light?
- What is needed for starter to turn?
- problem w/my friend's car (video clip)
- Need Advice about my fox cooling system
- Overheated after idling for 10 min
- 347 Dyno #s NA and Nitrous
- oil in intake prob.
- GT40 upper with Explorer lower...help please
- Anyone ever use-Water Outlet Restrictor kits???
- top or bottom
- Guys With Superchargers
- Found some Metal Shavings in oil pan?
- Need Help ASAP
- Why spend $250 on 3g when I can spend $150?
- are 4 cylinder springs worth putting in?
- Piston popped out of caliper...(?)
- To those running superchargers
- New top and weatherstripping....cut down wind noise ?
- aem management system
- WHICH FAN?
- Odd Question / Cracks on the alternator?
- cold start, good idle.....warm start, no idle
- cobra brake system
- 1.7.1 rockers crane ford
- aod no shift
- Fuel pressure too high?
- 351 swap
- High RPM power loss.. oil filler breather?
- 2 parts: vibration at 1k rpm + bad tps?
- Parking brake vibration/noise
- Questions about cutting front coolant ports out of headgasket and need FP vac. line?
- "Rev Limiter" feeling @ ~2500 RPM w/ Blower Installed
- car strats when cold doesn't when hot
- looking for after market gauge pics..pre 87
- McLeod Twin Disc Users
- Early Explorer ?
- so I see no search function.
- TPS Installation
- best t-5 rebuild kit?
- Anderson PMS harness with no MAP plug?
- lower torque box reinforcement question
- does anyone know how you burp a cooling system?
- jegs x pipe
- 88GT vert 17x9's SMALLEST TIRE UP FRONT??
- '95 spindles on a '90.....pandamonium
- strange overheating problem/please help
- bad throttle response
- Injector electrical issues! HELP!
- Piston questions
- 4cyl to 5.0 brakes.
- Save money...Weld cats on?
- Milodon oil pan and windage try?
- need a O2 senser
- Fuel? electrical? Timing advance? i cant figure this out
- Fiberglass hood for 94 - 98. Please Help!
- Part throttle miss comes back again
- Are E7TE pass & driver side heads the same
- BACK UP LIGHT HARNESS?
- favorite clutch quadrant??
- Whats a good cruising EGT?
